  3. My 2AA battery sensor
90 Posts 27 Posters 128.5k Views 36 Watching
  • A
    ahhk
    i think it would be better to open a new thread for this, instead to discuss two topics in one thread....the 2xaa battery sensor is very interesting ;)
    • m26872M m26872
      I declare the 6 months criteria easily passed. And the chinese step up regulator to be good value for money. Next target; 12 months.
      m26872M
      m26872M
      m26872
      wrote on last edited by m26872
      #72
      The 12 months target was done a few days ago. Today's status 105: 63% and 106: 27%
      I had a thought to celebrate their birthday by retrieve old Vera data and make nice plot, but that has to wait. Next, 18 months.
      Just to clarify that these are no "sleeping" nodes; they transmit 100-150 messages each every day.
      • m26872M
        m26872M
        m26872
        Battery level status report after 18 months:
        Node 105: 51%
        Node 106 (with used batteries): Died early January.
        Next 24 months.
        • rhuehnR
          rhuehnR
          rhuehn
          Hey @m26872 Congrats on the testing and results! Looks great! I was wondering if I could get your feedback on something. I'm trying to build a very low powered ( 2 x AA ) Battery powered 3 in 1 sensor. ( Platform is a Pro Mini 8Mhz, 3.3v, with an PIR HC-SR501, NRF24L01, and a DHT 11 Temp and Hum sensor. The sensor should also report battery power periodically ideally using the vcc library ( not implemented yet ). Because these components use power hungry devices ( PIR, DHT ), I have already moded the PIR to work at 3.3, and have removed the regulator / LED from the pro mini. Would it make sense to use a step up / down regulator, or power directly from the VCC pin? I can't decide what would be more effective in prolonging battery life? Also, in terms of reporting battery state. I'm not sure what would be best also, hence the question around the VCC library?
          Below is my sketch. It is really taken from various posts on this forum and stitched together. If you could have a peak at it, and see if it is "optimal", as I don't believe it is today. ie: Perhaps I could only report temp / hum if it changes +/- a degree? Or send everything in a single radio announcement, then "Deep Sleep"? Lots of questions, and of course I am sure there are lots of answers. I'm just trying to build the most optimal battery efficient ( 2 x AA ) powered sensor no problem right! :) Below is my current code:
           #define MY_GW_ID 31
          // Enable debug prints
          //Constants
          #define SKETCH_NAME           "3 in 1 Sensor"
          #define SKETCH_VERSION        "1.0"
          #define CHILD_ID_HUM 0                    // Child id for Humidity
          #define CHILD_ID_TEMP 1                   // Child id for Temperature
          #define CHILD_ID_MOT 2                   // Id of the sensor child
          #define HUMIDITY_SENSOR_DIGITAL_PIN 7    // Where is my DHT22 data pin connected to
          #define DIGITAL_INPUT_SENSOR 3           // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
          //Misc. variables
          uint8_t switchState = 2;
          unsigned long SLEEP_TIME = 820000;      // Sleep time between reads (in milliseconds) (close to 15')
          unsigned long SLEEP_TIME2 = 275000;     // Sleep time after int. (in milliseconds) (close to 5')
          uint8_t cycleInProgress = 0;
          uint8_t firstReportDone = 0;
          uint8_t firstReportWithZeroDone = 0;
          int oldBatteryPcnt = 0;
          DHT dht;
          float lastTemp = 0 ;
          float lastHum = 0 ;
          boolean lastTripped = false ;
          boolean metric = true;
          MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
             analogReference(INTERNAL1V1);
             analogReference(INTERNAL);
            gw.begin();
            gw.sendSketchInfo("3 in 1 Sensor", "1.0");
            gw.present(CHILD_ID_MOT, S_MOTION);
            if (isnan(temperature)) {
              lastTemp = temperature;
              if (!metric) {
              Serial.print("T: ");
            if (isnan(humidity)) {
                lastHum = humidity;
                Serial.print("H: ");
                Serial.println(humidity);
            // get the battery Voltage
             #ifdef DEBUG
             Serial.println(sensorValue);
             #ifdef DEBUG
             Serial.print(batteryV);
             Serial.println(" V");
             Serial.print(batteryPcnt);
             Serial.println(" %");
            // Read digital motion value
            if (tripped != lastTripped ) {
              Serial.println(tripped);
              gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
               // Power up radio after sleep
               oldBatteryPcnt = batteryPcnt;
            gw.sleep(INTERRUPT, CHANGE, 0 );
          thanks very much!
