  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.0k Views 31 Watching
  • NiklasON NiklasO
    I have changed the fuse settings for my setup. I don't know if it makes any difference but there is a fuse for "Preserve EEPROM memory through the Chip Erase cycle". Was noticing that my sensors was getting a new id every time I did some changes in my sketches and flashed using "Upload with programmer". I have not succeeded with OTA flashing yet.
    I also use the external crystal present on the Pro Mini. Using 0xFF, 0xD2 and 0xFE.
    Probably only used when programming using ICSP.
    MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (XTAL, BOD1V8)
    MYSBL13.menu.cpu.8MHzatmega328.upload.maximum_size=30720
    MYSBL13.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
    MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
    MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
    MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xD2
    MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0xFE
    MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBL13pre_atmega328_8Mhz.hex
    MYSBL13.menu.cpu.8MHzatmega328.build.mcu=atmega328p
    MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
    pkuP
    pkuP
    pku
    @NiklasO I'm using Arduino Mini 5V, 16Mhz with fuses as you have. Except BODLEVEL 2.7V and EEPROM Cleared. OTA works fine, 21kB hex file is sent in cca 2-5 minutes (very depends on count of wrong packets, without 47uF capacitor on NRF24 or with low power supply it takes about 2 hours :) ). I started with MYSController and small and easy Blink.ino.hex from MYSController distribution. Now I use MyController and own firmwares...
    • pkuP pku
      @tekka Thank you for great job on MYSBootloader. It works fine for me. Currently I'm testing it and have few questions.
      • Please can you provide source code? Maybe then I can answer my questions myself :)
      • Software signing doesn't work after firmware is uploaded. EEPROM is cleared. Is it possible to restore shared key HMAC after firmware is stored?
      • Is possible to send firmware with signing to prevent loading from fake gateway? I thing signing of available firmware version and firmware CRC is enough ..?
      Thank you for answers.
      JCLBJ
      JCLBJ
      JCLB
      @pku if your keys are in the sketch everything will work for signing.
      #define MY_SOFT_HMAC_KEY XXX... //signing key
      #define MY_AES_KEY XXX... // if you use encryption
      Of course if you want to use whitelisting then you need to compile each node sketch separately with it's serial.
      @NiklasO
      Personally I set the node ID manually to avoid this
      #define MY_NODE_ID 30 // Sets a static id for a node
      And I group tens so all my 3X nodes are in kitchen, 4X in office, 11X in bedroom 1 and so on.
      I would love to see a proxy mode in MYSController, in order to interface between a controller that doesn't support OTA and an Ethernet gateway :heart_eyes:
      Let say your LAN is the following:
      • MySensors gateway 192.168.0.1
      • controller (raspberry + Domoticz or else) 192.168.0.2
      • PC with MYSController 192.168.0.3
      Whenever you need to update a node, you launch MYSController but don't connect to the gateway, then you tells Domoticz .2 to connect to MYSController .3 instead of the gateway .1, at this point MYSController starts relaying everything between Domoticz and the gateway + provides you the ability to update a node.
      When you want to get back to normal operations, you set back 192.168.0.1 on Domoticz, MYSController receives a TCP reset and ends it's session with Domoticz and stop the session with the gateway.
      We would get a minimum downtime and can could use MYSController to update nodes and debug traffic while letting the normal controller...controlling
      NiklasON AndurilA 2 Replies Last reply
      • JCLBJ JCLB
        @NiklasO
        NiklasON
        NiklasON
        NiklasO
        @NiklasO
        Ah, yes. Setting static id sound like a solution to my problem. Thanks.
        • JCLBJ JCLB
          @NiklasO
          AndurilA
          AndurilA
          Anduril
          but that would give a listener your full MY_SOFT_HMAC_KEY and signing would be useless in future. Therefor it is better to write the key in eeprom with cable and later only update firmware without key via OTA.
          pkuP 1 Reply Last reply
          • AndurilA Anduril
            pkuP
            pkuP
            pku
            @Anduril
            1. I agree, keys located in sketch can be used as workaround only, because the security is broken.
            2. But I'm interesting in key located in EEPROM. How it is work during flashing? If Clear EEPROM fuse is not set then everybody can take my outside node, put his own firmware and it will work with keys from EEPROM. It is again a security issue (of course he must have physical access to my node).
