  3. 💬 MySensor Dioder (Ikea)
contest2017diodermysensorshuergbledtrimmerarduinoikea
41 Posts 10 Posters 19.5k Views 10 Watching
  • pentti12P
    pentti12P
    pentti12
    Sorry, but the compiler found a missing library file:
    MyTransportNRF24.h
    MySensors library 2.0 has MyTransportNRF24.cpp only
    • pentti12P
      pentti12P
      pentti12
      Hi
      I changed my Arduino IDE 1.6.11 using the MySensors development library v2.1.0-beta. Now the compiling went OK. I will continue with that. It will take few days before I have more info about how things went with actual hardware.
      • pentti12P
        pentti12P
        pentti12
        I tested this latest sketch in my actual hardware (Arduino Mega + Proto shield with additionla components + Ikea Dioder control board). I cannot get system working, nothing happens when I press UP, DOWN buttons. Led-lights stay ON after power up.
        I also tested to compile your sketch with Arduino IDE and MySensors Library V2.0.0. Compiling went OK, no progress with actual hardware.
        How can I test step by step what is happening during startup?
        • pentti12P pentti12
          mortommy
          @pentti12 ,
          add the line
          at the begging of the sketch so via Serial Monitor you'll be able to see the messages pushed by the commands println. You can add other println commands in other point to see the steps covered.
          • pentti12P
            pentti12P
            pentti12
            OK, I added the line and now I get:
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            So I have to check my radio-module or replace it with new one. I will continue ...
              mortommy
              ok, something is definitely wrong with the radio module. Can you check the connection according to this page?
              • pentti12P
                pentti12P
                pentti12
                I changed my Radio-module to new one. Does not help. So I have to check my wiring on prototype board.
                • pentti12P
                  pentti12P
                  pentti12
                  Wiring was OK, but 10uF elko is missing from the 3.3V supply. I have only 440nF capasitor at the moment. This seems to be too small value. I will have 10uF elko on next monday available. So project will take a break.
                  • pentti12P
                    pentti12P
                    pentti12
                    I added 10uF capasitor between VCC and GND pins of the radio module. I also added #define MY_DEBUG_VERBOSE_RF24 line into sketch. I got the following response:
                    TSM:INIT
                    RF24:write register, reg=0, value=14
                    RF24:write register, reg=3, value=3
                    RF24:write register, reg=4, value=95
                    RF24:write register, reg=5, value=76
                    RF24:write register, reg=6, value=39
                    RF24:read register, reg=6, value=255
                    RF24:read register, reg=5, value=255
                    RF24:Sanity check failed: configuration mismatch! Check wiring, replace module or non-P version
                    !TSM:RADIO:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    RF24:write register, reg=0, value=12
                    RF24:power down
                    I have changed the radio module to new one without success. So there must be some other reason why this sketch does not work in my hardware. Any ideas?
                      mortommy
                      Which module are you using? if it is NRF24L01+ be sure it is the "plus" version.
                      • pentti12P
                        pentti12P
                        pentti12
                        At least I have ordered nRF24L01+ versions. And I use them on other MySensors node and they are working OK.
                        • pentti12P
                          pentti12P
                          pentti12
                          Update:
                          I changed Arduino Board from Arduino Mega R3 to Arduino UNO board. I placed my protoshield above UNO-board and now I got following response:
                          TSM:INIT
                          RF24:read register, reg=6, value=39
                          RF24:read register, reg=5, value=76
                          RF24:write register, reg=16, value=115
                          RF24:write register, reg=29, value=6
                          RF24:write register, reg=2, value=2
                          RF24:write register, reg=1, value=0
                          RF24:write register, reg=28, value=3
                          RF24:flushRX
                          RF24:flushTX
                          RF24:write register, reg=7, value=112
                          TSM:RADIO:OK
                          RF24:write register, reg=2, value=3
                          RF24:write register, reg=1, value=1
                          RF24:start listening
                          RF24:write register, reg=0, value=15
                          RF24:write register, reg=10, value=9
                          TSP:ASSIGNID:OK (ID=9)
                          TSM:FPAR
                          RF24:stop listening
                          RF24:open writing pipe, recipient=255
                          RF24:write register, reg=10, value=255
                          RF24:write register, reg=16, value=255
                          RF24:send message to 255, len=7
                          RF24:flushTX
                          RF24:write register, reg=7, value=48
                          RF24:MAX_RT
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                          TSM:FPAR
                          RF24:stop listening
                          RF24:flushTX
                          RF24:MAX_RT
                          RF24:flushTX
                          RF24:read message, len=8
                          RF24:write register, reg=7, value=64
                          TSP:MSG:READ 0-0-9 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          TSP:MSG:PAR OK (ID=0, dist=1)
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:CHKID:OK (ID=9)
                          TSM:UPL
                          TSP:PING:SEND (dest=0)
                          RF24:stop listening
                          RF24:open writing pipe, recipient=0
                          RF24:write register, reg=10, value=0
                          RF24:write register, reg=16, value=0
                          RF24:send message to 0, len=8
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                          TSP:MSG:READ 0-0-9 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          TSP:MSG:PONG RECV (hops=1)
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          Setup... end.
