  3. Ethernet Gateway problem
93 Posts 18 Posters 61.5k Views 6 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    It is interesting that you get the W5100 to work with the RF module at all. I cannot have them coexist on the same SPI bus at all, but moving the RF module to a software implemented SPI bus seem to resolve that problem (it introduces other problems but they are believed to be related in other changes in the RF library that were piggy-backed with the introduction of the SW SPI support).
    Here is a thread on the topic: http://forum.mysensors.org/topic/467/ethernet-gateway-troubleshooting-advice
    • J
      J
      jkbrowne
      Hey Dan,
      Just curious, where did you get your Arduino and ethernet board? Is your Arduino a clone or a genuine board from Italy? I'm fighting some issues getting my gateway working and was curious specifically what you're using.
      • Dan S.D
        Dan S.D
        Dan S.
        My Arduino Uno is a genuine board from Italy. I got the Ethernet board from amazon: http://www.amazon.com/gp/product/B00CRX7BI2/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 "ZITRADES Ethernet Shield W5100 Development board For Arduino "
        I wouldn't exactly call it working. It works for a short time. From the symptoms, it appears that both the Ethernet and radio work for a time and then the radio eventually stops working. I no longer receive sensor updates but it appears that Vera keeps communicating with the gateway as indicated by commo lights on the Ethernet board and no Vera error messages.
        • bjornhallbergB
          bjornhallbergB
          bjornhallberg
          wrote on last edited by bjornhallberg
          I have the MQTT sketch (basically the same right?), a clone uno r3 and a clone w5100 shield with a three test sensors reporting data every 10min. Even had a motion sensor sketch completely pummel the gateway with a few hundred messages in a very short time. Does seem to work as intended for me at least. Doesn't show up under device list in the router either though. Same thing with my other Uno+W5100 that I also have connected for my old custom (no mysensors) mailbox alarm, despite it having routines to specifically request and re-request an ip using dhcp, it also usually doesn't show in the list (also running Tomato).
          I can also ping the IP for the MQTT gateway and get a response. Surely there must be a lot of people on the forum that have the ethernet shield working with the vanilla nrf24? This is the first I've heard of this.
          • Dan S.D
            Dan S.D
            Dan S.
            I plugged the sensor into the computer to monitor it. Start the serial gateway and the sensor shows proper commo with the gateway and Vera registers the light value. After a time the gateway stops commo the sensor. Restart the gateway and it starts communicating again. Right now the Ethernet gateway and the sensor have been reliably communicating for about an hour. Am guessing if I had the SPI bus problem it wouldn't work at all or is it that it causes the gateway to randomly lock up like I am experiencing?
            • AnticimexA
              AnticimexA
              Anticimex
              The shield maybe has a HW workaround to handle the SPI issue. I have gotten my GW to work using Ethernet as well, but have not investigated stability. My primary concern for the moment is to make sure the SPI problem is resolved in a good way. Using a soft SPI solution at least works, but I think of it is a last resort.
              • Dan S.D
                Dan S.D
                Dan S.
                Well, the gateway worked fine for an hour and a half, and then it stopped communicating with the sensor. Once that happens, it never recovers by itself. Have to unplug it , plug it back in and reload vera and everything starts working again.
                  And you'we got a cap on radio and tried switching power supply?
                  • Dan S.D
                    Dan S.D
                    Dan S.
                    Yes Have a cap on the radio and even have the radio receiving its 3.3 power from AMS1117 with everything connected to a 1 amp wall wart. It does seem to be a heat/power related problem. I noted that it stays online longer if I give it time to cool down before restarting. I am going to try a different, more capable wall wart.
                    • Dan S.D
                      Dan S.D
                      Dan S.
                      Tried new 2 amp 5v dc power supply. Same thing--after about an hour of receiving and acknowledging sensor messages, stopped responding to the messages. Plugin still appears to be connected to and communicating with Vera via the Ethernet, but no responding to (and probably not hearing) the sensor. My inclination is to blame the sharing of the SPI bus but I have no direct evidence and doubt that it is causing my problem. Need suggestions for further debugging. The only clue is that unplugging and plugging in the gateway results in it reestablishing commo with the sensor. It never appears to lose Ethernet commo with Vera.
                      • NuubiN
                        NuubiN
                        Nuubi
                        How often your sketch is sending? Just thinking that if it send continuously, things get piled up.
                        • Dan S.D
                          Dan S.D
                          Dan S.
                          sensor sends light level once per minute (if it changes during that time). Only one sense reporting
                          • Dan S.D
                            Dan S.D
                            Dan S.
                            I now have the gateway plugged into the computer to read the serial moniter. Had the sensor hooked up before and the gateway was plugged into the vera. Per the Serial.print line in the gateway sketch it showing the messages it is sending to the sensor. Will see if it hangs up after a while when it is not plugged into the internet. Given that it seems to be executing the main loop properly, would think it is a hardware problem that causes it to eventually stop.
                            • Dan S.D
                              Dan S.D
                              Dan S.
                              With the Ethernet gateway hooked to the pc and on the serial monitor, it just keeps humming along with no hang ups. So my gateway hangups are Ethernet related.
                              • Dan S.D
                                Dan S.D
                                Dan S.
                                Would like to try the softSPI solution but as a newbie I am not sure how to modify the gateway sketch and associated libraries to do this. Can anyone provide specific step by step instructions on how to modify and compile the gateway with softSPI?
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  #22
                                  I am a bit short on time tonight, but here is at least some pointers to get this to work:
                                  1. Get the patched RF24 lib
                                  2. Download the DigitalIO library and add it to your library tree (next to MySensors lib)
                                  3. Patch RF24_config.h to enable softspi, uncomment
                                    //#define SOFTSPI
                                    and select pins to use with
                                    const uint8_t SOFT_SPI_MISO_PIN = 15;
                                    const uint8_t SOFT_SPI_MOSI_PIN = 14;
                                    const uint8_t SOFT_SPI_SCK_PIN = 16;
                                    The setting above mean MOSI on A0, MISO on A1 and SCK on A2 on an Arduino Nano.
                                  I am going to give it another shot to patch the code to use the hardware SPI but I need a couple of days to do it (have other things going on at the moment). If I fail I will check with @hek if the ethernet gw description should be updated with info on how to use softSPI or how we should proceed (perhaps choosing a different ethernet module). No matter what, I intend to bend the W5100 to my will and once I got it wrestled down, I will share the details. This thread would be a good place to track that:
                                  Dan S.D 1 Reply Last reply
                                  • AnticimexA Anticimex
                                      //#define SOFTSPI
                                    Dan S.D
                                    Dan S.D
                                    Dan S.
                                    @Anticimex Thanks for your input. I downloaded the digitalio library. I assume that I should overwrite the Rf24 lib entries in the Mysensors Utilities lib folder with their patched counterparts?
                                    hekH 1 Reply Last reply
                                    • Dan S.D Dan S.
                                      @Dan-S.
                                      Yes, exactly. And un-comment SOFTSPI-define in RF24_config.h
                                      • AnticimexA
                                        AnticimexA
                                        Anticimex
                                        Correct. And I forgot to mention that you also need to include digitalio.h in you gateway sketch as well in order to compile.
                                        I have had some promising progress with my software patches. I hope to bring good news by the end of the week.
                                        • Dan S.D
                                          Dan S.D
                                          Dan S.
                                          In doing research on this I came across:
                                          https://github.com/nicoverduin/rf24
                                          Didn't know whether you all considered his implementation, but appears to have the same objective of allowing for softSPI on the radio.
