  3. using interrupt - cant back to void loop
7 Posts 3 Posters 2.0k Views 3 Watching
  • A
    afick
    I'm checking some sensors in some time period:
    unsigned long currentMillis_gas = millis();
    unsigned long currentMillis_temp = millis();
    if (currentMillis_temp - previousMillis_temp >= interval) {
    check_temp();
    check_gas();
    check_light();
    previousMillis_temp = currentMillis_temp;
    All working fine.
    But i have also PIR sensor.
    To catch PIR status I'm using interrupt
    attachInterrupt(digitalPinToInterrupt(2), check_pir, CHANGE);
    All works fine - except one think.
    When I call function check_pir() using interrupt, program is not able to back (after finishing function check_pir()) to running void loop.
    Its like program jump to check_pir() and stay there for ever....
    Any idea what im doing wrong ?
    mfalkviddM YveauxY 2 Replies Last reply
    • A afick
      check_temp();
      check_gas();
      check_light();
      All working fine.
      @afick would you mond posting the code for the check_pir function? That would help a lot when trying to figure out why it is wrong.
      Also, please use thr auto-format function (ctrl/cmd+T) in the Arduino IDE. That will make the code much easier to read, for yourself and everyone else.
      • A
        afick
        check_pir is standard function created from mysensors example (motion)
        void check_pir()
         Serial.println("check  PIR");
            // Read digital motion value
          Serial.println(tripped);
        • A afick
          void check_pir()
          @afick that code is supposed to be in the loop. It is not supposed to be an interrupt handler. Interrupt handlers can not interact with Serial and they can not call the MySensors send function.
          See the section "About Interrupt Service Routines" at https://www.arduino.cc/en/Reference/attachInterrupt
          • A afick
            check_temp();
            check_gas();
            check_light();
            All working fine.
            @afick please post your whole sketch first, otherwise we won't be able to help.
            • A
              afick
              A little bit messy :>
                 REVISION HISTORY
                 Version 1.0 - Henrik Ekblad
                 DESCRIPTION
                 Motion Sensor example using HC-SR501
                 http://www.mysensors.org/build/motion
              // Enable debug prints
              //pir================================================================================================================
              #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
              #define CHILD_ID 40   // Id of the sensor child
              // Initialize motion message
              bool lasttripped;
              //gas================================================================================================================
              #define   CHILD_ID_MQ                   43
              /************************Hardware Related Macros************************************/
              #define   MQ_SENSOR_ANALOG_PIN         (4)  //define which analog input channel you are going to use
              #define         RL_VALUE                     (5)     //define the load resistance on the board, in kilo ohms
              #define         RO_CLEAN_AIR_FACTOR          (9.83)  //RO_CLEAR_AIR_FACTOR=(Sensor resistance in clean air)/RO,
              //which is derived from the chart in datasheet
              /***********************Software Related Macros************************************/
              #define         CALIBARAION_SAMPLE_TIMES     (50)    //define how many samples you are going to take in the calibration phase
              #define         CALIBRATION_SAMPLE_INTERVAL  (500)   //define the time interal(in milisecond) between each samples in the
              //cablibration phase
              #define         READ_SAMPLE_INTERVAL         (50)    //define how many samples you are going to take in normal operation
              #define         READ_SAMPLE_TIMES            (5)     //define the time interal(in milisecond) between each samples in
              //normal operation
              /**********************Application Related Macros**********************************/
              #define         GAS_LPG                      (0)
              #define         GAS_CO                       (1)
              #define         GAS_SMOKE                    (2)
              /*****************************Globals***********************************************/
              //VARIABLES
              float Ro = 10000.0;    // this has to be tuned 10K Ohm
              int val = 0;           // variable to store the value coming from the sensor
              float valMQ = 0.0;
              float lastMQ = 0.0;
              float           LPGCurve[3]  =  {2.3, 0.21, -0.47}; //two points are taken from the curve.
