  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 219.0k Views 53 Watching
  • tonnerre33T
    tonnerre33T
    tonnerre33
    Did you put this command in the setup sketch ?
    analogReference(INTERNAL);
    • bjacobtB
      bjacobtB
      bjacobt
      @tonnerre33, yes I've analogReference(INTERNAL); in setup()
      • tonnerre33T
        tonnerre33T
        tonnerre33
        It's normal to have 1.1V on A0 when you have 3.3V on your batteries.
        Where did you get the 1.11V value ? In the serial print or with your multimeter ?
        If you read the value with the serial print, which variable is it (sensorValue or batteryV) ?
        • bjacobtB
          bjacobtB
          bjacobt
          @tonnerre33 in the serial print and MySensor MQTT gateway
          • bjacobtB
            bjacobtB
            bjacobt
            @tonnerre33, I'm trying to build arduio that can run on 2 AA batteries. I'm using MySensors for library and building arduino circuit based on this https://openhomeautomation.net/arduino-battery/
            • tonnerre33T
              tonnerre33T
              tonnerre33
              Can you post the logs of your node and the skech used ?
              bjacobtB 1 Reply Last reply
              • bjacobtB bjacobt
                @bjacobt https://www.mysensors.org/build/battery#measuring-and-reporting-battery-level describes how the battery voltage is calculated and the example sketch has code for doing the calculation. Looks like you've missed reading this part:
                • tonnerre33T tonnerre33
                  bjacobtB
                  bjacobtB
                  bjacobt
                  @tonnerre33
                  Here are the logs from Arduino Serial console
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=101)
                  TSM:FPAR
                  TSP:MSG:SEND 101-101-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSP:MSG:READ 0-0-101 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  TSP:MSG:PAR OK (ID=0, dist=1)
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=101)
                  TSM:UPL
                  TSP:PING:SEND (dest=0)
                  TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                  TSP:MSG:READ 0-0-101 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  TSP:MSG:PONG RECV (hops=1)
                  TSP:CHKUPL:OK
                  TSM:UPL:OK
                  TSM:READY
                  TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                  !TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                  TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                  TSP:MSG:READ 0-0-101 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=ok:Battery Meter
                  TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                  Request registration...
                  TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                  TSP:MSG:READ 0-0-101 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  Node registration=1
                  Init complete, id=101, parent=0, distance=1, registration=1
                  330
                  Battery Voltage: 1.11 V
                  Battery percent: 33 %
                  TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:33
                  The sketch used is this:
                  #define MY_NODE_ID  101
                  unsigned long SLEEP_TIME = 100000;  // sleep time between reads (seconds * 1000 milliseconds)
                  int oldBatteryPcnt = 0;
                     analogReference(INTERNAL1V1);
                     sendSketchInfo("Battery Meter", "1.0");
                     // get the battery Voltage
                     #ifdef MY_DEBUG
                     Serial.println(sensorValue);
                     #ifdef MY_DEBUG
                     Serial.print(batteryV);
                     Serial.println(" V");
                     Serial.print(batteryPcnt);
                     Serial.println(" %");
                       // Power up radio after sleep
                       oldBatteryPcnt = batteryPcnt;
                     sleep(SLEEP_TIME);
                  What I see on the gateway is:
                  mysGateway: TSF:MSG:READ,101-101-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  mysGateway: TSF:MSG:BC
                  mysGateway: TSF:MSG:FPAR REQ,ID=101
                  mysGateway: TSF:PNG:SEND,TO=0
                  mysGateway: TSF:CKU:OK
                  mysGateway: TSF:MSG:GWL OK
                  mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  mysGateway: TSF:MSG:PINGED,ID=101,HP=1
                  mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  mysGateway: !TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                  mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  mysGateway: Sending message on topic: mysensors-out/101/255/3/0/6
                  mysGateway: TSF:CKU:OK,FCTRL
                  mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Battery Meter
                  mysGateway: Sending message on topic: mysensors-out/101/255/3/0/11
                  mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                  mysGateway: Sending message on topic: mysensors-out/101/255/3/0/12
                  mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=0,pt=1,l=1,sg=0:33
                  mysGateway: Sending message on topic: mysensors-out/101/255/3/0/0```
                  Thank for your help!
