  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 331.3k Views 52 Watching
  • HuczasH Huczas
    @petewill
    Yes, I've tested this and it's working well!
    Link to the hackerspace - HackerSpace Warsaw, they are on irc - where I talk with them, #hackerspace-pl at freenode servers.
    petewillP
    petewillP
    petewill
    @Huczas the code has been updated in the 2.0 GitHub branch. The wiring diagram has also been updated. Thanks for the fix!
    HuczasH 1 Reply Last reply
    • petewillP petewill
      HuczasH
      HuczasH
      Huczas
      @petewill as I sad before - pull up 1k resistor and wire it to Arduino pin 6 - I mean
      pull up - connect to power,
      so should be 1k resistor connected with power source(that make sence with pull up) and also with pin 6. Like below:
      petewillP 1 Reply Last reply
      • HuczasH Huczas
        petewillP
        petewillP
        petewill
        @Huczas Ah, missed that. I fixed it.
        • B
          B
          bsivley
          I just finished building this but when I go to upload the code to my arduino i get this error
          'byte clock [8]' redeclared as different kind of symbol
          what does this mean ?
          thanks
          • B bsivley
            thanks
            petewillP
            petewillP
            petewill
            @bsivley Are you using the libraries from the MySensors github page (https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries)? I just compiled it without any errors. What version of the Arduino IDE are you using? What version of MySensors are you using?
            Andrej_ABA 1 Reply Last reply
              Andrej_ABA
              Andrej_ABA
              Andrej_AB
              @petewill Hi, Please can you advise what version Arduino IDE you are using for this sketch?
              rechin304R 1 Reply Last reply
              • Andrej_ABA Andrej_AB
                rechin304R
                rechin304R
                rechin304
                • Andrej_ABA
                  Andrej_ABA
                  Andrej_AB
                  Hi, Maybe somebody can help me with this issue? Managed to upload code for irrigation controller with Arduino IDE 1.6.12 but can't pair with Vera controller.
                    petewillP
                    petewillP
                    petewill
                    @Andrej_AB I'm using 1.6.12 but I haven't changed my node to 2.0 yet.
                    What is the issue you are having with pairing? Do you see the presentation messages on your gateway? Do you have other nodes successfully paired with your Vera?
                      Andrej_ABA
                      Andrej_ABA
                      Andrej_AB
                      @petewill Hi, All my other nodes have successfully paired with Vera, but irrigation controller node can't pair with Vera, I have started inclusion mode on Vera, one minute passed 0 devices found.
                      Please see attached picture.
                        petewillP
                        petewillP
                        petewill
                        @Andrej_AB It looks like it's communicating ok because it's getting the time. Have you ever had a mysenors node #5 in your Vera previously and deleted it? Could it be that the Vera thinks it's already there? What happens if you clear your eeprom on your irrigation controller then manually assign a different ID and then try to pair it again?
                          Andrej_ABA
                          Andrej_ABA
                          Andrej_AB
                          Also thinking about it, eprom was cleaned and manually assigned new ID but still can't pair with Vera.
                          Today I tried upload sketch from My sensors library 1.5.4 and node was successfully paired with Vera, then tried again last sketch and again can't pair.
                            petewillP
                            petewillP
                            petewill
                            @Andrej_AB Can you post the full log from your sensor? The device is never getting presented in what you've posted so far. I don't have enough time to dig in to the code to know if this will help but can you try moving
                                present(i, S_LIGHT);
                            so it's above
                            I still haven't updated my irrigation controller to 2.0 yet so I haven't tested any of the code.
                              so it's above
                              Andrej_ABA
                              Andrej_ABA
                              Andrej_AB
                              @petewill Finally managed to pair node with Vera controller, many thanks to @petewill for assistance with this issue.
                              #define NUMBER_OF_VALVES 6  // Change this to set your valve count up to 16.
                              #define RADIO_ID 7  // Set this to fix your Radio ID or use Auto```
                              • impertusI
                                impertusI
                                impertus
                                wrote on last edited by m26872
                                #264
                                hey @petewill
                                finally i am done making the controller. but when i want to upload the code i get the error..
