  3. Gateway Not Working
Gateway Not Working
43 Posts 5 Posters 21.0k Views 2 Watching
  • clippermiamiC clippermiami
    On a guess I changed the radio modules on the Gateway and the Sensor to no avail.
    If I accidentally touch the Gateway Nano I get a few dozen outputs like this:
    0;0;4;11;Message available on pipe 7
    But nothing else.
    I'm composing messages on each end as follows:
    0;0;4;11;Test Message "x"
    There is no indication that these messages are processed on either end let alone transmitted.
    @clippermiami
    What example sketch are you running on the sensor node?
    What do you mean by "0;0;4;11;Test Message "x""? Where are you composing this message? Are you using the MySensors API to send a message?
    Just stay calm .. we will fix this :smile:
    • clippermiamiC
      clippermiamiC
      clippermiami
      @hek I'm running the Light Sensor example from the web site.
      The message I composed in the send window at the top of the Serial Monitor dialog. I tried all sorts of things from a simple text "TEST" to the example I gave. I noticed the Arduino Startup complete message was prefaced with "0;0;4;11; " so I tried that in case the logic required some sort of preamble
      I'm calm :-)
      John
        wrote on last edited by hek
        #22
        AH.. ok. but the 0;0;4;11 issues a debug print to controller (from gateway) and does not use the radio parts.
        Have you followed these instructions to enable debug prints?
        http://www.mysensors.org/build/debug
        When debug is enabled upload your light sensor sketch again and watch the serial-output.
        clippermiamiC 1 Reply Last reply
          clippermiamiC
          clippermiamiC
          clippermiami
          wrote on last edited by clippermiami
          #23
          @hek I did as the "debug" said, which is why I'm guessing i got the "Arduino statup complete" message as I had not seen that in previous attempts without the debug set, and I got exactly what I said, nothing on either end.
          I wasn't aware of the meaning of the "0;0;4;11;" part but that was just the latest of several things tried. I already tried simple plain text "Testing", "Test 1", etc. and got nothing on either end.
          The compile/upload works fine and it sends the startup message so I'm assuming that both Arduinos are working and the base code is executing as intended. I've done, undone and redone the wiring on both ends several times; I've swapped the radio modules on both ends, I've compiled and recompiled, uploaded and re-uploaded, the code several times, with and without the debug. i'm running out of ideas. Its obviously something I'm doing wrong or some defective item because I'm the only one with the problem. But I swear I don't know what it is.
            If you had enabled debug correctly you would see much more information in the Serial Monitor when you turn on on the light sensor and it is hooked up to your computer.
              @clippermiami said:
              Wait a minute... in you previous post you said that gateway AND sensor outputs this:
              Arduino startup complete.
              But that makes no sense. Sensors do not print this at startup... only gateway does. Are you sure you have uploaded the Sensor sketch correctly?
                clippermiamiC
                clippermiamiC
                clippermiami
                @hek I'll do it again, as I said i've done it several times but I'm running out of ideas :)
                Right now i have both devices on the same notebook PC on different USB/Com ports obviously. I'll recompile the light sensor and upload it again, i suppose I could have messed that up along the way.
                • clippermiamiC
                  clippermiamiC
                  clippermiami
                  #27
                  @hek
                  I have no idea how they got crossed but they were apparently. When I started the sensor I get this. so NOW i apparently have the sensor code running on the senor.
                  Started sensor.
                  Open ping reading pipe: 255
                  Tx: fr=255,to=255,la=255,ne=255,ci=255,mt=4,ty=9,cr=184:
                  No relay nodes was found. Trying again in 10 seconds.
                  However, it still not working, the sensor can't find a "relay" node? Nothing happens at the gateway other than the startup complete message
                  UPDATE:
                  Changed radios again on both ends and restarted with no change.
                  BTW, the Sensor code is a cut/paste from the listing on the mysensors.org web site
                  • clippermiamiC
                    clippermiamiC
                    clippermiami
                    A further update, on the off chance I swapped out the Gateway Arduino Nano board, recompiled and uploaded the Serial Gateway code. Same as before.
                    Can someone tell me what this means:
                    And if it offers any guidance as to what is wrong. The Sensor code was a cut/paste from the code on the web site so it ought o be correct.
                    hekH 1 Reply Last reply
                      @clippermiami
                      Your sensor is trying to get in contact with either the gateway or an relaying node. It's trying to find the way home so to say.
                      Once it get contact with something it will request an unique radio-id.
                      So either you haven't started the gateway or having radio-problem. Did you put capacitors on the radios?
