  3. 💬 MySensor Dioder (Ikea)
contest2017diodermysensorshuergbledtrimmerarduinoikea
41 Posts 10 Posters 19.5k Views 10 Watching
  • pentti12P
    pentti12P
    pentti12
    OK, I added the line and now I get:
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    So I have to check my radio-module or replace it with new one. I will continue ...
      mortommy
      ok, something is definitely wrong with the radio module. Can you check the connection according to this page?
      • pentti12P
        pentti12P
        pentti12
        I changed my Radio-module to new one. Does not help. So I have to check my wiring on prototype board.
        • pentti12P
          pentti12P
          pentti12
          Wiring was OK, but 10uF elko is missing from the 3.3V supply. I have only 440nF capasitor at the moment. This seems to be too small value. I will have 10uF elko on next monday available. So project will take a break.
          • pentti12P
            pentti12P
            pentti12
            I added 10uF capasitor between VCC and GND pins of the radio module. I also added #define MY_DEBUG_VERBOSE_RF24 line into sketch. I got the following response:
            TSM:INIT
            RF24:write register, reg=0, value=14
            RF24:write register, reg=3, value=3
            RF24:write register, reg=4, value=95
            RF24:write register, reg=5, value=76
            RF24:write register, reg=6, value=39
            RF24:read register, reg=6, value=255
            RF24:read register, reg=5, value=255
            RF24:Sanity check failed: configuration mismatch! Check wiring, replace module or non-P version
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            RF24:write register, reg=0, value=12
            RF24:power down
            I have changed the radio module to new one without success. So there must be some other reason why this sketch does not work in my hardware. Any ideas?
              mortommy
              Which module are you using? if it is NRF24L01+ be sure it is the "plus" version.
              • pentti12P
                pentti12P
                pentti12
                At least I have ordered nRF24L01+ versions. And I use them on other MySensors node and they are working OK.
                • pentti12P
                  pentti12P
                  pentti12
                  Update:
                  I changed Arduino Board from Arduino Mega R3 to Arduino UNO board. I placed my protoshield above UNO-board and now I got following response:
                  TSM:INIT
                  RF24:read register, reg=6, value=39
                  RF24:read register, reg=5, value=76
                  RF24:write register, reg=16, value=115
                  RF24:write register, reg=29, value=6
                  RF24:write register, reg=2, value=2
                  RF24:write register, reg=1, value=0
                  RF24:write register, reg=28, value=3
                  RF24:flushRX
                  RF24:flushTX
                  RF24:write register, reg=7, value=112
                  TSM:RADIO:OK
                  RF24:write register, reg=2, value=3
                  RF24:write register, reg=1, value=1
                  RF24:start listening
                  RF24:write register, reg=0, value=15
                  RF24:write register, reg=10, value=9
                  TSP:ASSIGNID:OK (ID=9)
                  TSM:FPAR
                  RF24:stop listening
                  RF24:open writing pipe, recipient=255
                  RF24:write register, reg=10, value=255
                  RF24:write register, reg=16, value=255
                  RF24:send message to 255, len=7
                  RF24:flushTX
                  RF24:write register, reg=7, value=48
                  RF24:MAX_RT
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  RF24:stop listening
                  RF24:flushTX
                  RF24:MAX_RT
                  RF24:flushTX
                  RF24:read message, len=8
                  RF24:write register, reg=7, value=64
                  TSP:MSG:READ 0-0-9 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  TSP:MSG:PAR OK (ID=0, dist=1)
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=9)
                  TSM:UPL
                  TSP:PING:SEND (dest=0)
                  RF24:stop listening
                  RF24:open writing pipe, recipient=0
                  RF24:write register, reg=10, value=0
                  RF24:write register, reg=16, value=0
                  RF24:send message to 0, len=8
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                  TSP:MSG:READ 0-0-9 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  TSP:MSG:PONG RECV (hops=1)
                  TSP:CHKUPL:OK
                  TSM:UPL:OK
                  TSM:READY
                  Setup... end.
                  RF24:stop listening
                  RF24:send message to 0, len=9
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                  RF24:stop listening
                  RF24:send message to 0, len=12
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                  RF24:stop listening
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                  RF24:read message, len=9
                  TSP:MSG:READ 0-0-9 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  Incoming message: 15
                  RF24:stop listening
                  RF24:send message to 0, len=21
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,ft=0,st=ok:MySensorDioder
                  RF24:stop listening
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                  RF24:stop listening
                  RF24:send message to 0, len=7
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=0,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                  RF24:stop listening
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=1,c=0,t=26,pt=0,l=0,sg=0,ft=0,st=ok:
                  Request registration...
                  RF24:stop listening
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                  TSP:MSG:READ 0-0-9 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  Node registration=1
                  Init complete, id=9, parent=0, distance=1, registration=1
                  Wheel position changed.
                  Wheel position: 0
                  Hue value of the Wheel position: 0
                  Send command to lights.
                  Bright: 0
                  Red: 0
                  Green: 0
                  Blue: 0
                  RGB in HEX: 000000
                  RF24:stop listening
                  RF24:send message to 0, len=11
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=0,c=1,t=3,pt=4,l=4,sg=0,ft=0,st=ok:0
                  RF24:stop listening
                  RF24:send message to 0, len=13
                  RF24:flushTX
                  TSP:MSG:SEND 9-9-0-0 s=1,c=1,t=40,pt=0,l=6,sg=0,ft=0,st=ok:000000
                  Now sketch seems to work. I will continue by adding IKEA DIODER Leds. More info later.
                  • pentti12P
                    pentti12P
                    pentti12
                    Update:
                    I can control locally the IKEA DIODER now. So the hardware is more or less working as expected, but do you have good instructions how I can get OpenHAB2 and MySensors Ethernet Gateway working together. Today I can see MySensors Ethernet Gateway ONLINE state and I can manually add Custom Sensor as a thing, but I cannot control items via Openhab.
                    I use the latest OH2 Snapshot ( on Pine64 with Debian Jessie) and latest MySensors GatewayW5100 (library 2.0) on the MySensors Gateway (Arduino UNO based) and I have tried to start/stop/restart OH2 after MySensors Gateway is up and running without success.
                    OH2 is capable to control for example Philips HUE lights without problems at the moment.
                      mortommy
                      wrote on last edited by mortommy
                      #40
                      Great news!
                      Regarding OH, I didn't have the opportunity to play with the v2.0 yet, I'm still on 1.8.1.
                      I have a serial mysensors gateway and this is my set up:
                      OH (v1.8.1) <-> OH MQTT binding (as MQTT client) <-> Mosquitto (as MQTT server) <-> mosquitto to serial (python script that reverts messages with topic mysensors to the serial port and vice-versa) <-> serial gateway.
                      So my items in OH are based on mqtt binding.
                      I guess OH2 and mysensors openhab binding make everything easier.
                      • pentti12P
                        pentti12P
                        pentti12
                        Do you have interest to try OH2 together with MySensors Ethernet Gateway to get working?
                        I do not have enough force to push developers to make this happen. At the moment there is some problem on this, because full control is not possible. I think that MySensors Serial Gateway is working with OH2, but I don't like to use it. I like to connect my devices into LAN not cabling via old fashioned way using serial wires.
