  2. Announcements
  • JahFyahhJ JahFyahh
    I just did a fresh install of pimatic and MsGateway on the pi. But pimatic does not seem to get de messages. i started the gateway via the daemon method, is there a way to see if the sensor is reaching the gateway?
    marceloaqno
    Code Contributor
    @JahFyahh To view messages being exchanged with the sensors, run the gateway in debug mode:
    mysGateway -d
    • JahFyahhJ
      JahFyahhJ
      JahFyahh
      @marceloaqno thank you for the reply, I tried that and I receive "mysGateway: acce[t: Bad file descriptor" Any idea what this means?
        marceloaqno
        Code Contributor
        @JahFyahh Could you provide the full debug log?
        • manulM
          manulM
          manul
          Hi team,
          First of all, thanks for this amazing project and this doc.
          I'm trying to use arduino nanos with Raspberry Pi 2 as a gateway: I can get it working when I configure the Raspberry Pi using serial gateway, however, it does not work using MQTT with latest version from git.
          The error message is:
          "mysGateway: accept: Bad file descriptor"
          I followed all explanations given on this page.
          Any idea?
          Thanks again
          • manulM manul
            Hi team,
            Any idea?
            Thanks again
            marceloaqno
            Code Contributor
            @manul Which MQTT broker are you using? Did you try to update it?
            • H
              H
              hausinger
              I wanted to use the mysGateway with a USB/RS485 converter.
              Here is my config: ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 my-rs485-baudrate=57600
              make does it's job, but after i start the gateway it says:
              mysGateway: Starting gateway....
              mysGateway: Protocol version - 2.0.1-beta
              mysGateway: MCO:BGN:INIT GW,CP=RSNG---,VER=2.0.1-beta
              mysGateway: TSM:INIT
              mysGateway: TSM:INIT:TSP OK
              mysGateway: TSM:INIT: GW Mode
              mysGateway: TSM:READY
              after that it stopped to work.
              Whats wrong in my configuration?
              • H hausinger
                marceloaqno
                Code Contributor
                @hausinger Have you checked if /dev/ttyUSB0 is receiving any data?
                H 1 Reply Last reply
                  marceloaqno
                  Code Contributor
                  wrote on last edited by marceloaqno
                  #125
                  The RPi port has just received a new update that changes some important things related to the location and name of the gateway binary and services:
                  mysGateway was renamed to mysgw
                  mysgateway service was renamed to mysgw
                  Now, after successfully running the make command, you will find the gateway file under ./bin/mygw
                  Also, before installing the new version you need to manually remove the old one:
                  If you are using systemd
                  sudo systemctl disable mysgateway.service
                  sudo rm /etc/systemd/system/mysgateway.service
                  sudo rm /usr/local/bin/mysGateway
                  If you are using sysvinit
                  sudo update-rc.d -f mysgateway remove
                  sudo rm /etc/init.d/mysgateway
                  • M marceloaqno
                    H
                    H
                    hausinger
                    Thank you for your answer. I don't know, how to check that? The wiring to my nodes is correct, the serial port is correct (dmesg says that).
                    Could you confirm, that my configuration from my last post is correct?
                    M 2 Replies Last reply
                    • H hausinger
                      marceloaqno
                      Code Contributor
                      #127
                      @hausinger Your configuration is correct. To check the serial, install the screen package (if you haven't already done so) and run:
                      screen /dev/ttyUSB0 57600
                      You should see some strange characters being printed.
                      I did a quick test here with your setup and found out that there is a bug with the gateway when the rs485 baud rate is set to 57600. With 9600 it works fine. I'll try to fix this.
                      • H hausinger
                        marceloaqno
                        Code Contributor
                        #128
                        @hausinger You forgot "--" for my-rs485-baudrate=57600 in your configuration.
                        It should be:
                        ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
                        • M marceloaqno
                          It should be:
                          H
                          H
                          hausinger
                          It should be:
                          Hi @marceloaqno
                          Thank you for your answers. Yes, i saw this, but I did the "--", i forgot it in the last post, because I can't use copy & paste on my raspberry (remote Desktop).
                          Did this configuration work on your System?
                          Are you sure, that my configuration is ok? (with the "--")
                          Whats the normal behavior when i start the mysGateway with debug (mysGateway -d)? If i type the starting command in the terminal, the Gateway gives me the Messages (from my last post) and thats it (not more). I can now type a new command
                          I'm now not at home (Business trip), if I get home, i will try your "Screen" command
                          • jmmorgan83J
                            jmmorgan83J
                            jmmorgan83
                            I followed the instruction above to make a mysgw file, but no file was generated.
                            • jmmorgan83J jmmorgan83
                              #131
                              @jmmorgan83 do you think there is any information you can share might help us help you?
                              • jmmorgan83J
                                jmmorgan83J
                                jmmorgan83
                                I reset everything and ran it again. It did generate the file this time. Thanks, - Now to test it.
                                • jmmorgan83J
                                  jmmorgan83J
                                  jmmorgan83
                                  Has anyone gotten the raspberry pi gateway to work with Openhab on the same raspberry pi? I have both the virtual and mqtt gateways working, but I can get either one to communicate with Openhab.
                                  • H hausinger
                                    It should be:
                                    Hi @marceloaqno
                                    H
                                    H
                                    hausinger
                                    @hausinger said:
                                    It should be:
                                    Hi @marceloaqno
                                    So I'm at home today and make some Test.
                                    The screen comand gives me some strange characters, thats ok I think.
                                    But if i start the Gateway, I only get the same messages as shown in my other post.
                                    Here are 2 Pics that show you, how it look like.
                                    I also tried to make the gw with a baudrate of 9600, but still the same issues.!0_1480068509863_mysGateway.JPG 0_1480068518084_screen.JPG
                                    • PureGrainP
                                      PureGrainP
                                      PureGrain
                                      Has anyone been able to get this to successfully work with a Vera?
                                      • RogerB68R
                                        RogerB68R
                                        RogerB68
                                        Have been running MySensors for some time now with a EthernetGW running on Arduino. To clean-up the installation, I'm trying to get the Gateway running on my Raspberry instead but something stops the make process.
                                        pi@raspberrypi ~/MySensors $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24                       [SECTION] Detecting target machine.
                                        [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
                                        [OK] init system detected: sysvinit
                                        [OK] Finished.
                                        gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/RPi -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                        cc1: error: bad value (cortex-a7) for -mtune switch
                                        Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
                                        Any hints what I have done wrong ?
                                        TigroenotT 1 Reply Last reply
                                        • RogerB68R
                                          RogerB68R
                                          RogerB68
                                          Issue solved, manual update of compiler from 4.6,3 -> 4.7.2 enables the make process. Similar problem also reported in post.
                                          Using
                                          • sudo apt-get update
                                          • sudo apt-get upgrade
                                          does not upgrade compiler. I used instruction according to How to upgrade GCC to 4.7+.
