  3. General advice
General advice
advicenewbiesensor
21 Posts 8 Posters 12.5k Views 2 Watching
  • NuubiN Nuubi
    This is a lot of fun diy home automation.
    Out of curiosity, what was the total for all the fun stuff? Did you forget temp (+hum) sensors from the list..
    shawn_kyS
    shawn_kyS
    shawn_ky
    @Nuubi I got the 10PCS IC DS18B20 TO-92 DALLAS for temperature but did not get any of the humidity sensors. After going back and forth with several of the sellers trying to bundle where I could to save on shipping it was about $170 or so. Found the Fluke on a local Facebook group for $20 new (still had plastic over LCD). Hardest part was going back and forth trying to decide what to get and making sure that shipping wasn't making it cost more when it didn't have to.
    Any suggestions on a good soldering iron?
    • NuubiN
      NuubiN
      Nuubi
      Not bad for that much of goodies.
      Soldering iron, it's a bit tricky. The price range is from couple of bucks to ... alot. I got a used Weller, which is great. Genarally, I'd look for something that had at least a stand integrated and possibility to replace tips. Over the years I bought something like 5 cheapos before settled with used Weller...
      • shawn_kyS shawn_ky
        bjornhallbergB
        bjornhallbergB
        bjornhallberg
        @shawn_ky One the one hand, doing through-hole components and stuff will work even on the cheapest iron so I guess it depends on your budget. I've made do with a cheap rebranded Velleman iron for some time until I decided to get the Xytronic LF-3000 90W soldering station the other week. A discontinued (?) model sold by the Distrelec Group here in Europe (Reichelt / Elfa / etc ...). Seemed like good value, but as always, second hand is probably the way to go if you can find any. I looked around but realized that many of the used stations were another step up in terms of price/quality still so I just gave up on that.
        Don't know how good the value is for some of these Ebay stations. Some people love them. Some claim they overshoot and misrepresent the temperature. Probably not worth importing since they're pretty heavy, better to find locally.
        • shawn_kyS
          shawn_kyS
          shawn_ky
          Thanks for the advice @Nuubi and @bjornhallberg ! As far as budget, I don't really know. I guess I know I've tried with the cheap ones before (many years ago now) and it always seemed like if you weren't experienced already then it was a bit more difficult. Perhaps looking for a used Weller is the route to go... I'll look for the one @bjornhallberg mentioned also just in case. Never know, maybe Amazon will have a good deal!
          • sowardS
            sowardS
            soward
            I have a weller non-adjustable unit that I used for years, and I recently moved it to the garage and obtained an adjustable temp hakko 888D, it heats up a little quicker than the weller (okay maybe 1/4 the time) and the holder is a bit nicer, but otherwise they both work well and have a variety of swappable tips. Of course, now I'm thinking I might should have gotten something with hot-air rework capabilities, though really I'm probably not steady enough to do too much SMD fiddling.
            Seems wise to go with the E-Net gateway straight away, I ran with the serial for several month but E-net has lots of advantages. I had some difficulties with the ENC board locking up. I've been using a UNO w/ 5100 as you have listed for a few days w/o issue.
            I recently bought a new vera for our office which came with UI7 instead of UI5, not sure what issues that might present.
            does the _ky indicate that you are in Kentucky?
            shawn_kyS marceltrapmanM 2 Replies Last reply
            • sowardS soward
              shawn_kyS
              shawn_kyS
              shawn_ky
              @soward Yes, I am in Kentucky.... Located in a tri-state area with Ohio and West Virginia close by.
              The hakko 888D looks interesting. Suddenly it appears there are a lot of choices. My assumption is to make sure that it's adjustable and things will work out ok.
              I definitely wanted to go the Ethernet gateway model as it just made more sense to me. Probably moreso in my comfort zone. Glad to hear it's working okay for you...
              I also have UI7 which I have seen good and bad with so far. I have a few X10 devices and would really like to be able to use them through Vera, but at this time the MochaD plugin isn't working properly with UI7. As far as this library, it looks like it is working ok.
              • sowardS soward
                marceltrapmanM
                marceltrapmanM
                marceltrapman
                That is what I thought too. It is really not that difficult though...
                Fulltime Servoy Developer
                  I'm about to go crazy over my cheap soldering iron. The tip losen itself and the handle is crap. Guess sometimes you get what you pay for (≈40USD).