              I thing it should work with this scenario:
            • reguest for new firmware
            • copy key, serial and rsa into RAM
            • flash new firmware (with fuse clear EEPROM)
            • copy key, serial and rsa back into EEPROM
            What do you thing?
            • AndurilA
              AndurilA
              Anduril
              For a node that is physically accessable it is realy hard. First: does this node needs signing? For sensor data you don't need in most cases. Maybe you should use the hardware chip, there you can't read out the key and if it was locked you also can't change it.
              If you still need to use softsigning you could use whitelisting and revoke the whitelist-entry in case of corruption.
              • jmkhaelJ
                jmkhaelJ
                jmkhael
                wrote on last edited by jmkhael
                #36
                I am trying to use MYSController with MYSBootloader 1.3pre2 to reassign a node's ID, and I cannot make it work.
                I've tried to check/uncheck the Auto ID toggle/tried to use the MYSBootloader CMDs/Assign ID and setting a new one to no avail.
                After that, when it reboots, the node reask for it's firmware, and MYSController re-uploads it, but the node keeps the old ID from the EEProm. (note that the sketch don't hardcode the node's ID).
                I'd like to keep the ID management free (i.e. do not hardcode all my node's IDs of course)
                How can I do that?
                 [2016-10-21 13:41:33.318 Info] CLICK	Reassign ID from 1 to 20
                 [2016-10-21 13:41:33.319 Info] TX	1;0;3;0;13;0
                 [2016-10-21 13:41:33.364 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=fail:0
                 [2016-10-21 13:41:37.886 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155561124
                 [2016-10-21 13:41:37.886 Info] RX	4;255;3;0;22;155561124
                 [2016-10-21 13:41:42.855 Info] RX	0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                 [2016-10-21 13:41:42.857 Info] RX	2;1;1;0;16;0
                 [2016-10-21 13:41:46.623 Info] RX	0;255;3;0;9;TSP:MSG:READ 8-5-0 s=2,c=1,t=16,pt=0,l=1,sg=0:0
                 [2016-10-21 13:41:46.625 Info] RX	8;2;1;0;16;0
                 [2016-10-21 13:41:47.899 Info] RX	0;255;3;0;9;TSP:MSG:READ 8-5-0 s=3,c=1,t=23,pt=2,l=2,sg=0:80
                 [2016-10-21 13:41:47.901 Info] RX	8;3;1;0;23;80
                 [2016-10-21 13:41:50.491 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
                 [2016-10-21 13:41:50.494 Info] RX	0;255;3;0;9;TSP:MSG:ACK msg
                 [2016-10-21 13:41:50.540 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:22.0
                 [2016-10-21 13:41:50.540 Info] RX	4;1;1;0;0;22.0
                 [2016-10-21 13:41:50.570 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155562401
                 [2016-10-21 13:41:50.570 Info] RX	4;255;3;0;22;155562401
                 [2016-10-21 13:41:57.014 Info] RX	0;255;3;0;9;TSP:SANCHK:OK
                 [2016-10-21 13:42:02.832 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155563404
                 [2016-10-21 13:42:02.832 Info] RX	4;255;3;0;22;155563404
                 [2016-10-21 13:42:20.453 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=22,pt=5,l=4,sg=0:4712
                 [2016-10-21 13:42:20.453 Info] RX	1;255;3;0;22;4712
                 [2016-10-21 13:42:20.453 Info] CHILD	New child discovered, node id=1, child id=internal
                 [2016-10-21 13:42:20.951 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:0
                 [2016-10-21 13:42:20.953 Info] RX	1;2;1;0;16;0
                 [2016-10-21 13:42:20.953 Info] CHILD	New child discovered, node id=1, child id=2
                 [2016-10-21 13:42:21.954 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=3,c=1,t=23,pt=2,l=2,sg=0:42
                 [2016-10-21 13:42:21.956 Info] RX	1;3;1;0;23;42
                 [2016-10-21 13:42:21.956 Info] CHILD	New child discovered, node id=1, child id=3
                 [2016-10-21 13:42:27.773 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155565680
                 [2016-10-21 13:42:27.774 Info] RX	4;255;3;0;22;155565680
                 [2016-10-21 13:42:40.382 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155566954
                 [2016-10-21 13:42:40.382 Info] RX	4;255;3;0;22;155566954
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=1)
                TSM:FPAR
                TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSP:MSG:READ 5-5-1 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                TSP:MSG:FPAR RES (ID=5, dist=1)
                TSP:MSG:PAR OK (ID=5, dist=2)
                TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSP:MSG:PAR OK (ID=0, dist=1)
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=1)
                TSM:UPL
                TSP:PING:SEND (dest=0)
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                TSP:MSG:PONG RECV (hops=1)
                TSP:CHKUPL:OK
                TSM:UPL:OK
                TSM:READY
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:Multi Sensor
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 1-1-0-0 s=3,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=ok:
                Request registration...
