  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 329.8k Views 52 Watching
  • Andrej_ABA Andrej_AB
    @petewill Hi, Please can you advise what version Arduino IDE you are using for this sketch?
    rechin304R
    rechin304R
    rechin304
    • Andrej_ABA
      Andrej_ABA
      Andrej_AB
      Hi, Maybe somebody can help me with this issue? Managed to upload code for irrigation controller with Arduino IDE 1.6.12 but can't pair with Vera controller.
      petewillP 1 Reply Last reply
        petewillP
        petewillP
        petewill
        @Andrej_AB I'm using 1.6.12 but I haven't changed my node to 2.0 yet.
        What is the issue you are having with pairing? Do you see the presentation messages on your gateway? Do you have other nodes successfully paired with your Vera?
        Andrej_ABA 1 Reply Last reply
        • petewillP petewill
          Andrej_ABA
          Andrej_ABA
          Andrej_AB
          @petewill Hi, All my other nodes have successfully paired with Vera, but irrigation controller node can't pair with Vera, I have started inclusion mode on Vera, one minute passed 0 devices found.
          Please see attached picture.
            petewillP
            petewillP
            petewill
            @Andrej_AB It looks like it's communicating ok because it's getting the time. Have you ever had a mysenors node #5 in your Vera previously and deleted it? Could it be that the Vera thinks it's already there? What happens if you clear your eeprom on your irrigation controller then manually assign a different ID and then try to pair it again?
              Andrej_ABA
              Andrej_ABA
              Andrej_AB
              Also thinking about it, eprom was cleaned and manually assigned new ID but still can't pair with Vera.
              Today I tried upload sketch from My sensors library 1.5.4 and node was successfully paired with Vera, then tried again last sketch and again can't pair.
                petewillP
                petewillP
                petewill
                @Andrej_AB Can you post the full log from your sensor? The device is never getting presented in what you've posted so far. I don't have enough time to dig in to the code to know if this will help but can you try moving
                    present(i, S_LIGHT);
                so it's above
                I still haven't updated my irrigation controller to 2.0 yet so I haven't tested any of the code.
                  so it's above
                  Andrej_ABA
                  Andrej_ABA
                  Andrej_AB
                  @petewill Finally managed to pair node with Vera controller, many thanks to @petewill for assistance with this issue.
                  #define NUMBER_OF_VALVES 6  // Change this to set your valve count up to 16.
                  #define RADIO_ID 7  // Set this to fix your Radio ID or use Auto```
                  • impertusI
                    impertusI
                    impertus
                    wrote on last edited by m26872
                    #264
                    hey @petewill
                    finally i am done making the controller. but when i want to upload the code i get the error..
                    C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void setup()':
                    Vanding:112: error: 'lcd' was not declared in this scope
                    C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void loop()':
                    Vanding:255: error: 'lcd' was not declared in this scope
                           lcd.clear();
                    C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void displayMenu()':
                    Vanding:388: error: 'lcd' was not declared in this scope
                         lcd.clear();
                    Vanding:399: error: 'lcd' was not declared in this scope
                         lcd.print(F("."));
                    C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void updateDisplay()':
                    Vanding:589: error: 'lcd' was not declared in this scope
                             lcd.setCursor(0, 0);
                    C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void fastClear()':
                    Vanding:750: error: 'lcd' was not declared in this scope
                    C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void updateClock()':
                    Vanding:762: error: 'lcd' was not declared in this scope
                         lcd.setCursor(15, 0);
                    C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void goGetValveTimes()':
                    Vanding:791: error: 'lcd' was not declared in this scope
                    exit status 1
                    do you have some help 4 me??
                    dbemowskD 2 Replies Last reply
                    • impertusI impertus
                      hey @petewill
                             lcd.clear();
                           lcd.clear();
                           lcd.print(F("."));
                      exit status 1
                      dbemowskD
                      dbemowskD
                      @impertus Can you post your entire sketch?
