  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.0k Views 31 Watching
  • jmkhaelJ
    jmkhaelJ
    jmkhael
    wrote on last edited by jmkhael
    #36
    I am trying to use MYSController with MYSBootloader 1.3pre2 to reassign a node's ID, and I cannot make it work.
    I've tried to check/uncheck the Auto ID toggle/tried to use the MYSBootloader CMDs/Assign ID and setting a new one to no avail.
    After that, when it reboots, the node reask for it's firmware, and MYSController re-uploads it, but the node keeps the old ID from the EEProm. (note that the sketch don't hardcode the node's ID).
    I'd like to keep the ID management free (i.e. do not hardcode all my node's IDs of course)
    How can I do that?
     [2016-10-21 13:41:33.318 Info] CLICK	Reassign ID from 1 to 20
     [2016-10-21 13:41:33.319 Info] TX	1;0;3;0;13;0
     [2016-10-21 13:41:33.364 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=fail:0
     [2016-10-21 13:41:37.886 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155561124
     [2016-10-21 13:41:37.886 Info] RX	4;255;3;0;22;155561124
     [2016-10-21 13:41:42.855 Info] RX	0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
     [2016-10-21 13:41:42.857 Info] RX	2;1;1;0;16;0
     [2016-10-21 13:41:46.623 Info] RX	0;255;3;0;9;TSP:MSG:READ 8-5-0 s=2,c=1,t=16,pt=0,l=1,sg=0:0
     [2016-10-21 13:41:46.625 Info] RX	8;2;1;0;16;0
     [2016-10-21 13:41:47.899 Info] RX	0;255;3;0;9;TSP:MSG:READ 8-5-0 s=3,c=1,t=23,pt=2,l=2,sg=0:80
     [2016-10-21 13:41:47.901 Info] RX	8;3;1;0;23;80
     [2016-10-21 13:41:50.491 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
     [2016-10-21 13:41:50.494 Info] RX	0;255;3;0;9;TSP:MSG:ACK msg
     [2016-10-21 13:41:50.540 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:22.0
     [2016-10-21 13:41:50.540 Info] RX	4;1;1;0;0;22.0
     [2016-10-21 13:41:50.570 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155562401
     [2016-10-21 13:41:50.570 Info] RX	4;255;3;0;22;155562401
     [2016-10-21 13:41:57.014 Info] RX	0;255;3;0;9;TSP:SANCHK:OK
     [2016-10-21 13:42:02.832 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155563404
     [2016-10-21 13:42:02.832 Info] RX	4;255;3;0;22;155563404
     [2016-10-21 13:42:20.453 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=22,pt=5,l=4,sg=0:4712
     [2016-10-21 13:42:20.453 Info] RX	1;255;3;0;22;4712
     [2016-10-21 13:42:20.453 Info] CHILD	New child discovered, node id=1, child id=internal
     [2016-10-21 13:42:20.951 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:0
     [2016-10-21 13:42:20.953 Info] RX	1;2;1;0;16;0
     [2016-10-21 13:42:20.953 Info] CHILD	New child discovered, node id=1, child id=2
     [2016-10-21 13:42:21.954 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=3,c=1,t=23,pt=2,l=2,sg=0:42
     [2016-10-21 13:42:21.956 Info] RX	1;3;1;0;23;42
     [2016-10-21 13:42:21.956 Info] CHILD	New child discovered, node id=1, child id=3
     [2016-10-21 13:42:27.773 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155565680
     [2016-10-21 13:42:27.774 Info] RX	4;255;3;0;22;155565680
     [2016-10-21 13:42:40.382 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155566954
     [2016-10-21 13:42:40.382 Info] RX	4;255;3;0;22;155566954
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 5-5-1 s=255,c=3,t=8,pt=1,l=1,sg=0:1
    TSP:MSG:FPAR RES (ID=5, dist=1)
    TSP:MSG:PAR OK (ID=5, dist=2)
    TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
    TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
    TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:Multi Sensor
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
    TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 1-1-0-0 s=3,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=ok:
    Request registration...
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=1, parent=0, distance=1, registration=1
    TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=ok:0
    TSP:MSG:SEND 1-1-0-0 s=3,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:54
    tekkaT 1 Reply Last reply
    • JamesT42J
      JamesT42J
      JamesT42
      Hi! Great work!
      I have a small question: How does your Bootloader know which channel to listen on?
      pkuP tekkaT 2 Replies Last reply
      • JamesT42J JamesT42
        Hi! Great work!
        pkuP
        pkuP
        pku
        @JamesT42
        Hi, it is hardcoded within the bootloader: nRF24 (Channel 76, base address 0xA8A8E1FC00, data rate 250kbs)
        • jmkhaelJ jmkhael
          How can I do that?