          AWIA 1 Reply Last reply
          • rhuehnR rhuehn
             #define MY_GW_ID 31
            //Constants
            //Misc. variables
            DHT dht;
            float lastHum = 0 ;
              gw.begin();
                if (!metric) {
                  lastHum = humidity;
               #ifdef DEBUG
               #ifdef DEBUG
            thanks very much!
            AWIA
            AWIA
            AWI
            @rhuehn It looks like you are repeating the conversation in this thread. Its better to continue the discussion there.
            • mfalkviddM
              I agree with AWI, but would like to add one thing: By using the DHT11 you are really fighting an uphill battle. There are several sensors that are more suitable for battery-powered sensors. See the study referenced by @AWI in https://forum.mysensors.org/topic/3801/witch-temp-hum-sensor-is-best-to-use-for-battery-powered-sensors/2
              • rhuehnR
                rhuehnR
                rhuehn
                Thanks @mfalkvidd Starting to realize that..... I might swap to the HTU21D, but keep in mind I'm also using a PIR..... Is there a reliable, low voltage PIR sensor that works well? I haven't seen one yet ( 2 x AA BATT's, under 2.8 V )?
                • rhuehnR
                  rhuehnR
                  rhuehn
                  I have updated the original post if anyone can offer any suggestions. it is located Here
                  Any feedback is greatly appreciated
                  • N
                    N
                    Nicklas Starkel
                    @EasyIoT , how are your sensors doing, its been 2 years :)
                    And also, @m26872 , the node 105. Is it alive?
                    m26872M 1 Reply Last reply
                    • N Nicklas Starkel
                      m26872M
                      m26872M
                      m26872
                      @Nicklas-Starkel I've been busy for few months moving to a new house and have had my sensor network offline until now because of this. Node 105 was kept on and handled with care, but I was pretty sure it would be dead when I started my gateway yesterday. BUT, it was ALIVE ?! at 14% battery level. Amazing! 24 months with such poor and simple hardware and software. :exclamation: :two_hearts: :star: :musical_note: :dancers: :clap: :muscle: Same batteries and only one restart (due to my controller change last year).
                      One little remark though, it doesn't seem to send temperature och pressure, only humidity and battery level. Maybe an issue of voltage recovery time between transmissions.
                        sineverba
                          sineverba
                          Sorry for the noob question...
                          I would re-create your setup. At which point of it you insert the multimeter to measure the current?
                          Is it ok to "interrupt" the ground (proximity to the step up) and measure the current there?
                          Thank you
                          • S sineverba
                            Thank you
                            m26872M
                            m26872M
                            m26872
                            @sineverba Just cut one of the battery wires of the finished assembly. Solder together again when your done measuring.
                            • P
                              P
                              palmerfarmer
                              Has anyone got a V2 version working for this?
                              F 1 Reply Last reply
                              • P palmerfarmer
                                F
                                F
                                flopp
                                @palmerfarmer said in My 2AA battery sensor:
                                Do you mean running with MySensors 2.3?
                                • P
                                  P
                                  palmerfarmer
                                  Any Ver 2.xx,
                                  So I have cobbled together/hacked this and it seem to work, battery has stayed at 97% for 2 weeks now. Feel free to Hack about and improve i have this mounted on an easyPCB board, x2AA batteries, NRF radio, BME280 with a 3.3v convertor .