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                Node registration=1
                Init complete, id=1, parent=0, distance=1, registration=1
                TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=ok:0
                TSP:MSG:SEND 1-1-0-0 s=3,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:54
                tekkaT 1 Reply Last reply
                • JamesT42J
                  JamesT42J
                  JamesT42
                  Hi! Great work!
                  I have a small question: How does your Bootloader know which channel to listen on?
                  pkuP tekkaT 2 Replies Last reply
                  • JamesT42J JamesT42
                    Hi! Great work!
                    pkuP
                    pkuP
                    pku
                    @JamesT42
                    Hi, it is hardcoded within the bootloader: nRF24 (Channel 76, base address 0xA8A8E1FC00, data rate 250kbs)
                    • jmkhaelJ jmkhael
                      How can I do that?
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:CHKID:OK (ID=1)
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      Node registration=1
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      #39
                      @jmkhael Bootloader commands have been removed due to size constraints (see initial post). If you want to change the node ID you can send a C_INTERNAL / I_ID_RESPONSE / <new ID> message to an actively listening node.
                        Hi! Great work!
                        tekkaT
                        tekkaT
                        tekka
                        @JamesT42 Thanks. As @pku pointed out, this is hardcoded. With the final release of MYSBootloader and its source code, everybody will be able to adjust settings and recompile the bootloader as needed.
                        • jmkhaelJ
                          jmkhaelJ
                          jmkhael
                          @tekka : fair enough, i should read better next time :)
                          i'll try the way you suggest. thank you.
                          • kleinerDracheK
                            kleinerDracheK
                            kleinerDrache
                            hi tekka
                            I had to change the channel of the NRF from 76 to 0 here because of massive disturbances . Unfortunately, no OTA works now. Is it possible to create a modified bootloader that works with 0 instead of 76? Sorry for the bad english it is translated with google.
                            • LorenzoL
                              LorenzoL
                              Lorenzo
                              Hi, thank for the great work.
                              I also use a different Channel, in fact I have 3 area with 3 differents Channels.
                              Do you have a plan about source code release date ?
                              • techRHT
                                techRHT
                                techRH
                                wrote on last edited by techRH
                                #44
                                Is there a way to debug the bootloader should it print debug information and how to see this?
                                • Suresh MaliS
                                  Suresh MaliS
                                  Suresh Mali
                                  • TetnobicT
                                    TetnobicT
                                    Tetnobic
                                    wrote on last edited by Tetnobic
                                    #46
                                    I just start to test this bootloader...
                                    I use an ATmega328p on breadboard with no external clock, with nRF24 and somes sensors.
                                    Firmware Upload (by usbasp) and Run is ok, Send/Receive Data is ok too , but when I ask a reboot (with MYSController 1.0.0beta), my node enter in sort of strange start loop...
                                    My Fuse settings :
                                    bootloader.unlock_bits=0x3F
                                    bootloader.lock_bits=0x0F
                                    bootloader.low_fuses=0x62
                                    bootloader.high_fuses=0xDA
                                    bootloader.extended_fuses=0x07
                                    Node debug Trace :
                                    TSP:MSG:READ 0-0-4 s=2,c=1,t=0,pt=7,l=5,sg=0:28.18
                                    TSP:MSG:READ 0-0-4 s=1,c=1,t=1,pt=7,l=5,sg=0:38.28
                                    TSP:MSG:READ 0-0-4 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                                    StartiStartiStartiStartiþStartiþStartiþStartiStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþ
                                    The "Startiþ" text is the first char of the first text printed by bootloader at start : "Starting sensor....."