                  Jacob
                    bjacobtB
                    bjacobtB
                    bjacobt
                    hi @mfalkvidd,
                    Do you mind clarifying a bit, I've done sensorValue * 0.003363075
                    Gives me 330, so
                    330 * 0.003363075 = 1.10981475 volts
                    Thank You!
                    Jacob
                    • bjacobtB bjacobt
                      hi @mfalkvidd,
                      Gives me 330, so
                      Thank You!
                      Jacob
                      @bjacobt hmm. Yes, you are correct. The calculation seem a bit strange.
                      Using this calculator I entered
                      output 1.10981475 V
                      R1 1000000
                      R2 470000
                      Which gives a battery voltage of 3.471V
                      Looks like the calculations in the sketch are wrong? Or at least confusing :) I'm pretty lost.
                      • tonnerre33T
                        tonnerre33T
                        tonnerre33
                        #21
                        must give you 1023 and not 330.
                        For me it's a problem of value resistance or analogReference.
                        Try to add this
                          #ifdef MY_DEBUG
                         Serial.print("Value A0 before force reference: ");
                         Serial.print(sensorValue);
                        delay(10000);
                          #ifdef MY_DEBUG
                         Serial.print("Value A0 after force reference: ");
                        Just after this existing code :
                           #ifdef MY_DEBUG
                        And plz send me the logs of the node ;)
                          Try to add this
                            #ifdef MY_DEBUG
                          delay(10000);
                            #ifdef MY_DEBUG
                             #ifdef MY_DEBUG
                          bjacobtB
                          bjacobtB
                          bjacobt
                          @tonnerre33 Its still the same
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:UPL
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                          TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                          Node registration=1
                          330
                          Value A0 before force reference: 327
                          Value A0 after force reference: 329
                          Battery percent: 32 %
                          TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:32
                             #ifdef MY_DEBUG
                            #ifdef MY_DEBUG
                          delay(10000);
                            #ifdef MY_DEBUG
                             #ifdef MY_DEBUG
                             sleep(SLEEP_TIME);
                          • tonnerre33T
                            tonnerre33T
                            tonnerre33
                            #23
                            Ok it's not a problem with the analogReference, you can delete this part of code.
                            Did you control your resistance value and did you do this schema ?
                            • bjacobtB
                              bjacobtB
                              bjacobt
                              wrote on last edited by bjacobt
                              #24
                              I'm sorry what do you mean by "control your resistance value"
                              this is my circuit,
                              1M resistor to +V rail, 470K resistor to GND and middle point to A0.
                              0_1478097209731_IMG_1543.JPG ,
                              • tonnerre33T
                                tonnerre33T
                                tonnerre33
                                Ok try to remove the jumper between V+ and AREF
                                  bjacobtB
                                  bjacobtB
                                  bjacobt
                                  @tonnerre33 That was it!
                                  I'm getting Battery Voltage: 3.10 V
                                  Battery percent: 92 %
                                  Thank you so much :)
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:UPL
                                  TSP:CHKUPL:OK
                                  TSM:UPL:OK
                                  TSM:READY
                                  Node registration=1
                                  922
                                  Value A0 before force reference: 924
                                  Value A0 after force reference: 923
                                  TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:92
                                  • Meshx86M
                                    Meshx86M
                                    Meshx86
                                    can Li 18650 3.7 batteries be used as they are rechargeable ? knowing the max voltage at full might reach 4.1-4.2v ? maybe keeping the voltage regulator ?
                                    • Meshx86M Meshx86
                                      @Meshx86 yes they can be used but as you've already identified the nrf (and maybe other components) will need to be protected from the high voltage when the battery is full.
                                      The self-discharge rate of li-ion is higher than alkaline batteries which might affect how long the node can run before it needs charging.
                                      • parachutesjP
                                        parachutesjP
                                        parachutesj
                                        I just built the circuit which is explained in the thread with a Pro Mini 3.3 8 mHz
                                        So far so good, I can read the voltage of the battery etc but my problem is, it consumes about 1.2 mA while in sleep, this is about factor 10 of the findings from the thread.
                                        I just copied the code 1:1
                                        Any glue what could be wrong or what get others with that setup? The Arduino is not modified at all.
                                        SJ
                                        N 1 Reply Last reply
                                        • parachutesjP parachutesj
                                          SJ
                                          N
                                          N
                                          Nicklas Starkel
                                          @parachutesj you have to modify the pro mini. Remove the power led according to instructions!
                                          parachutesjP 1 Reply Last reply
