  3. Gateway Not Working
Gateway Not Working
43 Posts 5 Posters 21.0k Views 2 Watching
  • clippermiamiC
    clippermiamiC
    clippermiami
    Well, my "new" Ethernet shield arrived and there is no change.
    The Vera logs reflect what would be expected, no response from the Arduino Gateway
    root@MiOS_30010119:/tmp/log/cmh# tail -f LuaUPnP.log | grep "192.168.15.118"
    4547 root 1672 S ping -c 1 192.168.15.118
    4545 root 1676 S /bin/sh -c ping -c 1 192.168.15.118
    4575 root 1672 S grep 192.168.15.118
    50 04/28/14 14:48:11.941 luup_log:292: Arduino: Using network connection: IP address is 192.168.15.118:5001 <0x2b92f680>
    01 04/28/14 14:48:14.956 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:48:21.966 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:48:28.976 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:48:35.986 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:48:42.996 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:48:50.006 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:48:57.026 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:49:04.036 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:49:11.046 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:49:18.056 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:49:25.066 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:49:32.076 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:49:39.086 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:49:45.156 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:49:52.166 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    01 04/28/14 14:49:59.176 IOPort::Connect connect -1 192.168.15.118:5001 <0x35640680>
    ^C
    So I guess the enext step is to fall back to the Serial Gateway as @hek has suggested and try to go forward from there.
    • clippermiamiC
      clippermiamiC
      clippermiami
      wrote on last edited by clippermiami
      As @hek suggested I went to the SerialGateway route and it it appears to have worked, at least Vera can apparently talk to it I no longer get Lua startup failures. The "Lib version" is 1.2+ and clicking "Start" inclusion results in "0 devices found" --- there are no sensors built yet so that makes sense.
      I'd still like to get the Ethernet version working, I want to place the gateway elsewhere. But at this point i know my Arduino works and it does compile and upload, Vera can talk to it.
      • clippermiamiC
        clippermiamiC
        clippermiami
        I've built and installed the serial Gateway (Arduino Nano ATMEGA328) and I've wired up a Light Sensor (Arduino Pro Mini 5v ATMEGA328).
        Apparently Vera recognizes the Gateway, the Vera USB LED flashes continuously several times per second I get nothing attempting to include a device from the Vera Plugin.
        I've brought both the Gateway and Sensor up on a PC on separate USB ports and started the Serial Port Monitor for each, the Gateway on COM6 and the Sensor on COM11. When I power up the devices I get "0;0;4;11;Arduino startup complete." on each and that's it. I tried manually sending a message in each direction but I do not get anything on the other end and there is no confirmation that it was sent or received.
        The "Arduino startup complete" tells me that both Arduinos are OK and that the programs are running on each.
        • clippermiamiC
          clippermiamiC
          clippermiami
          On a guess I changed the radio modules on the Gateway and the Sensor to no avail.
          If I accidentally touch the Gateway Nano I get a few dozen outputs like this:
          0;0;4;11;Message available on pipe 7
          But nothing else.
          I'm composing messages on each end as follows:
          0;0;4;11;Test Message "x"
          There is no indication that these messages are processed on either end let alone transmitted.
          hekH 1 Reply Last reply
          • clippermiamiC clippermiami
            But nothing else.
            @clippermiami
            What example sketch are you running on the sensor node?
            What do you mean by "0;0;4;11;Test Message "x""? Where are you composing this message? Are you using the MySensors API to send a message?
            Just stay calm .. we will fix this :smile:
            • clippermiamiC
              clippermiamiC
              clippermiami
              @hek I'm running the Light Sensor example from the web site.
              The message I composed in the send window at the top of the Serial Monitor dialog. I tried all sorts of things from a simple text "TEST" to the example I gave. I noticed the Arduino Startup complete message was prefaced with "0;0;4;11; " so I tried that in case the logic required some sort of preamble
              I'm calm :-)
              John
                wrote on last edited by hek
                #22
                AH.. ok. but the 0;0;4;11 issues a debug print to controller (from gateway) and does not use the radio parts.
                Have you followed these instructions to enable debug prints?
                http://www.mysensors.org/build/debug
                When debug is enabled upload your light sensor sketch again and watch the serial-output.
                clippermiamiC 1 Reply Last reply
                  clippermiamiC
                  clippermiamiC
                  clippermiami
                  #23
                  @hek I did as the "debug" said, which is why I'm guessing i got the "Arduino statup complete" message as I had not seen that in previous attempts without the debug set, and I got exactly what I said, nothing on either end.
                  I wasn't aware of the meaning of the "0;0;4;11;" part but that was just the latest of several things tried. I already tried simple plain text "Testing", "Test 1", etc. and got nothing on either end.
