  3. 💬 MySensor Dioder (Ikea)
contest2017diodermysensorshuergbledtrimmerarduinoikea
41 Posts 10 Posters 19.5k Views 10 Watching
  • kevvetteK
    kevvetteK
    kevvette
    Just for clarification, you posted in a comment that S3(AIN2) -> D11 but shouldn't it be D4 per schematic and source code? Also, it looks like R20 has been removed. Why was that done and is it critical to make this work? Thanks, nice work.
      mortommy
      Hi @kevvette ,
      yes, my mistake, S3 goes to D4, I'll correct the post, thank you.
      Regarding the R20, it is just a jumper and first I thought I could use that point for some connection but at the end I didn't use it, so I reestablished the connection. It is not needed to remove the R20.
      • TON RIJNAARDT
        TON RIJNAARDT
        TON RIJNAARD
        Very nice project!
        Is it possible to use in DOMOTICZ?
        Ton
          mortommy
          if you are already using a gateway in Domoticz I guess so. From the mysensor point of view is a RGB sensor (or light switch or dimmer light) the source of the command sento to the serial gateway and then to the ikea mysensorized sensor it doesn't matter.
          • Juan8tacoJ
            Juan8tacoJ
            Juan8taco
            I was using your code from MySensorDioder_133.ino
            I downloaded the library from https://github.com/mysensors/MySensors
            I tried to run the code but I got a error message saying no such file located.
            These were the two files that couldn't be found
            MyTransportNRF24.h
            MySensor.h
            I was wondering if you had the same issues when you were working on the code?
              mortommy
              wrote on last edited by mortommy
              yes it happens sometimes. Try to import the library by Arduino IDE (Sketch -> Include Library -> MySensors). You'll have in the sketch two new lines:
              #include <MyConfig.h>
              and you can delete the same lines already included in the code.
              Remember that the sketch is based on mysensor library 1.5.4 it is not converted to 2.0 yet.
              Hope it helps.
              • Juan8tacoJ
                Juan8tacoJ
                Juan8taco
                Thank you,
                I found those missing files and uses the mysensor library 1.5.4 but after I put all the files it asked for I got this odd message. I was looking for the error but had no luck. It says that "was not declared in this scope". Did you happened to run into this issue?
                0_1479706500439_upload-81042e07-857f-48cb-aef0-f62af70f2189
                  mortommy
                  Have you cleaned the folder MySensor within the folder libraries before to copy the 1.5.4 one?
                  • pentti12P
                    pentti12P
                    pentti12
                    Hello
                    I got lot of errors during the compiling stage. I tried to use older MySensors 1.5.4 library and Arduino 1.5.7 IDE. My question is, how to install correct MySensors library and not use anything else?
                      mortommy
                      Delete the MySensors folder in libraries and download it again.
                      • pentti12P
                        pentti12P
                        pentti12
                        Now I downloaded Arduino IDE 1.6.5.zip, then I extracted it into C:/tools folder. Then I deleted everything from the library folder. Then I started Arduino IDE and I added MySensors-1.5.4.zip library. IDE reported that this file does not contain valid library. I closed IDE. So I unzipped MySensors-1.5.4.zip library directly into library folder. Then I started again IDE and checked that IDE can see MySensors-1.5.4 library. I opened MySensorDioder_133.ino and tried to compile it.
                        Still got the following error:
                        MySensorDioder_133.ino:38:30: fatal error: MyTransportNRF24.h: No such file or directory
                        compilation terminated.
                        How to continue?
                        • pentti12P
                          pentti12P
                          pentti12
                          Mortommy: Can you change your sketch so that it support MySensors 2.0 library?
                            mortommy
                            Hi @pentti12 ,
                            please find the sketch 2.0.0 in the project. I couldn't test it yet, I have converted it following the guidance and I just verified that it compiles successfully.
                            • pentti12P
                              pentti12P
                              pentti12
                              Sorry, but the compiler found a missing library file:
                              MyTransportNRF24.h
                              MySensors library 2.0 has MyTransportNRF24.cpp only
                              • pentti12P
                                pentti12P
                                pentti12
                                Hi
                                I changed my Arduino IDE 1.6.11 using the MySensors development library v2.1.0-beta. Now the compiling went OK. I will continue with that. It will take few days before I have more info about how things went with actual hardware.
                                • pentti12P
                                  pentti12P
                                  pentti12
                                  I tested this latest sketch in my actual hardware (Arduino Mega + Proto shield with additionla components + Ikea Dioder control board). I cannot get system working, nothing happens when I press UP, DOWN buttons. Led-lights stay ON after power up.
                                  I also tested to compile your sketch with Arduino IDE and MySensors Library V2.0.0. Compiling went OK, no progress with actual hardware.
                                  How can I test step by step what is happening during startup?
                                  • pentti12P pentti12
                                    mortommy
                                    @pentti12 ,
                                    add the line
                                    at the begging of the sketch so via Serial Monitor you'll be able to see the messages pushed by the commands println. You can add other println commands in other point to see the steps covered.
                                    • pentti12P
                                      pentti12P
                                      pentti12
                                      OK, I added the line and now I get:
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      So I have to check my radio-module or replace it with new one. I will continue ...
                                        mortommy
                                        ok, something is definitely wrong with the radio module. Can you check the connection according to this page?
                                        • pentti12P
                                          pentti12P
                                          pentti12
                                          I changed my Radio-module to new one. Does not help. So I have to check my wiring on prototype board.
