  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.0k Views 31 Watching
  • JamesT42J JamesT42
    Hi! Great work!
    I have a small question: How does your Bootloader know which channel to listen on?
    tekkaT
    tekkaT
    tekka
    @JamesT42 Thanks. As @pku pointed out, this is hardcoded. With the final release of MYSBootloader and its source code, everybody will be able to adjust settings and recompile the bootloader as needed.
    • jmkhaelJ
      jmkhaelJ
      jmkhael
      @tekka : fair enough, i should read better next time :)
      i'll try the way you suggest. thank you.
      • kleinerDracheK
        kleinerDracheK
        kleinerDrache
        hi tekka
        I had to change the channel of the NRF from 76 to 0 here because of massive disturbances . Unfortunately, no OTA works now. Is it possible to create a modified bootloader that works with 0 instead of 76? Sorry for the bad english it is translated with google.
        • LorenzoL
          LorenzoL
          Lorenzo
          Hi, thank for the great work.
          I also use a different Channel, in fact I have 3 area with 3 differents Channels.
          Do you have a plan about source code release date ?
          • techRHT
            techRHT
            techRH
            wrote on last edited by techRH
            #44
            Is there a way to debug the bootloader should it print debug information and how to see this?
            • Suresh MaliS
              Suresh MaliS
              Suresh Mali
              • TetnobicT
                TetnobicT
                Tetnobic
                wrote on last edited by Tetnobic
                #46
                I just start to test this bootloader...
                I use an ATmega328p on breadboard with no external clock, with nRF24 and somes sensors.
                Firmware Upload (by usbasp) and Run is ok, Send/Receive Data is ok too , but when I ask a reboot (with MYSController 1.0.0beta), my node enter in sort of strange start loop...
                My Fuse settings :
                bootloader.unlock_bits=0x3F
                bootloader.lock_bits=0x0F
                bootloader.low_fuses=0x62
                bootloader.high_fuses=0xDA
                bootloader.extended_fuses=0x07
                Node debug Trace :
                TSP:MSG:READ 0-0-4 s=2,c=1,t=0,pt=7,l=5,sg=0:28.18
                TSP:MSG:READ 0-0-4 s=1,c=1,t=1,pt=7,l=5,sg=0:38.28
                TSP:MSG:READ 0-0-4 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                StartiStartiStartiStartiþStartiþStartiþStartiStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþ
                The "Startiþ" text is the first char of the first text printed by bootloader at start : "Starting sensor....."
                Have you an idea ?
                • tekkaT
                  tekkaT
                  tekka
                  Please provide additional information such as library version, full debug log of your GW and node. Which bootloader/version are you using?
                  TetnobicT 1 Reply Last reply
                  • tekkaT tekka
                    TetnobicT
                    TetnobicT
                    Tetnobic
                    @tekka Thanks for you response
                    For gateway :
                    Raspberrry PI Gateway in Ethernet mode
                    Protocol version : 2.0.1-beta
                    For Node :
                    I use bootloader : MYSBL13pre_atmega328_1Mhz.hex
                    Inital Sketch do nothing :) :
                    #define MY_BAUD_RATE 9600
                    #define MY_OTA_FIRMWARE_FEATURE
                    #define MY_NODE_ID 1
                    void presentation(){
                      sendSketchInfo("MyFirstBoard", "0.0.2", true);
                      wait(5000);
                    Test Case: Start Gateway, Connect MYSController 1.0.0beta, then start my sensor, after init complete, click reboot in MYSController
                    Gateway Log :
                    mysgw: Starting gateway...
                    mysgw: Protocol version - 2.0.1-beta
                    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSM:INIT:TSP OK
                    mysgw: TSM:INIT:GW MODE
                    mysgw: TSM:READY
                    mysgw: MCO:REG:NOT NEEDED
                    mysgw: MCO:BGN:STP
                    mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                    mysgw: New connection from 10.31.10.59
                    mysgw: Client 0 connected
                    mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                    mysgw: TSF:MSG:BC
                    mysgw: TSF:MSG:FPAR REQ,ID=1
                    mysgw: TSF:PNG:SEND,TO=0
                    mysgw: TSF:CKU:OK
                    mysgw: TSF:MSG:GWL OK
                    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                    mysgw: TSF:MSG:PINGED,ID=1,HP=1
                    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                    mysgw: TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
                    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    mysgw: TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    mysgw: Client 0: 1;255;3;0;6;M
                    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
                    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
                    mysgw: TSF:MSG:ACK REQ
                    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:MyFirstBoard
                    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
                    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=OK:0.0.2
                    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                    mysgw: Client 0: 1;0;3;0;13;0
                    mysgw: TSF:MSG:SEND,0-0-1-1,s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=OK:0
                    NodeLog :
                    Starting sensor (RNONA-, 2.0.0)
                    TSM:INIT
                    TSM:RADIO:OK
                    TSP:ASSIGNID:OK (ID=1)
                    TSM:FPAR
                    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                    TSM:FPAR
                    TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    TSP:MSG:PAR OK (ID=0, dist=1)
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:CHKID:OK (ID=1)
                    TSM:UPL
                    TSP:PING:SEND (dest=0)
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                    TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    TSP:MSG:PONG RECV (hops=1)
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    TSP:MSG:SEND 1-1-0-0 s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=ok:FFFFFFFFFFFFFFFF0300
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                    TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                    TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:MyFirstBoard
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=ok:0.0.2
                    Request registration...