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=1)
          TSM:UPL
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          Node registration=1
          tekkaT
          tekkaT
          tekka
          wrote on last edited by tekka
          #39
          @jmkhael Bootloader commands have been removed due to size constraints (see initial post). If you want to change the node ID you can send a C_INTERNAL / I_ID_RESPONSE / <new ID> message to an actively listening node.
            Hi! Great work!
            tekkaT
            tekkaT
            tekka
            @JamesT42 Thanks. As @pku pointed out, this is hardcoded. With the final release of MYSBootloader and its source code, everybody will be able to adjust settings and recompile the bootloader as needed.
            • jmkhaelJ
              jmkhaelJ
              jmkhael
              @tekka : fair enough, i should read better next time :)
              i'll try the way you suggest. thank you.
              • kleinerDracheK
                kleinerDracheK
                kleinerDrache
                hi tekka
                I had to change the channel of the NRF from 76 to 0 here because of massive disturbances . Unfortunately, no OTA works now. Is it possible to create a modified bootloader that works with 0 instead of 76? Sorry for the bad english it is translated with google.
                • LorenzoL
                  LorenzoL
                  Lorenzo
                  Hi, thank for the great work.
                  I also use a different Channel, in fact I have 3 area with 3 differents Channels.
                  Do you have a plan about source code release date ?
                  • techRHT
                    techRHT
                    techRH
                    wrote on last edited by techRH
                    #44
                    Is there a way to debug the bootloader should it print debug information and how to see this?
                    • Suresh MaliS
                      Suresh MaliS
                      Suresh Mali
                      • TetnobicT
                        TetnobicT
                        Tetnobic
                        wrote on last edited by Tetnobic
                        #46
                        I just start to test this bootloader...
                        I use an ATmega328p on breadboard with no external clock, with nRF24 and somes sensors.
                        Firmware Upload (by usbasp) and Run is ok, Send/Receive Data is ok too , but when I ask a reboot (with MYSController 1.0.0beta), my node enter in sort of strange start loop...
                        My Fuse settings :
                        bootloader.unlock_bits=0x3F
                        bootloader.lock_bits=0x0F
                        bootloader.low_fuses=0x62
                        bootloader.high_fuses=0xDA
                        bootloader.extended_fuses=0x07
                        Node debug Trace :
                        TSP:MSG:READ 0-0-4 s=2,c=1,t=0,pt=7,l=5,sg=0:28.18
                        TSP:MSG:READ 0-0-4 s=1,c=1,t=1,pt=7,l=5,sg=0:38.28
                        TSP:MSG:READ 0-0-4 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                        StartiStartiStartiStartiþStartiþStartiþStartiStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþ
                        The "Startiþ" text is the first char of the first text printed by bootloader at start : "Starting sensor....."
                        Have you an idea ?
                        • tekkaT
                          tekkaT
                          tekka
                          Please provide additional information such as library version, full debug log of your GW and node. Which bootloader/version are you using?
                          TetnobicT 1 Reply Last reply
                          • tekkaT tekka
                            TetnobicT
                            TetnobicT
                            Tetnobic
                            @tekka Thanks for you response
                            For gateway :
                            Raspberrry PI Gateway in Ethernet mode
                            Protocol version : 2.0.1-beta
                            For Node :
                            I use bootloader : MYSBL13pre_atmega328_1Mhz.hex
                            Inital Sketch do nothing :) :
                            #define MY_BAUD_RATE 9600
                            #define MY_OTA_FIRMWARE_FEATURE
                            #define MY_NODE_ID 1
                            void presentation(){
                              sendSketchInfo("MyFirstBoard", "0.0.2", true);
                              wait(5000);
                            Test Case: Start Gateway, Connect MYSController 1.0.0beta, then start my sensor, after init complete, click reboot in MYSController
                            Gateway Log :
                            mysgw: Starting gateway...
