  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 329.8k Views 52 Watching
  • B bsivley
    I just finished building this but when I go to upload the code to my arduino i get this error
    'byte clock [8]' redeclared as different kind of symbol
    what does this mean ?
    thanks
    petewillP
    petewillP
    petewill
    @bsivley Are you using the libraries from the MySensors github page (https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries)? I just compiled it without any errors. What version of the Arduino IDE are you using? What version of MySensors are you using?
    Andrej_ABA 1 Reply Last reply
    • petewillP petewill
      Andrej_ABA
      Andrej_ABA
      Andrej_AB
      @petewill Hi, Please can you advise what version Arduino IDE you are using for this sketch?
      rechin304R 1 Reply Last reply
      • Andrej_ABA Andrej_AB
        rechin304R
        rechin304R
        rechin304
        • Andrej_ABA
          Andrej_ABA
          Andrej_AB
          Hi, Maybe somebody can help me with this issue? Managed to upload code for irrigation controller with Arduino IDE 1.6.12 but can't pair with Vera controller.
          petewillP 1 Reply Last reply
            petewillP
            petewillP
            petewill
            @Andrej_AB I'm using 1.6.12 but I haven't changed my node to 2.0 yet.
            What is the issue you are having with pairing? Do you see the presentation messages on your gateway? Do you have other nodes successfully paired with your Vera?
              Andrej_ABA
              Andrej_ABA
              Andrej_AB
              @petewill Hi, All my other nodes have successfully paired with Vera, but irrigation controller node can't pair with Vera, I have started inclusion mode on Vera, one minute passed 0 devices found.
              Please see attached picture.
                petewillP
                petewillP
                petewill
                @Andrej_AB It looks like it's communicating ok because it's getting the time. Have you ever had a mysenors node #5 in your Vera previously and deleted it? Could it be that the Vera thinks it's already there? What happens if you clear your eeprom on your irrigation controller then manually assign a different ID and then try to pair it again?
                  Andrej_ABA
                  Andrej_ABA
                  Andrej_AB
                  Also thinking about it, eprom was cleaned and manually assigned new ID but still can't pair with Vera.
                  Today I tried upload sketch from My sensors library 1.5.4 and node was successfully paired with Vera, then tried again last sketch and again can't pair.
                    petewillP
                    petewillP
                    petewill
                    @Andrej_AB Can you post the full log from your sensor? The device is never getting presented in what you've posted so far. I don't have enough time to dig in to the code to know if this will help but can you try moving
                        present(i, S_LIGHT);
                    so it's above
                    I still haven't updated my irrigation controller to 2.0 yet so I haven't tested any of the code.
                      so it's above
                      Andrej_ABA
                      Andrej_ABA
                      Andrej_AB
                      @petewill Finally managed to pair node with Vera controller, many thanks to @petewill for assistance with this issue.
                      #define NUMBER_OF_VALVES 6  // Change this to set your valve count up to 16.
                      #define RADIO_ID 7  // Set this to fix your Radio ID or use Auto```
                      • impertusI
                        impertusI
                        impertus
                        wrote on last edited by m26872
                        #264
                        hey @petewill
                        finally i am done making the controller. but when i want to upload the code i get the error..
                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void setup()':
                        Vanding:112: error: 'lcd' was not declared in this scope
                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void loop()':
                        Vanding:255: error: 'lcd' was not declared in this scope
                               lcd.clear();
                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void displayMenu()':
                        Vanding:388: error: 'lcd' was not declared in this scope
                             lcd.clear();
                        Vanding:399: error: 'lcd' was not declared in this scope
                             lcd.print(F("."));
                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void updateDisplay()':
                        Vanding:589: error: 'lcd' was not declared in this scope
                                 lcd.setCursor(0, 0);
                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void fastClear()':
                        Vanding:750: error: 'lcd' was not declared in this scope
                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void updateClock()':
                        Vanding:762: error: 'lcd' was not declared in this scope
                             lcd.setCursor(15, 0);
                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void goGetValveTimes()':
                        Vanding:791: error: 'lcd' was not declared in this scope
                        exit status 1
                        do you have some help 4 me??
