  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 40.4k Views 31 Watching
  • Suresh MaliS
    Suresh MaliS
    Suresh Mali
    • TetnobicT
      TetnobicT
      Tetnobic
      wrote on last edited by Tetnobic
      #46
      I just start to test this bootloader...
      I use an ATmega328p on breadboard with no external clock, with nRF24 and somes sensors.
      Firmware Upload (by usbasp) and Run is ok, Send/Receive Data is ok too , but when I ask a reboot (with MYSController 1.0.0beta), my node enter in sort of strange start loop...
      My Fuse settings :
      bootloader.unlock_bits=0x3F
      bootloader.lock_bits=0x0F
      bootloader.low_fuses=0x62
      bootloader.high_fuses=0xDA
      bootloader.extended_fuses=0x07
      Node debug Trace :
      TSP:MSG:READ 0-0-4 s=2,c=1,t=0,pt=7,l=5,sg=0:28.18
      TSP:MSG:READ 0-0-4 s=1,c=1,t=1,pt=7,l=5,sg=0:38.28
      TSP:MSG:READ 0-0-4 s=0,c=3,t=13,pt=0,l=1,sg=0:0
      StartiStartiStartiStartiþStartiþStartiþStartiStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþStartiþ
      The "Startiþ" text is the first char of the first text printed by bootloader at start : "Starting sensor....."
      Have you an idea ?
      • tekkaT
        tekkaT
        tekka
        Please provide additional information such as library version, full debug log of your GW and node. Which bootloader/version are you using?
        TetnobicT 1 Reply Last reply
        • tekkaT tekka
          TetnobicT
          TetnobicT
          Tetnobic
          @tekka Thanks for you response
          For gateway :
          Raspberrry PI Gateway in Ethernet mode
          Protocol version : 2.0.1-beta
          For Node :
          I use bootloader : MYSBL13pre_atmega328_1Mhz.hex
          Inital Sketch do nothing :) :
          #define MY_BAUD_RATE 9600
          #define MY_OTA_FIRMWARE_FEATURE
          #define MY_NODE_ID 1
          void presentation(){
            sendSketchInfo("MyFirstBoard", "0.0.2", true);
            wait(5000);
          Test Case: Start Gateway, Connect MYSController 1.0.0beta, then start my sensor, after init complete, click reboot in MYSController
          Gateway Log :
          mysgw: Starting gateway...
          mysgw: Protocol version - 2.0.1-beta
          mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSM:INIT:TSP OK
          mysgw: TSM:INIT:GW MODE
          mysgw: TSM:READY
          mysgw: MCO:REG:NOT NEEDED
          mysgw: MCO:BGN:STP
          mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
          mysgw: New connection from 10.31.10.59
          mysgw: Client 0 connected
          mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          mysgw: TSF:MSG:BC
          mysgw: TSF:MSG:FPAR REQ,ID=1
          mysgw: TSF:PNG:SEND,TO=0
          mysgw: TSF:CKU:OK
          mysgw: TSF:MSG:GWL OK
          mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          mysgw: TSF:MSG:PINGED,ID=1,HP=1
          mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
          mysgw: Client 0: 1;255;3;0;6;M
          mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
          mysgw: TSF:MSG:ACK REQ
          mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:MyFirstBoard
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
          mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=OK:0.0.2
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
          mysgw: Client 0: 1;0;3;0;13;0
          mysgw: TSF:MSG:SEND,0-0-1-1,s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=OK:0
          NodeLog :
          Starting sensor (RNONA-, 2.0.0)
          TSM:INIT
          TSM:RADIO:OK
          TSP:ASSIGNID:OK (ID=1)
          TSM:FPAR
          TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:FPAR
          TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
          TSP:MSG:PAR OK (ID=0, dist=1)
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=1)
          TSM:UPL
          TSP:PING:SEND (dest=0)
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
          TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
          TSP:MSG:PONG RECV (hops=1)
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          TSP:MSG:SEND 1-1-0-0 s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=ok:FFFFFFFFFFFFFFFF0300
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
          TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
          TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:MyFirstBoard
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=ok:0.0.2
          Request registration...
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
          TSP:MSG:READ 0-0-1 s=255,c=3,t=11,pt=0,l=12,sg=0:MyFirstBoard
          TSP:MSG:READ 0-0-1 s=255,c=3,t=12,pt=0,l=5,sg=0:0.0.2
          TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
          Node registration=1
          Init complete, id=1, parent=0, distance=1, registration=1
          TSP:MSG:READ 0-0-1 s=0,c=3,t=13,pt=0,l=1,sg=0:0
          StartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiîStartiîStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiþStartiStartiStartiStartiStartiStartiStartiStartiStartiStartiStarti
          Need others infos ?
          Thanks for your time
          tekkaT 1 Reply Last reply
          • TetnobicT Tetnobic
            For gateway :
            For Node :
              wait(5000);
            Gateway Log :
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSM:READY
            mysgw: MCO:BGN:STP
            mysgw: TSF:MSG:BC
            mysgw: TSF:CKU:OK
            NodeLog :
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:CHKID:OK (ID=1)
            TSM:UPL
            TSP:CHKUPL:OK
            TSM:UPL:OK
            TSM:READY
            Node registration=1
            Need others infos ?
            tekkaT
            tekkaT
            tekka
            @Tetnobic
            Your node is running MySensors 2.0.0 (your GW is at 2.0.1, please consider updating), also, there is no sign of MYSBootloader in your GW log - please double-check if you followed the correct procedure.
