  3. Solar Powered Soil Moisture Sensor
79 Posts 19 Posters 48.8k Views 35 Watching
  • HuczasH
    HuczasH
    Huczas
    it's misstaken source code - line 11 should be deleted and then all is compiling well, it's just end of comment from line 10, [enter] is unnecessery there.
    • F flopp
      @dbemowsk
      If you have the solar in the sun and the sensors in the shadow and protected from rain that will work.
      My idea is to use a solar for all my outdoor sensors but have a bigger solar panel and a bigger(more mah) that feeds my nodes, rain, temp, hum, pressure, light, UV and in future lightning.
      breimannB
      breimannB
      breimann
      @flopp
      I've been thinking along the same lines in terms of powering all my outdoor sensors with solar. Have you had a chance to try your ideas out yet? I'd be very interested in what you my have found. Should we start a new thread about that though? i'm very new to the forum so not sure (just joined tonight!).
      F 1 Reply Last reply
      • breimannB breimann
        @flopp
        F
        F
        flopp
        @breimann
        It have been in use since I write this post.
        I have had many problems with the nodes. I don't know if the problem is with my repeater node/GW.
        Time to time is stop sending and then suddenly without restarting the node, it start to send again.
        I have restarted the nodes sometimes also.
        Maybe it is to "small" solar panel so it takes time for it to recharge the battery?
        If you will do a solar panel node, go for a big panel with high mA output and also a big battery(1000mA), I am using 1.2 v battery. I think it is much better to use at least 2.5 volt battery then you don't need the step-up.
        breimannB 1 Reply Last reply
        • Nca78N
          I think the problem is the nimh battery, this kind of partial charge/discharge cycles is more suitable for a li-ion battery. It's ok when used as a garden light because the battery will discharge completely during the night and will not have a memory effect, but with the low power usage of a sensor it will lose capacity quickly.
          Also if the solar panel is 1.2V like one your picture I don't understand how it could have enough voltage to charge the battery after the voltage drop of the diode ? On the garden light I bought the solar panel is 2V so it's possible to charge the battery to 100% at 1.4V+
          • Nca78N Nca78
            F
            F
            flopp
            @Nca78
            Yes it can be the NiMh battery, but it is actually run for days maybe weeks with out any problem.
            Today I disconnect the power to ATmega and put it back directly and it started to work.
            If the power goes below 0.8-0.9 it seems that I have to disconnect the step-up otherwise the solar panel cannot charge the battery.
            Solar panel is 1.4V and battery is 1.2V it seems to work and I have around 1.2-1.3 V during night
            P 1 Reply Last reply
            • F flopp
              @breimann
              breimannB
              breimannB
              breimann
              @flopp
              Thank you for your reply. That's all helpful info.
              • F
                F
                flopp
                A funny thing,
                Yesterday I power off/on both my solar nodes and now the second one sent the data, haha strange??!! It was about 20 hours ago I powered it off/on
                • F flopp
                  @Nca78
                  P
                  P
                  punter9
                  wrote on last edited by punter9
                  #56
                  @flopp
                  guys seriously this is just yet another reason to write your reporting interval based on battery voltage and time and not on time alone.
                  You are using extremely cheap systems with cheap batteries of unknown age that are likely very prone to incur reduced capacity over shorter times and memory from discharge cycles.
                  See the posts above. This really is one of the greatest ideas I have seen for monitoring, just needs a tweak
                  With these findings I would set a floor voltage around 1-1.1 V for the arduino to go into sleep mode (find your own floor voltage by looking at your sleep discharge rate and length of night time).
                  • PaweMedP
                    PaweMedP
                    PaweMed
                    Hello.
                    Do you have any idea how to add to this code auto reset for instance every one hour? i have a problem with my sensor, because sometimes it is not responding, and i dont have any idea how to reset arduino automaticly
                    • mrwombleM
                      mrwombleM
                      mrwomble
                      Hi all, I was so impressed by this thread that I decided to build my own. I must have spent maybe £6 or so - I really pushed the boat out. :smiley:
                      It's been running successfully for a few weeks now, so I thought I'd share my code and a few pics. I upgraded the original code to v2.0. I've kept the update frequency high and it's running just fine, but we'll see how it goes in winter with less sun.
                      Pics!
                      Here you can see the boost converter and the Arduino pro mini.
                      Here you can see the finished product in its natural environment. The RF radio sits in the plastic area, as I figured the metal collar at the top (where the arduino + battery sits) would have blocked/reduced the RF transmission.
                      Code to follow.
                      • mrwombleM
                        mrwombleM
                        mrwomble
                        I meant to mention that the wires coming out of the bottom are the wires that go to the soil moisture probes.
                        Here's the code in case anyone else would like it:
                        // Updated to v2.0 of Mysensors
                        // Enable debug prints
                        #define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
                        #define CHILD_ID_MOISTURE 0
                        #define CHILD_ID_BATTERY 1
                        #define SLEEP_TIME 10000 // Sleep time between reads (in milliseconds), was 10000
                        #define THRESHOLD 1.1 // Only make a new reading with reverse polarity if the change is larger than 10%.
                        #define STABILIZATION_TIME 1000 // Let the sensor stabilize before reading default BOD settings
                        const int SENSOR_ANALOG_PINS[] = {A4, A5}; // Sensor is connected to these two pins. Avoid A3 if using ATSHA204. A6 and A7 cannot be used because they don't have pullups.