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                    TSP:MSG:READ 0-0-1 s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
                    TSP:MSG:READ 0-0-1 s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
                    TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    Node registration=1
                    Init complete, id=1, parent=0, distance=1, registration=1
                    TSP:MSG:READ 0-0-1 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                    StartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiþStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStarti
                    Need others infos ?
                    Thanks for your time
                    tekkaT 1 Reply Last reply
                    • TetnobicT Tetnobic
                      For gateway :
                      For Node :
                        wait(5000);
                      Gateway Log :
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSM:READY
                      mysgw: MCO:BGN:STP
                      mysgw: TSF:MSG:BC
                      mysgw: TSF:CKU:OK
                      NodeLog :
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:CHKID:OK (ID=1)
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      Node registration=1
                      Need others infos ?
                      tekkaT
                      tekkaT
                      tekka
                      @Tetnobic
                      Your node is running MySensors 2.0.0 (your GW is at 2.0.1, please consider updating), also, there is no sign of MYSBootloader in your GW log - please double-check if you followed the correct procedure.
                      One more thing: the startup message indicates that you enabled OTA firmware features (RNONA-) - this is not required with MYSBootloader.
                      Please have a look at @scalz's OTA guide for additional information.
                      • tekkaT tekka
                        @Tetnobic
                        TetnobicT
                        TetnobicT
                        Tetnobic
                        @tekka Thanks for your response
                        What are the sign of MYSBootloader in GW log ?
                        Can I also see any sign of MYSBootloader in Node Log ?
                        I remove OTA firmware features, I now have :
                        but same problem, after receive reboot message I have a "StartiStartiStartiStartiS...." loop :(:(
                          tekkaT
                          tekkaT
                          tekka
                          @Tetnobic No, you won't see anything in the node log - but in the GW log you should see somehting like:
                          1;255;4;0;0;64000200C803948D0105
                          • tekkaT tekka
                            TetnobicT
                            TetnobicT
                            Tetnobic
                            @tekka Hi, I found my mistake ! You were absolutely right when you said there is no sign of MYSBootloader in my GW log...
                            But now I know why :) :
                            I use an USBasp Programmer with Arduino IDE for upload my bootloader and my sketch..., and I mistakenly thought that when I upload bootloader then sketch, it keep bootloader.....but NOT, it overwrite bootloader :(
                            I fix it by uploading the xxx.with_bootloader.hex file generated by Arduino IDE when compile.
                            Sorry for the inconvenience and thank you for your help
                            AndurilA 1 Reply Last reply
                              AndurilA
                              AndurilA
                              Anduril
                              @Tetnobic can this be done within the IDE? I have some nodes where I have to upload with ISP and thought to still have the bootloader, but this explains why OTA didn't work afterwards...
                              • AndurilA Anduril
                                TetnobicT
                                TetnobicT
                                Tetnobic
                                @Anduril I think you can do this without Arduino IDE...
                                but how compile you code for generate sketch+bootloader ( the xxx.with_bootloader.hex file) in command line I don't know....
                                For upload this file on my ATMega, I use avrdude, the same command line that ardunio IDE use, but change the .hex file...
                                • TigroenotT
                                  TigroenotT
                                  Tigroenot
                                  Tried this bootloader.
                                  Have two nodes 8MHz internal, two nodes 1MHz. All run beautifully, the OTA firmware update around a minute with binaryButton sketch. But the node startup is around 7-8 seconds. And no problems uploading the sketch via serial.
                                  I use an UNO as an ASP to burn the bootloader and a simple USB_TTL FTDI converter to upload sketches.
                                  • jerseyguy1996J
                                    jerseyguy1996J
                                    jerseyguy1996
                                    This may be a stupid question, but I'm using the mysgateway on a Raspberry Pi as my controller which is described here:
                                    Building a Raspberry Pi Gateway
                                    The Raspberry pi runs headless and I do everything through ssh. Is there any way to use MYSBootloader using the mysgateway and initiating the OTA update using the command line?
                                    RedferneR 1 Reply Last reply
                                    • RedferneR
                                      RedferneR
                                      Redferne
                                      Shall we all join hands and give a warm applause to @tekka for his work and pray that he'll find the time to give us a lovely christmas present. The MYSBootloader 1.3+ pushed to github 😃
                                      pkuP 1 Reply Last reply
                                      • J
                                        J
                                        jacikaas
                                        • RedferneR Redferne
                                          pkuP
                                          pkuP
                                          pku
                                          @tekka pleeeease.... :pray:
