  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 227.8k Views 53 Watching
  • N
    N
    Nicklas Starkel
    Sorry, where do you measure the power when it is in sleep mode? ie, where do you put your multimeter probes.
    • N Nicklas Starkel
      @Nicklas-Starkel you put them in serial. So:
      battery+ to multimeter- (set to uA mode)
      Multimeter+ to vcc
      Battery- to gnd
      You need a very sensitive multimeter though. Most multimeters won't be able to measure low current reliably.
      N 1 Reply Last reply
        Multimeter+ to vcc
        Battery- to gnd
        N
        N
        Nicklas Starkel
        @mfalkvidd that's what I thought! I see that I'm getting 3.4V in the multimeter but my pro mini nor nano will start up (I have not removed the LEDs so they should light up).
        If I use more V (6.8V) I put in via RAW on the PRO mini, and I can see teh voltage, but the same thing, it's not starting up, hmmm I wonder what rookie mistake I'm doing!
        • N Nicklas Starkel
          @Nicklas-Starkel sounds like you have the multimeter set to measure voltage instead of current. Which multimeter model are you using? Could you post a photo? There is usually a dial that can be turned to switch mode. Many multimeters also require moving one of the probes to a different connector (on the multimeter itself).
            N
            N
            Nicklas Starkel
            @mfalkvidd , it was too late at night for me.
            I had it at current but it didn't show anything. So without thinking I put it at voltage.
            And the problem with not showing anything when I had it at current was I had blown the internal multimeter fuse some days ago.
            Ehrmm.. yes. move along, nothing to see here :)
            • N Nicklas Starkel
              @Nicklas-Starkel great that you figured out what was wrong
              • bjacobtB
                bjacobtB
                bjacobt
                Hi, I built this circuit and arduino reads 1.11 V or 33%. I've new batteries and multimeter reads 3.10 volts. Do you know what could be wrong? I'm using 1M and 470k resistors on pin A0.
                • tonnerre33T
                  tonnerre33T
                  tonnerre33
                  Did you put this command in the setup sketch ?
                  analogReference(INTERNAL);
                  • bjacobtB
                    bjacobtB
                    bjacobt
                    @tonnerre33, yes I've analogReference(INTERNAL); in setup()
                    • tonnerre33T
                      tonnerre33T
                      tonnerre33
                      It's normal to have 1.1V on A0 when you have 3.3V on your batteries.
                      Where did you get the 1.11V value ? In the serial print or with your multimeter ?
                      If you read the value with the serial print, which variable is it (sensorValue or batteryV) ?
                      • bjacobtB
                        bjacobtB
                        bjacobt
                        @tonnerre33 in the serial print and MySensor MQTT gateway
                        • bjacobtB
                          bjacobtB
                          bjacobt
                          @tonnerre33, I'm trying to build arduio that can run on 2 AA batteries. I'm using MySensors for library and building arduino circuit based on this https://openhomeautomation.net/arduino-battery/
                          • tonnerre33T
                            tonnerre33T
                            tonnerre33
                            Can you post the logs of your node and the skech used ?
                            bjacobtB 1 Reply Last reply
                            • bjacobtB bjacobt
                              @bjacobt https://www.mysensors.org/build/battery#measuring-and-reporting-battery-level describes how the battery voltage is calculated and the example sketch has code for doing the calculation. Looks like you've missed reading this part:
                              • tonnerre33T tonnerre33
                                bjacobtB
                                bjacobtB
                                bjacobt
                                @tonnerre33
                                Here are the logs from Arduino Serial console
                                TSM:INIT
                                TSM:RADIO:OK
                                TSP:ASSIGNID:OK (ID=101)
                                TSM:FPAR
                                TSP:MSG:SEND 101-101-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                TSP:MSG:READ 0-0-101 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                TSP:MSG:PAR OK (ID=0, dist=1)
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:CHKID:OK (ID=101)
                                TSM:UPL
                                TSP:PING:SEND (dest=0)
                                TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                TSP:MSG:READ 0-0-101 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                TSP:MSG:PONG RECV (hops=1)
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                !TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                                TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                                TSP:MSG:READ 0-0-101 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=ok:Battery Meter
                                TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                                Request registration...
                                TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                TSP:MSG:READ 0-0-101 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                Node registration=1
                                Init complete, id=101, parent=0, distance=1, registration=1
                                330
                                Battery Voltage: 1.11 V
                                Battery percent: 33 %
                                TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:33
                                The sketch used is this:
                                #define MY_NODE_ID  101
                                unsigned long SLEEP_TIME = 100000;  // sleep time between reads (seconds * 1000 milliseconds)
                                int oldBatteryPcnt = 0;
                                   analogReference(INTERNAL1V1);
                                   sendSketchInfo("Battery Meter", "1.0");
                                   // get the battery Voltage
                                   #ifdef MY_DEBUG
                                   Serial.println(sensorValue);
                                   #ifdef MY_DEBUG
                                   Serial.print(batteryV);
                                   Serial.println(" V");
                                   Serial.print(batteryPcnt);
                                   Serial.println(" %");
                                     // Power up radio after sleep
                                     oldBatteryPcnt = batteryPcnt;
                                   sleep(SLEEP_TIME);
                                What I see on the gateway is:
                                mysGateway: TSF:MSG:READ,101-101-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                mysGateway: TSF:MSG:BC
                                mysGateway: TSF:MSG:FPAR REQ,ID=101
                                mysGateway: TSF:PNG:SEND,TO=0
                                mysGateway: TSF:CKU:OK
                                mysGateway: TSF:MSG:GWL OK
                                mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                mysGateway: TSF:MSG:PINGED,ID=101,HP=1
                                mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                mysGateway: !TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                                mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                mysGateway: Sending message on topic: mysensors-out/101/255/3/0/6
                                mysGateway: TSF:CKU:OK,FCTRL
                                mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Battery Meter
                                mysGateway: Sending message on topic: mysensors-out/101/255/3/0/11
                                mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                mysGateway: Sending message on topic: mysensors-out/101/255/3/0/12
                                mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=0,pt=1,l=1,sg=0:33
                                mysGateway: Sending message on topic: mysensors-out/101/255/3/0/0```
                                Thank for your help!
                                Jacob
                                  bjacobtB
                                  bjacobtB
                                  bjacobt
                                  hi @mfalkvidd,
                                  Do you mind clarifying a bit, I've done sensorValue * 0.003363075
                                  Gives me 330, so
                                  330 * 0.003363075 = 1.10981475 volts
                                  Thank You!
                                  Jacob
                                  • bjacobtB bjacobt
                                    hi @mfalkvidd,
                                    Gives me 330, so
                                    Thank You!
                                    Jacob
                                    @bjacobt hmm. Yes, you are correct. The calculation seem a bit strange.
                                    Using this calculator I entered
                                    output 1.10981475 V
                                    R1 1000000
                                    R2 470000
                                    Which gives a battery voltage of 3.471V
                                    Looks like the calculations in the sketch are wrong? Or at least confusing :) I'm pretty lost.
                                    • tonnerre33T
                                      tonnerre33T
                                      tonnerre33
                                      #21
                                      must give you 1023 and not 330.
                                      For me it's a problem of value resistance or analogReference.
                                      Try to add this
                                        #ifdef MY_DEBUG
                                       Serial.print("Value A0 before force reference: ");
                                       Serial.print(sensorValue);
                                      delay(10000);
                                        #ifdef MY_DEBUG
                                       Serial.print("Value A0 after force reference: ");
                                      Just after this existing code :
                                         #ifdef MY_DEBUG
                                      And plz send me the logs of the node ;)
                                        Try to add this
                                          #ifdef MY_DEBUG
                                        delay(10000);
                                          #ifdef MY_DEBUG
                                           #ifdef MY_DEBUG
                                        bjacobtB
                                        bjacobtB
                                        bjacobt
                                        @tonnerre33 Its still the same
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:UPL
                                        TSP:CHKUPL:OK
                                        TSM:UPL:OK
                                        TSM:READY
                                        TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                        TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                        Node registration=1
                                        330
                                        Value A0 before force reference: 327
                                        Value A0 after force reference: 329
                                        Battery percent: 32 %
                                        TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:32
                                           #ifdef MY_DEBUG
                                          #ifdef MY_DEBUG
                                        delay(10000);
                                          #ifdef MY_DEBUG
                                           #ifdef MY_DEBUG
                                           sleep(SLEEP_TIME);
                                        • tonnerre33T
                                          tonnerre33T
                                          tonnerre33
                                          #23
                                          Ok it's not a problem with the analogReference, you can delete this part of code.
                                          Did you control your resistance value and did you do this schema ?