                        dbemowskD 2 Replies Last reply
                        • impertusI impertus
                          hey @petewill
                                 lcd.clear();
                               lcd.clear();
                               lcd.print(F("."));
                          exit status 1
                          dbemowskD
                          dbemowskD
                          @impertus Can you post your entire sketch?
                            hey @petewill
                                   lcd.clear();
                                 lcd.clear();
                                 lcd.print(F("."));
                            exit status 1
                            dbemowskD
                            dbemowskD
                            @impertus Those errors have to do with this line:
                            LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                            This is where the declaration happens. If this is commented or fails, you will get the errors you described. Do you have the correct LCD libraries installed for this?
                            impertusI 1 Reply Last reply
                            • dbemowskD dbemowsk
                              impertusI
                              impertusI
                              impertus
                              #267
                              @dbemowsk i just copy/paste from the site.
                              witch library should i use?
                              i have added mysensors-master to IDE
                              edit i could see i have out comment the line. Now i get this error
                              Vanding:92: error: 'POSITIVE' was not declared in this scope
                              Vanding:116: error: no matching function for call to 'LiquidCrystal_I2C::begin(int, int)'
                              C:\Users\crame\Desktop\Vanding\Vanding.ino:116:18: note: candidate is:
                              In file included from C:\Users\crame\Desktop\Vanding\Vanding.ino:1:0:
                              C:\Program Files (x86)\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: void LiquidCrystal_I2C::begin()
                                void begin();
                              C:\Program Files (x86)\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note:   candidate expects 0 arguments, 2 provided
                              exit status 1
                              the sketch.
                              // Enable debug prints
                              //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
                              #include <TimeLib.h>
                              #include <LiquidCrystal.h>
                              #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
                              #define SKETCH_VERSION "2.0"
                              #define CHILD_ID_SPRINKLER 0
                              #define ACTIVE_LOW // comment out this line if your relays are active high
                              #ifdef ACTIVE_LOW
                              #define ALL_VALVES_OFF 0xFFFF
                              #define ALL_VALVES_OFF 0U
                              #ifdef DEBUG_ON
                              #define SERIAL_START(x)
                              typedef enum {
                              SprinklerStates;
                              SprinklerStates lastState;
                              byte menuState = 0;
                              unsigned long menuTimer;
                              byte countDownTime = 10;
                              int allZoneTime [NUMBER_OF_VALVES + 1];
                              int valveSoloTime [NUMBER_OF_VALVES + 1];
                              int valveNumber;
                              int lastValve;
                              unsigned long startMillis;
                              const int ledPin = 5;
                              const int waterButtonPin = 3;
                              bool buttonPushed = false;
                              bool showTime = true;
                              bool clockUpdating = false;
                              bool recentUpdate = true;
                              const char *dayOfWeek[] = {
                              String valveNickName[17] = {
                              time_t lastTimeRun = 0;
                              //Setup Shift Register...
