  3. 💬 Wall Socket Insertable Node
rfm69atsha204amysensorsrelaypower supply
77 Posts 21 Posters 34.3k Views 27 Watching
  • PierreStP
    PierreStP
    PierreSt
    Would it be possible for the diameter of the box to be smaller? In Germany the standard wall sockets are 68mm. So 60-65 mm fot the box would be ideal.
    Y 1 Reply Last reply
    • PierreStP PierreSt
      Y
      Y
      yury
      wrote on last edited by yury
      #34
      @PierreSt
      www.aliexpress.com/item/55-22mm-5pcs-LED-ceiling-circular-drive-casing-fire-retardant-PC-power-supply-housing-with-cooling/32643161481.html?spm=2114.13010608.0.72.VRC6ws
      is the smallest. will get them soon. not sure if the thing will fit inside though.
      So far we a bit stuck with our PCBA contractor. Negotiating hard for better prices.
      • Sander TeunissenS
        Sander TeunissenS
        Sander Teunissen
        Any update on your progress ? I am really watching out for this one !
        KoreshK 1 Reply Last reply
        • Sander TeunissenS Sander Teunissen
          KoreshK
          KoreshK
          Koresh
          @Sander-Teunissen Thanks for your attention to this project. There are Chinese national holidays until 8 october. So there are no updates now.
          • J
            J
            jkandasa
            @Koresh This project looks super cool and very small. Thanks to the open hardware. Can you post SMPS transformer design specifications?
            • J
              J
              jacikaas
              Hello, great project! I'm very intrested in it and waiting for testing results :)
              One quick question: in this and also in other your profects with RFM69 you are don't using antenna for it. Is it not necessary, becose in introduction about radios (https://www.mysensors.org/build/connect_radio) there is note:
              IMPORTANT: You MUST attach an antenna to the board. Aside from not working without an antenna, transmitters can be damaged if they transmit without an antenna present.
              So does antenna for RFM69 is necessary?
              • J jacikaas
                KoreshK
                KoreshK
                Koresh
                @jacikaas Thanks for your attention. Of course antenna is necessary, I use 17cm wire as antenna for all projects (so flexible antenna :))
                Unfortunately I was extremely busy last months. I became a father :baby: and I had a rush job with my work projects :worried: . But I hope I will have a little more time. Now I am waiting for the boards for the first relatively large batch of all my projects. I am waiting for the large pack of components too :satisfied: Also I found a reliable pcba partner (I hope). So I really hope to introduce my boards (preassembled) for purchase soon.
                Latest version of this board, for example looks as these screenshots:
                I also have very interesting new modifications of this and other boards (it is secret for now :stuck_out_tongue_winking_eye: , but I will show it soon ).
                • Sander TeunissenS
                  Sander TeunissenS
                  Sander Teunissen
                  I was looking for a gateway for the rfm69 chip. I just learned it is available in different frequencies. On which one of this component operating?
                  tonnerre33T KoreshK 2 Replies Last reply
                    tonnerre33T
                    tonnerre33T
                    tonnerre33
                    @Sander-Teunissen depend which rfm69 you will order. For example i have choosen 868Mhz, that's why i'll choose this frequency for all my nodes and my gateway ;)
                    Sander TeunissenS 1 Reply Last reply
                      KoreshK
                      KoreshK
                      Koresh
                      @Sander-Teunissen
                      315/433/868/915 MHz. I plan to mount 433Mhz for the first batch but it is easy to solder another if it necessary.
                      • Sander TeunissenS
                        Sander TeunissenS
                        Sander Teunissen
                        @Koresh thanks. I guess
                        https://www.openhardware.io/view/102/Wall-Switch-Insertable-Node
                        Will be 433 too then ?
                          KoreshK
                          KoreshK
                          Koresh
                          @Sander-Teunissen Yes. Very soon I hope. This board (switch) contains only 0603 components now (without 0402 components), so it will be avaliable as kit for soldering funs too :wink:
                          12/06/2016	2:47 P.M. Your package is at the clearing agency awaiting final release.
                          It is components package... So I hope I will mount boards soon.
                          • KoreshK Koresh
                            Sander TeunissenS
                            Sander TeunissenS
                            Sander Teunissen
                            @Koresh great! Looking forward to it!
                            • tonnerre33T tonnerre33
                              Sander TeunissenS
                              Sander TeunissenS
                              Sander Teunissen
                              I guess that's true when you do the board yourself.... But I am not tech savvy enough (or too lazy ;-) ) to do the board myself. I hope to buy them from Koresh directly...
                                shabba
                                Any update on this? This would scratch my latest itch! :-)
                                • S shabba
                                  KoreshK
                                  KoreshK
                                  Koresh
                                  Both versions of this board are under intensive testing now. I've tuned it a little these days for working in very cold enveronment (it is very cold now in my country, up to -25-30C).
                                  MiKaM 1 Reply Last reply
                                    shabba
                                    Great - Keep us informed!
                                    • KoreshK Koresh
                                      MiKaM
                                      MiKaM
                                      MiKa
                                      @Koresh
                                      Which type of transformer You are using (tr1)? type or order link?
                                      THX,
                                      MiKa
                                      • PierreStP
                                        PierreStP
                                        PierreSt
                                        Hi Koresh,
                                        Thanks for the last update and congratulations on finishing the design. You mentionned some time earlier that you wanted to sell these (and also CE approval?). Could you tell us the status of this?
                                        Pierre
                                          Hi Koresh,
                                          Pierre
                                          KoreshK
                                          KoreshK
                                          Koresh
                                          @PierreSt Many thanks for you attention to this project. I will add all assembled boards to Ebay next week. My devices successfully passed all safety tests. But unfortunatelly I have no enough resources to complete CE certification yet.
