  3. Geiger Counter
Geiger Counter
16 Posts 4 Posters 12.5k Views 4 Watching
    Cool! I also live near a plant but it has been closed for 10+ years unfortunately (?).
    • FotoFieberF FotoFieber
      As I live near a nuclear power plant, I thought it would be a good idea to have a radioactivity sensor:
      Components used:
      Geiger Counter Kit:
      http://www.ebay.com/itm/321499888801?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
      An SBM-20 tube:
      http://www.ebay.com/itm/280865770387?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
      And MySensors with this sketch:
      #define LOG_PERIOD 60000     //Logging period in milliseconds, recommended value 15000-60000.
      #define MAX_PERIOD 60000    //Maximum logging period
      unsigned long counts;             //variable for GM Tube events
      unsigned long cpm;                 //variable for CPM
      unsigned int multiplier;             //variable for calculation CPM in this sketch
      unsigned long previousMillis;      //variable for time measurement
      unsigned long timeReceived = 0;
      unsigned long timeRequested = 0;
      // Initialize motion message
      MyMessage msg(CHILD_ID, V_VAR1);
        wdt_enable(WDTO_8S);
        gw.begin();
        gw.sendSketchInfo("Geiger Sensor", "1.1");
        wdt_reset();
        gw.present(CHILD_ID, S_ARDUINO_NODE);
        // Geiger initialise
        counts = 0;
        cpm = 0;
        multiplier = MAX_PERIOD / LOG_PERIOD;      //calculating multiplier, depend on your log period
        pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the geiger sensor digital pin as input
        digitalWrite(DIGITAL_INPUT_SENSOR, HIGH);                                 // turn on internal pullup resistors, solder C-INT on the PCB
        attachInterrupt(1, tube_impulse, FALLING);  //define external interrupts
        wdt_reset();
        if (currentMillis - previousMillis >= LOG_PERIOD) {
          cpm = counts * multiplier;
          gw.send(msg.set(cpm));
          counts = 0;
      void tube_impulse() {              //procedure for capturing events from Geiger Kit
        counts++;
      I get cpm and in Node-Red I calculate microsievert/per hour:
      [{"id":"ba386057.845d3","type":"mqtt-broker","broker":"192.168.92.4","port":"1883","clientid":"NodeRed"},{"id":"75acf1fb.8a531","type":"mqtt in","name":"Geiger CPM","topic":"MyMQTT/48/1/V_VAR1","broker":"ba386057.845d3","x":146,"y":52,"z":"d1478aa9.2eb878","wires":[["d17bbe2a.2e844"]]},{"id":"d17bbe2a.2e844","type":"function","name":"Nach uSievert umrechnen","func":"cpm = msg.payload;\n\n// für SBM 20 Röhre\n// http://cs.stanford.edu/people/nick/geiger/\nusv = cpm * 0.0057;\n\nmsg.topic = 'NodeRed/Geiger/usv';\nmsg.payload = usv;\n\nreturn msg;","outputs":1,"valid":true,"x":377,"y":52,"z":"d1478aa9.2eb878","wires":[["c53927ba.3ac6d8"]]},{"id":"c53927ba.3ac6d8","type":"mqtt out","name":"","topic":"","qos":"","retain":"","broker":"ba386057.845d3","x":647,"y":52,"z":"d1478aa9.2eb878","wires":[]}]```
      SparkmanS
      SparkmanS
      Sparkman
      wrote on last edited by Sparkman
      @FotoFieber Thanks for posting. I have this Geiger counter kit on its way to me: https://sites.google.com/site/diygeigercounter/software-features along with an sbm-20. I plan to build the outside sending unit like this: https://sites.google.com/site/diygeigercounter/wireless-monitoring along with a custom shield that'll hold the NRF24 with PA/LNA and a few other components to control the power to the geiger counter and the NRF24. I won't need the indoor display station that's described on the site as I'm using the MySensors gateway and HomeSeer instead.
