  2. Announcements
  3. 💬 Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 73.8k Views 51 Watching
  • Fat FlyF
    Fat FlyF
    Fat Fly
    Yes. Network is same.
    • popP
      popP
      pop
      Can the esp8266Gateway be used as an MQTT gateway too? Is it a config issue or does more code need porting first?
        Yes,
        The configuration and example can be found here:
        https://www.mysensors.org/build/mqtt_gateway
        • popP
          popP
          pop
          Fantastic. Thanks.
          • Patrik SöderströmP
            Patrik SöderströmP
            Patrik Söderström
            Uploaded this sktech to a NodeMcu yesterday, i can add it in domoticz. When i try to add a light sensor, it shows up as a light sensor node in domoticz under the Mysensors lan gateway. but it does not show any device. Anyone who have an idea?
              Please use the development branch until 2.0.1 has been released.
              It allows presentation on gateway attached devices.
                Patrik SöderströmP
                Patrik Söderström
                Cool, I downloaded it and replaced the old master brach.
                Still get the same effect.
                I paste my sketch here, all except the wifi part, that works. Tell me if I should include it here as well. But I feel its something in this below part that is failing on me
                //###################### LIGHT SENSOR #####################
                #define CHILD_ID_LIGHT 0
                int lastLightLevel;
                sendSketchInfo("Light Sensor", "1.0");
                  int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                  Serial.println(lightLevel);
                      send(msg.set(lightLevel));
                      lastLightLevel = lightLevel;
                  sleep(SLEEP_TIME);
                • bgunnarbB
                  bgunnarbB
                  bgunnarb
                  A couple of ESP-12E modules arrived in the mail last Friday and I uploaded the ESP8266 MQTT GW sketch. It worked immediately. Fantastic!
                  I am using a cloudserver MQTT broker on cloudmqtt.com and the OpenHab controller subscribes to that as well.
                  Just a question... I tried to enable the LED BLINKING feature but it seems there are no free pins on the ESP-12 module. I've tried the not connected pins but whatever pin I select (0,1,3,4,9,10) this seems to stop the GW from starting. Ideas anyone?
                  I have never been so busy since I retired!
                  • bgunnarbB bgunnarb
                    @bgunnarb great that you got it working so quickly!
                    Not sure which numbering scheme you are using (there are unfortunately many ways to number the ESP pins) but many of the pins have special use and are therefore hard to utilize. Some of my notes on the subject:
                    GPIO0, gpio2 an gpio15 are tricky but can be used if special care is taken: http://www.instructables.com/id/ESP8266-Using-GPIO0-GPIO2-as-inputs/?ALLSTEPS
                    gpio16 also seems special, see http://bbs.espressif.com/viewtopic.php?t=632
                    GPIO6-GPIO11 are typically used to interface with the flash memory ICs on most esp8266 modules, so these pins should not generally be used.
                    http://www.esp8266.com/wiki/doku.php?id=esp8266_gpio_pin_allocations has lots of information on the pins.
                    Kolban's book on ESP has a nice clear and color-coded table describing which pins are "safe" to use without any hassle.
                    • siodS
                      siodS
                      siod
                      • siodS
                        siodS
                        siod
                        • FotoFieberF
                          FotoFieberF
                          FotoFieber
                          Please add a wiring diagram for the RFM69.
                          I found this:
                          https://forum.mysensors.org/topic/3061/solved-esp8266-gateway-with-rfm69-wdt-issues/4
                          But I miss the CE in that post.
                          • korttomaK
                            korttomaK
                            korttoma
                            There is no CE pin on the RFM69
                            https://www.mysensors.org/build/connect_radio
                            • Tomas
                            • Fat FlyF
                              Fat FlyF
                              Fat Fly
                              Please look right connection diagram. Not nrf24l01+. and you see how to connect. If you do not see you van watch with glasses.
                              • korttomaK korttoma
                                FotoFieberF
                                FotoFieberF
                                FotoFieber
                                @korttoma
                                :open_mouth:
                                Shame on me... I am using a NRF2RFM69 adapter with a CE pin and didn't realize it has no function.
                                • E
                                  E
                                  emc2
                                  I'm currently adding some wifi gateways at work, I was wondering:
                                  • is ATSHA204 signing support something planned, or will it stay on soft-sign only mode?
                                  • is IRQ support something planned too?
                                  It's mostly to see if I need to plan to add these features on the PCB for later, or not.
                                  • G
                                    G
                                    gmccarthy
                                    @FotoFieber Did you come right with the RFM69? I also struggling to get it working and need to confirm the wiring diagram.
                                    • ramoncarranzaR
                                      ramoncarranzaR
                                      ramoncarranza
                                        This thread contains comments for the article "Building a WiFi Gateway using ESP8266" posted on MySensors.org.
                                        ramoncarranzaR
                                        ramoncarranzaR
                                        ramoncarranza
                                        @hek Hi, I am new to arduino but not to Vera, have been using Veralite for a few years, I wuould like to know how to add the Serial Gateway to Vera, I find it very confusing, it would be ideal if a video was created or step by step instructions for newbees like me, I will be more than happy to donate via paypal, Thanks so much
                                        reply
                                          @ramoncarranza
                                          What part is confusing? Did you follow the steps outlined here:
                                          https://www.mysensors.org/controller/vera
                                          ramoncarranzaR 1 Reply Last reply