                              const int latchPin = 8;
                              const int clockPin = 4;
                              const int dataPin  = 7;
                              const int outputEnablePin = 6;
                              bool receivedInitialValue = false;
                                pinMode(latchPin, OUTPUT);
                                pinMode(clockPin, OUTPUT);
                                pinMode(dataPin, OUTPUT);
                                pinMode(ledPin, OUTPUT);
                                pinMode(outputEnablePin, OUTPUT);
                                digitalWrite (outputEnablePin, LOW);
                                attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
                                digitalWrite (ledPin, HIGH);
                                updateRelays(ALL_VALVES_OFF);
                                //delay(5000);
                                lcd.clear();
                                lcd.backlight();
                                lcd.createChar(0, clock);
                                lcd.createChar(1, raindrop);
                                delay(500);
                                if (loadState(0) == 0xFF) // EEPROM flag
                                  for (int i = 0; i < 4 ; i++)
                                    lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                                digitalWrite (ledPin, LOW);
                                DEBUG_PRINTLN(F("Ready..."));
                                lcd.write(byte(0));
                                lcd.setCursor(0, 1);
                                int clockCounter = 0;
                                  requestTime();
                                  wait(1000);
                                  lcd.print(".");
                                  clockCounter++;
                                  if (clockCounter > 16)
                                    lcd.clear();
                                    wait(2000);
                                lcd.clear();
                                  lcd.print(F(" Updating  "));
                                  lcd.print(i);
                                  bool flashIcon = false;
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINTLN(F(" Data..."));
                                  while (!receivedInitialValue)
                                    flashIcon = !flashIcon;
                                    request(i, V_VAR1);
                                    wait(500);
                                    request(i, V_VAR2);
                                    wait(500);
                                    request(i, V_VAR3);
                                    wait(500);
                                lcd.clear();
                                updateClock();
                                updateDisplay();
                                goGetValveTimes();
                                if (buttonPushed)
                                  menuTimer = millis();
                                    state = ZONE_SELECT_MENU;
                                    menuState = 0;
                                    menuState++;
                                      menuState = 0;
                                  slowToggleLED ();
                                  if (state != lastState)
                                      wait(50);
                                      send(msg1valve.setSensor(i).set(false), false);
                                    lcd.clear();
                                    lcd.setCursor(0,0);
                                    lcd.setCursor(0,1);
                                    wait(2000);
                                    lastValve = -1;
                                  if (lastValve != valveNumber)
                                        send(msg1valve.setSensor(i).set(true), false);
                                  lastValve = valveNumber;
                                  fastToggleLed();
                                    valveNumber = 1;
                                    startMillis = millis();
                                    valveNumber++;
                                      state = CYCLE_COMPLETE;
                                      lastValve = -1;
                                      lastTimeRun = now();
                                      DEBUG_PRINT(F("State = "));
                                      DEBUG_PRINTLN(state);
                                  fastToggleLed();
                                    DEBUG_PRINT(F("Zone: "));
                                    DEBUG_PRINTLN(valveNumber);
                                    fastToggleLed();
                                  displayMenu();
                                lastState = state;
                              void displayMenu(void)
                                static int lastSecond;
                                  lcd.clear();
                                  lcd.print(F("Starting"));
                                  lcd.print(F("."));
                                  Serial.print(".");
                                lastSecond = thisSecond;
                                  if (menuState == 0)
                                    valveNumber = 1;
                                    state = RUN_ALL_ZONES;
                                    valveNumber = menuState;
                                    state = RUN_SINGLE_ZONE;
                                lastMenuState = menuState;
                              void updateRelays(int value)
                                digitalWrite(latchPin, LOW);
                                digitalWrite(latchPin, HIGH);
                                  buttonPushed = true;
                              void fastToggleLed()
                                  fastLedTimer = millis ();
                              void slowToggleLED ()
                                  slowLedTimer = millis ();
                                bool zoneTimeUpdate = false;
                                if (message.isAck())
                                  if (message.sensor == i)
                                    if (message.type == V_LIGHT)
                                      if (switchState == 0)
                                        if (i == 0)
                                          valveNumber = 1;