                        hey @petewill
                               lcd.clear();
                             lcd.clear();
                             lcd.print(F("."));
                        exit status 1
                        dbemowskD
                        dbemowskD
                        @impertus Those errors have to do with this line:
                        LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                        This is where the declaration happens. If this is commented or fails, you will get the errors you described. Do you have the correct LCD libraries installed for this?
                        impertusI 1 Reply Last reply
                        • dbemowskD dbemowsk
                          impertusI
                          impertusI
                          impertus
                          #267
                          @dbemowsk i just copy/paste from the site.
                          witch library should i use?
                          i have added mysensors-master to IDE
                          edit i could see i have out comment the line. Now i get this error
                          Vanding:92: error: 'POSITIVE' was not declared in this scope
                          Vanding:116: error: no matching function for call to 'LiquidCrystal_I2C::begin(int, int)'
                          C:\Users\crame\Desktop\Vanding\Vanding.ino:116:18: note: candidate is:
                          In file included from C:\Users\crame\Desktop\Vanding\Vanding.ino:1:0:
                          C:\Program Files (x86)\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: void LiquidCrystal_I2C::begin()
                            void begin();
                          C:\Program Files (x86)\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note:   candidate expects 0 arguments, 2 provided
                          exit status 1
                          the sketch.
                          // Enable debug prints
                          //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
                          #include <TimeLib.h>
                          #include <LiquidCrystal.h>
                          #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
                          #define SKETCH_VERSION "2.0"
                          #define CHILD_ID_SPRINKLER 0
                          #define ACTIVE_LOW // comment out this line if your relays are active high
                          #ifdef ACTIVE_LOW
                          #define ALL_VALVES_OFF 0xFFFF
                          #define ALL_VALVES_OFF 0U
                          #ifdef DEBUG_ON
                          #define SERIAL_START(x)
                          typedef enum {
                          SprinklerStates;
                          SprinklerStates lastState;
                          byte menuState = 0;
                          unsigned long menuTimer;
                          byte countDownTime = 10;
                          int allZoneTime [NUMBER_OF_VALVES + 1];
                          int valveSoloTime [NUMBER_OF_VALVES + 1];
                          int valveNumber;
                          int lastValve;
                          unsigned long startMillis;
                          const int ledPin = 5;
                          const int waterButtonPin = 3;
                          bool buttonPushed = false;
                          bool showTime = true;
                          bool clockUpdating = false;
                          bool recentUpdate = true;
                          const char *dayOfWeek[] = {
                          String valveNickName[17] = {
                          time_t lastTimeRun = 0;
                          //Setup Shift Register...
                          const int latchPin = 8;
                          const int clockPin = 4;
                          const int dataPin  = 7;
                          const int outputEnablePin = 6;
                          bool receivedInitialValue = false;
                            pinMode(latchPin, OUTPUT);
                            pinMode(clockPin, OUTPUT);
                            pinMode(dataPin, OUTPUT);
                            pinMode(ledPin, OUTPUT);
                            pinMode(outputEnablePin, OUTPUT);
                            digitalWrite (outputEnablePin, LOW);
                            attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
                            digitalWrite (ledPin, HIGH);
                            updateRelays(ALL_VALVES_OFF);
                            //delay(5000);
                            lcd.clear();
                            lcd.backlight();
                            lcd.createChar(0, clock);
                            lcd.createChar(1, raindrop);
                            delay(500);
                            if (loadState(0) == 0xFF) // EEPROM flag
                              for (int i = 0; i < 4 ; i++)
                                lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                            digitalWrite (ledPin, LOW);
                            DEBUG_PRINTLN(F("Ready..."));
                            lcd.write(byte(0));
                            lcd.setCursor(0, 1);
                            int clockCounter = 0;
                              requestTime();
                              wait(1000);
                              lcd.print(".");
                              clockCounter++;
                              if (clockCounter > 16)
                                lcd.clear();
                                wait(2000);
                            lcd.clear();
                              lcd.print(F(" Updating  "));
                              lcd.print(i);
                              bool flashIcon = false;
                              DEBUG_PRINT(i);
                              DEBUG_PRINTLN(F(" Data..."));
                              while (!receivedInitialValue)
                                flashIcon = !flashIcon;
                                request(i, V_VAR1);
                                wait(500);
                                request(i, V_VAR2);
                                wait(500);
                                request(i, V_VAR3);
                                wait(500);
                            lcd.clear();
                            updateClock();
                            updateDisplay();