                  After googling a while I was thinking of buying a Weller WSD 81. Quite expensive but hopefully it will last for a while.
                  http://uk.farnell.com/weller/wsd-81-uk/soldering-station-80w-230v-uk/dp/1877455
                  Anyone knows how it compares to the hakko 888D?
                  shawn_kyS 1 Reply Last reply
                    shawn_kyS
                    shawn_kyS
                    shawn_ky
                    wrote on last edited by shawn_ky
                    @hek That's a great question and one that I was wondering also.... :smile:
                    • sowardS
                      sowardS
                      soward
                      I'm not sure about that exact model, but the one things the Weller digital units had over the hakkos when I was shopping was auto-power-off, so if that's a concern it might be worthwhile. However, they were quite a bit more $ here in the US anyway. The Hakko 888D can be had for ~$90US if you are patient. I don't remember the 81 even coming up in a search, the lower powered 51 I looked at, but it was in the $140US range with both less power than the Hakko and the non-adjustable WTCPT I have (temp is adjusted by the particular tip that is installed).
                      That said, the WTCPT is > 15 years old and still working fine, so I don't think you can go wrong with either.
                      Also, I think the 240V hakko might be more costly than it's 120V cousin, which might level the playing field outside of NA.
                        Santa came early this year. Finally decided on a WD1000. Hope it will last i lifetime.
                        • shawn_kyS
                          shawn_kyS
                          shawn_ky
                          Looks like you were a very good boy this year! :smiley: I finally received enough of my stuff to begin playing a bit. So far, it's great! Haven't finished the gateway yet but I've had some questions. How does one use a resistor or capacitor on a breadboard? Is there a proper way to connect it? Also the Ethernet module I order from the hardware list came in but was labeled differently than the instructions for the gateway... I'm on my phone now but will post an image shortly of the labeling. I just want to make sure it's hooked up right before I get too far.
                          Here are the pics...
                            You might wanna browse through these threads.
                            http://forum.mysensors.org/topic/467/ethernet-gateway-troubleshooting-advice
                            http://forum.mysensors.org/topic/466/ethernet-gateway-problem/3
                            SoftSPI for NRF24L01 radio seems to be the option to get Ethernet working on the same SPI bus.
                            A question for everyone: Is there any Ethernet module working side-by-side with radio without tweaking SPI behavior? The ENC-module requires too much memory and the WizNet has problems hogging SPI.
                            jocke4uJ 1 Reply Last reply
                              jocke4uJ
                              jocke4uJ
                              jocke4u
                              I bought SunFounder Uno + Ethernet shield and worked out of box
                              http://www.ebay.com/itm/Sunfounder-UNO-R3-Ethernet-Schild-W5100-Starter-Kit-fur-Arduino-Mega-2560-Nano-/161382223691?pt=Wissenschaftliche_Geräte&hash=item2593214f4b
                              sowardS 1 Reply Last reply
                              • jocke4uJ jocke4u
                                sowardS
                                sowardS
                                soward
                                I got the enc working, but it would hang after some number of hours (usually around 12, but +/- 8). It did not seem to be based on the volume of traffic flowing through it though, so I dunno if it was a similar SPI conflict or a bug in the IP stack.
                                I ordered the iTead, but it has yet to arrive, instead I ordered the same Sunfounder unit mentioned above, but from Amazon:
                                http://www.amazon.com/gp/product/B00JB2Z74W/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
                                I built it up and added a 16x4 LCD and some code to display the time and the last 3 communications received by the controller. It's been stable and online 24x7 since sunday night. No SPI modifications.
                                • daulagariD
                                  daulagariD
                                  daulagari
                                  WIZnet has apart from the W5100 also a W5500 that has Hardware TCP/IP Protocol Handling, 8 TCP/UDP Sockets and a 32KB RAM Buffer and AFAIK the SPI problems solved. According to showwiznet the W5500 is also considerably cheaper than the W5100.
                                  With it being cheaper it is weird I can not find boards with a W5500 on ebay. I ended up buying a WIZ5500io module via Antratek.nl. Will give it a try next weekend.
                                  hekH bjornhallbergB 2 Replies Last reply
                                  • daulagariD daulagari
                                    Great. Report back your findings.
                                      bjornhallbergB
                                      bjornhallbergB
                                      bjornhallberg
                                      @daulagari There are some on AliExpress. A bit cheaper than Antratek but not much. Not 100% sure you get the Uno shield adapter but it seems so. Still no big deal with the price since we only need one gateway.