                                C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void setup()':
                                Vanding:112: error: 'lcd' was not declared in this scope
                                C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void loop()':
                                Vanding:255: error: 'lcd' was not declared in this scope
                                       lcd.clear();
                                C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void displayMenu()':
                                Vanding:388: error: 'lcd' was not declared in this scope
                                     lcd.clear();
                                Vanding:399: error: 'lcd' was not declared in this scope
                                     lcd.print(F("."));
                                C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void updateDisplay()':
                                Vanding:589: error: 'lcd' was not declared in this scope
                                         lcd.setCursor(0, 0);
                                C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void fastClear()':
                                Vanding:750: error: 'lcd' was not declared in this scope
                                C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void updateClock()':
                                Vanding:762: error: 'lcd' was not declared in this scope
                                     lcd.setCursor(15, 0);
                                C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void goGetValveTimes()':
                                Vanding:791: error: 'lcd' was not declared in this scope
                                exit status 1
                                do you have some help 4 me??
                                dbemowskD 2 Replies Last reply
                                • impertusI impertus
                                  hey @petewill
                                         lcd.clear();
                                       lcd.clear();
                                       lcd.print(F("."));
                                  exit status 1
                                  dbemowskD
                                  dbemowskD
                                  @impertus Can you post your entire sketch?
                                    hey @petewill
                                           lcd.clear();
                                         lcd.clear();
                                         lcd.print(F("."));
                                    exit status 1
                                    dbemowskD
                                    dbemowskD
                                    @impertus Those errors have to do with this line:
                                    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                                    This is where the declaration happens. If this is commented or fails, you will get the errors you described. Do you have the correct LCD libraries installed for this?
                                    impertusI 1 Reply Last reply
                                    • dbemowskD dbemowsk
                                      impertusI
                                      impertusI
                                      impertus
                                      #267
                                      @dbemowsk i just copy/paste from the site.
                                      witch library should i use?
                                      i have added mysensors-master to IDE
                                      edit i could see i have out comment the line. Now i get this error
                                      Vanding:92: error: 'POSITIVE' was not declared in this scope
                                      Vanding:116: error: no matching function for call to 'LiquidCrystal_I2C::begin(int, int)'
                                      C:\Users\crame\Desktop\Vanding\Vanding.ino:116:18: note: candidate is:
                                      In file included from C:\Users\crame\Desktop\Vanding\Vanding.ino:1:0:
                                      C:\Program Files (x86)\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: void LiquidCrystal_I2C::begin()
                                        void begin();
                                      C:\Program Files (x86)\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note:   candidate expects 0 arguments, 2 provided
                                      exit status 1
                                      the sketch.
                                      // Enable debug prints
                                      //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
                                      #include <TimeLib.h>
                                      #include <LiquidCrystal.h>
                                      #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
                                      #define SKETCH_VERSION "2.0"
                                      #define CHILD_ID_SPRINKLER 0
                                      #define ACTIVE_LOW // comment out this line if your relays are active high
                                      #ifdef ACTIVE_LOW
                                      #define ALL_VALVES_OFF 0xFFFF
                                      #define ALL_VALVES_OFF 0U
                                      #ifdef DEBUG_ON
                                      #define SERIAL_START(x)
                                      typedef enum {
                                      SprinklerStates;
                                      SprinklerStates lastState;
                                      byte menuState = 0;
                                      unsigned long menuTimer;
                                      byte countDownTime = 10;
                                      int allZoneTime [NUMBER_OF_VALVES + 1];
                                      int valveSoloTime [NUMBER_OF_VALVES + 1];
                                      int valveNumber;
                                      int lastValve;
                                      unsigned long startMillis;
                                      const int ledPin = 5;
                                      const int waterButtonPin = 3;
                                      bool buttonPushed = false;
                                      bool showTime = true;
                                      bool clockUpdating = false;
                                      bool recentUpdate = true;
                                      const char *dayOfWeek[] = {
                                      String valveNickName[17] = {
                                      time_t lastTimeRun = 0;
                                      //Setup Shift Register...
