  3. Vera
  4. UI5 Mysensors library 2.0 gateway issues
73 Posts 8 Posters 25.1k Views 8 Watching
    "This example" refers to the example found on the mysensors page.
    "uses the external DHT library" means you have to install the library in your ide by downloading it and install in your IDEs library path.
    If you want to fetch all the examples and support libraries in one schwong, use this link:
    https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
    ramoncarranzaR
    ramoncarranzaR
    ramoncarranza
    @hek I got my sensors working now. The radio unit on the GW was defective, so I swapped it out and things are working fine, just need to change the readings on my DHT from C to F, how would I do that?
      The unit format is normally updated from the controller. When the sensor starts it asks for the configuration.
      But you can always hard code none-metric by setting it to false here:
      https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino#L69
      .. and removing this line:
      https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino#L85
      ramoncarranzaR 2 Replies Last reply
        ramoncarranzaR
        ramoncarranzaR
        ramoncarranza
        @hek got it
          ramoncarranzaR
          ramoncarranzaR
          ramoncarranza
          @hek hi, how can I activate repeater mode on a particular sensor?, I've had to build 2 repeating nodes so far to be able to reach a couple of my sensors. I am adding more sensors as we speak and and they are getting farther and farther, I know I will need a ton of repeaters, but I hate to waste a radio and an Arduino board just for repeaters.
            https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes
            • ramoncarranzaR
              ramoncarranzaR
              ramoncarranza
              thanks so much, I am becoming a pro at this, one day YOU will come to me for questions lol.
                Hope so, I might soon get senile ;)
                ramoncarranzaR 1 Reply Last reply
                  ramoncarranzaR
                  ramoncarranzaR
                  ramoncarranza
                  @hek said:
                  senile
                  are the the sensors/nodes awake at all times by default?
                  • dbemowskD
                    dbemowskD
                    I had started a different thread that relates to this one and wasn't getting much for response, In my digging on the issue, I found this thread.
                    I have owned my new Vera Plus for over a week now and I cannot get my sensors communicating with Vera. I am running UI7 I believe, and I have my gateway built with a pro mini and an Easy Newbie board from OpenHardware.IO. I appear to be getting communication from nodes over the gateway according to what I am seeing in the log, but I am not able to include my sensors. CLearly, when I press start and stop, inclusion mode is starting and stopping as I see it in the logs. My issue though goes back to a post in this thread from 5 months ago where he addresses an issue with incomming commands being discarded. Here is a snippet from my log that shows the process:
                    I posted as an image so you can better see the highlighting. For my TemperatureAndHumidity node, I have manually set the node ID to 84 as can be seen in the logs. The 3 lines in yellow look to me to be the sensor attempting to present itself, but the presentation messages are being discarded. I have seen this both with my humidity sensor node and my garage door sensor node. In the post I referred to from 5 months ago from BartE, he linked to the development version of the plugin, so I even tried that. The log snippet shown above is from the development branch plugin. I was originally using the UI7 branch linked in the Vera how-to setup guide on the website. This had a bit of a different look, but the logs looked the same when I would attempt inclusion.
                    It is getting a bit discouraging since I have owned the controller for over a week now and I can't get the MySensors part working, which is mainly why I got it. If it means anything, I had my gateway and sensors working in Domoticz.
                    You guys have been GREAT so far, so any help is appreciated.
                      @dbemowsk
                      This message appears when a none included node receives data.
                      https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L466
                      I can't see any presentation message from your node (84).. It should say "c=0" something.
                      • dbemowskD
                        dbemowskD
                        #42
                        @hek, thanks for the quick reply.
                        You say "This message appears when a none included node receives data." but the only time I see those yellow lines is when I present the node.
                        I see under the last discarded command:
                        50	12/27/16 9:12:38.441	luup_log:10: Arduino: Log: TSP:MSG:READ 84-84-0 s=0,c=0,t=7,pt=0,l=0,sg=0: <0x73e23520>
                        50	12/27/16 9:12:38.443	luup_log:10: Arduino: Presentation: 84;0;0;0;7; <0x73e23520>
                        50	12/27/16 9:12:38.446	luup_log:10: Arduino: Log: TSP:MSG:READ 84-84-0 s=1,c=0,t=6,pt=0,l=0,sg=0: <0x73e23520>
                        50	12/27/16 9:12:38.448	luup_log:10: Arduino: Presentation: 84;1;0;0;6; <0x73e23520>
                        The two TSP:MSG:READ lines contain c=0. Is this what you were referring to?
                          wrote on last edited by hek
                          #43
                          Yes, very strange. Presentation comes in. How could I miss that.
                          I still run UI5 on my Vera. Wondering if they changed any behaviour in recent firmware updates?
                          • dbemowskD
                            dbemowskD
                            I find it hard to believe that no one here has used UI7 and not seen this. It is a bit frustrating.
                              What happens if you let vera hand out id?
                              Clear eeprom and re-upload sketch. And try to include again.
                              • dbemowskD
                                dbemowskD
                                That was one of my questions in the other thread. I was thinking that Vera wasn't handing out IDs, which is why I manually assigned it. I will try clearing eeprom and try again. I'll post the log results.
                                  Yes, the Vera plugin hands out ids.
                                  I can't really explain the weird behaviour you're seeing. Communication seems to work...
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    Thanks @hek for chipping in an looking at the problem @dbemowsk is experiencing. This is really beyond my knowledge an I cannot understan why it is not working. I am running the latest UI7 firmware on my Veralite test device, am I cannot reproduce this issue. Including MySensor devices is no problem even if I use static node adress.
