716 Posts 111 Posters 703.2k Views 93 Watching
  • ChrisWC ChrisW
    @dbemowsk , yes I am using the 3.3 nano.
    I´m using 2 regular AA batteries 1,5 V. I am measuring on VCC for radio, which should be boosted to 3.3V.
    VCC on the left pin layout is 3.3, the 3.3-pin is same as battery.
    Booster output is 3.3V.
    I was unaware of the need for voltage regulator to the radio - since I´m going with 3.3 all the way I never realized this. That´s probably the culprit right there.
    I´ll try your suggestion tomorrow and see if it works out. Thank you for your time.
    @sundberg84 , det är OK, det är inte mitt förstaspråk heller.. ;)
    Tack för ett bra nybörjarpaket - väldigt enkelt att få ihop en bra hobbysensor!
    Jag misstänker att det är som dbemowsk säger - att jag skulle haft en booster till radion också.
    sundberg84S
    sundberg84S
    #234
    @ChrisW - Hi! (Writing in english so all can understand, även om det inte behövs :) )
    When you are using 3.3v pro mini and booster with BAT jumper it should not be 3.3v over the radio. This is because the booster generates alot of noice and the radio can handle down to 1.9v without any issues. This is how the PCB was designed due to learning by doing. The radio uses what comes raw from the batteries without booster. Evreything else on the PCB is boosted.
    If you are using 2xAA you should be able to run the it beteen 1.9V and 3V (which is most of the batteries since the voltage drops pretty fast below that).
    • ChrisWC ChrisW
      dbemowskD
      dbemowskD
      #235
      That's what I was trying to explain. You do not need the regulator, but the board is set up to use one in the event that you might use a 5 volt nano. That is why I mentioned adding the jumper wire. That is to jumper the input and output pins of where the regulator would normally go IF you were using a 5 volt arduino.
      regulator jumper placement
      EDIT:
      @sundberg84 I think we were typing messages at the same time. I did not realize that the radio could run at that low of a voltage. My method jumps the boosted 3.3 volts over to the radio. Shouldn't adding the 0.1uf and 10uf caps attenuate the noise from the booster when jumping the regulator pins?
      • dbemowskD dbemowsk
        EDIT:
        sundberg84S
        sundberg84S
        @dbemowsk - What I know the booster generates ALOT of noice and are really dependent of the quality of the booster. They are expensive as it is and if you buy the china ones its a big risk you get disturbance to the radio even if you use caps!
        I would not recommend to jump the boosted voltage to the radio. It might work in some cases (depending on the hardware) but there is a risk doing it.
        Some boosters even generate so much noice that even if you havent it connected directly to the radio it doesnt work.
          Matt
          Hiya Sundberg
          I think Im having boost converter noise issues from a dodgy ebay batch.
          I have soldered up 11 of your boards to date and two are real flaky.
          Aside from swapping out the boost converter is there a way to reduce the noise? 0.1UF cap across the radio power/gnd pins? Or across the GND and output pins of the booster itself?
          They are kind of expensive so dont want to bin them if I can bodge up a fix...
          Matt
          • M Matt
            Hiya Sundberg
            Matt
            sundberg84S
            sundberg84S
            @Matt - Hi!
            This issues has been addressed in the thread before, see if you can find it.
            I have had luck with a 0,1 ceramic cap on the booster from out to GND. There is more advances methods to reduce noice which I haven't tried but you can read about them above in the thread somewhere. As you said they are a bit pricey but some boards have I just not been able to fix due to really bad booster and scrapped.
            • sundberg84S sundberg84
              @Matt - Hi!
              Matt
              @sundberg84 Hiya yep found it, starts with your post 30th June 2016.
              To be honest its a bit over my head, inductors. ferrite beads etc. A picture of what to solder where would help.
              I did try to 0.1uf cap across OUT and GND but the things still only work for a minute then go silent.
              I will desolder existing booster then add a jumper from vin to vout to see how stable they are with a good solid battery supply.
              If they are reliable I will order some more boosters, but it seems a bit hit and miss as to reliability...
              Unless someone can post a pic or explain (for dummies) how to filter the booster effectively?
              I should pull out my scope, which involves tidying my workbench, not a task I undertake lightly....
              Matt
              • M Matt
                Matt
                Matt
                Have been doing some investigation of the boost converters, just with my DMM, which doesnt have frequency function.
                However it can measure ac ripple. On the working boosters there is a ripple amplitude of around 0.02V. On the flaky ones its anything from 0.03 to 0.05V. So this makes it easy for me to test to converters before comitting them with solder.
                • alexsh1A alexsh1
                  @sundberg84 typically, I try to add the lc-filter to the booster as some of them are very noisy. This is very simple - 3.3µH Axial lead inducter and a large 220µF capacitor (I use the SMD version). This helps to smooth any ripple effect.