                            goGetValveTimes();
                            if (buttonPushed)
                              menuTimer = millis();
                                state = ZONE_SELECT_MENU;
                                menuState = 0;
                                menuState++;
                                  menuState = 0;
                              slowToggleLED ();
                              if (state != lastState)
                                  wait(50);
                                  send(msg1valve.setSensor(i).set(false), false);
                                lcd.clear();
                                lcd.setCursor(0,0);
                                lcd.setCursor(0,1);
                                wait(2000);
                                lastValve = -1;
                              if (lastValve != valveNumber)
                                    send(msg1valve.setSensor(i).set(true), false);
                              lastValve = valveNumber;
                              fastToggleLed();
                                valveNumber = 1;
                                startMillis = millis();
                                valveNumber++;
                                  state = CYCLE_COMPLETE;
                                  lastValve = -1;
                                  lastTimeRun = now();
                                  DEBUG_PRINT(F("State = "));
                                  DEBUG_PRINTLN(state);
                              fastToggleLed();
                                DEBUG_PRINT(F("Zone: "));
                                DEBUG_PRINTLN(valveNumber);
                                fastToggleLed();
                              displayMenu();
                            lastState = state;
                          void displayMenu(void)
                            static int lastSecond;
                              lcd.clear();
                              lcd.print(F("Starting"));
                              lcd.print(F("."));
                              Serial.print(".");
                            lastSecond = thisSecond;
                              if (menuState == 0)
                                valveNumber = 1;
                                state = RUN_ALL_ZONES;
                                valveNumber = menuState;
                                state = RUN_SINGLE_ZONE;
                            lastMenuState = menuState;
                          void updateRelays(int value)
                            digitalWrite(latchPin, LOW);
                            digitalWrite(latchPin, HIGH);
                              buttonPushed = true;
                          void fastToggleLed()
                              fastLedTimer = millis ();
                          void slowToggleLED ()
                              slowLedTimer = millis ();
                            bool zoneTimeUpdate = false;
                            if (message.isAck())
                              if (message.sensor == i)
                                if (message.type == V_LIGHT)
                                  if (switchState == 0)
                                    if (i == 0)
                                      valveNumber = 1;
                                      valveNumber = i;
                                      DEBUG_PRINTLN(i);
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(F(" = "));
                                  DEBUG_PRINTLN(variable1);
                                    allZoneTime[i] = variable1;
                                    zoneTimeUpdate = true;
                                  receivedInitialValue = true;
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINTLN(variable2);
                                    valveSoloTime[i] = variable2;
                                  if (newMessage.length() == 0)
                                    DEBUG_PRINTLN(i);
                                  if (newMessage.length() > 16)
                                    newMessage.substring(0, 16);
                                  valveNickName[i] = "";
                                  DEBUG_PRINT(F("Recieved new name for zone "));
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(F(" and it is now called: "));
                            if (zoneTimeUpdate)
                                if (i != 0)
                                  DEBUG_PRINT(F("Zone "));
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINTLN(allZoneTime[i]);
                              recentUpdate = false;
                            static bool displayToggle = false;
                              switch (state) {
                                case STAND_BY_ALL_OFF:
                                  fastClear();
                                  if (displayToggle)
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.print(hourFormat12());
                                    lcd.print(minute());
                                    lcd.print(month());
                                    lcd.print(day());
                                    lcd.print(F("/"));
                                    lcd.print(year() % 100);
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.setCursor(11, 1);
                                    lcd.print(day(lastTimeRun));
                                case RUN_SINGLE_ZONE:
                                  fastClear();
                                  if (displayToggle)
                                    lcd.print(F(" Zone:"));
                                    lcd.print(valveNumber);
                                    lcd.print(F(" Active"));
                                      lcd.print("min");
                                      lcd.print("sec  ");
                                case RUN_ALL_ZONES:
                                  fastClear();
                                  if (displayToggle)
                                    lcd.print(F(" Active "));
                                    lcd.print("min");
                                    lcd.print("sec  ");
                                case CYCLE_COMPLETE:
                                  if (displayToggle)
                                    int totalTimeRan = 0;
                                    lcd.print(totalTimeRan);
                                    lcd.print(" Minutes   ");
                                default:
                                  // what of ZONE_SELECT_MENU?
