  3. 💬 MySensor Dioder (Ikea)
contest2017diodermysensorshuergbledtrimmerarduinoikea
41 Posts 10 Posters 19.5k Views 10 Watching
  • Juan8tacoJ
    Juan8tacoJ
    Juan8taco
    I was using your code from MySensorDioder_133.ino
    I downloaded the library from https://github.com/mysensors/MySensors
    I tried to run the code but I got a error message saying no such file located.
    These were the two files that couldn't be found
    MyTransportNRF24.h
    MySensor.h
    I was wondering if you had the same issues when you were working on the code?
      mortommy
      wrote on last edited by mortommy
      yes it happens sometimes. Try to import the library by Arduino IDE (Sketch -> Include Library -> MySensors). You'll have in the sketch two new lines:
      #include <MyConfig.h>
      and you can delete the same lines already included in the code.
      Remember that the sketch is based on mysensor library 1.5.4 it is not converted to 2.0 yet.
      Hope it helps.
      • Juan8tacoJ
        Juan8tacoJ
        Juan8taco
        Thank you,
        I found those missing files and uses the mysensor library 1.5.4 but after I put all the files it asked for I got this odd message. I was looking for the error but had no luck. It says that "was not declared in this scope". Did you happened to run into this issue?
        0_1479706500439_upload-81042e07-857f-48cb-aef0-f62af70f2189
          mortommy
          Have you cleaned the folder MySensor within the folder libraries before to copy the 1.5.4 one?
          • pentti12P
            pentti12P
            pentti12
            Hello
            I got lot of errors during the compiling stage. I tried to use older MySensors 1.5.4 library and Arduino 1.5.7 IDE. My question is, how to install correct MySensors library and not use anything else?
              mortommy
              Delete the MySensors folder in libraries and download it again.
              • pentti12P
                pentti12P
                pentti12
                Now I downloaded Arduino IDE 1.6.5.zip, then I extracted it into C:/tools folder. Then I deleted everything from the library folder. Then I started Arduino IDE and I added MySensors-1.5.4.zip library. IDE reported that this file does not contain valid library. I closed IDE. So I unzipped MySensors-1.5.4.zip library directly into library folder. Then I started again IDE and checked that IDE can see MySensors-1.5.4 library. I opened MySensorDioder_133.ino and tried to compile it.
                Still got the following error:
                MySensorDioder_133.ino:38:30: fatal error: MyTransportNRF24.h: No such file or directory
                compilation terminated.
                How to continue?
                • pentti12P
                  pentti12P
                  pentti12
                  Mortommy: Can you change your sketch so that it support MySensors 2.0 library?
                    mortommy
                    Hi @pentti12 ,
                    please find the sketch 2.0.0 in the project. I couldn't test it yet, I have converted it following the guidance and I just verified that it compiles successfully.
                    • pentti12P
                      pentti12P
                      pentti12
                      Sorry, but the compiler found a missing library file:
                      MyTransportNRF24.h
                      MySensors library 2.0 has MyTransportNRF24.cpp only
                      • pentti12P
                        pentti12P
                        pentti12
                        Hi
                        I changed my Arduino IDE 1.6.11 using the MySensors development library v2.1.0-beta. Now the compiling went OK. I will continue with that. It will take few days before I have more info about how things went with actual hardware.
                        • pentti12P
                          pentti12P
                          pentti12
                          I tested this latest sketch in my actual hardware (Arduino Mega + Proto shield with additionla components + Ikea Dioder control board). I cannot get system working, nothing happens when I press UP, DOWN buttons. Led-lights stay ON after power up.
                          I also tested to compile your sketch with Arduino IDE and MySensors Library V2.0.0. Compiling went OK, no progress with actual hardware.
                          How can I test step by step what is happening during startup?
                          • pentti12P pentti12
                            mortommy
                            @pentti12 ,
                            add the line
                            at the begging of the sketch so via Serial Monitor you'll be able to see the messages pushed by the commands println. You can add other println commands in other point to see the steps covered.
                            • pentti12P
                              pentti12P
                              pentti12
                              OK, I added the line and now I get:
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              !TSM:RADIO:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              So I have to check my radio-module or replace it with new one. I will continue ...
                                mortommy
                                ok, something is definitely wrong with the radio module. Can you check the connection according to this page?
                                • pentti12P
                                  pentti12P
                                  pentti12
                                  I changed my Radio-module to new one. Does not help. So I have to check my wiring on prototype board.
                                  • pentti12P
                                    pentti12P
                                    pentti12
                                    Wiring was OK, but 10uF elko is missing from the 3.3V supply. I have only 440nF capasitor at the moment. This seems to be too small value. I will have 10uF elko on next monday available. So project will take a break.
                                    • pentti12P
                                      pentti12P
                                      pentti12
                                      I added 10uF capasitor between VCC and GND pins of the radio module. I also added #define MY_DEBUG_VERBOSE_RF24 line into sketch. I got the following response:
                                      TSM:INIT
                                      RF24:write register, reg=0, value=14
                                      RF24:write register, reg=3, value=3
                                      RF24:write register, reg=4, value=95
                                      RF24:write register, reg=5, value=76
                                      RF24:write register, reg=6, value=39
                                      RF24:read register, reg=6, value=255
                                      RF24:read register, reg=5, value=255
                                      RF24:Sanity check failed: configuration mismatch! Check wiring, replace module or non-P version
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      RF24:write register, reg=0, value=12
                                      RF24:power down
                                      I have changed the radio module to new one without success. So there must be some other reason why this sketch does not work in my hardware. Any ideas?
                                        mortommy
                                        Which module are you using? if it is NRF24L01+ be sure it is the "plus" version.
                                        • pentti12P
                                          pentti12P
                                          pentti12
                                          At least I have ordered nRF24L01+ versions. And I use them on other MySensors node and they are working OK.
