  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.0k Views 31 Watching
  • AndurilA Anduril
    @JCLB said:
    @pku if your keys are in the sketch everything will work for signing.
    #define MY_SOFT_HMAC_KEY XXX... //signing key
    #define MY_AES_KEY XXX... // if you use encryption
    Of course if you want to use whitelisting then you need to compile each node sketch separately with it's serial.
    but that would give a listener your full MY_SOFT_HMAC_KEY and signing would be useless in future. Therefor it is better to write the key in eeprom with cable and later only update firmware without key via OTA.
    pkuP
    pkuP
    pku
    @Anduril
    1. I agree, keys located in sketch can be used as workaround only, because the security is broken.
    2. But I'm interesting in key located in EEPROM. How it is work during flashing? If Clear EEPROM fuse is not set then everybody can take my outside node, put his own firmware and it will work with keys from EEPROM. It is again a security issue (of course he must have physical access to my node).
      I thing it should work with this scenario:
    • reguest for new firmware
    • copy key, serial and rsa into RAM
    • flash new firmware (with fuse clear EEPROM)
    • copy key, serial and rsa back into EEPROM
    What do you thing?
    • AndurilA
      AndurilA
      Anduril
      For a node that is physically accessable it is realy hard. First: does this node needs signing? For sensor data you don't need in most cases. Maybe you should use the hardware chip, there you can't read out the key and if it was locked you also can't change it.
      If you still need to use softsigning you could use whitelisting and revoke the whitelist-entry in case of corruption.
      • jmkhaelJ
        jmkhaelJ
        jmkhael
        wrote on last edited by jmkhael
        #36
        I am trying to use MYSController with MYSBootloader 1.3pre2 to reassign a node's ID, and I cannot make it work.
        I've tried to check/uncheck the Auto ID toggle/tried to use the MYSBootloader CMDs/Assign ID and setting a new one to no avail.
        After that, when it reboots, the node reask for it's firmware, and MYSController re-uploads it, but the node keeps the old ID from the EEProm. (note that the sketch don't hardcode the node's ID).
        I'd like to keep the ID management free (i.e. do not hardcode all my node's IDs of course)
        How can I do that?
         [2016-10-21 13:41:33.318 Info] CLICK	Reassign ID from 1 to 20
         [2016-10-21 13:41:33.319 Info] TX	1;0;3;0;13;0
         [2016-10-21 13:41:33.364 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=fail:0
         [2016-10-21 13:41:37.886 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155561124
         [2016-10-21 13:41:37.886 Info] RX	4;255;3;0;22;155561124
         [2016-10-21 13:41:42.855 Info] RX	0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
         [2016-10-21 13:41:42.857 Info] RX	2;1;1;0;16;0
         [2016-10-21 13:41:46.623 Info] RX	0;255;3;0;9;TSP:MSG:READ 8-5-0 s=2,c=1,t=16,pt=0,l=1,sg=0:0
         [2016-10-21 13:41:46.625 Info] RX	8;2;1;0;16;0
         [2016-10-21 13:41:47.899 Info] RX	0;255;3;0;9;TSP:MSG:READ 8-5-0 s=3,c=1,t=23,pt=2,l=2,sg=0:80
         [2016-10-21 13:41:47.901 Info] RX	8;3;1;0;23;80
         [2016-10-21 13:41:50.491 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
         [2016-10-21 13:41:50.494 Info] RX	0;255;3;0;9;TSP:MSG:ACK msg
         [2016-10-21 13:41:50.540 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:22.0
         [2016-10-21 13:41:50.540 Info] RX	4;1;1;0;0;22.0
         [2016-10-21 13:41:50.570 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155562401
         [2016-10-21 13:41:50.570 Info] RX	4;255;3;0;22;155562401
         [2016-10-21 13:41:57.014 Info] RX	0;255;3;0;9;TSP:SANCHK:OK
         [2016-10-21 13:42:02.832 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155563404
         [2016-10-21 13:42:02.832 Info] RX	4;255;3;0;22;155563404
         [2016-10-21 13:42:20.453 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=22,pt=5,l=4,sg=0:4712
         [2016-10-21 13:42:20.453 Info] RX	1;255;3;0;22;4712
         [2016-10-21 13:42:20.453 Info] CHILD	New child discovered, node id=1, child id=internal
         [2016-10-21 13:42:20.951 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:0
         [2016-10-21 13:42:20.953 Info] RX	1;2;1;0;16;0
         [2016-10-21 13:42:20.953 Info] CHILD	New child discovered, node id=1, child id=2
         [2016-10-21 13:42:21.954 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=3,c=1,t=23,pt=2,l=2,sg=0:42
         [2016-10-21 13:42:21.956 Info] RX	1;3;1;0;23;42
         [2016-10-21 13:42:21.956 Info] CHILD	New child discovered, node id=1, child id=3
         [2016-10-21 13:42:27.773 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155565680
         [2016-10-21 13:42:27.774 Info] RX	4;255;3;0;22;155565680
         [2016-10-21 13:42:40.382 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155566954
         [2016-10-21 13:42:40.382 Info] RX	4;255;3;0;22;155566954
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=1)
        TSM:FPAR
        TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSP:MSG:READ 5-5-1 s=255,c=3,t=8,pt=1,l=1,sg=0:1
        TSP:MSG:FPAR RES (ID=5, dist=1)
        TSP:MSG:PAR OK (ID=5, dist=2)
        TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        TSP:MSG:PAR OK (ID=0, dist=1)
        TSM:FPAR:OK
        TSM:ID
        TSM:CHKID:OK (ID=1)
        TSM:UPL
        TSP:PING:SEND (dest=0)
        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
        TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
        TSP:MSG:PONG RECV (hops=1)
        TSP:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
        TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
        TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:Multi Sensor
        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
        TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
        TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
        TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
        TSP:MSG:SEND 1-1-0-0 s=3,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=ok:
        Request registration...