                              lastUpdateTime = millis();
                            lastDisplayState = state;
                            int lastSecond = second();
                            int lastMinute = minute();
                            int lastHour = hour();
                            setTime(newTime);
                              DEBUG_PRINT(hourFormat12());
                              DEBUG_PRINT(minute());
                              DEBUG_PRINT(month());
                              DEBUG_PRINT(F("/"));
                              DEBUG_PRINT(day());
                              DEBUG_PRINTLN(year());
                              showTime = false;
                          void fastClear()
                          void updateClock()
                              lcd.write(byte(0));
                              clockUpdating = true;
                              requestTime();
                              lastVeraGetTime = millis();
                            if (loadState(0) != 0xFF)
                              saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                            for (int i = 1; i < 5; i++)
                              saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                            static byte valveIndex = 1;
                            if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                              DEBUG_PRINTLN(F("Calling for Valve Data..."));
                              lcd.write(byte(1)); //lcd.write(1);
                              request(valveIndex, V_VAR1);
                              request(valveIndex, V_VAR2);
                              request(valveIndex, V_VAR3);
                              valveUpdateTime = millis();
                              valveIndex++;
                              if (valveIndex > NUMBER_OF_VALVES + 1)
                                valveIndex = 1;
                          • TON RIJNAARDT
                            TON RIJNAARDT
                            TON RIJNAARD
                            Can some one help me with a working sketch for Domoticz.
                            I have it a little working, only Domoticz give not the childs.
                            I get from the gate way the time and then is searching for the name from the zone.
                            If some one can give me a working sketch than i can see what is wrong.
                            Thanks in advance Ton
                            • TON RIJNAARDT
                              TON RIJNAARDT
                              TON RIJNAARD
                              • impertusI
                                impertusI
                                impertus
                                • GimlurG
                                  GimlurG
                                  Gimlur
                                  wrote on last edited by Gimlur
                                  #271
                                  first off all : thank you for your job.
                                  I'm trying to make this sketch, but i have some problems.
                                  Around the line 619 with V_VAR3
                                  In the sensor console i have this
                                  0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.0
                                  3 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  11 TSM:INIT:TSP OK
                                  13 TSF:SID:OK,ID=1
                                  15 TSM:FPAR
                                  51 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  144 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  149 TSF:MSG:FPAR OK,ID=0,D=1
                                  2058 TSM:FPAR:OK
                                  2059 TSM:ID
                                  2060 TSM:ID:OK
                                  2062 TSM:UPL
                                  2065 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  2072 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  2077 TSF:MSG:PONG RECV,HP=1
                                  2080 TSM:UPL:OK
                                  2081 TSM:READY:ID=1,PAR=0,DIS=1
                                  2086 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  2096 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  2103 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                                  2111 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  2129 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                  2137 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:MySprinkler
                                  2146 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
                                  2154 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2161 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2168 TSF:MSG:SEND,1-1-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2177 TSF:MSG:SEND,1-1-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2184 TSF:MSG:SEND,1-1-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2190 MCO:REG:REQ
                                  2193 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                  2199 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  2204 MCO:PIM:NODE REG=1
                                  2207 MCO:BGN:STP
                                  Initialisation...
                                  Mise des Vannes sur Off...
                                  Ready...
                                  2864 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2882 TSF:MSG:READ,0-0-1,s=255,c=3,t=1,pt=0,l=10,sg=0:1484768469
                                  Horloge mise à jour....
                                  Sensor's time currently set to: 07:41pm
                                  18/1/2017
                                  Mercredi
                                  Calling for Valve 0 Data...
