  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 170.5k Views 65 Watching
  • L
    L
    ludoarchi
    Hi
    Noob questions sorry !
    1/ Can i used it with 3way switches ?
    2/ what are the pins 7 GND and 4 for ?
    Thinks
    mr_constM 1 Reply Last reply
    • L ludoarchi
      Hi
      Thinks
      mr_constM
      mr_constM
      mr_const
      wrote on last edited by mr_const
      #109
      @ludoarchi
      7 and 4 pins are mapped to 7 and 4 in/out of an arduino module. GND is for ground. These pins could be used to manually control relay state.
      L 1 Reply Last reply
      • mr_constM mr_const
        @ludoarchi
        L
        L
        ludoarchi
        @mr_const ok i understand ! Thinks
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          wrote on last edited by rozpruwacz
          #111
          hi, great project. I have one idea, is it possible to add current and voltage measurement ?
          • Sander CrombeenS
            Sander CrombeenS
            Sander Crombeen
            Ordered all the components for this project but now i see there are 12 v solid state relays on the list?? mine is not working, does it not need to have 5V version??
            • AchimA
              AchimA
              Achim
              one question to the SSR Relay. The Arduino works with 5V, the SSR in the BOM is a 12V type. Is this a mistake? According to the Datasheet of the relay, the 12V type has an operating range from 9,6v to 14,4V
              • AchimA Achim
                mr_constM
                mr_constM
                mr_const
                @Achim looks like a mistake in BOM (maybe that aliexpress listing has changed). Project uses same relay, but 5V version is needed.
                JonnyDev13J 1 Reply Last reply
                • tonnerre33T
                  tonnerre33T
                  tonnerre33
                  #115
                  Hello all,
                  I have finished to assemble one of this board today.
                  You can see some pictures of my board here :
                  http://www.photorapide.com/albums/jordan/khreln/ac-dc-double-solid-state-relay-module.html
                  If you want more pictures, ask me ;)
                  The skecth works fine.
                  Thx for this project.
                  okosO 1 Reply Last reply
                  • tonnerre33T tonnerre33
                    Hello all,
                    okosO
                    okosO
                    okos
                    wrote on last edited by okos
                    #116
                    @tonnerre33
                    Avesome photogallery :smile:
                    whose sketch you used? because I have a problem with phisycal switches if I use sketch of Nca78 (I wrote about this earlier)
                    Nca78N 1 Reply Last reply
                    • tonnerre33T
                      tonnerre33T
                      tonnerre33
                      I used the sketch of Nca78 (2 months ago) but i only command relays from jeedom.
                      I didn't test physical switch change because i don't have neutral wire in my switch box :(
                      • okosO okos
                        @tonnerre33
                        @okos said:
                        @tonnerre33
                        Sorry Okos I didn't notice the problem came from my sketch. I'm not using the physical switches at the moment (same reason than tonnerre33, no neutral wire where I have put it at the moment), but I will try to find some time next week to fix the sketch. I'll fix the temperature sending too as sometimes I have some tiny variations of temperature that generate a lot of message sending in a burst and it perturbates other sensors.
                        • br0wnB
                          br0wnB
                          br0wn
                          @tonnerre33
                          Just a quick question before i order the PCB, is it realy 4.6x5 cm? (thats what it says on the dirtypcb website, but when i mesure the PCB in the diptrace file, it shows a perfect 5x5 cm.
                          can you please explain?
                          • Nca78N
                            PCB is 5*5cm.
                            You will also have to include the antenna of the NRF24 that is outside the PCB area.
                            • tonnerre33T
                              tonnerre33T
                              tonnerre33
                              Yes, it's 5x5cm.
                              For information, i can't place this pcb in my wall box.
                              I'll search other wall box this week in order to find a greater box..
                              If someone want just to test the PCB i can sell one PCB if you are in france ;)
                              I have ordered 10 boards but i don't think use everything.
                              Nca78N br0wnB 2 Replies Last reply
                                Yes, it's 5x5cm.
                                Same here if you are in Vietnam or asia, just pay postage and I can send you :p
                                I have 20 as first order from Seeed took too long to arrive I thought it was lost, so I ordered again from PCBWay. Then received both orders.
                                @tonnerre33 what is the space available in your wall box ? Would a 43*45mm pcb fit ? Only one relay/switch on my future board but phase + neutral in and phase + neutral out so no need to have additionnal connectors. No SMD, safe distance between tracks + milling. And 0.1'' tracks for load so it should be ok without reinforcing the tracks with solder.
                                  Yes, it's 5x5cm.
                                  br0wnB
                                  br0wnB
                                  br0wn
                                  @tonnerre33 Thanks buddy,
                                  do you know if dirtypcb are still operational? because i've seen in their website that they want to migrate to another website "dangerousprototype"
                                  did anyone order from them lately?
                                  • br0wnB br0wn
                                    @br0wn dev.dangerousprototypes.com is supposed to be a test site only, dirtypcb is still functional.
                                    br0wnB 1 Reply Last reply
                                    • Nca78N Nca78
                                      br0wnB
                                      br0wnB
                                      br0wn
                                      @Nca78
                                      Merci ^^
                                      • Nca78N Nca78
                                        tonnerre33T
                                        tonnerre33T
                                        tonnerre33
                                        #126
                                        @Nca78
                                        I have searched others wall box today but nothing fit (box from france).
                                        A 43x45mm pcb will fit well.
                                        I tried the pcb of the roller-shutter-node (45x46mm) and the wall box fits well.
                                        What do you mean by "no additionnal connectors" ? Will can use physical switches ?
                                          JonnyDev13J
                                          JonnyDev13J
                                          JonnyDev13
                                          Uggh, I just received 20 of the 12v ones yesterday that I purchased from the BOM link. Is it safe to say that these will absolutely not work, or is there some way to adapt them with a step-up converter or something?