                                          valveNumber = i;
                                          DEBUG_PRINTLN(i);
                                      DEBUG_PRINT(i);
                                      DEBUG_PRINT(F(" = "));
                                      DEBUG_PRINTLN(variable1);
                                        allZoneTime[i] = variable1;
                                        zoneTimeUpdate = true;
                                      receivedInitialValue = true;
                                      DEBUG_PRINT(i);
                                      DEBUG_PRINTLN(variable2);
                                        valveSoloTime[i] = variable2;
                                      if (newMessage.length() == 0)
                                        DEBUG_PRINTLN(i);
                                      if (newMessage.length() > 16)
                                        newMessage.substring(0, 16);
                                      valveNickName[i] = "";
                                      DEBUG_PRINT(F("Recieved new name for zone "));
                                      DEBUG_PRINT(i);
                                      DEBUG_PRINT(F(" and it is now called: "));
                                if (zoneTimeUpdate)
                                    if (i != 0)
                                      DEBUG_PRINT(F("Zone "));
                                      DEBUG_PRINT(i);
                                      DEBUG_PRINTLN(allZoneTime[i]);
                                  recentUpdate = false;
                                static bool displayToggle = false;
                                  switch (state) {
                                    case STAND_BY_ALL_OFF:
                                      fastClear();
                                      if (displayToggle)
                                        if (clockUpdating)
                                          lcd.write(byte(0));
                                        lcd.print(hourFormat12());
                                        lcd.print(minute());
                                        lcd.print(month());
                                        lcd.print(day());
                                        lcd.print(F("/"));
                                        lcd.print(year() % 100);
                                        if (clockUpdating)
                                          lcd.write(byte(0));
                                        lcd.setCursor(11, 1);
                                        lcd.print(day(lastTimeRun));
                                    case RUN_SINGLE_ZONE:
                                      fastClear();
                                      if (displayToggle)
                                        lcd.print(F(" Zone:"));
                                        lcd.print(valveNumber);
                                        lcd.print(F(" Active"));
                                          lcd.print("min");
                                          lcd.print("sec  ");
                                    case RUN_ALL_ZONES:
                                      fastClear();
                                      if (displayToggle)
                                        lcd.print(F(" Active "));
                                        lcd.print("min");
                                        lcd.print("sec  ");
                                    case CYCLE_COMPLETE:
                                      if (displayToggle)
                                        int totalTimeRan = 0;
                                        lcd.print(totalTimeRan);
                                        lcd.print(" Minutes   ");
                                    default:
                                      // what of ZONE_SELECT_MENU?
                                  lastUpdateTime = millis();
                                lastDisplayState = state;
                                int lastSecond = second();
                                int lastMinute = minute();
                                int lastHour = hour();
                                setTime(newTime);
                                  DEBUG_PRINT(hourFormat12());
                                  DEBUG_PRINT(minute());
                                  DEBUG_PRINT(month());
                                  DEBUG_PRINT(F("/"));
                                  DEBUG_PRINT(day());
                                  DEBUG_PRINTLN(year());
                                  showTime = false;
                              void fastClear()
                              void updateClock()
                                  lcd.write(byte(0));
                                  clockUpdating = true;
                                  requestTime();
                                  lastVeraGetTime = millis();
                                if (loadState(0) != 0xFF)
                                  saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                                for (int i = 1; i < 5; i++)
                                  saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                                static byte valveIndex = 1;
                                if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                                  DEBUG_PRINTLN(F("Calling for Valve Data..."));
                                  lcd.write(byte(1)); //lcd.write(1);
                                  request(valveIndex, V_VAR1);
                                  request(valveIndex, V_VAR2);
                                  request(valveIndex, V_VAR3);
                                  valveUpdateTime = millis();
                                  valveIndex++;
                                  if (valveIndex > NUMBER_OF_VALVES + 1)
                                    valveIndex = 1;
                              • TON RIJNAARDT
                                TON RIJNAARDT
                                TON RIJNAARD
                                Can some one help me with a working sketch for Domoticz.
                                I have it a little working, only Domoticz give not the childs.
                                I get from the gate way the time and then is searching for the name from the zone.
                                If some one can give me a working sketch than i can see what is wrong.