                  Matt
                  @alexsh1 I know its a bit historical but could you post a pic or explain how you connect the lc-filter to the boost converter? Having issues here, 0.1uf cap didnt help...
                  Thanks....
                  • M Matt
                    Thanks....
                    sundberg84S
                    sundberg84S
                    @Matt - It was some time ago now i experienced with this... but something like this:
                    0_1480492998281_1.JPG and to be hones maybe it was from ground (middle pin) to vin (left pin)... try both, cant do any harm. As I said - in most cases it works... I buy 10 and 10 batches and around 7-8 works good enough.
                      Matt
                      @sundberg84 thanks, that is how I have soldered the 0.1uF cap but it hasnt improved things.
                      I was hoping @alexsh1 would be happy to chip in here and show me how to solder the 220uf cap and 3.3uH choke?
                      AWIA 1 Reply Last reply
                      • M Matt
                        AWIA
                        AWIA
                        AWI
                        @Matt Take a look at link text
                        • AWIA AWI
                          Matt
                          @AWI hey thanks! I especially like this
                          Although.... Something tells me L should be in series on Vout, sureley if it was between BAT and 3.3 voltage weird things would happen....
                          Might be time to finally try to figure out how to use that cheap old scope in my garage...
                          Also, as it happens, am just getting in to RC stuff (well for my son, but you know...)
                          • sundberg84S
                            sundberg84S
                            #246
                            I have now updated this to Revision 9!
                            • Bigger mounting holes 2.5mm
                            • IRQ Jumper from Radio. This makes this trace disabled and D2 can be used for interupts unless jumper is connected.
                            • BAT and REG jumpers changed positions for better tracing.
                            • MysX 2,6
                            • Text on voltage regulater (Vout/Vin/Gnd)
                            • Bug with G on CAP now on the right side.
                            • GND and VCC swapped - so you could use a 2 pin block for GND/RAW as well.
                            • Capacitor to filter the booster output more (optional)
                            Please wait for PCB house to update to new gerber files before ordering (It should say M.Rev 5 (Manufacturer rev 5) for lastest revision when selecting PCB house)
                            I have not yet tested this rev... but no major changes so it should be pretty safe.
                            If you want to be 100% sure, download and order Rev 8.
                            scurbS M 2 Replies Last reply
                              • MysX 2,6
                              scurbS
                              scurbS
                              scurb
                              @sundberg84
                              Been a while since I made sensors now - but so what.. ordered 10 pcs in order to try it out :)
                                • MysX 2,6
                                Matt
                                  Wait, what?
                                  Missed this. I am using v8 boards. Cant seem to figure out how to search individual threads and 247 posts is a bit much to go through tonight. Will get the DMM out and try to figure it out, but what cap is labelled wrong?
                                Matt
                                • M Matt
                                    Wait, what?
                                  Matt
                                  sundberg84S
                                  sundberg84S
                                  @Matt - check the images: https://forum.mysensors.org/topic/2740/easy-newbie-pcb-for-mysensors/197
                                    Matt
                                    @sundberg84 cheers, no problem on my boards, multimeter confirms this...
                                      Matt
                                      wrote on last edited by Matt
                                      #251
                                      Hey I recently got a batch of ten pro 3.3v pro minis from ebay, I removed vreg + LED on two of them and they no longer work... Well, I cant upload. I have done this low power mod heaps of times, the boards are different from ones Ive seen before, has anyone here had this problem? Or am I just a problem magnet? Have yet to solder programming headers on a non modified board to see if its a bad batch... Maybe main power is routed through the vreg or LED regardless or something? I dont have the eyesight or mag abilities to play around...
                                      0_1482260686279_upload-22833514-2461-4622-9259-2d9e9fa6ed9b
                                      sundberg84S ferroF 2 Replies Last reply
                                      • M Matt
                                        sundberg84S
                                        sundberg84S
                                        @Matt - I have killed some when i tried to remove them led/reg with a knife (ie cutting). So i began desoldering them which workes nice. I have killed one because of a short circuit and one because i damaged the pad.
                                        Could be as you say another routing if its a new clone. Removing the led/resisotor led to being with should not affect this as it most likely only goes to ground.
                                          Matt
                                          #253
                                          @sundberg84
                                          Thanks for your reply. Given I've done six or seven to date without issue I am somewhat skeptical that I have borked two in a row. I use a fine tip hakko iron, solder sucker, wick + a tiny wee flathead screwdriver for the butchery.
                                          Maybe its time I invested in a magnifying glass heh.
                                          Is it necessary to remove the vreg as I would think its not doing anything anyway as we are powering via VCC rather than raw?