                                  3902 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                  3913 TSF:MSG:READ,0-0-1,s=0,c=2,t=24,pt=0,l=0,sg=0:
                                  Recieved variable1 valve:0 = 0
                                  4410 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                                  4431 TSF:MSG:READ,0-0-1,s=0,c=2,t=25,pt=0,l=0,sg=0:
                                  Recieved variable2 valve:0 = 0
                                  4919 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                                  4939 TSF:MSG:READ,0-0-1,s=0,c=2,t=26,pt=0,l=0,sg=0:
                                  No Name Recieved for zone 0
                                  5428 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                                  5447 TSF:MSG:READ,0-0-1,s=0,c=2,t=26,pt=0,l=0,sg=0:
                                  In my domoticz GW i have a node MySprinkler 2.0 with 6 childs : 0 to 4 S_LIGHT/S_BINARY, 255 REPREATER
                                  It's seems that the communication between gateway and sensors failed with V_VAR3, V_VAR1 and V_VAR2 are ok.
                                  Can somebody help me, please ?
                                  EDIT : according to the instructions inside this skecth :
                                  I can't find any Variable in my domoticz Controller, only S_LIGHT childs of Sprinkler Node :
                                  Where is my mistake ?
                                  • GimlurG
                                    GimlurG
                                    Gimlur
                                    I reply to myself...
                                    Like Huczas say before, you have to modify this Sketch for Domoticz. :(
                                    Domoticz don't receive and manage V_VAR1, V_VAR2, V_VAR3, so you have to fixe them in code.
                                    But i have another question :
                                    is there a possibility to declare a supplementary sensor wich can manage this variables ?
                                    • tombstoneT
                                      tombstoneT
                                      tombstone
                                      Hi I looking to do My 1st MySensors Project an hoping to use this one I have a 3.2" Nextion. Will it be hard to use a nextion as a Display. Will there be help so I can get it working as I think the nextion Display will be good .... with weather updates and maybe senses to tell if the plants has to much water or no water. but thats down the trake...
                                      • tombstoneT tombstone
                                        P
                                        P
                                        Paulb
                                        wrote on last edited by Paulb
                                        #274
                                        Hi, this is my first MySensors project having been inspired to jump in after finding @petewill great Youtube video. Thanks to @BulldogLowell for the code. After much perseverance I have everything working... kinda'.
                                        My last persistent issue is the system halting zone 2, ie, cycle starts and ~10 seconds in the irrigation is halted. This only happens for Zone 2 (pin 1 on the shift register). This issue only occurs when either starting Zone 2 singularly from the controller or as part of the All Zones from the controller - Zone 1 will complete, Zone 2 will start then stop after ~10 seconds. Zone 2 WILL complete fine when selected manually from the pushbutton. All Zones from the pushbutton or controller will both fail.
                                        I've checked and re-checked solder joints, wire connections, put the 10k external pullup resistor in and swapped out shift registers with no luck so far.
                                        Would appreciate any help to resolve. Thanks.
                                        I am using Domoticz and @Huczas modified sketch.
                                        Arduino Multi-Zone Sprinkler Control
                                        May 31, 2015
                                        *** Version 2.0
                                        * LED status indicator
                                        PARTS LIST:
                                        * Relays (8 channel)
                                        * NRF24L01 Radio
                                        * Arduino (I used a Pro Mini)
                                        * Capacitors (10uf and .1uf)
                                        * 3.3v voltage regulator
                                        * Resistors (270 & 10K)
                                        * Female Dupont Cables
                                        * LED
                                        * Push button
                                        * Shift Register (SN74HC595)
                                        * 18 gauge wire (for relay)
                                        INSTRUCTIONS:
                                          on the serial monitor.
                                        #include <Time.h>
                                        #define NUMBER_OF_VALVES 5  // Change this to set your valve count up to 16.