              //with these two points, a line is formed which is "approximately equivalent"
              //to the original curve.
              //data format:{ x, y, slope}; point1: (lg200, 0.21), point2: (lg10000, -0.59)
              float           COCurve[3]  =  {2.3, 0.72, -0.34};  //two points are taken from the curve.
              //data format:{ x, y, slope}; point1: (lg200, 0.72), point2: (lg10000,  0.15)
              float           SmokeCurve[3] = {2.3, 0.53, -0.44}; //two points are taken from the curve.
              //data format:{ x, y, slope}; point1: (lg200, 0.53), point2:(lg10000,-0.22)
              MyMessage msg_gas(CHILD_ID_MQ, V_LEVEL);
              unsigned long interval_gas = 10000; // sprawdzanie czasu dla gazu
              //light
              #define CHILD_ID_LIGHT 44
              #define LIGHT_SENSOR_ANALOG_PIN 2
              MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
              int lastLightLevel;
              //dht================================================================================================================
              #define CHILD_ID_HUM 41
              #define CHILD_ID_TEMP 42
              #define HUMIDITY_SENSOR_DIGITAL_PIN 6
              DHT dht;
              float lastTemp;
              float lastHum;
              boolean metric = true;
              unsigned long previousMillis_temp = 0;
              const long interval = 10000;
                //gas
                Ro = MQCalibration(MQ_SENSOR_ANALOG_PIN);         //Calibrating the sensor. Please make sure the sensor is in clean air
              void presentation()  {
                //dht
                present(CHILD_ID_HUM, S_HUM);
                //pir
                sendSketchInfo("Piwnica przejscie", "0.3");
                present(CHILD_ID, S_MOTION);
                //gas
                present(CHILD_ID_MQ, S_AIR_QUALITY);
                //light
                  check_temp();
                  check_gas();
                  check_light();
              void check_light()
                int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23;
                Serial.println(lightLevel);
                  send(msgLight.set(lightLevel));
                  lastLightLevel = lightLevel;
              void check_pir()
                send(msg.set(tripped ? "1" : "0")); // Send tripped value to gw
              void check_temp()
                if (isnan(temperature)) {
                  lastTemp = temperature;
                  if (!metric) {
              #ifdef MY_DEBUG
                  Serial.print("T: ");
                if (isnan(humidity)) {
                  lastHum = humidity;
              #ifdef MY_DEBUG
                  Serial.print("H: ");
                  Serial.println(humidity);
              void check_gas()
                uint16_t valMQ = MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN) / Ro, GAS_CO);
                Serial.println(val);
                Serial.print("LPG:");
                Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN) / Ro, GAS_LPG) );
                Serial.print( "ppm" );
                Serial.print("    ");
                Serial.print("CO:");
                Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN) / Ro, GAS_CO) );
                Serial.print("    ");
                Serial.print("SMOKE:");
                Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN) / Ro, GAS_SMOKE) );
                Serial.print("\n");
                if (valMQ != lastMQ) {
                  send(msg_gas.set((int)ceil(valMQ)));
                  lastMQ = ceil(valMQ);
              float MQResistanceCalculation(int raw_adc)
                return ( ((float)RL_VALUE * (1023 - raw_adc) / raw_adc));
              /***************************** MQCalibration ****************************************
                Input:   mq_pin - analog channel
                Output:  Ro of the sensor
                Remarks: This function assumes that the sensor is in clean air. It use
                       MQResistanceCalculation to calculates the sensor resistance in clean air
                       and then divides it with RO_CLEAN_AIR_FACTOR. RO_CLEAN_AIR_FACTOR is about
                       10, which differs slightly between different sensors.
              float MQCalibration(int mq_pin)
                int i;
                float val = 0;
                for (i = 0; i < CALIBARAION_SAMPLE_TIMES; i++) {      //take multiple samples
                  val += MQResistanceCalculation(analogRead(mq_pin));
                  delay(CALIBRATION_SAMPLE_INTERVAL);
                val = val / CALIBARAION_SAMPLE_TIMES;                 //calculate the average value
                val = val / RO_CLEAN_AIR_FACTOR;                      //divided by RO_CLEAN_AIR_FACTOR yields the Ro
                //according to the chart in the datasheet
                return val;
              /*****************************  MQRead *********************************************
                Output:  Rs of the sensor
                Remarks: This function use MQResistanceCalculation to caculate the sensor resistenc (Rs).