                                Thanks in advance Ton
                                • TON RIJNAARDT
                                  TON RIJNAARDT
                                  TON RIJNAARD
                                  • impertusI
                                    impertusI
                                    impertus
                                    • GimlurG
                                      GimlurG
                                      Gimlur
                                      wrote on last edited by Gimlur
                                      #271
                                      first off all : thank you for your job.
                                      I'm trying to make this sketch, but i have some problems.
                                      Around the line 619 with V_VAR3
                                      In the sensor console i have this
                                      0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.0
                                      3 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      11 TSM:INIT:TSP OK
                                      13 TSF:SID:OK,ID=1
                                      15 TSM:FPAR
                                      51 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      144 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      149 TSF:MSG:FPAR OK,ID=0,D=1
                                      2058 TSM:FPAR:OK
                                      2059 TSM:ID
                                      2060 TSM:ID:OK
                                      2062 TSM:UPL
                                      2065 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      2072 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      2077 TSF:MSG:PONG RECV,HP=1
                                      2080 TSM:UPL:OK
                                      2081 TSM:READY:ID=1,PAR=0,DIS=1
                                      2086 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      2096 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      2103 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                                      2111 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      2129 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                      2137 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:MySprinkler
                                      2146 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
                                      2154 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2161 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2168 TSF:MSG:SEND,1-1-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2177 TSF:MSG:SEND,1-1-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2184 TSF:MSG:SEND,1-1-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2190 MCO:REG:REQ
                                      2193 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      2199 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      2204 MCO:PIM:NODE REG=1
                                      2207 MCO:BGN:STP
                                      Initialisation...
                                      Mise des Vannes sur Off...
                                      Ready...
                                      2864 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2882 TSF:MSG:READ,0-0-1,s=255,c=3,t=1,pt=0,l=10,sg=0:1484768469
                                      Horloge mise à jour....
                                      Sensor's time currently set to: 07:41pm
                                      18/1/2017
                                      Mercredi
                                      Calling for Valve 0 Data...
                                      3902 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                      3913 TSF:MSG:READ,0-0-1,s=0,c=2,t=24,pt=0,l=0,sg=0:
                                      Recieved variable1 valve:0 = 0
                                      4410 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                                      4431 TSF:MSG:READ,0-0-1,s=0,c=2,t=25,pt=0,l=0,sg=0:
                                      Recieved variable2 valve:0 = 0
                                      4919 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                                      4939 TSF:MSG:READ,0-0-1,s=0,c=2,t=26,pt=0,l=0,sg=0:
                                      No Name Recieved for zone 0
                                      5428 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                                      5447 TSF:MSG:READ,0-0-1,s=0,c=2,t=26,pt=0,l=0,sg=0:
                                      In my domoticz GW i have a node MySprinkler 2.0 with 6 childs : 0 to 4 S_LIGHT/S_BINARY, 255 REPREATER
                                      It's seems that the communication between gateway and sensors failed with V_VAR3, V_VAR1 and V_VAR2 are ok.
                                      Can somebody help me, please ?
                                      EDIT : according to the instructions inside this skecth :
                                      I can't find any Variable in my domoticz Controller, only S_LIGHT childs of Sprinkler Node :
                                      Where is my mistake ?
                                      • GimlurG
                                        GimlurG
                                        Gimlur
                                        I reply to myself...
                                        Like Huczas say before, you have to modify this Sketch for Domoticz. :(
                                        Domoticz don't receive and manage V_VAR1, V_VAR2, V_VAR3, so you have to fixe them in code.
                                        But i have another question :
                                        is there a possibility to declare a supplementary sensor wich can manage this variables ?
                                        • tombstoneT
                                          tombstoneT
                                          tombstone
                                          Hi I looking to do My 1st MySensors Project an hoping to use this one I have a 3.2" Nextion. Will it be hard to use a nextion as a Display. Will there be help so I can get it working as I think the nextion Display will be good .... with weather updates and maybe senses to tell if the plants has to much water or no water. but thats down the trake...