                                    Have you an idea ?
                                    • tekkaT
                                      tekkaT
                                      tekka
                                      Please provide additional information such as library version, full debug log of your GW and node. Which bootloader/version are you using?
                                      TetnobicT 1 Reply Last reply
                                      • tekkaT tekka
                                        TetnobicT
                                        TetnobicT
                                        Tetnobic
                                        @tekka Thanks for you response
                                        For gateway :
                                        Raspberrry PI Gateway in Ethernet mode
                                        Protocol version : 2.0.1-beta
                                        For Node :
                                        I use bootloader : MYSBL13pre_atmega328_1Mhz.hex
                                        Inital Sketch do nothing :) :
                                        #define MY_BAUD_RATE 9600
                                        #define MY_OTA_FIRMWARE_FEATURE
                                        #define MY_NODE_ID 1
                                        void presentation(){
                                          sendSketchInfo("MyFirstBoard", "0.0.2", true);
                                          wait(5000);
                                        Test Case: Start Gateway, Connect MYSController 1.0.0beta, then start my sensor, after init complete, click reboot in MYSController
                                        Gateway Log :
                                        mysgw: Starting gateway...
                                        mysgw: Protocol version - 2.0.1-beta
                                        mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSM:INIT:TSP OK
                                        mysgw: TSM:INIT:GW MODE
                                        mysgw: TSM:READY
                                        mysgw: MCO:REG:NOT NEEDED
                                        mysgw: MCO:BGN:STP
                                        mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                        mysgw: New connection from 10.31.10.59
                                        mysgw: Client 0 connected
                                        mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                        mysgw: TSF:MSG:BC
                                        mysgw: TSF:MSG:FPAR REQ,ID=1
                                        mysgw: TSF:PNG:SEND,TO=0
                                        mysgw: TSF:CKU:OK
                                        mysgw: TSF:MSG:GWL OK
                                        mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                        mysgw: TSF:MSG:PINGED,ID=1,HP=1
                                        mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                        mysgw: TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
                                        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                        mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                        mysgw: TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                                        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                        mysgw: Client 0: 1;255;3;0;6;M
                                        mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
                                        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
                                        mysgw: TSF:MSG:ACK REQ
                                        mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:MyFirstBoard
                                        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
                                        mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=OK:0.0.2
                                        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                        mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                        mysgw: Client 0: 1;0;3;0;13;0
                                        mysgw: TSF:MSG:SEND,0-0-1-1,s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=OK:0
                                        NodeLog :
                                        Starting sensor (RNONA-, 2.0.0)
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:CHKID:OK (ID=1)
                                        TSM:UPL
                                        TSP:CHKUPL:OK
                                        TSM:UPL:OK
                                        TSM:READY
                                        TSP:MSG:SEND 1-1-0-0 s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=ok:FFFFFFFFFFFFFFFF0300
                                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:MyFirstBoard
                                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=ok:0.0.2
                                        TSP:MSG:READ 0-0-1 s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
                                        TSP:MSG:READ 0-0-1 s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
                                        Node registration=1
                                        TSP:MSG:READ 0-0-1 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                                        StartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiþStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStarti
                                        Need others infos ?
                                        Thanks for your time
                                        • TetnobicT Tetnobic
                                          For gateway :
                                          For Node :
                                            wait(5000);
                                          Gateway Log :
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSM:READY
                                          mysgw: MCO:BGN:STP
                                          mysgw: TSF:MSG:BC
                                          mysgw: TSF:CKU:OK
                                          NodeLog :
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:CHKID:OK (ID=1)
                                          TSM:UPL
                                          TSP:CHKUPL:OK
                                          TSM:UPL:OK
                                          TSM:READY
                                          Node registration=1
                                          Need others infos ?
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Tetnobic
                                          Your node is running MySensors 2.0.0 (your GW is at 2.0.1, please consider updating), also, there is no sign of MYSBootloader in your GW log - please double-check if you followed the correct procedure.
                                          One more thing: the startup message indicates that you enabled OTA firmware features (RNONA-) - this is not required with MYSBootloader.
                                          Please have a look at @scalz's OTA guide for additional information.