                       The Rs changes as the sensor is in the different consentration of the target
                       gas. The sample times and the time interval between samples could be configured
                       by changing the definition of the macros.
              float MQRead(int mq_pin)
                int i;
                float rs = 0;
                for (i = 0; i < READ_SAMPLE_TIMES; i++) {
                  rs += MQResistanceCalculation(analogRead(mq_pin));
                  delay(READ_SAMPLE_INTERVAL);
                rs = rs / READ_SAMPLE_TIMES;
                return rs;
              /*****************************  MQGetGasPercentage **********************************
                Input:   rs_ro_ratio - Rs divided by Ro
                       gas_id      - target gas type
                Output:  ppm of the target gas
                Remarks: This function passes different curves to the MQGetPercentage function which
                       calculates the ppm (parts per million) of the target gas.
              int MQGetGasPercentage(float rs_ro_ratio, int gas_id)
                if ( gas_id == GAS_LPG ) {
                  return MQGetPercentage(rs_ro_ratio, LPGCurve);
                } else if ( gas_id == GAS_CO ) {
                  return MQGetPercentage(rs_ro_ratio, COCurve);
                } else if ( gas_id == GAS_SMOKE ) {
                  return MQGetPercentage(rs_ro_ratio, SmokeCurve);
                return 0;
              /*****************************  MQGetPercentage **********************************
                       pcurve      - pointer to the curve of the target gas
                Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
                       of the line could be derived if y(rs_ro_ratio) is provided. As it is a
                       logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
                       value.
              int  MQGetPercentage(float rs_ro_ratio, float *pcurve)
                return (pow(10, ( ((log(rs_ro_ratio) - pcurve[1]) / pcurve[2]) + pcurve[0])));
              • A afick
                   REVISION HISTORY
                   DESCRIPTION
                bool lasttripped;
                //normal operation
                #define         GAS_LPG                      (0)
                #define         GAS_CO                       (1)
                //VARIABLES
                float valMQ = 0.0;
                float lastMQ = 0.0;
                //light
                int lastLightLevel;
                DHT dht;
                float lastTemp;
                float lastHum;
                  //gas
                  //dht
                  //pir
                  //gas
                  //light
                    check_temp();
                    check_gas();
                    check_light();
                void check_light()
                void check_pir()
                void check_temp()
                    if (!metric) {
                #ifdef MY_DEBUG
                    lastHum = humidity;
                #ifdef MY_DEBUG
                void check_gas()
                  Serial.print("    ");
                  Serial.print("    ");
                  Serial.print("\n");
                  int i;
                  float val = 0;
                  return val;
                  int i;
                  float rs = 0;
                  return rs;
                  return 0;
                         value.
                @afick Sorry for my request for the full sketch -- for some reason I only saw your first post.
                Anyway, @mfalkvidd is right, you should not access the MySensors library (e.g. send messages) from an interrupt handler. That will certainly mess up things.
                What you could do is set e.g. a flag from the interrupt handler and check in the loop() function if this flag has been set. If so, send a message and clear the flag.
                E.g. (untested):
                static volatile bool pirChanged = false;
                static volatile bool pirTripped;
                void check_pir()
                  pirTripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                  pirChanged = true;
                  // .. your old code ..
                  if (pirChanged)
                    send(msg.set(pirTripped ? "1" : "0"));   // Send tripped value to gw
                    pirChanged = false;
