  3. 💬 Wall Socket Insertable Node
rfm69atsha204amysensorsrelaypower supply
77 Posts 21 Posters 34.3k Views 27 Watching
  • J
    J
    jacikaas
    Hello, great project! I'm very intrested in it and waiting for testing results :)
    One quick question: in this and also in other your profects with RFM69 you are don't using antenna for it. Is it not necessary, becose in introduction about radios (https://www.mysensors.org/build/connect_radio) there is note:
    IMPORTANT: You MUST attach an antenna to the board. Aside from not working without an antenna, transmitters can be damaged if they transmit without an antenna present.
    So does antenna for RFM69 is necessary?
    KoreshK 1 Reply Last reply
    • J jacikaas
      KoreshK
      KoreshK
      Koresh
      @jacikaas Thanks for your attention. Of course antenna is necessary, I use 17cm wire as antenna for all projects (so flexible antenna :))
      Unfortunately I was extremely busy last months. I became a father :baby: and I had a rush job with my work projects :worried: . But I hope I will have a little more time. Now I am waiting for the boards for the first relatively large batch of all my projects. I am waiting for the large pack of components too :satisfied: Also I found a reliable pcba partner (I hope). So I really hope to introduce my boards (preassembled) for purchase soon.
      Latest version of this board, for example looks as these screenshots:
      I also have very interesting new modifications of this and other boards (it is secret for now :stuck_out_tongue_winking_eye: , but I will show it soon ).
      • Sander TeunissenS
        Sander TeunissenS
        Sander Teunissen
        I was looking for a gateway for the rfm69 chip. I just learned it is available in different frequencies. On which one of this component operating?
        tonnerre33T KoreshK 2 Replies Last reply
        • Sander TeunissenS Sander Teunissen
          tonnerre33T
          tonnerre33T
          tonnerre33
          @Sander-Teunissen depend which rfm69 you will order. For example i have choosen 868Mhz, that's why i'll choose this frequency for all my nodes and my gateway ;)
          Sander TeunissenS 1 Reply Last reply
            KoreshK
            KoreshK
            Koresh
            @Sander-Teunissen
            315/433/868/915 MHz. I plan to mount 433Mhz for the first batch but it is easy to solder another if it necessary.
            • Sander TeunissenS
              Sander TeunissenS
              Sander Teunissen
              @Koresh thanks. I guess
              https://www.openhardware.io/view/102/Wall-Switch-Insertable-Node
              Will be 433 too then ?
                KoreshK
                KoreshK
                Koresh
                @Sander-Teunissen Yes. Very soon I hope. This board (switch) contains only 0603 components now (without 0402 components), so it will be avaliable as kit for soldering funs too :wink:
                12/06/2016	2:47 P.M. Your package is at the clearing agency awaiting final release.
                It is components package... So I hope I will mount boards soon.
                • KoreshK Koresh
                  Sander TeunissenS
                  Sander TeunissenS
                  Sander Teunissen
                  @Koresh great! Looking forward to it!
                  • tonnerre33T tonnerre33
                    Sander TeunissenS
                    Sander TeunissenS
                    Sander Teunissen
                    I guess that's true when you do the board yourself.... But I am not tech savvy enough (or too lazy ;-) ) to do the board myself. I hope to buy them from Koresh directly...
                      shabba
                      Any update on this? This would scratch my latest itch! :-)
                      • S shabba
                        KoreshK
                        KoreshK
                        Koresh
                        Both versions of this board are under intensive testing now. I've tuned it a little these days for working in very cold enveronment (it is very cold now in my country, up to -25-30C).
                        MiKaM 1 Reply Last reply
                          shabba
                          Great - Keep us informed!
                          • KoreshK Koresh
                            MiKaM
                            MiKaM
                            MiKa
                            @Koresh
                            Which type of transformer You are using (tr1)? type or order link?
                            THX,
                            MiKa
                            • PierreStP
                              PierreStP
                              PierreSt
                              Hi Koresh,
                              Thanks for the last update and congratulations on finishing the design. You mentionned some time earlier that you wanted to sell these (and also CE approval?). Could you tell us the status of this?
                              Pierre
                              • PierreStP PierreSt
                                Hi Koresh,
                                Pierre
                                KoreshK
                                KoreshK
                                Koresh
                                @PierreSt Many thanks for you attention to this project. I will add all assembled boards to Ebay next week. My devices successfully passed all safety tests. But unfortunatelly I have no enough resources to complete CE certification yet.
                                  shabba
                                  Hi @Koresh - Brilliant! I can't wait to order a whole pile of your boards! :)
                                  Please shout when there are available!
                                  • fisherF
                                    fisherF
                                    fisher
                                    Found it on ebay - is it yours Koresh?
                                    http://www.ebay.com/usr/easysensors
                                    For now there is only Wall Socket insertable node on stock, more boards will come soon I hope
                                    Y 1 Reply Last reply
                                    • fisherF fisher
                                      Y
                                      Y
                                      yury
                                      Hi @fisher yes this is Koresh board. Hope to upload others soon... We did production and testing with him together.
                                      • D
                                        DavidZH
                                        @Koresh I'd like to repeat the question @MiKa asked on Januari 10th; can you share details on the transformer you used? Or a hint on where you got the inspiration for the power supply for the board?
                                        • D DavidZH
                                          KoreshK
                                          KoreshK
                                          Koresh
                                          @DavidZH Sorry for such long delay with this question. I will try to explain it carefully now.
                                          I think it is not possible to buy ready transformer on ali or anywhere else. You can only derive it yourself according to your schematic and produce it at any factory according to your requirements.
                                          This board has flyback power supply so you can use any flyback transformer design guide, or use as similar as possible reference design. I used EBC10010 reference design to produce the required transformer.
                                          The main difficulty is the difference between theoretical transformers and produced transformers, so we should tune our schematic to produced transformer a little. Now I have a small batch of transformers almost all of which are soldered on the boards. When I place an order for the next batch of transformers (may be a larger one), I can who send it to anyone who is interested (of course with a tuned schematic if the next batch is different).
                                          D Z 2 Replies Last reply