                        @clippermiami
                        clippermiamiC
                        clippermiamiC
                        clippermiami
                        @hek
                        Sounds like the sensor end is working. i've put LEDs on the three leads defined in the sketch and there is nothing happening on any of them so I'm guessing that something basic is wrong with the Gateway.
                        i've tried the capacitors and no change so far. At this point I'd think that at least one of the LEDs (Tx, TX or Error) would indicate something.
                        BTW, i appreciate your patience with a newbie.
                          @hek
                          @clippermiami
                          And your using the simple radio model on both ends (no amplified radio)?
                          Are you really sure the radio-wiring is correct? And no lose contacts (it has happened more than once for me:) ?
                          The radios also seems to be very sensitive when it comes to stability of the power feeding (sometimes). Do you have the possibility to feed them through Wall-wart/USB or something else than your computer?
                            @clippermiami
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            me too. More than I care to admit and more frustrating than anything.
                            @clippermiami
                            did you switch out the jumper wires already, too?
                            • clippermiamiC
                              clippermiamiC
                              clippermiami
                              I think i've found the problem.
                              In the instructions on mysensors.org under building the USB-Serial Gateway it says
                              [code]
                              Building a USB-connected Gateway
                              NOTE: You must use an Arduino Nano for the USB version of the gateway. The Nano is the officially supported and tested model so if you try a different version, we cannot guarantee that the Vera will recognize it.
                              Start by connecting the radio module.
                              [/code]
                              When you follow the link to "connecting the radio module it leads to a Arduino Pro-Mini configuration NOT a Nano. I used the radio configuration from the Ethernet gateway because it depicts the wiring for a Nano.
                              I found some code on forum.micasaverde.com that was to debug the radio connection and put it in my Gateway code and it says the **radio is not connected properly. **
                              So now i'm confused, what wiring IS correct for the NANO in the USB Serial Gateway?
                                Yes, the radio wiring is different for ethernet vs serial version of the gateway.
                                So, like the instructions say, when building the Serial version you should follow the guide here:
                                http://www.mysensors.org/build/connect_radio
                                The pin numbers is identical between pro mini and nano.
                                  clippermiamiC
                                  clippermiamiC
                                  clippermiami
                                  @hek As I recall the difference is in pins for CE/CSN (from memory here so I may be wrong) in which case my radio is in fact wired incorrectly as it used the Nano pinout from the Ethernet Gateway. I shall fix it and hopefully everything will start to play together. (Fingers, toes, legs, eyes crossed :-) )
                                  • clippermiamiC
                                    clippermiamiC
                                    clippermiami
                                    Well, that didn't do it either. i do however now have a ERR LED indication on SOLID.
                                    I have the following wiring (checked, rechecked)
                                    Arduino...............Radio
                                    Pin 2 IRQ Gray
                                    Pin 4 LED Err
                                    Pin 5 LED Tx
                                    Pin 6 LED Rx
                                    Pin 9 CE Org
                                    Pin 10 CSN Yel
                                    Pin 11 MOSI Blue
                                    Pin 12 MISO Violet
                                    Pin 13 SCK Grn
                                    3.3 V Out Radio Vcc
                                    5v Out LEDs
                                    GND Radio GND
                                    4.7 uF Cap Radio Vcc to Radio GND
                                    Changed power supply from Laptop USB to separate 5V USB Wall Wart
                                      Pin 2 IRQ Gray
                                      Pin 4 LED Err
                                      Pin 5 LED Tx
                                      Pin 6 LED Rx
                                      Pin 9 CE Org
                                      Pin 10 CSN Yel
                                      Pin 11 MOSI Blue
                                      Pin 12 MISO Violet
                                      Pin 13 SCK Grn
                                      3.3 V Out Radio Vcc
                                      5v Out LEDs
                                      GND Radio GND
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @clippermiami
                                      I just had a similar connectivity issue with a project I was completing. I switched to 1.2A 5V cell phone charger and that did it...
                                      not enough power...
                                      What is the output of your wall wort?
                                        @clippermiami
                                        not enough power...
                                        clippermiamiC
                                        clippermiamiC
                                        clippermiami
                                        @BulldogLowell Rated 5 volts 1 amp. I'm having a hard time imagining this consuming that kind of power
                                          #39
                                          @clippermiami said:
                                          All looks ok from your description.
                                          Pin 4 LED Err
                                          Pin 5 LED Tx
                                          Pin 6 LED Rx
                                          ...and resistors in series I hope.
                                          Maybe you should go back and run some of the examples in RF24/examples folder. Remember to use the same CE/CSN in constructor when testing Ping sketch for example.
                                          12.5k