        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
        TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
        Node registration=1
        Init complete, id=1, parent=0, distance=1, registration=1
        TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=ok:0
        TSP:MSG:SEND 1-1-0-0 s=3,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:54
        tekkaT 1 Reply Last reply
        • JamesT42J
          JamesT42J
          JamesT42
          Hi! Great work!
          I have a small question: How does your Bootloader know which channel to listen on?
          pkuP tekkaT 2 Replies Last reply
          • JamesT42J JamesT42
            Hi! Great work!
            pkuP
            pkuP
            pku
            @JamesT42
            Hi, it is hardcoded within the bootloader: nRF24 (Channel 76, base address 0xA8A8E1FC00, data rate 250kbs)
            • jmkhaelJ jmkhael
              How can I do that?
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:CHKID:OK (ID=1)
              TSM:UPL
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              Node registration=1
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              #39
              @jmkhael Bootloader commands have been removed due to size constraints (see initial post). If you want to change the node ID you can send a C_INTERNAL / I_ID_RESPONSE / <new ID> message to an actively listening node.
                Hi! Great work!
                tekkaT
                tekkaT
                tekka
                @JamesT42 Thanks. As @pku pointed out, this is hardcoded. With the final release of MYSBootloader and its source code, everybody will be able to adjust settings and recompile the bootloader as needed.
                • jmkhaelJ
                  jmkhaelJ
                  jmkhael
                  @tekka : fair enough, i should read better next time :)
                  i'll try the way you suggest. thank you.
                  • kleinerDracheK
                    kleinerDracheK
                    kleinerDrache
                    hi tekka
                    I had to change the channel of the NRF from 76 to 0 here because of massive disturbances . Unfortunately, no OTA works now. Is it possible to create a modified bootloader that works with 0 instead of 76? Sorry for the bad english it is translated with google.
                    • LorenzoL
                      LorenzoL
                      Lorenzo
                      Hi, thank for the great work.
                      I also use a different Channel, in fact I have 3 area with 3 differents Channels.
                      Do you have a plan about source code release date ?
                      • techRHT
                        techRHT
                        techRH
                        wrote on last edited by techRH
                        #44
                        Is there a way to debug the bootloader should it print debug information and how to see this?
                        • Suresh MaliS
                          Suresh MaliS
                          Suresh Mali
                          • TetnobicT
                            TetnobicT
                            Tetnobic
                            wrote on last edited by Tetnobic
                            #46
                            I just start to test this bootloader...
                            I use an ATmega328p on breadboard with no external clock, with nRF24 and somes sensors.
                            Firmware Upload (by usbasp) and Run is ok, Send/Receive Data is ok too , but when I ask a reboot (with MYSController 1.0.0beta), my node enter in sort of strange start loop...
                            My Fuse settings :
                            bootloader.unlock_bits=0x3F
                            bootloader.lock_bits=0x0F
                            bootloader.low_fuses=0x62
                            bootloader.high_fuses=0xDA
                            bootloader.extended_fuses=0x07
                            Node debug Trace :
                            TSP:MSG:READ 0-0-4 s=2,c=1,t=0,pt=7,l=5,sg=0:28.18
                            TSP:MSG:READ 0-0-4 s=1,c=1,t=1,pt=7,l=5,sg=0:38.28
                            TSP:MSG:READ 0-0-4 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                            StartiStartiStartiStartiþStartiþStartiþStartiStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþ
                            The "Startiþ" text is the first char of the first text printed by bootloader at start : "Starting sensor....."
                            Have you an idea ?
                            • tekkaT
                              tekkaT
                              tekka
                              Please provide additional information such as library version, full debug log of your GW and node. Which bootloader/version are you using?
