  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 227.8k Views 53 Watching
  • tonnerre33T
    tonnerre33T
    tonnerre33
    It's normal to have 1.1V on A0 when you have 3.3V on your batteries.
    Where did you get the 1.11V value ? In the serial print or with your multimeter ?
    If you read the value with the serial print, which variable is it (sensorValue or batteryV) ?
    • bjacobtB
      bjacobtB
      bjacobt
      @tonnerre33 in the serial print and MySensor MQTT gateway
      • bjacobtB
        bjacobtB
        bjacobt
        @tonnerre33, I'm trying to build arduio that can run on 2 AA batteries. I'm using MySensors for library and building arduino circuit based on this https://openhomeautomation.net/arduino-battery/
        • tonnerre33T
          tonnerre33T
          tonnerre33
          Can you post the logs of your node and the skech used ?
          bjacobtB 1 Reply Last reply
          • bjacobtB bjacobt
            @bjacobt https://www.mysensors.org/build/battery#measuring-and-reporting-battery-level describes how the battery voltage is calculated and the example sketch has code for doing the calculation. Looks like you've missed reading this part:
            • tonnerre33T tonnerre33
              bjacobtB
              bjacobtB
              bjacobt
              @tonnerre33
              Here are the logs from Arduino Serial console
              TSM:INIT
              TSM:RADIO:OK
              TSP:ASSIGNID:OK (ID=101)
              TSM:FPAR
              TSP:MSG:SEND 101-101-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              TSP:MSG:READ 0-0-101 s=255,c=3,t=8,pt=1,l=1,sg=0:0
              TSP:MSG:PAR OK (ID=0, dist=1)
              TSM:FPAR:OK
              TSM:ID
              TSM:CHKID:OK (ID=101)
              TSM:UPL
              TSP:PING:SEND (dest=0)
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
              TSP:MSG:READ 0-0-101 s=255,c=3,t=25,pt=1,l=1,sg=0:1
              TSP:MSG:PONG RECV (hops=1)
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
              !TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
              TSP:MSG:READ 0-0-101 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=ok:Battery Meter
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
              Request registration...
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
              TSP:MSG:READ 0-0-101 s=255,c=3,t=27,pt=1,l=1,sg=0:1
              Node registration=1
              Init complete, id=101, parent=0, distance=1, registration=1
              330
              Battery Voltage: 1.11 V
              Battery percent: 33 %
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:33
              The sketch used is this:
              #define MY_NODE_ID  101
              unsigned long SLEEP_TIME = 100000;  // sleep time between reads (seconds * 1000 milliseconds)
              int oldBatteryPcnt = 0;
                 analogReference(INTERNAL1V1);
                 analogReference(INTERNAL);
                 sendSketchInfo("Battery Meter", "1.0");
                 // get the battery Voltage
                 #ifdef MY_DEBUG
                 Serial.println(sensorValue);
                 #ifdef MY_DEBUG
                 Serial.print(batteryV);
                 Serial.println(" V");
                 Serial.print(batteryPcnt);
                 Serial.println(" %");
                   // Power up radio after sleep
                   oldBatteryPcnt = batteryPcnt;
                 sleep(SLEEP_TIME);
              What I see on the gateway is:
              mysGateway: TSF:MSG:READ,101-101-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              mysGateway: TSF:MSG:BC
              mysGateway: TSF:MSG:FPAR REQ,ID=101
              mysGateway: TSF:PNG:SEND,TO=0
              mysGateway: TSF:CKU:OK
              mysGateway: TSF:MSG:GWL OK
              mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              mysGateway: TSF:MSG:PINGED,ID=101,HP=1
              mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              mysGateway: !TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
              mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
              mysGateway: Sending message on topic: mysensors-out/101/255/3/0/6
              mysGateway: TSF:CKU:OK,FCTRL
              mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Battery Meter
              mysGateway: Sending message on topic: mysensors-out/101/255/3/0/11
              mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
              mysGateway: Sending message on topic: mysensors-out/101/255/3/0/12
              mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
              mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=0,pt=1,l=1,sg=0:33
              mysGateway: Sending message on topic: mysensors-out/101/255/3/0/0```
              Thank for your help!
              Jacob
                bjacobtB
                bjacobtB
                bjacobt
                hi @mfalkvidd,
                Do you mind clarifying a bit, I've done sensorValue * 0.003363075
                Gives me 330, so
                330 * 0.003363075 = 1.10981475 volts
                Thank You!
                Jacob
                • bjacobtB bjacobt
                  hi @mfalkvidd,
                  Gives me 330, so
                  Thank You!
                  Jacob
                  @bjacobt hmm. Yes, you are correct. The calculation seem a bit strange.
                  Using this calculator I entered
                  output 1.10981475 V
                  R1 1000000
                  R2 470000
                  Which gives a battery voltage of 3.471V
                  Looks like the calculations in the sketch are wrong? Or at least confusing :) I'm pretty lost.