                                    • Tomas
                                    • dbemowskD
                                      dbemowskD
                                      So I cleared the eeprom and re-uploaded the humidity sensor sketch. Had to rebuild it from the example because the arduino IDE crashed and erased it. That has happened to me a couple times now since starting with the IDE. This is with debug turned on and viewing the serial monitor. To me it looks like it fails to get an ID from Vera. This is what I was seeing before which was why I manually assigned the ID.
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                      TSM:FPAR
                                      TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      TSP:MSG:PAR OK (ID=0, dist=1)
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                      TSM:ID
                                      TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0 l=0,sg=0,ft=0,st=ok:
                                      TSM:ID
                                      TSM:ID
                                      !TSM:CHKID:FAIL (ID=255)
                                      !TSM:FAILURE
                                      TSM:PDT
                                      This is the Vera log from start to stop inclusion with the node trying to get an ID. Here I see no c=0 or presentation entries.
                                      50	12/27/16 12:24:41.287	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                                      08	12/27/16 12:24:42.769	JobHandler_LuaUPnP::HandleActionRequest device: 10 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StartInclusion <0x73c23520>
                                      08	12/27/16 12:24:42.770	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=10 <0x73c23520>
                                      08	12/27/16 12:24:42.770	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x73c23520>
                                      08	12/27/16 12:24:42.770	JobHandler_LuaUPnP::HandleActionRequest argument action=StartInclusion <0x73c23520>
                                      50	12/27/16 12:24:42.772	luup_log:10: Arduino: Sending: 0;0;3;0;5;1 <0x779ea320>
                                      04	12/27/16 12:24:42.774	 <0x779ea320>
                                      50	12/27/16 12:24:43.305	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                                      50	12/27/16 12:24:43.307	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                                      50	12/27/16 12:24:45.325	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                                      50	12/27/16 12:24:45.327	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                                      50	12/27/16 12:24:51.308	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x73e23520>
                                      50	12/27/16 12:24:51.310	luup_log:10: Arduino: Log: TSP:MSG:BC <0x73e23520>
                                      50	12/27/16 12:24:51.314	luup_log:10: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x73e23520>
                                      50	12/27/16 12:24:51.316	luup_log:10: Arduino: Log: TSP:CHKUPL:OK <0x73e23520>
                                      50	12/27/16 12:24:51.319	luup_log:10: Arduino: Log: TSP:MSG:GWL OK <0x73e23520>
                                      50	12/27/16 12:24:52.259	luup_log:10: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x73e23520>
                                      50	12/27/16 12:24:53.331	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x73e23520>
                                      50	12/27/16 12:24:53.332	luup_log:10: Arduino: Log: TSP:MSG:BC <0x73e23520>
                                      50	12/27/16 12:24:53.334	luup_log:10: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x73e23520>
                                      50	12/27/16 12:24:53.339	luup_log:10: Arduino: Log: TSP:CHKUPL:OK (FLDCTRL) <0x73e23520>
                                      50	12/27/16 12:24:53.340	luup_log:10: Arduino: Log: TSP:MSG:GWL OK <0x73e23520>
                                      50	12/27/16 12:24:54.252	luup_log:10: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x73e23520>
                                      50	12/27/16 12:24:57.369	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                                      50	12/27/16 12:24:57.370	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                                      50	12/27/16 12:24:59.388	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                                      50	12/27/16 12:24:59.390	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                                      50	12/27/16 12:25:01.408	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                                      50	12/27/16 12:25:01.410	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                                      50	12/27/16 12:25:13.497	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x73e23520>
                                      50	12/27/16 12:25:13.499	luup_log:10: Arduino: Log: TSP:MSG:BC <0x73e23520>
                                      50	12/27/16 12:25:13.503	luup_log:10: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x73e23520>
                                      50	12/27/16 12:25:13.505	luup_log:10: Arduino: Log: TSP:CHKUPL:OK <0x73e23520>
                                      50	12/27/16 12:25:13.507	luup_log:10: Arduino: Log: TSP:MSG:GWL OK <0x73e23520>
                                      08	12/27/16 12:25:13.563	JobHandler_LuaUPnP::HandleActionRequest device: 10 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StopInclusion <0x74423520>
                                      08	12/27/16 12:25:13.564	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=10 <0x74423520>
                                      08	12/27/16 12:25:13.564	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x74423520>
                                      08	12/27/16 12:25:13.564	JobHandler_LuaUPnP::HandleActionRequest argument action=StopInclusion <0x74423520>
                                      50	12/27/16 12:25:13.565	luup_log:10: Arduino: Sending: 0;0;3;0;5;0 <0x779ea320>
                                      04	12/27/16 12:25:13.567	 <0x779ea320>
                                      I am not sure what to do next.
                                        #50
                                        Hmm.. it looks like your Vera is sending out id 255.. (255;255;3;0;4;255) which usually means that all ids has been used up.
                                        https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L299
                                        The table of used ids is build during plugin startup.. here:
                                        https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L686
                                        I have no idea why this get filled up (or why the plugin thinks so..) when you don't have any child devices to your gateway.
                                        dbemowskD 1 Reply Last reply
                                          dbemowskD
                                          dbemowskD
                                          @hek Is there any way for me to debug what is happening with the availableIds[i] array? or at least finding where it is stored and clearing it? If not, maybe I'll try restoring my unit to default and try again. I am assuming that would clear the availableIds array. The only thing I currently have set up on the unit is my 1-Wire temp sensors, and there is only 7 of them. I can rebuild those easy enough.
