  2. Announcements
  3. 💬 Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 73.8k Views 51 Watching
  • Patrik SöderströmP
    Patrik SöderströmP
    Patrik Söderström
    Cool, I downloaded it and replaced the old master brach.
    Still get the same effect.
    I paste my sketch here, all except the wifi part, that works. Tell me if I should include it here as well. But I feel its something in this below part that is failing on me
    //###################### LIGHT SENSOR #####################
    #define CHILD_ID_LIGHT 0
    int lastLightLevel;
    sendSketchInfo("Light Sensor", "1.0");
      int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
          send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
      sleep(SLEEP_TIME);
    • bgunnarbB
      bgunnarbB
      bgunnarb
      A couple of ESP-12E modules arrived in the mail last Friday and I uploaded the ESP8266 MQTT GW sketch. It worked immediately. Fantastic!
      I am using a cloudserver MQTT broker on cloudmqtt.com and the OpenHab controller subscribes to that as well.
      Just a question... I tried to enable the LED BLINKING feature but it seems there are no free pins on the ESP-12 module. I've tried the not connected pins but whatever pin I select (0,1,3,4,9,10) this seems to stop the GW from starting. Ideas anyone?
      I have never been so busy since I retired!
      • bgunnarbB bgunnarb
        @bgunnarb great that you got it working so quickly!
        Not sure which numbering scheme you are using (there are unfortunately many ways to number the ESP pins) but many of the pins have special use and are therefore hard to utilize. Some of my notes on the subject:
        GPIO0, gpio2 an gpio15 are tricky but can be used if special care is taken: http://www.instructables.com/id/ESP8266-Using-GPIO0-GPIO2-as-inputs/?ALLSTEPS
        gpio16 also seems special, see http://bbs.espressif.com/viewtopic.php?t=632
        GPIO6-GPIO11 are typically used to interface with the flash memory ICs on most esp8266 modules, so these pins should not generally be used.
        http://www.esp8266.com/wiki/doku.php?id=esp8266_gpio_pin_allocations has lots of information on the pins.
        Kolban's book on ESP has a nice clear and color-coded table describing which pins are "safe" to use without any hassle.
        • siodS
          siodS
          siod
          • siodS
            siodS
            siod
            • FotoFieberF
              FotoFieberF
              FotoFieber
              Please add a wiring diagram for the RFM69.
              I found this:
              https://forum.mysensors.org/topic/3061/solved-esp8266-gateway-with-rfm69-wdt-issues/4
              But I miss the CE in that post.
              • korttomaK
                korttomaK
                korttoma
                There is no CE pin on the RFM69
                https://www.mysensors.org/build/connect_radio
                • Tomas
                • Fat FlyF
                  Fat FlyF
                  Fat Fly
                  Please look right connection diagram. Not nrf24l01+. and you see how to connect. If you do not see you van watch with glasses.
                  • korttomaK korttoma
                    FotoFieberF
                    FotoFieberF
                    FotoFieber
                    @korttoma
                    :open_mouth:
                    Shame on me... I am using a NRF2RFM69 adapter with a CE pin and didn't realize it has no function.
                    • E
                      E
                      emc2
                      I'm currently adding some wifi gateways at work, I was wondering:
                      • is ATSHA204 signing support something planned, or will it stay on soft-sign only mode?
                      • is IRQ support something planned too?
                      It's mostly to see if I need to plan to add these features on the PCB for later, or not.
                      • G
                        G
                        gmccarthy
                        @FotoFieber Did you come right with the RFM69? I also struggling to get it working and need to confirm the wiring diagram.
                        • ramoncarranzaR
                          ramoncarranzaR
                          ramoncarranza
                            This thread contains comments for the article "Building a WiFi Gateway using ESP8266" posted on MySensors.org.
                            ramoncarranzaR
                            ramoncarranzaR
                            ramoncarranza
                            @hek Hi, I am new to arduino but not to Vera, have been using Veralite for a few years, I wuould like to know how to add the Serial Gateway to Vera, I find it very confusing, it would be ideal if a video was created or step by step instructions for newbees like me, I will be more than happy to donate via paypal, Thanks so much
                            reply
                              @ramoncarranza
                              What part is confusing? Did you follow the steps outlined here:
                              https://www.mysensors.org/controller/vera
                              ramoncarranzaR 1 Reply Last reply
                                @ramoncarranza
                                ramoncarranzaR
                                ramoncarranzaR
                                ramoncarranza
                                @hek I got it already, I was confused on the Vera Plugin vs the Arduino Plugin not realizing they were both the same, but now I get the following message on Vera
                                "MySensors plugin : Choose the Serial Port"
                                "MySensors Plugin[105] : Running Lua Startup"
                                I have yet to assemble the Serial Gateway though, so I'm assuming the messages will go away once the Gateway is installed??????
                                  Yes, once you insert the usb gateway you just have to follow the instructions here:
                                  https://www.mysensors.org/controller/vera#configuring-the-vera-plugin-for-the-serialusb-gateway
                                  • ramoncarranzaR
                                    ramoncarranzaR
                                    ramoncarranza
                                    Thanks so much!!
                                    This thing's Amazing!!!!!!
                                    • sghazaghS
                                      sghazaghS
                                      sghazagh
                                      Hi all,
                                      I try to connect the Radio to Wemos D1 mini Pro and it's not working? I used both ESP8266Gateway and RelayActuator sketches and both Radio Fails...
                                      Are the pins here work fine with Wemos D1Mini?here is the pinout: http://escapequotes.net/wp-content/uploads/2016/02/d1-mini-esp8266-board-sh_fixled.jpg
                                      And here is the error I get:
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      thanks,
                                      • korttomaK
                                        korttomaK
                                        korttoma
                                        If you are using the NRF24L01+ you should wire it according to the instructions here
                                        And use the sketch from the same page.
                                        So check your wiring of the radio module.
                                        • Tomas
                                        • sghazaghS
                                          sghazaghS
                                          sghazagh
                                          I used the same link (pins and sketches!). Checked it 10 times!
                                          I think my Radios are not functional....
                                          korttomaK 1 Reply Last reply