            One more thing: the startup message indicates that you enabled OTA firmware features (RNONA-) - this is not required with MYSBootloader.
            Please have a look at @scalz's OTA guide for additional information.
            • tekkaT tekka
              @Tetnobic
              TetnobicT
              TetnobicT
              Tetnobic
              @tekka Thanks for your response
              What are the sign of MYSBootloader in GW log ?
              Can I also see any sign of MYSBootloader in Node Log ?
              I remove OTA firmware features, I now have :
              but same problem, after receive reboot message I have a "StartiStartiStartiStartiS...." loop :(:(
                tekkaT
                tekkaT
                tekka
                @Tetnobic No, you won't see anything in the node log - but in the GW log you should see somehting like:
                1;255;4;0;0;64000200C803948D0105
                • tekkaT tekka
                  TetnobicT
                  TetnobicT
                  Tetnobic
                  @tekka Hi, I found my mistake ! You were absolutely right when you said there is no sign of MYSBootloader in my GW log...
                  But now I know why :) :
                  I use an USBasp Programmer with Arduino IDE for upload my bootloader and my sketch..., and I mistakenly thought that when I upload bootloader then sketch, it keep bootloader.....but NOT, it overwrite bootloader :(
                  I fix it by uploading the xxx.with_bootloader.hex file generated by Arduino IDE when compile.
                  Sorry for the inconvenience and thank you for your help
                  AndurilA 1 Reply Last reply
                    AndurilA
                    AndurilA
                    Anduril
                    @Tetnobic can this be done within the IDE? I have some nodes where I have to upload with ISP and thought to still have the bootloader, but this explains why OTA didn't work afterwards...
                    • AndurilA Anduril
                      TetnobicT
                      TetnobicT
                      Tetnobic
                      @Anduril I think you can do this without Arduino IDE...
                      but how compile you code for generate sketch+bootloader ( the xxx.with_bootloader.hex file) in command line I don't know....
                      For upload this file on my ATMega, I use avrdude, the same command line that ardunio IDE use, but change the .hex file...
                      • TigroenotT
                        TigroenotT
                        Tigroenot
                        Tried this bootloader.
                        Have two nodes 8MHz internal, two nodes 1MHz. All run beautifully, the OTA firmware update around a minute with binaryButton sketch. But the node startup is around 7-8 seconds. And no problems uploading the sketch via serial.
                        I use an UNO as an ASP to burn the bootloader and a simple USB_TTL FTDI converter to upload sketches.
                        • jerseyguy1996J
                          jerseyguy1996J
                          jerseyguy1996
                          This may be a stupid question, but I'm using the mysgateway on a Raspberry Pi as my controller which is described here:
                          Building a Raspberry Pi Gateway
                          The Raspberry pi runs headless and I do everything through ssh. Is there any way to use MYSBootloader using the mysgateway and initiating the OTA update using the command line?
                          RedferneR 1 Reply Last reply
                          • RedferneR
                            RedferneR
                            Redferne
                            Shall we all join hands and give a warm applause to @tekka for his work and pray that he'll find the time to give us a lovely christmas present. The MYSBootloader 1.3+ pushed to github 😃
                            pkuP 1 Reply Last reply
                            • J
                              J
                              jacikaas
                              • RedferneR Redferne
                                pkuP
                                pkuP
                                pku
                                @tekka pleeeease.... :pray:
                                • Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  It's been asked that the source is uploaded multiple times over the last year +, I guess it will not happen anytime soon... :disappointed:
                                  • jerseyguy1996J jerseyguy1996
                                    RedferneR
                                    RedferneR
                                    Redferne
                                    @jerseyguy1996
                                    You'll need a Controller to update the firmware in the nodes. I'm using MyController.org running on a RPI3 with a MySensors serial Gateway. Works great!
                                    • karlheinz2000K
                                      karlheinz2000K
                                      karlheinz2000
                                      For all who have problems with serial (debug) output using MYSBootloader:
                                      When you burn the 8MHz bootloader, it sets avr fuses to internal 8MHz RC oscillator. This has high tolerance. The serial baudrate was only 108000baud in my case and Arduino IDE did not work.
                                      Setting the fuse to use the external quartz/resonator lead to 111000baud, which was close enough to 115200, to get arduino IDE to read serial data.
                                      • T
                                        tlustoch
                                        Please, can you provide source code? I need to configure radio pins (default MySensors CE and CS pins 9 and 10 are PWM so I need to connect the radio in other way). Thanks a lot!
                                        • TigroenotT
                                          TigroenotT
                                          Tigroenot
                                          Please help to debug:
                                          0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          12 !TSM:INIT:TSP FAIL
                                          14 TSM:FAIL:CNT=1
                                          16 TSM:FAIL:PDT
                                          LorenzoL 1 Reply Last reply
