  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.0k Views 31 Watching
  • AndurilA Anduril
    @Tetnobic can this be done within the IDE? I have some nodes where I have to upload with ISP and thought to still have the bootloader, but this explains why OTA didn't work afterwards...
    TetnobicT
    TetnobicT
    Tetnobic
    @Anduril I think you can do this without Arduino IDE...
    but how compile you code for generate sketch+bootloader ( the xxx.with_bootloader.hex file) in command line I don't know....
    For upload this file on my ATMega, I use avrdude, the same command line that ardunio IDE use, but change the .hex file...
    • TigroenotT
      TigroenotT
      Tigroenot
      Tried this bootloader.
      Have two nodes 8MHz internal, two nodes 1MHz. All run beautifully, the OTA firmware update around a minute with binaryButton sketch. But the node startup is around 7-8 seconds. And no problems uploading the sketch via serial.
      I use an UNO as an ASP to burn the bootloader and a simple USB_TTL FTDI converter to upload sketches.
      • jerseyguy1996J
        jerseyguy1996J
        jerseyguy1996
        This may be a stupid question, but I'm using the mysgateway on a Raspberry Pi as my controller which is described here:
        Building a Raspberry Pi Gateway
        The Raspberry pi runs headless and I do everything through ssh. Is there any way to use MYSBootloader using the mysgateway and initiating the OTA update using the command line?
        RedferneR 1 Reply Last reply
        • RedferneR
          RedferneR
          Redferne
          Shall we all join hands and give a warm applause to @tekka for his work and pray that he'll find the time to give us a lovely christmas present. The MYSBootloader 1.3+ pushed to github 😃
          pkuP 1 Reply Last reply
          • J
            J
            jacikaas
            • RedferneR Redferne
              pkuP
              pkuP
              pku
              @tekka pleeeease.... :pray:
              • Mark SwiftM
                Mark SwiftM
                Mark Swift
                It's been asked that the source is uploaded multiple times over the last year +, I guess it will not happen anytime soon... :disappointed:
                • jerseyguy1996J jerseyguy1996
                  RedferneR
                  RedferneR
                  Redferne
                  @jerseyguy1996
                  You'll need a Controller to update the firmware in the nodes. I'm using MyController.org running on a RPI3 with a MySensors serial Gateway. Works great!
                  • karlheinz2000K
                    karlheinz2000K
                    karlheinz2000
                    For all who have problems with serial (debug) output using MYSBootloader:
                    When you burn the 8MHz bootloader, it sets avr fuses to internal 8MHz RC oscillator. This has high tolerance. The serial baudrate was only 108000baud in my case and Arduino IDE did not work.
                    Setting the fuse to use the external quartz/resonator lead to 111000baud, which was close enough to 115200, to get arduino IDE to read serial data.
                    • T
                      tlustoch
                      Please, can you provide source code? I need to configure radio pins (default MySensors CE and CS pins 9 and 10 are PWM so I need to connect the radio in other way). Thanks a lot!
                      • TigroenotT
                        TigroenotT
                        Tigroenot
                        Please help to debug:
                        0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
                        4 TSM:INIT
                        4 TSF:WUR:MS=0
                        12 !TSM:INIT:TSP FAIL
                        14 TSM:FAIL:CNT=1
                        16 TSM:FAIL:PDT
                        LorenzoL 1 Reply Last reply
                        • TigroenotT Tigroenot
                          4 TSM:INIT
                          4 TSF:WUR:MS=0
                          14 TSM:FAIL:CNT=1
                          16 TSM:FAIL:PDT
                          LorenzoL
                          LorenzoL
                          Lorenzo
                          @Tigroenot Hi,
                          TSM Transmission
                          TSP Transport
                          PDT Power Down
                          !TSM:INIT:TSP FAIL Error during Transport initialization (Radio)
                          TSM:FAILURE Error on Transmition (of course, you have a radio error)
                          TSM:FAILURE:PDT Radio in Power Down (due to the error)
                          Check your radio cabling. If all ok add a capacitor on radio power pins
                          • TigroenotT
                            TigroenotT
                            Tigroenot
                            The radio is not wired, it's directly soldered as a chip. I use MySensors Stable Node by @Koresh, but the nrf chips I got from China are probably counterfeit or don't work at all :)
                            • karlheinz2000K
                              karlheinz2000K
                              karlheinz2000
                              After flasing a node with ISP (bootloader+sketch) the node will not start since the eeprom is emty (forgot to enable eeprom safe). Node needs to get a ID from controller, even if ID is defined in the sketch. After receiving a ID from controller the node starts and uses the ID from sketch.
                              Any solution to overcome this?
                              • karlheinz2000K karlheinz2000
                                #68
                                @karlheinz2000 that should not happen. Starting from empty eeprom is normal, that's what all nodes do the first time.
                                Could you post debug output of the node and the gateway when it fails to use the defined id?
                                Just to check: the id was defined before including MySensors.h right?
                                • karlheinz2000K
                                  karlheinz2000K
                                  karlheinz2000
                                  Attached the log file from MYSC. After activating AUTO ID the node starts. No other GW active.
                                  No serial output during this time.
                                  Node ID is defined before including .h.
                                  Node is flashed via ISP (Dragon) with "...with_bootloader.hex".
                                  0_1483653188071_MySensors_20170105-223345.log
                                  tekkaT 1 Reply Last reply
                                    tekkaT
                                    tekkaT
                                    tekka
                                    wrote on last edited by tekka
                                    #70
                                    @karlheinz2000 I'm not sure I understand you correctly:
                                    With a cleared EEPROM, the bootloader will not know any ID defined in the sketch. Instead, the bootloader will fetch a new ID from the controller and store it in EEPROM. Once the sketch starts it will either overtake this newly assigned ID (if MY_NODE_ID == AUTO) or overwrite and use a static ID (if MY_NODE_ID != AUTO) from now on. Does this answer your question?
                                    • karlheinz2000K
                                      karlheinz2000K
                                      karlheinz2000
                                      Understood.
                                      But if I'm not using MYSB, I can flash a sketch with defined ID and this will work instantly in the network.
                                      With MYSB I always have to do assign a new ID just to get the node to run the first time after flashing.
                                      Any chance to get MYSB to know, if a sketch is an flash?
                                      And start this sketch, which then will use the defined ID or request a new ID from controller and writes the eeprom?
                                        Understood.
                                        tekkaT
                                        tekkaT
                                        tekka
                                        Yes
                                        Only true if EEPROM (i.e. ID address location) was cleared.
                                        During booting, MYSBootloader calculates the FW CRC in flash and verifies it against the FW CRC stored in EEPROM (which is written after a successful OTA FW update) - if it matches, the sketch starts, if not, the bootloader remains active.
                                        • berkseoB
                                          berkseoB
                                          berkseo