                  The compile/upload works fine and it sends the startup message so I'm assuming that both Arduinos are working and the base code is executing as intended. I've done, undone and redone the wiring on both ends several times; I've swapped the radio modules on both ends, I've compiled and recompiled, uploaded and re-uploaded, the code several times, with and without the debug. i'm running out of ideas. Its obviously something I'm doing wrong or some defective item because I'm the only one with the problem. But I swear I don't know what it is.
                    If you had enabled debug correctly you would see much more information in the Serial Monitor when you turn on on the light sensor and it is hooked up to your computer.
                      @clippermiami said:
                      Wait a minute... in you previous post you said that gateway AND sensor outputs this:
                      But that makes no sense. Sensors do not print this at startup... only gateway does. Are you sure you have uploaded the Sensor sketch correctly?
                        clippermiamiC
                        clippermiamiC
                        clippermiami
                        @hek I'll do it again, as I said i've done it several times but I'm running out of ideas :)
                        Right now i have both devices on the same notebook PC on different USB/Com ports obviously. I'll recompile the light sensor and upload it again, i suppose I could have messed that up along the way.
                        • clippermiamiC
                          clippermiamiC
                          clippermiami
                          #27
                          @hek
                          I have no idea how they got crossed but they were apparently. When I started the sensor I get this. so NOW i apparently have the sensor code running on the senor.
                          Started sensor.
                          Open ping reading pipe: 255
                          Tx: fr=255,to=255,la=255,ne=255,ci=255,mt=4,ty=9,cr=184:
                          No relay nodes was found. Trying again in 10 seconds.
                          However, it still not working, the sensor can't find a "relay" node? Nothing happens at the gateway other than the startup complete message
                          UPDATE:
                          Changed radios again on both ends and restarted with no change.
                          BTW, the Sensor code is a cut/paste from the listing on the mysensors.org web site
                          • clippermiamiC
                            clippermiamiC
                            clippermiami
                            A further update, on the off chance I swapped out the Gateway Arduino Nano board, recompiled and uploaded the Serial Gateway code. Same as before.
                            Can someone tell me what this means:
                            And if it offers any guidance as to what is wrong. The Sensor code was a cut/paste from the code on the web site so it ought o be correct.
                              @clippermiami
                              Your sensor is trying to get in contact with either the gateway or an relaying node. It's trying to find the way home so to say.
                              Once it get contact with something it will request an unique radio-id.
                              So either you haven't started the gateway or having radio-problem. Did you put capacitors on the radios?
                                @clippermiami
                                clippermiamiC
                                clippermiamiC
                                clippermiami
                                @hek
                                Sounds like the sensor end is working. i've put LEDs on the three leads defined in the sketch and there is nothing happening on any of them so I'm guessing that something basic is wrong with the Gateway.
                                i've tried the capacitors and no change so far. At this point I'd think that at least one of the LEDs (Tx, TX or Error) would indicate something.
                                BTW, i appreciate your patience with a newbie.
                                  @hek
                                  @clippermiami
                                  And your using the simple radio model on both ends (no amplified radio)?
                                  Are you really sure the radio-wiring is correct? And no lose contacts (it has happened more than once for me:) ?
                                  The radios also seems to be very sensitive when it comes to stability of the power feeding (sometimes). Do you have the possibility to feed them through Wall-wart/USB or something else than your computer?
                                    @clippermiami
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    me too. More than I care to admit and more frustrating than anything.
                                    @clippermiami
                                    did you switch out the jumper wires already, too?
                                    • clippermiamiC
                                      clippermiamiC
                                      clippermiami
                                      I think i've found the problem.
                                      In the instructions on mysensors.org under building the USB-Serial Gateway it says
                                      [code]
                                      Building a USB-connected Gateway
                                      NOTE: You must use an Arduino Nano for the USB version of the gateway. The Nano is the officially supported and tested model so if you try a different version, we cannot guarantee that the Vera will recognize it.
                                      Start by connecting the radio module.
                                      [/code]
                                      When you follow the link to "connecting the radio module it leads to a Arduino Pro-Mini configuration NOT a Nano. I used the radio configuration from the Ethernet gateway because it depicts the wiring for a Nano.
                                      I found some code on forum.micasaverde.com that was to debug the radio connection and put it in my Gateway code and it says the **radio is not connected properly. **
                                      So now i'm confused, what wiring IS correct for the NANO in the USB Serial Gateway?
                                        Yes, the radio wiring is different for ethernet vs serial version of the gateway.
                                        So, like the instructions say, when building the Serial version you should follow the guide here:
                                        http://www.mysensors.org/build/connect_radio
                                        The pin numbers is identical between pro mini and nano.
                                          clippermiamiC
                                          clippermiamiC
                                          clippermiami
                                          @hek As I recall the difference is in pins for CE/CSN (from memory here so I may be wrong) in which case my radio is in fact wired incorrectly as it used the Nano pinout from the Ethernet Gateway. I shall fix it and hopefully everything will start to play together. (Fingers, toes, legs, eyes crossed :-) )
                                          12.5k