                          RF24:stop listening
                          RF24:send message to 0, len=9
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                          RF24:stop listening
                          RF24:send message to 0, len=12
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                          RF24:stop listening
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                          RF24:read message, len=9
                          TSP:MSG:READ 0-0-9 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          Incoming message: 15
                          RF24:stop listening
                          RF24:send message to 0, len=21
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,ft=0,st=ok:MySensorDioder
                          RF24:stop listening
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                          RF24:stop listening
                          RF24:send message to 0, len=7
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=0,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                          RF24:stop listening
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=1,c=0,t=26,pt=0,l=0,sg=0,ft=0,st=ok:
                          Request registration...
                          RF24:stop listening
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                          TSP:MSG:READ 0-0-9 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          Node registration=1
                          Init complete, id=9, parent=0, distance=1, registration=1
                          Wheel position changed.
                          Wheel position: 0
                          Hue value of the Wheel position: 0
                          Send command to lights.
                          Bright: 0
                          Red: 0
                          Green: 0
                          Blue: 0
                          RGB in HEX: 000000
                          RF24:stop listening
                          RF24:send message to 0, len=11
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=0,c=1,t=3,pt=4,l=4,sg=0,ft=0,st=ok:0
                          RF24:stop listening
                          RF24:send message to 0, len=13
                          RF24:flushTX
                          TSP:MSG:SEND 9-9-0-0 s=1,c=1,t=40,pt=0,l=6,sg=0,ft=0,st=ok:000000
                          Now sketch seems to work. I will continue by adding IKEA DIODER Leds. More info later.
                          • pentti12P
                            pentti12P
                            pentti12
                            Update:
                            I can control locally the IKEA DIODER now. So the hardware is more or less working as expected, but do you have good instructions how I can get OpenHAB2 and MySensors Ethernet Gateway working together. Today I can see MySensors Ethernet Gateway ONLINE state and I can manually add Custom Sensor as a thing, but I cannot control items via Openhab.
                            I use the latest OH2 Snapshot ( on Pine64 with Debian Jessie) and latest MySensors GatewayW5100 (library 2.0) on the MySensors Gateway (Arduino UNO based) and I have tried to start/stop/restart OH2 after MySensors Gateway is up and running without success.
                            OH2 is capable to control for example Philips HUE lights without problems at the moment.
                              mortommy
                              wrote on last edited by mortommy
                              #40
                              Great news!
                              Regarding OH, I didn't have the opportunity to play with the v2.0 yet, I'm still on 1.8.1.
                              I have a serial mysensors gateway and this is my set up:
                              OH (v1.8.1) <-> OH MQTT binding (as MQTT client) <-> Mosquitto (as MQTT server) <-> mosquitto to serial (python script that reverts messages with topic mysensors to the serial port and vice-versa) <-> serial gateway.
                              So my items in OH are based on mqtt binding.
                              I guess OH2 and mysensors openhab binding make everything easier.
                              • pentti12P
                                pentti12P
                                pentti12
                                Do you have interest to try OH2 together with MySensors Ethernet Gateway to get working?
                                I do not have enough force to push developers to make this happen. At the moment there is some problem on this, because full control is not possible. I think that MySensors Serial Gateway is working with OH2, but I don't like to use it. I like to connect my devices into LAN not cabling via old fashioned way using serial wires.