                              TetnobicT 1 Reply Last reply
                              • tekkaT tekka
                                TetnobicT
                                TetnobicT
                                Tetnobic
                                @tekka Thanks for you response
                                For gateway :
                                Raspberrry PI Gateway in Ethernet mode
                                Protocol version : 2.0.1-beta
                                For Node :
                                I use bootloader : MYSBL13pre_atmega328_1Mhz.hex
                                Inital Sketch do nothing :) :
                                #define MY_BAUD_RATE 9600
                                #define MY_OTA_FIRMWARE_FEATURE
                                #define MY_NODE_ID 1
                                void presentation(){
                                  sendSketchInfo("MyFirstBoard", "0.0.2", true);
                                  wait(5000);
                                Test Case: Start Gateway, Connect MYSController 1.0.0beta, then start my sensor, after init complete, click reboot in MYSController
                                Gateway Log :
                                mysgw: Starting gateway...
                                mysgw: Protocol version - 2.0.1-beta
                                mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSM:INIT:TSP OK
                                mysgw: TSM:INIT:GW MODE
                                mysgw: TSM:READY
                                mysgw: MCO:REG:NOT NEEDED
                                mysgw: MCO:BGN:STP
                                mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                mysgw: New connection from 10.31.10.59
                                mysgw: Client 0 connected
                                mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                mysgw: TSF:MSG:BC
                                mysgw: TSF:MSG:FPAR REQ,ID=1
                                mysgw: TSF:PNG:SEND,TO=0
                                mysgw: TSF:CKU:OK
                                mysgw: TSF:MSG:GWL OK
                                mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                mysgw: TSF:MSG:PINGED,ID=1,HP=1
                                mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                mysgw: TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
                                mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                mysgw: TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                                mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                mysgw: Client 0: 1;255;3;0;6;M
                                mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
                                mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
                                mysgw: TSF:MSG:ACK REQ
                                mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:MyFirstBoard
                                mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
                                mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=OK:0.0.2
                                mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                mysgw: Client 0: 1;0;3;0;13;0
                                mysgw: TSF:MSG:SEND,0-0-1-1,s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=OK:0
                                NodeLog :
                                Starting sensor (RNONA-, 2.0.0)
                                TSM:INIT
                                TSM:RADIO:OK
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:CHKID:OK (ID=1)
                                TSM:UPL
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                TSP:MSG:SEND 1-1-0-0 s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=ok:FFFFFFFFFFFFFFFF0300
                                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:MyFirstBoard
                                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=ok:0.0.2
                                TSP:MSG:READ 0-0-1 s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
                                TSP:MSG:READ 0-0-1 s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
                                Node registration=1
                                TSP:MSG:READ 0-0-1 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                                StartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiþStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStarti
                                Need others infos ?
                                Thanks for your time
                                • TetnobicT Tetnobic
                                  For gateway :
                                  For Node :
                                    wait(5000);
                                  Gateway Log :
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSM:READY
                                  mysgw: MCO:BGN:STP
                                  mysgw: TSF:MSG:BC
                                  mysgw: TSF:CKU:OK
                                  NodeLog :
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:CHKID:OK (ID=1)
                                  TSM:UPL
                                  TSP:CHKUPL:OK
                                  TSM:UPL:OK
                                  TSM:READY
                                  Node registration=1
                                  Need others infos ?
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Tetnobic
                                  Your node is running MySensors 2.0.0 (your GW is at 2.0.1, please consider updating), also, there is no sign of MYSBootloader in your GW log - please double-check if you followed the correct procedure.
                                  One more thing: the startup message indicates that you enabled OTA firmware features (RNONA-) - this is not required with MYSBootloader.
                                  Please have a look at @scalz's OTA guide for additional information.
                                  • tekkaT tekka
                                    @Tetnobic
                                    TetnobicT
                                    TetnobicT
                                    Tetnobic
                                    @tekka Thanks for your response
                                    What are the sign of MYSBootloader in GW log ?
                                    Can I also see any sign of MYSBootloader in Node Log ?
                                    I remove OTA firmware features, I now have :
                                    but same problem, after receive reboot message I have a "StartiStartiStartiStartiS...." loop :(:(
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @Tetnobic No, you won't see anything in the node log - but in the GW log you should see somehting like:
                                      1;255;4;0;0;64000200C803948D0105
                                      • tekkaT tekka
                                        TetnobicT
                                        TetnobicT
                                        Tetnobic
                                        @tekka Hi, I found my mistake ! You were absolutely right when you said there is no sign of MYSBootloader in my GW log...
                                        But now I know why :) :
                                        I use an USBasp Programmer with Arduino IDE for upload my bootloader and my sketch..., and I mistakenly thought that when I upload bootloader then sketch, it keep bootloader.....but NOT, it overwrite bootloader :(
                                        I fix it by uploading the xxx.with_bootloader.hex file generated by Arduino IDE when compile.
                                        Sorry for the inconvenience and thank you for your help
                                        AndurilA 1 Reply Last reply
                                          AndurilA
                                          AndurilA
                                          Anduril
                                          @Tetnobic can this be done within the IDE? I have some nodes where I have to upload with ISP and thought to still have the bootloader, but this explains why OTA didn't work afterwards...
