  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.6k Views 37 Watching
  • mikeSM
    mikeSM
    mikeS
    I built this node but it doesn't seem to work. It shows up in the hardware list of my controller (Domoticz latest stable) as S_Power but no values appear like I was expecting V_WATT, V_KWH etc. Nothing appears under the devices section. Does the sketch need modifying for 2.0 or is it a Domoticz issue? Anybody else got one of these working?
    • mikeSM mikeS
      @mikeS has the sensor sent any values? Domotics does not show anything until the first value has been sent.
      Could you post the log from the sensor and the gateway?
      • mikeSM
        mikeSM
        mikeS
        Sorry please disregard, I got it working, the pot just needed trimming down, it was permanently triggered so not reading pulses. It worked straight away as soon as I did that. I thought the green light on the lm393 was a power indicator as it was always on, not pulsing.
        • mikeSM mikeS
          @mikeS great work, thanks for reporting back
          • mikeSM
            mikeSM
            mikeS
            Like all the nodes and the project in general, it's amazing, but in the space of 24hrs I have turned into a "turn everything off" sort of a guy. I cringed when I suddenly had a log of how much money I was wasting! One thing that's weird is that Domoticz shows 2 devices; usage and meter, the usage one doesn't update at all, but the meter one displays everything you need anyway. It's a bit like the DHT node, in that they show as 3 devices TempHum combined which update nicely; and 2x LacrosseTX which update randomly.
            • Fat FlyF
              Fat FlyF
              Fat Fly
              I do not understand. My boiler is 3KW. https://1drv.ms/i/s!AtuQgBKT8NIPhi4F_I3mPVYW0S9P
              F 1 Reply Last reply
              • Fat FlyF Fat Fly
                F
                F
                flopp
                @Fat-Fly
                I think something is wrong in your code.
                Is the pulse setup correct?
                • miljumeM
                  miljumeM
                  miljume
                  Can someone please explain how the sleep mode works?
                  My sensor works like a charm when sleep mode is "false" but when changing to "true" i get nothing to the GW
                  Exactly the same setup, the only thing I changed is from "false" to "true"
                  • miljumeM miljume
                    F
                    F
                    flopp
                    @miljume
                    Use sleep mode if you have battery for the node.
                    Maybe it need lots of Kwh before sending new data. If you don't use sleep mode it will send watt more often.
                    miljumeM 1 Reply Last reply
                    • F flopp
                      @miljume
                      miljumeM
                      miljumeM
                      miljume
                      @flopp Yes, that was my intention
                      But I wonder how often the sensor send data to the gateway in that mode i.e. how the mechanism works
                      I might not have waited long enough but it would be good to know what "long enough" is
                      • F
                        F
                        flopp
                        wrote on last edited by flopp
                        it need to change 0,02 kWh before sending new value
                        see more information here
                        https://forum.mysensors.org/topic/4727/energy-meter-not-sending-at-expected
                        • F flopp
                          F
                          F
                          flopp
                          • F flopp
                            [[topic:post-is-deleted]]
                            miljumeM
                            miljumeM
                            miljume
                            @flopp Thanks for the link but I still cant get anything in sleep mode
                            Now I have waited for over an hour with simulated blinks approx twice/second but so far the device havent reported one single time!
                            By the way, does anyone know how to reset the value stored in the GW?
                            After some testing the value get's quite high :smiley:
                            • asgardroA
                              asgardroA
                              asgardro
                              Hi. I built this sensor and loaded the example. It appears the sensor registers with my serial gateway and appears in domoticz. The problem is it hasn't updated the value in 24h? Any ideas?
                              • asgardroA asgardro
                                F
                                F
                                flopp
                                @asgardro
                                What does the serial output in arduino says?
                                • asgardroA
                                  asgardroA
                                  asgardro
                                  In the end it displays the watt value and then just hangs. I haven't modified the example at all. I am @ work now but will be able to check again later
                                  • asgardroA
                                    asgardroA
                                    asgardro
                                    Came back from work and checked. it is sending to the gateway the first value and gets displayed in domoticz. then dead.. it appears it does not get the pulse count from the gateway respectively from domoticz. has anyone got this working with domoticz?
                                      F
                                      F
                                      flopp
                                      @asgardro
                                      I am using two of these to DZ.
                                      One has been working perfect for 1,5 month the second I had some problem with initialize after 3 weeks.
                                      • asgardroA
                                        asgardroA
                                        asgardro
                                        would you mind please sharing the sketch? i don't know whats wrong. i even forced it with "bool pcReceived = false" puting it to true. thanks
                                        • asgardroA
                                          asgardroA
                                          asgardro
                                          i do not get Serial.print("Received last pulse count from gw:"); in serial output
                                          F 2 Replies Last reply