                  • tonnerre33T
                    tonnerre33T
                    tonnerre33
                    #21
                    must give you 1023 and not 330.
                    For me it's a problem of value resistance or analogReference.
                    Try to add this
                      #ifdef MY_DEBUG
                     Serial.print("Value A0 before force reference: ");
                     Serial.print(sensorValue);
                    delay(10000);
                      #ifdef MY_DEBUG
                     Serial.print("Value A0 after force reference: ");
                    Just after this existing code :
                       #ifdef MY_DEBUG
                    And plz send me the logs of the node ;)
                      Try to add this
                        #ifdef MY_DEBUG
                      delay(10000);
                        #ifdef MY_DEBUG
                         #ifdef MY_DEBUG
                      bjacobtB
                      bjacobtB
                      bjacobt
                      @tonnerre33 Its still the same
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                      Node registration=1
                      330
                      Value A0 before force reference: 327
                      Value A0 after force reference: 329
                      Battery percent: 32 %
                      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:32
                         #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                      delay(10000);
                        #ifdef MY_DEBUG
                         #ifdef MY_DEBUG
                         sleep(SLEEP_TIME);
                      • tonnerre33T
                        tonnerre33T
                        tonnerre33
                        #23
                        Ok it's not a problem with the analogReference, you can delete this part of code.
                        Did you control your resistance value and did you do this schema ?
                        • bjacobtB
                          bjacobtB
                          bjacobt
                          wrote on last edited by bjacobt
                          #24
                          I'm sorry what do you mean by "control your resistance value"
                          this is my circuit,
                          1M resistor to +V rail, 470K resistor to GND and middle point to A0.
                          0_1478097209731_IMG_1543.JPG ,
                          • tonnerre33T
                            tonnerre33T
                            tonnerre33
                            Ok try to remove the jumper between V+ and AREF
                              bjacobtB
                              bjacobtB
                              bjacobt
                              @tonnerre33 That was it!
                              I'm getting Battery Voltage: 3.10 V
                              Battery percent: 92 %
                              Thank you so much :)
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              Node registration=1
                              922
                              Value A0 before force reference: 924
                              Value A0 after force reference: 923
                              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:92
                              • Meshx86M
                                Meshx86M
                                Meshx86
                                can Li 18650 3.7 batteries be used as they are rechargeable ? knowing the max voltage at full might reach 4.1-4.2v ? maybe keeping the voltage regulator ?
                                • Meshx86M Meshx86
                                  @Meshx86 yes they can be used but as you've already identified the nrf (and maybe other components) will need to be protected from the high voltage when the battery is full.
                                  The self-discharge rate of li-ion is higher than alkaline batteries which might affect how long the node can run before it needs charging.
                                  • parachutesjP
                                    parachutesjP
                                    parachutesj
                                    I just built the circuit which is explained in the thread with a Pro Mini 3.3 8 mHz
                                    So far so good, I can read the voltage of the battery etc but my problem is, it consumes about 1.2 mA while in sleep, this is about factor 10 of the findings from the thread.
                                    I just copied the code 1:1
                                    Any glue what could be wrong or what get others with that setup? The Arduino is not modified at all.
                                    SJ
                                    N 1 Reply Last reply
                                    • parachutesjP parachutesj
                                      SJ
                                      N
                                      N
                                      Nicklas Starkel
                                      @parachutesj you have to modify the pro mini. Remove the power led according to instructions!
                                      parachutesjP 1 Reply Last reply
                                      • N Nicklas Starkel
                                        parachutesjP
                                        parachutesjP
                                        parachutesj
                                        @Nicklas-Starkel thank you. If one could read...
                                        I read the description again and thought that it should be 120uA stock and when removing LED and regulator it will even go down further but thinking about it, how should at base 120 uA and removing LED save additional 1.5mA???? LOL, sorry was a long day.
                                        My Fluke reads 0.044 mA in sleep now (without LED). Sweet!
                                        • N
                                          N
                                          Nicklas Starkel
                                          Another battery related question that I really do not understand.
                                          Are there different versions on how to read battery consumption?
                                          I see some sketches uses:
                                          long readVcc() {
                                            long result;
                                            noInterrupts ();
                                            // start the conversion
                                            ADCSRA |= _BV (ADSC) | _BV (ADIE);
                                            set_sleep_mode (SLEEP_MODE_ADC);    // sleep during sample
                                            interrupts ();
                                            sleep_mode ();
                                            // reading should be done, but better make sure
                                            // maybe the timer interrupt fired
                                            result = ADCL;
                                            result |= ADCH<<8;
                                            result = 1126400L / result; // Back-calculate AVcc in mV```
                                          However some (like the original one in this thread) uses:
                                          Is it due to different libraries or maybe it is the same but just programming wise different?