                                  * use mysensors library 2.2.0
                                  * ALL WORKING AND TESTED ON EASY PCB BOARD WITH BATTERY SAVING CODE 29/11/18
                                  * Time SET to 15 mins
                                  * also added BME280.writeMode (smSleep); to reduce quisecent to current to 40uA
                                  * BME280 sensor connections: 3.3v, 0V, SCL to A5, SDA to A4, BAT to A0
                                  //Enable debug prints to serial monitor
                                  #define MY_RF24_PA_LEVEL RF24_PA_MIN //settings are MIN, LOW, HIGH, MAX
                                  #define MY_NODE_ID 18
                                  #include <BME280_MOD-1022.h>
                                  // BME280 libraries and variables
                                  // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code
                                  // Written originally by Embedded Adventures
                                  // https://github.com/embeddedadventures/BME280
                                  #define BARO_CHILD 0
                                  #define TEMP_CHILD 1
                                  #define HUM_CHILD 2
                                  unsigned long SLEEP_TIME = 15*60000;  // sleep time between reads (seconds x*1000 milliseconds)
                                  //unsigned long SLEEP_TIME = 20000;  // Debug test time 20 seconds
                                  long interval = 1000;                // 1 min interval at which to send (milliseconds)
                                  long previousMillis = interval;        // will store last time data was sent
                                  const float ALTITUDE = 0; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
                                  const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
                                  enum FORECAST
                                    STABLE = 0,     // "Stable Weather Pattern"
                                    SUNNY = 1,      // "Slowly rising Good Weather", "Clear/Sunny "
                                    CLOUDY = 2,     // "Slowly falling L-Pressure ", "Cloudy/Rain "
                                    UNSTABLE = 3,   // "Quickly rising H-Press",     "Not Stable"
                                    THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
                                    UNKNOWN = 5     // "Unknown (More Time needed)
                                  const int LAST_SAMPLES_COUNT = 5;
                                  float lastPressureSamples[LAST_SAMPLES_COUNT];
                                  // this CONVERSION_FACTOR is used to convert from Pa to kPa in the forecast algorithm
                                  // get kPa/h by dividing hPa by 10
                                  #define CONVERSION_FACTOR (1.0/10.0)
                                  int minuteCount = 0;
                                  bool firstRound = true;
                                  // average value is used in forecast algorithm.
                                  float pressureAvg;
                                  // average after 2 hours is used as reference value for the next iteration.
                                  float pressureAvg2;
                                  float dP_dt;
                                  boolean metric;
                                  MyMessage humMsg(HUM_CHILD, V_HUM);
                                  float getLastPressureSamplesAverage()
                                    float lastPressureSamplesAverage = 0;
                                    for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                                      lastPressureSamplesAverage += lastPressureSamples[i];
                                    lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                                    return lastPressureSamplesAverage;
                                  // Algorithm found here
                                  // Pressure in hPa -->  forecast done by calculating kPa/h
                                  int sample(float pressure)
                                    // Calculate the average of the last n minutes.
                                    int index = minuteCount % LAST_SAMPLES_COUNT;
                                    lastPressureSamples[index] = pressure;
                                    minuteCount++;
                                    if (minuteCount > 185)
                                      minuteCount = 6;
                                    if (minuteCount == 5)
                                      pressureAvg = getLastPressureSamplesAverage();
                                    else if (minuteCount == 35)
                                      float lastPressureAvg = getLastPressureSamplesAverage();
                                      float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                                        dP_dt = change * 2; // note this is for t = 0.5hour
                                        dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
                                    else if (minuteCount == 65)
                                        dP_dt = change; //note this is for t = 1 hour
                                        dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
                                    else if (minuteCount == 95)
                                        dP_dt = change / 1.5; // note this is for t = 1.5 hour
                                        dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
                                    else if (minuteCount == 125)
                                      pressureAvg2 = lastPressureAvg; // store for later use.