                                      const int latchPin = 8;
                                      const int clockPin = 4;
                                      const int dataPin  = 7;
                                      const int outputEnablePin = 6;
                                      bool receivedInitialValue = false;
                                        pinMode(latchPin, OUTPUT);
                                        pinMode(clockPin, OUTPUT);
                                        pinMode(dataPin, OUTPUT);
                                        pinMode(ledPin, OUTPUT);
                                        pinMode(outputEnablePin, OUTPUT);
                                        digitalWrite (outputEnablePin, LOW);
                                        attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
                                        digitalWrite (ledPin, HIGH);
                                        updateRelays(ALL_VALVES_OFF);
                                        //delay(5000);
                                        lcd.clear();
                                        lcd.backlight();
                                        lcd.createChar(0, clock);
                                        lcd.createChar(1, raindrop);
                                        delay(500);
                                        if (loadState(0) == 0xFF) // EEPROM flag
                                          for (int i = 0; i < 4 ; i++)
                                            lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                                        digitalWrite (ledPin, LOW);
                                        DEBUG_PRINTLN(F("Ready..."));
                                        lcd.write(byte(0));
                                        lcd.setCursor(0, 1);
                                        int clockCounter = 0;
                                          requestTime();
                                          wait(1000);
                                          lcd.print(".");
                                          clockCounter++;
                                          if (clockCounter > 16)
                                            lcd.clear();
                                            wait(2000);
                                        lcd.clear();
                                          lcd.print(F(" Updating  "));
                                          lcd.print(i);
                                          bool flashIcon = false;
                                          DEBUG_PRINT(i);
                                          DEBUG_PRINTLN(F(" Data..."));
                                          while (!receivedInitialValue)
                                            flashIcon = !flashIcon;
                                            request(i, V_VAR1);
                                            wait(500);
                                            request(i, V_VAR2);
                                            wait(500);
                                            request(i, V_VAR3);
                                            wait(500);
                                        lcd.clear();
                                        updateClock();
                                        updateDisplay();
                                        goGetValveTimes();
                                        if (buttonPushed)
                                          menuTimer = millis();
                                            state = ZONE_SELECT_MENU;
                                            menuState = 0;
                                            menuState++;
                                              menuState = 0;
                                          slowToggleLED ();
                                          if (state != lastState)
                                              wait(50);
                                              send(msg1valve.setSensor(i).set(false), false);
                                            lcd.clear();
                                            lcd.setCursor(0,0);
                                            lcd.setCursor(0,1);
                                            wait(2000);
                                            lastValve = -1;
                                          if (lastValve != valveNumber)
                                                send(msg1valve.setSensor(i).set(true), false);
                                          lastValve = valveNumber;
                                          fastToggleLed();
                                            valveNumber = 1;
                                            startMillis = millis();
                                            valveNumber++;
                                              state = CYCLE_COMPLETE;
                                              lastValve = -1;
                                              lastTimeRun = now();
                                              DEBUG_PRINT(F("State = "));
                                              DEBUG_PRINTLN(state);
                                          fastToggleLed();
                                            DEBUG_PRINT(F("Zone: "));
                                            DEBUG_PRINTLN(valveNumber);
                                            fastToggleLed();
                                          displayMenu();
                                        lastState = state;
                                      void displayMenu(void)
                                        static int lastSecond;
                                          lcd.clear();
                                          lcd.print(F("Starting"));
                                          lcd.print(F("."));
                                          Serial.print(".");
                                        lastSecond = thisSecond;
                                          if (menuState == 0)
                                            valveNumber = 1;
                                            state = RUN_ALL_ZONES;
                                            valveNumber = menuState;
                                            state = RUN_SINGLE_ZONE;
                                        lastMenuState = menuState;
                                      void updateRelays(int value)
                                        digitalWrite(latchPin, LOW);
                                        digitalWrite(latchPin, HIGH);
                                          buttonPushed = true;
                                      void fastToggleLed()
                                          fastLedTimer = millis ();
                                      void slowToggleLED ()
                                          slowLedTimer = millis ();
                                        bool zoneTimeUpdate = false;
                                        if (message.isAck())
                                          if (message.sensor == i)
                                            if (message.type == V_LIGHT)
                                              if (switchState == 0)
                                                if (i == 0)
                                                  valveNumber = 1;
                                                  valveNumber = i;
