  2. Announcements
  • JahFyahhJ
    JahFyahhJ
    JahFyahh
    Either its not stated or I cannot see it, but i was wondering... Is this version 2 voor de rPi?
    At the moment I am using MySensors version 1.5 with Pimatic as controller. And I would like to use v2.
    • E
      E
      ericvdb
      @ben999 Yes, version 2
      • ben999B
        ben999B
        ben999
        wrote on last edited by ben999
        #113
        I feel a bit sorry to come back here for my own little troubles...
        1- So i installed openhab2 on RPi3 with a fresh SDCard
        2- I followed tobof 's excellent step-by-step howto
        3- I installed mysGateway
        4- With pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d i can see that my motion sensor and my RPi gateway get on well... they do speak to each other, right ?
        mysGateway: Starting gateway...
        mysGateway: Protocol version - 2.0.1-beta
        mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
        mysGateway: TSF:LRT:OK
        mysGateway: TSM:INIT
        mysGateway: TSM:INIT:TSP OK
        mysGateway: TSM:INIT:GW MODE
        mysGateway: TSM:READY
        mysGateway: MCO:REG:NOT NEEDED
        mysGateway: MCO:BGN:STP
        mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
        mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
        mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:0
        5-in things/demo.things" I put this.
        Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/2", sendDelay=200 ] {  }
        Right away, it worked (king of the world!) and i could see that bridge in paperUI !!!
        But i got that after a reboot of RPi
        openhab> Failed to connect on port: /dev/pts/2 exception:
        gnu.io.NoSuchPortException
                at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273)
                at gnu.io.NRSerialPort.connect(NRSerialPort.java:48)
                at org.openhab.binding.mysensors.protocol.serial.MySensorsSerialConnection.<init>(MySensorsSerialConnection.java:52)
                at org.openhab.binding.mysensors.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:63)
                at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:764)
                at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)
                at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)
                at java.util.concurrent.FutureTask.run(FutureTask.java:266)
                at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
                at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
                at java.lang.Thread.run(Thread.java:745)
        Wrong serial port ?
        Juste to make it clear : mysGateway bit of software is the magic that makes RPi believe that there's an arduino acting as a gateway on USB and collects the NRF24 info through GPio ?
        • ben999B ben999
          Wrong serial port ?
          @ben999 said:
          Wrong serial port ?
          Likely ;-)
          /dev/pts/x are pseudo-terminals , not serial ports.
          On my (old) Pi running Raspbian the serial port is /dev/ttyAMA0
          You could run something like
          dmesg |grep -i tty
          to get an idea of serial ports on your Pi.
          ben999B 1 Reply Last reply
          • YveauxY Yveaux
            @ben999 said:
            Wrong serial port ?
            Likely ;-)
            dmesg |grep -i tty
            ben999B
            ben999B
            ben999
            @Yveaux thanks a lot for your answer. Understanding linux is a slow and painful process :laughing:
            Here is the output from your command : dmesg |grep -i tty
            pi@raspberrypi:~ $ dmesg |grep -i tty
            [    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xcc3e67e3 smsc95xx.macaddr=B8:27:EB:3E:67:E3 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
            [    0.001337] console [tty1] enabled
            [    1.772114] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
            What a mess...
            ttyAMA0 is the one !!!
            Thanks @Yveaux you got me on the right path !!! Goto next step! :smile:
            • JahFyahhJ
              JahFyahhJ
              JahFyahh
              I just did a fresh install of pimatic and MsGateway on the pi. But pimatic does not seem to get de messages. i started the gateway via the daemon method, is there a way to see if the sensor is reaching the gateway?
              • H
                H
                hausinger
                @b0rmann
                Do you still using the rs485 usb "dongle" to connect the rs485 nodes to the rpi? Do you attached some more nodes to your rs485 rpi Gateway?
                Is it stable?
                How do you do the configuration for it?
                • JahFyahhJ JahFyahh
                  marceloaqno
                  Code Contributor
                  @JahFyahh To view messages being exchanged with the sensors, run the gateway in debug mode:
                  mysGateway -d
                  • JahFyahhJ
                    JahFyahhJ
                    JahFyahh
                    @marceloaqno thank you for the reply, I tried that and I receive "mysGateway: acce[t: Bad file descriptor" Any idea what this means?
                      marceloaqno
                      Code Contributor
                      @JahFyahh Could you provide the full debug log?