                        // MySensor gw;   //removed for v2.0
                        MyMessage msg(CHILD_ID_MOISTURE, V_HUM);
                        long oldvoltage = 0;
                        byte direction = 0;
                        int oldMoistureLevel = -1;
                        float batteryPcnt;
                        float batteryVolt;
                        int LED = 5;
                          pinMode(LED, OUTPUT);
                          digitalWrite(LED, HIGH);
                          delay(200);
                          digitalWrite(LED, LOW);
                          delay(200);
                          delay(200);
                          //  gw.begin(); //Removed for v2.0
                          for (int i = 0; i < N_ELEMENTS(SENSOR_ANALOG_PINS); i++) {
                            pinMode(SENSOR_ANALOG_PINS[i], OUTPUT);
                            digitalWrite(SENSOR_ANALOG_PINS[i], LOW);
                        void presentation(){  //created for v2.0
                          sendSketchInfo("Plant moisture w solar", "1.0");
                          present(CHILD_ID_MOISTURE, S_HUM);
                          delay(250);
                          int moistureLevel = readMoisture();
                          // Send rolling average of 2 samples to get rid of the "ripple" produced by different resistance in the internal pull-up resistors
                          // See http://forum.mysensors.org/topic/2147/office-plant-monitoring/55 for more information
                          if (oldMoistureLevel == -1) { // First reading, save current value as old
                          if (moistureLevel > (oldMoistureLevel * THRESHOLD) || moistureLevel < (oldMoistureLevel / THRESHOLD)) {
                            // The change was large, so it was probably not caused by the difference in internal pull-ups.
                            // Measure again, this time with reversed polarity.
                          send(msg.set((moistureLevel + oldMoistureLevel) / 2.0 / 10.23, 1));
                          int sensorValue = analogRead(A0);
                          Serial.print("--Sensor value:");Serial.println(sensorValue);
                          float voltage=sensorValue*(3.3/1023);
                          Serial.print("--Voltage:");Serial.println(voltage);
                          batteryPcnt = (sensorValue - 248) * 0.72;
                          Serial.print("--Battery %:");Serial.println(batteryPcnt);
                          batteryVolt = voltage;
                          resend((voltage_msg.set(batteryVolt, 3)), 10);
                          //send(voltage_msg.set(batteryVolt), 3);
                          //flash led to indicate send
                          delay(200);
                          sleep(SLEEP_TIME);
                        void resend(MyMessage &msg, int repeats)
                          int repeat = 1;
                          int repeatdelay = 0;
                          boolean sendOK = false;
                          send(msg);
                          while ((sendOK == false) and (repeat < repeats)) {
                            if (send(msg)) {
                              sendOK = true;
                              sendOK = false;
                              Serial.print("Error ");
                              Serial.println(repeat);
                              repeatdelay += 500;
                            } repeat++; delay(repeatdelay);
                        int readMoisture() {
                          pinMode(SENSOR_ANALOG_PINS[direction], INPUT_PULLUP); // Power on the sensor
                          analogRead(SENSOR_ANALOG_PINS[direction]);// Read once to let the ADC capacitor start charging
                          sleep(STABILIZATION_TIME);
                          int moistureLevel = (1023 - analogRead(SENSOR_ANALOG_PINS[direction]));
                          // Turn off the sensor to conserve battery and minimize corrosion
                          direction = (direction + 1) % 2; // Make direction alternate between 0 and 1 to reverse polarity which reduces corrosion
                          return moistureLevel;
                        My thanks to flopp for the cool idea and to everyone else on the thread for the contributions.
                          #60
                          Interesting project. To what degree, if any, has corrosion been a problem after you switched to soldered connections? Obviously the operating environment (near the ground outdoors) can be intrinsically humid.
                          Also, can someone please post a larger photo of how the sensor is attached at the base? The area of interest on the photo provided is miniscule, and it's too grainy if I try to enlarge it to a better size:
                          NeverDieN F 2 Replies Last reply
                            By the way, I notice this guy has a rather interesting soil moisture sensor that appears to go beyond measuring mere electrical conductance: https://www.tindie.com/products/Power_Modules/fdr-100mhz-plant-soil-sensor-mineral-transparency/
                            mrwombleM 1 Reply Last reply
                            • AWIA
                              AWIA
                              AWI
                              @flopp Can you please include the pictures in your posting as the "tinypic.com" is rather intrusive, thanks...
                                F
                                F
                                flopp
                                wrote on last edited by flopp
                                #63
                                I have not checked how the sensor look like now, but I have only run it for 6 months. I have always used soldered connections.
                                1_1479545970922_20160606_131714652_iOS.jpg 0_1479545970922_20160606_131710115_iOS.jpg
                                • AWIA
                                  AWIA
                                  AWI
                                  @flopp Just copy the area's of intrest with a "snipping tool" (screen print) and copy in the post. Or, use one of the less intrusive services of the big cloud names...
                                    mrwombleM
                                    mrwombleM
                                    mrwomble
                                    Interesting, but would make the project a little pricey.
                                    • F flopp
                                      #66
                                      @flopp
                                      Perfect! Thanks a bunch. I like it. Very clever.
                                      I think you were wise to cover the insulated wire with the silicon. Despite the appearance of being waterproof, I've noticed that regular wire insulation isn't waterproof/vaporproof, and regular wires used outdoors don't survive well (especially "copper" wires from China, which tend to have a high iron content and thus literally rust their way to failure). I don't know that silicon is sufficient, but if it isn't it might at least slow down the degradation process. It takes some effort to put these things together, so plainly you want them to last as long as possible.
                                      Nice work!
                                      Nca78N 1 Reply Last reply
                                        @flopp
                                        Nice work!
                                        wrote on last edited by Nca78
                                        #67
                                        Silicon is water proof, but not vapor proof. Else, it would not cure ;)
                                        • F
                                          F
                                          flopp
                                          #68
                                          I have put glue on top of the soldering