                                        dP_dt = change / 2; // note this is for t = 2 hour
                                        dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
                                    else if (minuteCount == 155)
                                        dP_dt = change / 2.5; // note this is for t = 2.5 hour
                                        dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
                                    else if (minuteCount == 185)
                                        dP_dt = change / 3; // note this is for t = 3 hour
                                        dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
                                      pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                                    int forecast = UNKNOWN;
                                      forecast = UNKNOWN;
                                    else if (dP_dt < (-0.25))
                                      forecast = THUNDERSTORM;
                                    else if (dP_dt > 0.25)
                                      forecast = UNSTABLE;
                                      forecast = CLOUDY;
                                      forecast = SUNNY;
                                    else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
                                      forecast = STABLE;
                                      forecast = UNKNOWN;
                                    return forecast;
                                    metric = getControllerConfig().isMetric;  // was getConfig().isMetric; before MySensors v2.1.1
                                    Wire.begin(); // Wire.begin(sda, scl)
                                  void presentation()  {
                                    sendSketchInfo("BME280_BAT_V2", "V2e.");
                                    // Register sensors to gw (they will be created as child devices)
                                    present(BARO_CHILD, S_BARO);
                                    present(TEMP_CHILD, S_TEMP);
                                    present(HUM_CHILD, S_HUM);
                                  // Loop
                                     #ifdef MY_DEBUG
                                     #ifdef MY_DEBUG
                                   //  sleep(SLEEP_TIME);
                                  if(currentMillis - previousMillis > interval) {
                                      // save the last time sent the data
                                    wait(500);
                                    // need to read the NVM compensation parameters
                                    BME280.readCompensationParams();
                                    // Normal mode for regular automatic samples
                                    BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
                                    BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
                                    BME280.writeOversamplingPressure(os16x);    // pressure x16
                                    BME280.writeOversamplingTemperature(os8x);  // temperature x8
                                    BME280.writeOversamplingHumidity(os8x);     // humidity x8
                                    BME280.writeMode(smNormal);
                                      // Just to be sure, wait until sensor is done mesuring
                                      while (BME280.isMeasuring()) {
                                    // Read out the data - must do this before calling the getxxxxx routines
                                    BME280.readMeasurements();
                                    float temperature = BME280.getTemperatureMostAccurate();                    // must get temp first
                                    float humidity = BME280.getHumidityMostAccurate();
                                    float pressure_local = BME280.getPressureMostAccurate();                    // Get pressure at current location
                                    float pressure = pressure_local/pow((1.0 - ( ALTITUDE / 44330.0 )), 5.255); // Adjust to sea level pressure using user altitude
                                    int forecast = sample(pressure);
                                    if (!metric)
                                      // Convert to fahrenheit
                                      temperature = temperature * 9.0 / 5.0 + 32.0;
                                    Serial.println();
                                    Serial.print("Temperature = ");
                                    Serial.print(temperature);
                                    Serial.println(metric ? " °C" : " °F");
                                    Serial.print("Humidity = ");
                                    Serial.print(humidity);
                                    Serial.print("Pressure = ");
                                    Serial.print(pressure);
                                    Serial.println(" hPa");
                                    Serial.print("Forecast = ");
                                    Serial.println();
                                      send(tempMsg.set(temperature, 1));
                                  wait(50);
                                      send(humMsg.set(humidity, 1));
                                  wait(50);
                                      send(pressureMsg.set(pressure, 2));
                                  wait(50);
                                  sleep(SLEEP_TIME);
                                  • P
                                    P
                                    palmerfarmer
                                    wrote on last edited by palmerfarmer
                                    #87
                                    11months on battery at 87%... still working!0_1574260268012_BME280 battery.JPG
                                    TRS-80T 1 Reply Last reply
                                    • P
                                      P
                                      palmerfarmer
                                      • P palmerfarmer
                                        TRS-80T
                                        TRS-80T
                                        TRS-80
                                        @palmerfarmer,
                                        That project box is perfect! Where did you find it (it doesn't look printed)?
                                        • P
                                          P
                                          palmerfarmer
                                          I got it from CPC in the UK which are owned by Farnell
                                          https://cpc.farnell.com/hammond/1593qgy/case-with-bat-compart-110x66x28mm/dp/EN82140
                                          You may have to make a slight mod to the board or enclosure to make it fit.
                                          good luck