      Al
      • FotoFieberF
        FotoFieberF
        FotoFieber
        Here is the update for mysensors 2.0
        #define SKETCH_NAME "Geiger Sensor"
        #define SKETCH_MAJOR_VER "2"
        #define SKETCH_MINOR_VER "0"
        #define MY_RF24_CHANNEL  13
        #define MY_RF24_BASE_RADIO_ID ((uint64_t)0xF8A813FC09CL)
          counts = 0;
          cpm = 0;
          wdt_reset();
          wdt_reset();
          wait(500);
          wdt_reset();
          wait(500);
          wdt_reset();
            send(msg.set(cpm));
            counts = 0;
          counts++;
        @Hek
        What do you think about a sensor type geiger counter with cpm and microsievert? V_VAR1 for cpm ist not cool :cool:
        alexsh1A 1 Reply Last reply
          Haha, not cool. :D What? Radioactivity is always cool!
          Well, we still use VAR_1 for pulses in EnergyMeterPulseSensor, which probably is a bit more commonly used. A generic V_PULSECOUNT perhaps..On the EnergyMeterPulseSensor is it only used for saving a state in case of power failure. Is it the same use-case here?
          • FotoFieberF
            FotoFieberF
            FotoFieber
            @hek
            counts per minute:
            https://en.wikipedia.org/wiki/Counts_per_minute
            A generic V_PULSECOUNT would be fine.
            The microsievert is the interesting physical unit you can derive from the cpm. The calculation is depending from the tube you use.
            In my case:
            usv = cpm * 0.0057;
            What about a type S_RADIOACTIVITY?
            Here the natural radioactivity in my garage:
            The sum of the doses you get over time is the interesting number:
            https://en.wikipedia.org/wiki/Sievert
              S_RADIOACTIVITY sounds like useful new device type.
              When reading up a bit more. Wouldn't it be better to send in radiation level (uSv/hr) as V_LEVEL. We try to re-use V_LEVEL between device-types for SI-levels of any kind.
              I have started this a new issue here to discuss it further:
              https://github.com/mysensors/MySensors/issues/567
              • alexsh1A
                alexsh1A
                alexsh1
                Excellent - thank you guys. I have been looking for an addition to my weather station.
                I think I'll place an order for this one: http://www.ebay.co.uk/itm/182166337823?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                This is 100% Japanese built Arduino based Geiger counter.
                • alexsh1A
                  alexsh1A
                  alexsh1
                  @hek Henrik, where do you stand with S_RADIOACTIVITY please?
                  Unfortunately, I cannot use S_CUSTOM or any other with Domoticz so has to wait for a S_RADIOACTIVITY being implemented with (1) MySensors (2) Domoticz.
                  Alex
                    It's just a matter on agreeing on what types/data to send. Please post your input in the issue.
                    alexsh1A 2 Replies Last reply
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @hek The logging software is reporting is as follows every minute:
                      CPS, 2, CPM, 15, uSv/hr, 0.08, SLOW
                      (Please see http://mightyohm.com/blog/2012/02/tutorial-geiger-counter-data-logging/)
                      Therefore, there are four parameters here and I propose to use the following:
                      1. CPS --> ???
                      2. CPM --> ???
                      3. uSv/hr --> S_RADIOACTIVITY (V_LEVEL)
                      4. SLOW/FAST -> S_INFO (V_TEXT)
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        We can keep it simple - CPM and uSv/hr are the two typically reported.
                        Even more simple - knowing CPM we can figure out uSv/hr
                        • alexsh1A alexsh1
                          FotoFieberF
                          FotoFieberF
                          FotoFieber
                          @alexsh1
                          Calculation of uSv/hr based on CPM is dependent of the tube. If we do not implement the calculation in the sketch, it must be done in the controller.
                            @alexsh1
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @FotoFieber my understanding is that all meters are calibrated to either Cs137 or Co60, which is more likely down to the tube. However, I do not understand why we care about the conversion. My geiger meter reports both uSv/hr and CPM and a number of other meters reports exactly the same. If there is any conversion required, it has to be done in the sketch IMHO.
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @hek Any news on this please? I am missing definition for CPS/CPM.
                                  counts = 0;
                                  cpm = 0;
                                  wdt_reset();
                                  wdt_reset();
                                  wait(500);
                                  wdt_reset();
                                  wait(500);
                                  wdt_reset();
                                    send(msg.set(cpm));
                                    counts = 0;
                                  counts++;
                                @Hek
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @FotoFieber Cannot use MyMessage msg(CHILD_ID, V_VAR1); as this is not supported by Domoticz.
