  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 331.3k Views 52 Watching
  • HuczasH
    HuczasH
    Huczas
    wrote on last edited by Huczas
    #246
    ok, I just get back from Hackerspace. Some people fix this issue:
    SN74HC595 - 13 pin (OE from datascheet) - remove GND and then add pull up 1k resistor and wire it to Arduino pin 6
    and software, added three lines in code:
      const int outputEnablePin = 6;
      pinMode(outputEnablePin, OUTPUT);
      digitalWrite (outputEnablePin, LOW);
    put them after 190 line https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/IrrigationController/IrrigationController.ino
    should be like that:
    <some code>
     //Setup Shift Register...
    const int latchPin = 8;
    const int clockPin = 4;
    const int dataPin  = 7;
    LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
      SERIAL_START(115200);
      pinMode(latchPin, OUTPUT);
      pinMode(clockPin, OUTPUT);
      pinMode(dataPin, OUTPUT);
      pinMode(ledPin, OUTPUT);
      attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
      digitalWrite (ledPin, HIGH);
      updateRelays(ALL_VALVES_OFF);
    <some code>
    If somebody can update this project in github and that fritzling draw - would be super nice.
    petewillP 1 Reply Last reply
    • HuczasH Huczas
      <some code>
      <some code>
      petewillP
      petewillP
      petewill
      @Huczas Great, thanks! Have you tested these updates? Also, can you post a link the info on hackerspace?
      HuczasH 1 Reply Last reply
      • petewillP petewill
        HuczasH
        HuczasH
        Huczas
        @petewill
        Yes, I've tested this and it's working well!
        Link to the hackerspace - HackerSpace Warsaw, they are on irc - where I talk with them, #hackerspace-pl at freenode servers.
        petewillP 2 Replies Last reply
        • HuczasH Huczas
          @petewill
          petewillP
          petewillP
          petewill
          @Huczas Oh, ok. I thought it was a forum post. Thanks for the update. I will work to get this updated.
          • HuczasH Huczas
            @petewill
            petewillP
            petewillP
            petewill
            @Huczas the code has been updated in the 2.0 GitHub branch. The wiring diagram has also been updated. Thanks for the fix!
              HuczasH
              HuczasH
              Huczas
              @petewill as I sad before - pull up 1k resistor and wire it to Arduino pin 6 - I mean
              pull up - connect to power,
              so should be 1k resistor connected with power source(that make sence with pull up) and also with pin 6. Like below:
              • HuczasH Huczas
                petewillP
                petewillP
                petewill
                @Huczas Ah, missed that. I fixed it.
                • B
                  B
                  bsivley
                  I just finished building this but when I go to upload the code to my arduino i get this error
                  'byte clock [8]' redeclared as different kind of symbol
                  what does this mean ?
                  thanks
                  • B bsivley
                    thanks
                    petewillP
                    petewillP
                    petewill
                    @bsivley Are you using the libraries from the MySensors github page (https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries)? I just compiled it without any errors. What version of the Arduino IDE are you using? What version of MySensors are you using?
                    Andrej_ABA 1 Reply Last reply
                      Andrej_ABA
                      Andrej_ABA
                      Andrej_AB
                      @petewill Hi, Please can you advise what version Arduino IDE you are using for this sketch?
                      rechin304R 1 Reply Last reply
                      • Andrej_ABA Andrej_AB
                        rechin304R
                        rechin304R
                        rechin304
                        • Andrej_ABA
                          Andrej_ABA
                          Andrej_AB
                          Hi, Maybe somebody can help me with this issue? Managed to upload code for irrigation controller with Arduino IDE 1.6.12 but can't pair with Vera controller.
                            petewillP
                            petewillP
                            petewill
                            @Andrej_AB I'm using 1.6.12 but I haven't changed my node to 2.0 yet.
                            What is the issue you are having with pairing? Do you see the presentation messages on your gateway? Do you have other nodes successfully paired with your Vera?
                              Andrej_ABA
                              Andrej_ABA
                              Andrej_AB
                              @petewill Hi, All my other nodes have successfully paired with Vera, but irrigation controller node can't pair with Vera, I have started inclusion mode on Vera, one minute passed 0 devices found.
                              Please see attached picture.
                                petewillP
                                petewillP
                                petewill
                                @Andrej_AB It looks like it's communicating ok because it's getting the time. Have you ever had a mysenors node #5 in your Vera previously and deleted it? Could it be that the Vera thinks it's already there? What happens if you clear your eeprom on your irrigation controller then manually assign a different ID and then try to pair it again?
                                  Andrej_ABA
                                  Andrej_ABA
                                  Andrej_AB
                                  Also thinking about it, eprom was cleaned and manually assigned new ID but still can't pair with Vera.
                                  Today I tried upload sketch from My sensors library 1.5.4 and node was successfully paired with Vera, then tried again last sketch and again can't pair.
                                    petewillP
                                    petewillP
                                    petewill
                                    @Andrej_AB Can you post the full log from your sensor? The device is never getting presented in what you've posted so far. I don't have enough time to dig in to the code to know if this will help but can you try moving
                                        present(i, S_LIGHT);
                                    so it's above
                                    I still haven't updated my irrigation controller to 2.0 yet so I haven't tested any of the code.
                                      so it's above
                                      Andrej_ABA
                                      Andrej_ABA
                                      Andrej_AB
                                      @petewill Finally managed to pair node with Vera controller, many thanks to @petewill for assistance with this issue.
                                      #define NUMBER_OF_VALVES 6  // Change this to set your valve count up to 16.
                                      #define RADIO_ID 7  // Set this to fix your Radio ID or use Auto```
                                      • impertusI
                                        impertusI
                                        impertus
                                        wrote on last edited by m26872
                                        #264
                                        hey @petewill
                                        finally i am done making the controller. but when i want to upload the code i get the error..
                                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void setup()':
                                        Vanding:112: error: 'lcd' was not declared in this scope
                                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void loop()':
                                        Vanding:255: error: 'lcd' was not declared in this scope
                                               lcd.clear();
                                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void displayMenu()':
                                        Vanding:388: error: 'lcd' was not declared in this scope
                                             lcd.clear();
                                        Vanding:399: error: 'lcd' was not declared in this scope
                                             lcd.print(F("."));
                                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void updateDisplay()':
                                        Vanding:589: error: 'lcd' was not declared in this scope
                                                 lcd.setCursor(0, 0);
                                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void fastClear()':
                                        Vanding:750: error: 'lcd' was not declared in this scope
                                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void updateClock()':
                                        Vanding:762: error: 'lcd' was not declared in this scope
                                             lcd.setCursor(15, 0);
                                        C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void goGetValveTimes()':
                                        Vanding:791: error: 'lcd' was not declared in this scope
                                        exit status 1
                                        do you have some help 4 me??
                                        dbemowskD 2 Replies Last reply
                                        • impertusI impertus
                                          hey @petewill
                                                 lcd.clear();
                                               lcd.clear();
                                               lcd.print(F("."));
                                          exit status 1
                                          dbemowskD
                                          dbemowskD
                                          @impertus Can you post your entire sketch?
