  2. Announcements
  • YveauxY Yveaux
    @ben999 said:
    Wrong serial port ?
    Likely ;-)
    /dev/pts/x are pseudo-terminals , not serial ports.
    On my (old) Pi running Raspbian the serial port is /dev/ttyAMA0
    You could run something like
    dmesg |grep -i tty
    to get an idea of serial ports on your Pi.
    ben999B
    ben999B
    ben999
    @Yveaux thanks a lot for your answer. Understanding linux is a slow and painful process :laughing:
    Here is the output from your command : dmesg |grep -i tty
    pi@raspberrypi:~ $ dmesg |grep -i tty
    [    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xcc3e67e3 smsc95xx.macaddr=B8:27:EB:3E:67:E3 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.001337] console [tty1] enabled
    [    1.772114] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
    What a mess...
    ttyAMA0 is the one !!!
    Thanks @Yveaux you got me on the right path !!! Goto next step! :smile:
    • JahFyahhJ
      JahFyahhJ
      JahFyahh
      I just did a fresh install of pimatic and MsGateway on the pi. But pimatic does not seem to get de messages. i started the gateway via the daemon method, is there a way to see if the sensor is reaching the gateway?
      • H
        H
        hausinger
        @b0rmann
        Do you still using the rs485 usb "dongle" to connect the rs485 nodes to the rpi? Do you attached some more nodes to your rs485 rpi Gateway?
        Is it stable?
        How do you do the configuration for it?
        • JahFyahhJ JahFyahh
          marceloaqno
          Code Contributor
          @JahFyahh To view messages being exchanged with the sensors, run the gateway in debug mode:
          mysGateway -d
          • JahFyahhJ
            JahFyahhJ
            JahFyahh
            @marceloaqno thank you for the reply, I tried that and I receive "mysGateway: acce[t: Bad file descriptor" Any idea what this means?
              marceloaqno
              Code Contributor
              @JahFyahh Could you provide the full debug log?
              • manulM
                manulM
                manul
                Hi team,
                First of all, thanks for this amazing project and this doc.
                I'm trying to use arduino nanos with Raspberry Pi 2 as a gateway: I can get it working when I configure the Raspberry Pi using serial gateway, however, it does not work using MQTT with latest version from git.
                The error message is:
                "mysGateway: accept: Bad file descriptor"
                I followed all explanations given on this page.
                Any idea?
                Thanks again
                • manulM manul
                  Hi team,
                  Any idea?
                  Thanks again
                  marceloaqno
                  Code Contributor
                  @manul Which MQTT broker are you using? Did you try to update it?
                  • H
                    H
                    hausinger
                    I wanted to use the mysGateway with a USB/RS485 converter.
                    Here is my config: ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 my-rs485-baudrate=57600
                    make does it's job, but after i start the gateway it says:
                    mysGateway: Starting gateway....
                    mysGateway: Protocol version - 2.0.1-beta
                    mysGateway: MCO:BGN:INIT GW,CP=RSNG---,VER=2.0.1-beta
                    mysGateway: TSM:INIT
                    mysGateway: TSM:INIT:TSP OK
                    mysGateway: TSM:INIT: GW Mode
                    mysGateway: TSM:READY
                    after that it stopped to work.
                    Whats wrong in my configuration?
                    • H hausinger
                      marceloaqno
                      Code Contributor
                      @hausinger Have you checked if /dev/ttyUSB0 is receiving any data?
                      H 1 Reply Last reply
                        marceloaqno
                        Code Contributor
                        wrote on last edited by marceloaqno
                        #125
                        The RPi port has just received a new update that changes some important things related to the location and name of the gateway binary and services:
                        mysGateway was renamed to mysgw
                        mysgateway service was renamed to mysgw
                        Now, after successfully running the make command, you will find the gateway file under ./bin/mygw
                        Also, before installing the new version you need to manually remove the old one:
                        If you are using systemd
                        sudo systemctl disable mysgateway.service
                        sudo rm /etc/systemd/system/mysgateway.service
                        sudo rm /usr/local/bin/mysGateway
                        If you are using sysvinit
                        sudo update-rc.d -f mysgateway remove
                        sudo rm /etc/init.d/mysgateway
                        • M marceloaqno
                          H
                          H
                          hausinger
                          Thank you for your answer. I don't know, how to check that? The wiring to my nodes is correct, the serial port is correct (dmesg says that).
                          Could you confirm, that my configuration from my last post is correct?
                          M 2 Replies Last reply
                          • H hausinger
                            marceloaqno
                            Code Contributor
                            #127
                            @hausinger Your configuration is correct. To check the serial, install the screen package (if you haven't already done so) and run:
                            screen /dev/ttyUSB0 57600
                            You should see some strange characters being printed.
                            I did a quick test here with your setup and found out that there is a bug with the gateway when the rs485 baud rate is set to 57600. With 9600 it works fine. I'll try to fix this.
                            • H hausinger
                              marceloaqno
                              Code Contributor
                              #128
                              @hausinger You forgot "--" for my-rs485-baudrate=57600 in your configuration.
                              It should be:
                              ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
                              • M marceloaqno
                                It should be:
                                H
                                H
                                hausinger
                                It should be:
                                Hi @marceloaqno
                                Thank you for your answers. Yes, i saw this, but I did the "--", i forgot it in the last post, because I can't use copy & paste on my raspberry (remote Desktop).
                                Did this configuration work on your System?
                                Are you sure, that my configuration is ok? (with the "--")
                                Whats the normal behavior when i start the mysGateway with debug (mysGateway -d)? If i type the starting command in the terminal, the Gateway gives me the Messages (from my last post) and thats it (not more). I can now type a new command
                                I'm now not at home (Business trip), if I get home, i will try your "Screen" command
                                • jmmorgan83J
                                  jmmorgan83J
                                  jmmorgan83
                                  I followed the instruction above to make a mysgw file, but no file was generated.
                                  • jmmorgan83J jmmorgan83
                                    #131
                                    @jmmorgan83 do you think there is any information you can share might help us help you?
                                    • jmmorgan83J
                                      jmmorgan83J
                                      jmmorgan83
                                      I reset everything and ran it again. It did generate the file this time. Thanks, - Now to test it.
                                      • jmmorgan83J
                                        jmmorgan83J
                                        jmmorgan83
                                        Has anyone gotten the raspberry pi gateway to work with Openhab on the same raspberry pi? I have both the virtual and mqtt gateways working, but I can get either one to communicate with Openhab.
                                        • H hausinger
                                          It should be:
                                          Hi @marceloaqno
                                          H
                                          H
                                          hausinger
                                          @hausinger said:
                                          It should be:
                                          Hi @marceloaqno
                                          So I'm at home today and make some Test.
                                          The screen comand gives me some strange characters, thats ok I think.
                                          But if i start the Gateway, I only get the same messages as shown in my other post.
                                          Here are 2 Pics that show you, how it look like.
                                          I also tried to make the gw with a baudrate of 9600, but still the same issues.!0_1480068509863_mysGateway.JPG 0_1480068518084_screen.JPG
