  2. Announcements
  3. πŸ’¬ Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 73.8k Views 51 Watching
  • G
    G
    gmccarthy
    @FotoFieber Did you come right with the RFM69? I also struggling to get it working and need to confirm the wiring diagram.
    • ramoncarranzaR
      ramoncarranzaR
      ramoncarranza
        This thread contains comments for the article "Building a WiFi Gateway using ESP8266" posted on MySensors.org.
        ramoncarranzaR
        ramoncarranzaR
        ramoncarranza
        @hek Hi, I am new to arduino but not to Vera, have been using Veralite for a few years, I wuould like to know how to add the Serial Gateway to Vera, I find it very confusing, it would be ideal if a video was created or step by step instructions for newbees like me, I will be more than happy to donate via paypal, Thanks so much
        reply
          @ramoncarranza
          What part is confusing? Did you follow the steps outlined here:
          https://www.mysensors.org/controller/vera
          ramoncarranzaR 1 Reply Last reply
            @ramoncarranza
            ramoncarranzaR
            ramoncarranzaR
            ramoncarranza
            @hek I got it already, I was confused on the Vera Plugin vs the Arduino Plugin not realizing they were both the same, but now I get the following message on Vera
            "MySensors plugin : Choose the Serial Port"
            "MySensors Plugin[105] : Running Lua Startup"
            I have yet to assemble the Serial Gateway though, so I'm assuming the messages will go away once the Gateway is installed??????
              Yes, once you insert the usb gateway you just have to follow the instructions here:
              https://www.mysensors.org/controller/vera#configuring-the-vera-plugin-for-the-serialusb-gateway
              • ramoncarranzaR
                ramoncarranzaR
                ramoncarranza
                Thanks so much!!
                This thing's Amazing!!!!!!
                • sghazaghS
                  sghazaghS
                  sghazagh
                  Hi all,
                  I try to connect the Radio to Wemos D1 mini Pro and it's not working? I used both ESP8266Gateway and RelayActuator sketches and both Radio Fails...
                  Are the pins here work fine with Wemos D1Mini?here is the pinout: http://escapequotes.net/wp-content/uploads/2016/02/d1-mini-esp8266-board-sh_fixled.jpg
                  And here is the error I get:
                  TSM:INIT
                  !TSM:RADIO:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  thanks,
                  • korttomaK
                    korttomaK
                    korttoma
                    If you are using the NRF24L01+ you should wire it according to the instructions here
                    And use the sketch from the same page.
                    So check your wiring of the radio module.
                    • Tomas
                    • sghazaghS
                      sghazaghS
                      sghazagh
                      I used the same link (pins and sketches!). Checked it 10 times!
                      I think my Radios are not functional....
                      korttomaK 1 Reply Last reply
                      • sghazaghS sghazagh
                        korttomaK
                        korttomaK
                        korttoma
                        @sghazagh maybe you can take a picture of the setup. Maybe someone else can see something that you don't.
                        • Tomas
                        • sghazaghS
                          sghazaghS
                          sghazagh
                          wrote on last edited by sghazagh
                          #31
                          Good idea,
                          Here is the side by side image from front and back of the PCB.
                          The 'j1' marked on wrong pin ,that's why I think my radio is not working at all as it seems it's very bad replicate.
                          However, I have rotated it by 180 degree and tried that as well. same result!
                          • sghazaghS
                            sghazaghS
                            sghazagh
                            Guys, just an update for my issue regarding Radio and my circuit.
                            The Radio was faulty, I received the new one, swapped it and all worked fine.
                            I just posted that here if someone want to use my last post image as a reference for connecting the Radio.
                            The wiring all are correct.
                            • jakesJ
                              jakesJ
                              jakes
                              Hi Hek,
                              Thanks for this guide... I have added an additional 433 RF receiver to my ESP8266 gateway. How can I send the data received from 433 RF to the my Home Assistant controller?
                              • denisvdbD
                                denisvdbD
                                denisvdb
                                Hello, i have build a wifi gateway and use it in jeedom.
                                My gateway wifi as connection problem.
                                In jeedom, in the log of my sensors node I have almost every 2 days the message: diconnected from network gateway.
                                If I restart the node the communication is re-established.
                                Is this a problem with nrf24l01?
                                • D
                                  derrij
                                  why esp8266 gateway shows only debug info?
                                  when i comment //#define MY_DEBUG
                                  where is no any serial output.
                                  • D derrij
                                    @derrij because it is a wifi gateway?
                                    • A
                                      AndreD
                                      If put in client mode
                                      #define MY_CONTROLLER_IP_ADDRESS 192, 168, 2, 9
                                      I get an error. How to win.
                                      Arduino: 1.8.2 (Windows 7), ΠŸΠ»Π°Ρ‚Π°:"Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
                                      "C:\Users\DedHP\AppData\Local\Temp\arduino_build_364162\sketch\GatewayESP8266.ino.cpp.o"
                                      In file included from C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                                                   from C:\Users\DedHP\AppData\Local\Temp\arduino_modified_sketch_313960\GatewayESP8266.ino:132:
                                      C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
                                      C:\Documents\Arduino\ams\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:207:58: required from here
                                      C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
                                       size_t left = source.available();
                                      C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
                                       source.read(buffer.get(), will_send);
                                      Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ ESP8266WiFi вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
                                      Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ MySensors вСрсии 2.1.1 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Documents\Arduino\ams\Arduino\libraries\MySensors
                                      Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ EEPROM вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM
                                      Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ SPI вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
                                      exit status 1
                                      Ошибка компиляции для ΠΏΠ»Π°Ρ‚Ρ‹ Generic ESP8266 Module.*
                                      • Jonathan CaesJ
                                        Jonathan CaesJ
                                        Jonathan Caes
                                        Is it possible to use this setup without the nrf24l01 atached, so that i can use the esp8266 just as a sensor (not as a gateway)?
                                        • Jonathan CaesJ Jonathan Caes
                                          #39
                                          @Jonathan-Caes yes. Don't define MY_RADIO_NRF24 and you're good to go. It will still be a gateway, but a gateway with local sensors and no radio.
                                          With your input, this post could be even better πŸ’—