                            mysgw: Protocol version - 2.0.1-beta
                            mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSM:INIT:TSP OK
                            mysgw: TSM:INIT:GW MODE
                            mysgw: TSM:READY
                            mysgw: MCO:REG:NOT NEEDED
                            mysgw: MCO:BGN:STP
                            mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                            mysgw: New connection from 10.31.10.59
                            mysgw: Client 0 connected
                            mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                            mysgw: TSF:MSG:BC
                            mysgw: TSF:MSG:FPAR REQ,ID=1
                            mysgw: TSF:PNG:SEND,TO=0
                            mysgw: TSF:CKU:OK
                            mysgw: TSF:MSG:GWL OK
                            mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                            mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                            mysgw: TSF:MSG:PINGED,ID=1,HP=1
                            mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                            mysgw: TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
                            mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                            mysgw: TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                            mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                            mysgw: Client 0: 1;255;3;0;6;M
                            mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
                            mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
                            mysgw: TSF:MSG:ACK REQ
                            mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:MyFirstBoard
                            mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
                            mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=OK:0.0.2
                            mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                            mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                            mysgw: Client 0: 1;0;3;0;13;0
                            mysgw: TSF:MSG:SEND,0-0-1-1,s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=OK:0
                            NodeLog :
                            Starting sensor (RNONA-, 2.0.0)
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:CHKID:OK (ID=1)
                            TSM:UPL
                            TSP:CHKUPL:OK
                            TSM:UPL:OK
                            TSM:READY
                            TSP:MSG:SEND 1-1-0-0 s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=ok:FFFFFFFFFFFFFFFF0300
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:MyFirstBoard
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=ok:0.0.2
                            TSP:MSG:READ 0-0-1 s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
                            TSP:MSG:READ 0-0-1 s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
                            Node registration=1
                            TSP:MSG:READ 0-0-1 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                            StartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiþStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStarti
                            Need others infos ?
                            Thanks for your time
                            • TetnobicT Tetnobic
                              For gateway :
                              For Node :
                                wait(5000);
                              Gateway Log :
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSM:READY
                              mysgw: MCO:BGN:STP
                              mysgw: TSF:MSG:BC
                              mysgw: TSF:CKU:OK
                              NodeLog :
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:CHKID:OK (ID=1)
                              TSM:UPL
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              Node registration=1
                              Need others infos ?
                              tekkaT
                              tekkaT
                              tekka
                              @Tetnobic
                              Your node is running MySensors 2.0.0 (your GW is at 2.0.1, please consider updating), also, there is no sign of MYSBootloader in your GW log - please double-check if you followed the correct procedure.
                              One more thing: the startup message indicates that you enabled OTA firmware features (RNONA-) - this is not required with MYSBootloader.
                              Please have a look at @scalz's OTA guide for additional information.
                              • tekkaT tekka
                                @Tetnobic
                                TetnobicT
                                TetnobicT
                                Tetnobic
                                @tekka Thanks for your response
                                What are the sign of MYSBootloader in GW log ?
                                Can I also see any sign of MYSBootloader in Node Log ?
                                I remove OTA firmware features, I now have :
                                but same problem, after receive reboot message I have a "StartiStartiStartiStartiS...." loop :(:(
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Tetnobic No, you won't see anything in the node log - but in the GW log you should see somehting like:
                                  1;255;4;0;0;64000200C803948D0105
                                  • tekkaT tekka
                                    TetnobicT
                                    TetnobicT
                                    Tetnobic
                                    @tekka Hi, I found my mistake ! You were absolutely right when you said there is no sign of MYSBootloader in my GW log...
                                    But now I know why :) :
                                    I use an USBasp Programmer with Arduino IDE for upload my bootloader and my sketch..., and I mistakenly thought that when I upload bootloader then sketch, it keep bootloader.....but NOT, it overwrite bootloader :(
                                    I fix it by uploading the xxx.with_bootloader.hex file generated by Arduino IDE when compile.
                                    Sorry for the inconvenience and thank you for your help
                                    AndurilA 1 Reply Last reply
                                      AndurilA
                                      AndurilA
                                      Anduril
                                      @Tetnobic can this be done within the IDE? I have some nodes where I have to upload with ISP and thought to still have the bootloader, but this explains why OTA didn't work afterwards...
                                      • AndurilA Anduril
                                        TetnobicT
                                        TetnobicT
                                        Tetnobic
                                        @Anduril I think you can do this without Arduino IDE...
                                        but how compile you code for generate sketch+bootloader ( the xxx.with_bootloader.hex file) in command line I don't know....
                                        For upload this file on my ATMega, I use avrdude, the same command line that ardunio IDE use, but change the .hex file...
                                        • TigroenotT
                                          TigroenotT
                                          Tigroenot
                                          Tried this bootloader.
                                          Have two nodes 8MHz internal, two nodes 1MHz. All run beautifully, the OTA firmware update around a minute with binaryButton sketch. But the node startup is around 7-8 seconds. And no problems uploading the sketch via serial.
                                          I use an UNO as an ASP to burn the bootloader and a simple USB_TTL FTDI converter to upload sketches.
