  3. Ethernet Gateway problem
93 Posts 18 Posters 61.5k Views 6 Watching
  • Dan S.D
    Dan S.D
    Dan S.
    Tried new 2 amp 5v dc power supply. Same thing--after about an hour of receiving and acknowledging sensor messages, stopped responding to the messages. Plugin still appears to be connected to and communicating with Vera via the Ethernet, but no responding to (and probably not hearing) the sensor. My inclination is to blame the sharing of the SPI bus but I have no direct evidence and doubt that it is causing my problem. Need suggestions for further debugging. The only clue is that unplugging and plugging in the gateway results in it reestablishing commo with the sensor. It never appears to lose Ethernet commo with Vera.
    • NuubiN
      NuubiN
      Nuubi
      How often your sketch is sending? Just thinking that if it send continuously, things get piled up.
      • Dan S.D
        Dan S.D
        Dan S.
        sensor sends light level once per minute (if it changes during that time). Only one sense reporting
        • Dan S.D
          Dan S.D
          Dan S.
          I now have the gateway plugged into the computer to read the serial moniter. Had the sensor hooked up before and the gateway was plugged into the vera. Per the Serial.print line in the gateway sketch it showing the messages it is sending to the sensor. Will see if it hangs up after a while when it is not plugged into the internet. Given that it seems to be executing the main loop properly, would think it is a hardware problem that causes it to eventually stop.
          • Dan S.D
            Dan S.D
            Dan S.
            With the Ethernet gateway hooked to the pc and on the serial monitor, it just keeps humming along with no hang ups. So my gateway hangups are Ethernet related.
            • Dan S.D
              Dan S.D
              Dan S.
              Would like to try the softSPI solution but as a newbie I am not sure how to modify the gateway sketch and associated libraries to do this. Can anyone provide specific step by step instructions on how to modify and compile the gateway with softSPI?
              • AnticimexA
                AnticimexA
                Anticimex
                #22
                I am a bit short on time tonight, but here is at least some pointers to get this to work:
                1. Get the patched RF24 lib
                2. Download the DigitalIO library and add it to your library tree (next to MySensors lib)
                3. Patch RF24_config.h to enable softspi, uncomment
                  //#define SOFTSPI
                  and select pins to use with
                  const uint8_t SOFT_SPI_MISO_PIN = 15;
                  const uint8_t SOFT_SPI_MOSI_PIN = 14;
                  const uint8_t SOFT_SPI_SCK_PIN = 16;
                  The setting above mean MOSI on A0, MISO on A1 and SCK on A2 on an Arduino Nano.
                I am going to give it another shot to patch the code to use the hardware SPI but I need a couple of days to do it (have other things going on at the moment). If I fail I will check with @hek if the ethernet gw description should be updated with info on how to use softSPI or how we should proceed (perhaps choosing a different ethernet module). No matter what, I intend to bend the W5100 to my will and once I got it wrestled down, I will share the details. This thread would be a good place to track that:
                Dan S.D 1 Reply Last reply
                • AnticimexA Anticimex
                    //#define SOFTSPI
                  Dan S.D
                  Dan S.D
                  Dan S.
                  @Anticimex Thanks for your input. I downloaded the digitalio library. I assume that I should overwrite the Rf24 lib entries in the Mysensors Utilities lib folder with their patched counterparts?
                  hekH 1 Reply Last reply
                  • Dan S.D Dan S.
                    @Dan-S.
                    Yes, exactly. And un-comment SOFTSPI-define in RF24_config.h
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      Correct. And I forgot to mention that you also need to include digitalio.h in you gateway sketch as well in order to compile.
                      I have had some promising progress with my software patches. I hope to bring good news by the end of the week.
                      • Dan S.D
                        Dan S.D
                        Dan S.
                        In doing research on this I came across:
                        https://github.com/nicoverduin/rf24
                        Didn't know whether you all considered his implementation, but appears to have the same objective of allowing for softSPI on the radio.
                        • Dan S.D
                          Dan S.D
                          Dan S.
                          Am getting a compile error on this line in RF24.h:
                          SoftSPI<SOFT_SPI_MISO_PIN, SOFT_SPI_MOSI_PIN, SOFT_SPI_SCK_PIN, SPI_MODE> spi;
                          error: ISO C++ forbids declaration of 'SoftSPI' with no type
                          error: expected ';' before '<' token
                          AnticimexA 1 Reply Last reply
                          • Dan S.D Dan S.
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @Dan-S. have you included digitalio.h in your sketch?
                            • Dan S.D
                              Dan S.D
                              Dan S.
                              Double checked. Yes I have.
                              • AnticimexA
                                AnticimexA
                                Anticimex
                                Hum...then I cannot think of anything more than that I had to change (because I made that mistake and the error message looks familiar).
                                But if you are patient a while longer, I will push a patch to githup with a fix for the ethernet gateway sketch so it works with HW SPI. I have confirmed it now.
                                • Dan S.D
                                  Dan S.D
                                  Dan S.
                                  Figured it out and had a successful compile. Did not have my digital IO Lib properly set up. Now to download and test on the gateway!
                                  • Dan S.D
                                    Dan S.D
                                    Dan S.
                                    Compiled successfully and downloaded. But doesn't show any signs of operation when plugged in. Guess I will wait for your patch.
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      My patch is now merged to the development branch.
                                      Note that I had to increase the SPI clock divider to get it to work on my breadboard. This might not be needed for everybody, but in case you cannot get it to work, it might be worth a try on that.
                                      For details, see here:
                                      • Dan S.D
                                        Dan S.D
                                        Dan S.
                                        I looked at your new gateway sketch and noted you use pin 4 f0r Ethernet enable. According to arduino Ethernet shield documentation, pin 4 is used for writing to the sd card on the shield. You select the W5100 with pin 10 and the sd card with pin 4. So if you have an Ethernet shield, should you be using pin 10 to select and deselect the W5100 instead of pin 4 as you do in your breadboard setup?
                                        • Dan S.D Dan S.
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @Dan-S. You are probably right. I use no shields, just a Nano, so I am free to use any available pin. But I have left this configurable so it is possible to change which pin to use if needed.