                                        #define VALVE_RESET_TIME 4500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
                                        #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                                        #define SKETCH_NAME "MySprinkler Domoticz"
                                        #ifdef ACTIVE_LOW
                                        #ifdef DEBUG_ON
                                        typedef enum {
                                        SprinklerStates;
                                        byte menuState = 0;
                                        int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 5 chan relay
                                        int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 5 chan relay
                                        int valveNumber;
                                        int lastValve;
                                        boolean buttonPushed = false;
                                        boolean showTime = true;
                                        boolean clockUpdating = false;
                                        boolean recentUpdate = true;
                                        //extra for 1k resistor
                                        //const int outputEnablePin = 6;
                                        //end extra 1k
                                          SERIAL_START(115200);
                                          //internal pullup use next line
                                          //pinMode(waterButtonPin, INPUT_PULLUP);
                                          //external pullup use next line
                                          attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                                          //pinMode(outputEnablePin, OUTPUT);
                                          //digitalWrite (outputEnablePin, LOW);
                                          //end extra 1k
                                          //delay(5000);
                                          //delay(5000);
                                          lcd.clear();
                                          lcd.backlight();
                                          delay(500);
                                          if (gw.loadState(0) == 0xFF); // EEPROM flag
                                              lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                                          gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                                            gw.present(i, S_LIGHT);
                                          lcd.write(byte(0));
                                            gw.requestTime(receiveTime);
                                            delay(1000);
                                            lcd.print(".");
                                            clockCounter++;
                                              lcd.clear();
                                              delay(2000);
                                          lcd.clear();
                                            lcd.print(i);
                                            boolean flashIcon = false;
                                            DEBUG_PRINT(i);
                                            while (gw.process() == false)
                                              gw.request(i, V_VAR1);
                                              delay(100);
                                              gw.request(i, V_VAR2);
                                              delay(100);
                                              gw.request(i, V_VAR3);
                                              delay(100);
                                          lcd.clear();
                                          updateClock();
                                          updateDisplay();
                                          //goGetValveTimes();
                                          if (buttonPushed)
                                              menuState = 0;
                                              menuState++;
                                                menuState = 0;
                                            slowToggleLED ();
                                                delay(50);
                                                gw.send(msg1valve.setSensor(i).set(false), false);
                                              lcd.clear();
                                              lcd.setCursor(0,0);
                                              lcd.setCursor(0,1);
                                              delay(2000);
                                              lastValve = -1;
                                                  gw.send(msg1valve.setSensor(i).set(true), false);
                                            fastToggleLed();
                                              valveNumber = 1;
                                              valveNumber++;
                                                lastValve = -1;
                                            fastToggleLed();
                                              fastToggleLed();
                                          else if (state = ZONE_SELECT_MENU)
                                            displayMenu();
                                          lastState = state;
                                            lcd.clear();
                                            lcd.print(F("."));
                                            Serial.print(".");
                                            if (menuState == 0)
                                              valveNumber = 1;
                                          boolean zoneTimeUpdate = false;
                                                  if (i == 0)
                                                    valveNumber = 1;
                                                    valveNumber = i;
                                                    DEBUG_PRINTLN(i);
                                                DEBUG_PRINT(i);
                                                DEBUG_PRINT(i);
                                                  DEBUG_PRINTLN(i);
                                                DEBUG_PRINT(i);
                                          if (zoneTimeUpdate)
                                              if (i != 0)
                                                DEBUG_PRINT(i);
                                          static boolean displayToggle = false;
                                            switch (state) {
                                                fastClear();
                                                if (displayToggle)
                                                  if (clockUpdating)
                                                    lcd.write(byte(0));
                                                  lcd.print(month());
                                                  lcd.print(day());
                                                  lcd.print(F("/"));
                                                  if (clockUpdating)
                                                    lcd.write(byte(0));
                                                  lcd.print(day(lastTimeRun) < 10 ? F("0") : F("/"));
                                                fastClear();
                                                if (displayToggle)
                                                    lcd.print("min");
                                                    lcd.print("sec  ");
                                              case RUN_ALL_ZONES:
                                                fastClear();
                                                if (displayToggle)
                                                  lcd.print("min");
                                                  lcd.print("sec  ");