                      • manulM
                        manulM
                        manul
                        Hi team,
                        First of all, thanks for this amazing project and this doc.
                        I'm trying to use arduino nanos with Raspberry Pi 2 as a gateway: I can get it working when I configure the Raspberry Pi using serial gateway, however, it does not work using MQTT with latest version from git.
                        The error message is:
                        "mysGateway: accept: Bad file descriptor"
                        I followed all explanations given on this page.
                        Any idea?
                        Thanks again
                        • manulM manul
                          Hi team,
                          Any idea?
                          Thanks again
                          marceloaqno
                          Code Contributor
                          @manul Which MQTT broker are you using? Did you try to update it?
                          • H
                            H
                            hausinger
                            I wanted to use the mysGateway with a USB/RS485 converter.
                            Here is my config: ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 my-rs485-baudrate=57600
                            make does it's job, but after i start the gateway it says:
                            mysGateway: Starting gateway....
                            mysGateway: MCO:BGN:INIT GW,CP=RSNG---,VER=2.0.1-beta
                            mysGateway: TSM:INIT: GW Mode
                            after that it stopped to work.
                            Whats wrong in my configuration?
                            • H hausinger
                              marceloaqno
                              Code Contributor
                              @hausinger Have you checked if /dev/ttyUSB0 is receiving any data?
                              H 1 Reply Last reply
                                marceloaqno
                                Code Contributor
                                wrote on last edited by marceloaqno
                                #125
                                The RPi port has just received a new update that changes some important things related to the location and name of the gateway binary and services:
                                mysGateway was renamed to mysgw
                                mysgateway service was renamed to mysgw
                                Now, after successfully running the make command, you will find the gateway file under ./bin/mygw
                                Also, before installing the new version you need to manually remove the old one:
                                If you are using systemd
                                sudo systemctl disable mysgateway.service
                                sudo rm /etc/systemd/system/mysgateway.service
                                sudo rm /usr/local/bin/mysGateway
                                If you are using sysvinit
                                sudo update-rc.d -f mysgateway remove
                                sudo rm /etc/init.d/mysgateway
                                • M marceloaqno
                                  H
                                  H
                                  hausinger
                                  Thank you for your answer. I don't know, how to check that? The wiring to my nodes is correct, the serial port is correct (dmesg says that).
                                  Could you confirm, that my configuration from my last post is correct?
                                  M 2 Replies Last reply
                                  • H hausinger
                                    marceloaqno
                                    Code Contributor
                                    #127
                                    @hausinger Your configuration is correct. To check the serial, install the screen package (if you haven't already done so) and run:
                                    screen /dev/ttyUSB0 57600
                                    You should see some strange characters being printed.
                                    I did a quick test here with your setup and found out that there is a bug with the gateway when the rs485 baud rate is set to 57600. With 9600 it works fine. I'll try to fix this.
                                    • H hausinger
                                      marceloaqno
                                      Code Contributor
                                      #128
                                      @hausinger You forgot "--" for my-rs485-baudrate=57600 in your configuration.
                                      It should be:
                                      ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
                                      • M marceloaqno
                                        It should be:
                                        H
                                        H
                                        hausinger
                                        It should be:
                                        Hi @marceloaqno
                                        Thank you for your answers. Yes, i saw this, but I did the "--", i forgot it in the last post, because I can't use copy & paste on my raspberry (remote Desktop).
                                        Did this configuration work on your System?
                                        Are you sure, that my configuration is ok? (with the "--")
                                        Whats the normal behavior when i start the mysGateway with debug (mysGateway -d)? If i type the starting command in the terminal, the Gateway gives me the Messages (from my last post) and thats it (not more). I can now type a new command
                                        I'm now not at home (Business trip), if I get home, i will try your "Screen" command
                                        • jmmorgan83J
                                          jmmorgan83J
                                          jmmorgan83
                                          I followed the instruction above to make a mysgw file, but no file was generated.
