  2. Announcements
  • manulM
    manulM
    manul
    Hi team,
    First of all, thanks for this amazing project and this doc.
    I'm trying to use arduino nanos with Raspberry Pi 2 as a gateway: I can get it working when I configure the Raspberry Pi using serial gateway, however, it does not work using MQTT with latest version from git.
    The error message is:
    "mysGateway: accept: Bad file descriptor"
    I followed all explanations given on this page.
    Any idea?
    Thanks again
    • manulM manul
      Hi team,
      Any idea?
      Thanks again
      marceloaqno
      Code Contributor
      @manul Which MQTT broker are you using? Did you try to update it?
      • H
        H
        hausinger
        I wanted to use the mysGateway with a USB/RS485 converter.
        Here is my config: ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 my-rs485-baudrate=57600
        make does it's job, but after i start the gateway it says:
        mysGateway: Starting gateway....
        mysGateway: Protocol version - 2.0.1-beta
        mysGateway: MCO:BGN:INIT GW,CP=RSNG---,VER=2.0.1-beta
        mysGateway: TSM:INIT
        mysGateway: TSM:INIT:TSP OK
        mysGateway: TSM:INIT: GW Mode
        mysGateway: TSM:READY
        after that it stopped to work.
        Whats wrong in my configuration?
        • H hausinger
          marceloaqno
          Code Contributor
          @hausinger Have you checked if /dev/ttyUSB0 is receiving any data?
          H 1 Reply Last reply
            marceloaqno
            Code Contributor
            wrote on last edited by marceloaqno
            #125
            The RPi port has just received a new update that changes some important things related to the location and name of the gateway binary and services:
            mysGateway was renamed to mysgw
            mysgateway service was renamed to mysgw
            Now, after successfully running the make command, you will find the gateway file under ./bin/mygw
            Also, before installing the new version you need to manually remove the old one:
            If you are using systemd
            sudo systemctl disable mysgateway.service
            sudo rm /etc/systemd/system/mysgateway.service
            sudo rm /usr/local/bin/mysGateway
            If you are using sysvinit
            sudo update-rc.d -f mysgateway remove
            sudo rm /etc/init.d/mysgateway
            • M marceloaqno
              H
              H
              hausinger
              Thank you for your answer. I don't know, how to check that? The wiring to my nodes is correct, the serial port is correct (dmesg says that).
              Could you confirm, that my configuration from my last post is correct?
              M 2 Replies Last reply
              • H hausinger
                marceloaqno
                Code Contributor
                #127
                @hausinger Your configuration is correct. To check the serial, install the screen package (if you haven't already done so) and run:
                screen /dev/ttyUSB0 57600
                You should see some strange characters being printed.
                I did a quick test here with your setup and found out that there is a bug with the gateway when the rs485 baud rate is set to 57600. With 9600 it works fine. I'll try to fix this.
                • H hausinger
                  marceloaqno
                  Code Contributor
                  #128
                  @hausinger You forgot "--" for my-rs485-baudrate=57600 in your configuration.
                  It should be:
                  ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
                  • M marceloaqno
                    It should be:
                    H
                    H
                    hausinger
                    It should be:
                    Hi @marceloaqno
                    Thank you for your answers. Yes, i saw this, but I did the "--", i forgot it in the last post, because I can't use copy & paste on my raspberry (remote Desktop).
                    Did this configuration work on your System?
                    Are you sure, that my configuration is ok? (with the "--")
                    Whats the normal behavior when i start the mysGateway with debug (mysGateway -d)? If i type the starting command in the terminal, the Gateway gives me the Messages (from my last post) and thats it (not more). I can now type a new command
                    I'm now not at home (Business trip), if I get home, i will try your "Screen" command
                    • jmmorgan83J
                      jmmorgan83J
                      jmmorgan83
                      I followed the instruction above to make a mysgw file, but no file was generated.
                      • jmmorgan83J jmmorgan83
                        #131
                        @jmmorgan83 do you think there is any information you can share might help us help you?
                        • jmmorgan83J
                          jmmorgan83J
                          jmmorgan83
                          I reset everything and ran it again. It did generate the file this time. Thanks, - Now to test it.
                          • jmmorgan83J
                            jmmorgan83J
                            jmmorgan83
                            Has anyone gotten the raspberry pi gateway to work with Openhab on the same raspberry pi? I have both the virtual and mqtt gateways working, but I can get either one to communicate with Openhab.
                            • H hausinger
                              It should be:
                              Hi @marceloaqno
                              H
                              H
                              hausinger
                              @hausinger said:
                              It should be:
                              Hi @marceloaqno
                              So I'm at home today and make some Test.
                              The screen comand gives me some strange characters, thats ok I think.
                              But if i start the Gateway, I only get the same messages as shown in my other post.
                              Here are 2 Pics that show you, how it look like.
                              I also tried to make the gw with a baudrate of 9600, but still the same issues.!0_1480068509863_mysGateway.JPG 0_1480068518084_screen.JPG
                              • PureGrainP
                                PureGrainP
                                PureGrain
                                Has anyone been able to get this to successfully work with a Vera?
                                • RogerB68R
                                  RogerB68R
                                  RogerB68
                                  Have been running MySensors for some time now with a EthernetGW running on Arduino. To clean-up the installation, I'm trying to get the Gateway running on my Raspberry instead but something stops the make process.
                                  pi@raspberrypi ~/MySensors $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24                       [SECTION] Detecting target machine.
                                  [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
                                  [OK] init system detected: sysvinit
                                  [OK] Finished.
                                  gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/RPi -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                  cc1: error: bad value (cortex-a7) for -mtune switch
                                  Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
                                  Any hints what I have done wrong ?
                                  TigroenotT 1 Reply Last reply
                                  • RogerB68R
                                    RogerB68R
                                    RogerB68
                                    Issue solved, manual update of compiler from 4.6,3 -> 4.7.2 enables the make process. Similar problem also reported in post.
                                    Using
                                    • sudo apt-get update
                                    • sudo apt-get upgrade
                                    does not upgrade compiler. I used instruction according to How to upgrade GCC to 4.7+.
                                    • RogerB68R RogerB68
                                      [OK] Finished.
                                      TigroenotT
                                      TigroenotT
                                      Tigroenot
                                      @RogerB68 I had the same situation. I have removed the mtune parameter from the config file and compilation went fine. I don't know what it affects though. :)
                                      • jmmorgan83J
                                        jmmorgan83J
                                        jmmorgan83
                                        I created a virtual serial port using this ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway. I can see the port in the dev folder, but when I run dmesg I do not see it listed and therefore my openhab can not find it. How can I fix this?
                                        • H hausinger
                                          @hausinger said:
                                          It should be:
                                          Hi @marceloaqno
                                          marceloaqno
                                          Code Contributor
                                          @hausinger After the command:
                                          sudo ./bin/mysgw -d
                                          It wasn't supposed to go back to bash, the gateway would wait for new messages.
                                          I'm not sure what's going on with your setup because I tested your configuration options here and it worked.