                                                if (displayToggle)
                                          setTime(newTime);
                                            DEBUG_PRINT(day());
                                            showTime = false;
                                        void fastClear()
                                        void updateClock()
                                            lcd.write(byte(0));
                                          if (gw.loadState(0) != 0xFF)
                                            gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                                            gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                                            gw.request(valveIndex, V_VAR1);
                                            gw.request(valveIndex, V_VAR2);
                                            gw.request(valveIndex, V_VAR3);
                                            valveIndex++;
                                              valveIndex = 1;
                                        • P Paulb
                                          May 31, 2015
                                          *** Version 2.0
                                          PARTS LIST:
                                          * NRF24L01 Radio
                                          * LED
                                          * Push button
                                          INSTRUCTIONS:
                                          #include <Time.h>
                                          #ifdef ACTIVE_LOW
                                          #ifdef DEBUG_ON
                                          typedef enum {
                                          SprinklerStates;
                                          byte menuState = 0;
                                          int valveNumber;
                                          int lastValve;
                                          //end extra 1k
                                            //end extra 1k
                                            //delay(5000);
                                            //delay(5000);
                                            lcd.clear();
                                            lcd.backlight();
                                            delay(500);
                                            lcd.write(byte(0));
                                              delay(1000);
                                              lcd.print(".");
                                              clockCounter++;
                                                lcd.clear();
                                                delay(2000);
                                            lcd.clear();
                                              lcd.print(i);
                                              DEBUG_PRINT(i);
                                                delay(100);
                                                delay(100);
                                                delay(100);
                                            lcd.clear();
                                            updateClock();
                                            updateDisplay();
                                            if (buttonPushed)
                                                menuState = 0;
                                                menuState++;
                                                  menuState = 0;
                                              slowToggleLED ();
                                                  delay(50);
                                                lcd.clear();
                                                lcd.setCursor(0,0);
                                                lcd.setCursor(0,1);
                                                delay(2000);
                                                lastValve = -1;
                                              fastToggleLed();
                                                valveNumber = 1;
                                                valveNumber++;
                                                  lastValve = -1;
                                              fastToggleLed();
                                                fastToggleLed();
                                              displayMenu();
                                            lastState = state;
                                              lcd.clear();
                                              lcd.print(F("."));
                                              Serial.print(".");
                                              if (menuState == 0)
                                                valveNumber = 1;
                                                    if (i == 0)
                                                      valveNumber = 1;
                                                      valveNumber = i;
                                                      DEBUG_PRINTLN(i);
                                                  DEBUG_PRINT(i);
                                                  DEBUG_PRINT(i);
                                                    DEBUG_PRINTLN(i);
                                                  DEBUG_PRINT(i);
                                            if (zoneTimeUpdate)
                                                if (i != 0)
                                                  DEBUG_PRINT(i);
                                              switch (state) {
                                                  fastClear();
                                                  if (displayToggle)
                                                    if (clockUpdating)
                                                      lcd.write(byte(0));
                                                    lcd.print(month());
                                                    lcd.print(day());
                                                    lcd.print(F("/"));
                                                    if (clockUpdating)
                                                      lcd.write(byte(0));
                                                  fastClear();
                                                  if (displayToggle)
                                                      lcd.print("min");
                                                      lcd.print("sec  ");
                                                case RUN_ALL_ZONES:
                                                  fastClear();
                                                  if (displayToggle)
                                                    lcd.print("min");
                                                    lcd.print("sec  ");
                                                  if (displayToggle)
                                            setTime(newTime);
                                              DEBUG_PRINT(day());
                                              showTime = false;
                                          void fastClear()
                                          void updateClock()
                                              lcd.write(byte(0));
                                              valveIndex++;
                                                valveIndex = 1;
                                          P
                                          P
                                          Paulb
                                          @Paulb After more troubleshooting I finally narrowed down the problem to an external factor. It seems the old desk lamp I was using on my workbench interfered with the radio signal. It is a fluorescent tube which I understand can be quite 'noisy'. Replicated the conditions several times, stopped using the lamp - presto! everything works as it should.