                                                  DEBUG_PRINTLN(i);
                                              DEBUG_PRINT(i);
                                              DEBUG_PRINT(F(" = "));
                                              DEBUG_PRINTLN(variable1);
                                                allZoneTime[i] = variable1;
                                                zoneTimeUpdate = true;
                                              receivedInitialValue = true;
                                              DEBUG_PRINT(i);
                                              DEBUG_PRINTLN(variable2);
                                                valveSoloTime[i] = variable2;
                                              if (newMessage.length() == 0)
                                                DEBUG_PRINTLN(i);
                                              if (newMessage.length() > 16)
                                                newMessage.substring(0, 16);
                                              valveNickName[i] = "";
                                              DEBUG_PRINT(F("Recieved new name for zone "));
                                              DEBUG_PRINT(i);
                                              DEBUG_PRINT(F(" and it is now called: "));
                                        if (zoneTimeUpdate)
                                            if (i != 0)
                                              DEBUG_PRINT(F("Zone "));
                                              DEBUG_PRINT(i);
                                              DEBUG_PRINTLN(allZoneTime[i]);
                                          recentUpdate = false;
                                        static bool displayToggle = false;
                                          switch (state) {
                                            case STAND_BY_ALL_OFF:
                                              fastClear();
                                              if (displayToggle)
                                                if (clockUpdating)
                                                  lcd.write(byte(0));
                                                lcd.print(hourFormat12());
                                                lcd.print(minute());
                                                lcd.print(month());
                                                lcd.print(day());
                                                lcd.print(F("/"));
                                                lcd.print(year() % 100);
                                                if (clockUpdating)
                                                  lcd.write(byte(0));
                                                lcd.setCursor(11, 1);
                                                lcd.print(day(lastTimeRun));
                                            case RUN_SINGLE_ZONE:
                                              fastClear();
                                              if (displayToggle)
                                                lcd.print(F(" Zone:"));
                                                lcd.print(valveNumber);
                                                lcd.print(F(" Active"));
                                                  lcd.print("min");
                                                  lcd.print("sec  ");
                                            case RUN_ALL_ZONES:
                                              fastClear();
                                              if (displayToggle)
                                                lcd.print(F(" Active "));
                                                lcd.print("min");
                                                lcd.print("sec  ");
                                            case CYCLE_COMPLETE:
                                              if (displayToggle)
                                                int totalTimeRan = 0;
                                                lcd.print(totalTimeRan);
                                                lcd.print(" Minutes   ");
                                            default:
                                              // what of ZONE_SELECT_MENU?
                                          lastUpdateTime = millis();
                                        lastDisplayState = state;
                                        int lastSecond = second();
                                        int lastMinute = minute();
                                        int lastHour = hour();
                                        setTime(newTime);
                                          DEBUG_PRINT(hourFormat12());
                                          DEBUG_PRINT(minute());
                                          DEBUG_PRINT(month());
                                          DEBUG_PRINT(F("/"));
                                          DEBUG_PRINT(day());
                                          DEBUG_PRINTLN(year());
                                          showTime = false;
                                      void fastClear()
                                      void updateClock()
                                          lcd.write(byte(0));
                                          clockUpdating = true;
                                          requestTime();
                                          lastVeraGetTime = millis();
                                        if (loadState(0) != 0xFF)
                                          saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                                        for (int i = 1; i < 5; i++)
                                          saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                                        static byte valveIndex = 1;
                                        if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                                          DEBUG_PRINTLN(F("Calling for Valve Data..."));
                                          lcd.write(byte(1)); //lcd.write(1);
                                          request(valveIndex, V_VAR1);
                                          request(valveIndex, V_VAR2);
                                          request(valveIndex, V_VAR3);
                                          valveUpdateTime = millis();
                                          valveIndex++;
                                          if (valveIndex > NUMBER_OF_VALVES + 1)
                                            valveIndex = 1;
                                      • TON RIJNAARDT
                                        TON RIJNAARDT
                                        TON RIJNAARD
                                        Can some one help me with a working sketch for Domoticz.
                                        I have it a little working, only Domoticz give not the childs.
                                        I get from the gate way the time and then is searching for the name from the zone.
                                        If some one can give me a working sketch than i can see what is wrong.
                                        Thanks in advance Ton
                                        • TON RIJNAARDT
                                          TON RIJNAARDT
                                          TON RIJNAARD
