  3. Vera
  4. UI5 Mysensors library 2.0 gateway issues
73 Posts 8 Posters 25.1k Views 8 Watching
    https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes
    • ramoncarranzaR
      ramoncarranzaR
      ramoncarranza
      thanks so much, I am becoming a pro at this, one day YOU will come to me for questions lol.
        Hope so, I might soon get senile ;)
        ramoncarranzaR 1 Reply Last reply
          ramoncarranzaR
          ramoncarranzaR
          ramoncarranza
          @hek said:
          senile
          are the the sensors/nodes awake at all times by default?
          • dbemowskD
            dbemowskD
            I had started a different thread that relates to this one and wasn't getting much for response, In my digging on the issue, I found this thread.
            I have owned my new Vera Plus for over a week now and I cannot get my sensors communicating with Vera. I am running UI7 I believe, and I have my gateway built with a pro mini and an Easy Newbie board from OpenHardware.IO. I appear to be getting communication from nodes over the gateway according to what I am seeing in the log, but I am not able to include my sensors. CLearly, when I press start and stop, inclusion mode is starting and stopping as I see it in the logs. My issue though goes back to a post in this thread from 5 months ago where he addresses an issue with incomming commands being discarded. Here is a snippet from my log that shows the process:
            I posted as an image so you can better see the highlighting. For my TemperatureAndHumidity node, I have manually set the node ID to 84 as can be seen in the logs. The 3 lines in yellow look to me to be the sensor attempting to present itself, but the presentation messages are being discarded. I have seen this both with my humidity sensor node and my garage door sensor node. In the post I referred to from 5 months ago from BartE, he linked to the development version of the plugin, so I even tried that. The log snippet shown above is from the development branch plugin. I was originally using the UI7 branch linked in the Vera how-to setup guide on the website. This had a bit of a different look, but the logs looked the same when I would attempt inclusion.
            It is getting a bit discouraging since I have owned the controller for over a week now and I can't get the MySensors part working, which is mainly why I got it. If it means anything, I had my gateway and sensors working in Domoticz.
            You guys have been GREAT so far, so any help is appreciated.
              @dbemowsk
              This message appears when a none included node receives data.
              https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L466
              I can't see any presentation message from your node (84).. It should say "c=0" something.
              • dbemowskD
                dbemowskD
                #42
                @hek, thanks for the quick reply.
                You say "This message appears when a none included node receives data." but the only time I see those yellow lines is when I present the node.
                I see under the last discarded command:
                50	12/27/16 9:12:38.441	luup_log:10: Arduino: Log: TSP:MSG:READ 84-84-0 s=0,c=0,t=7,pt=0,l=0,sg=0: <0x73e23520>
                50	12/27/16 9:12:38.443	luup_log:10: Arduino: Presentation: 84;0;0;0;7; <0x73e23520>
                50	12/27/16 9:12:38.446	luup_log:10: Arduino: Log: TSP:MSG:READ 84-84-0 s=1,c=0,t=6,pt=0,l=0,sg=0: <0x73e23520>
                50	12/27/16 9:12:38.448	luup_log:10: Arduino: Presentation: 84;1;0;0;6; <0x73e23520>
                The two TSP:MSG:READ lines contain c=0. Is this what you were referring to?
                  wrote on last edited by hek
                  #43
                  Yes, very strange. Presentation comes in. How could I miss that.
                  I still run UI5 on my Vera. Wondering if they changed any behaviour in recent firmware updates?
                  • dbemowskD
                    dbemowskD
                    I find it hard to believe that no one here has used UI7 and not seen this. It is a bit frustrating.
                      What happens if you let vera hand out id?
                      Clear eeprom and re-upload sketch. And try to include again.
                      • dbemowskD
                        dbemowskD
                        That was one of my questions in the other thread. I was thinking that Vera wasn't handing out IDs, which is why I manually assigned it. I will try clearing eeprom and try again. I'll post the log results.
                          Yes, the Vera plugin hands out ids.
                          I can't really explain the weird behaviour you're seeing. Communication seems to work...
                          • korttomaK
                            korttomaK
                            korttoma
                            Thanks @hek for chipping in an looking at the problem @dbemowsk is experiencing. This is really beyond my knowledge an I cannot understan why it is not working. I am running the latest UI7 firmware on my Veralite test device, am I cannot reproduce this issue. Including MySensor devices is no problem even if I use static node adress.
                            • Tomas
                            • dbemowskD
                              dbemowskD
                              So I cleared the eeprom and re-uploaded the humidity sensor sketch. Had to rebuild it from the example because the arduino IDE crashed and erased it. That has happened to me a couple times now since starting with the IDE. This is with debug turned on and viewing the serial monitor. To me it looks like it fails to get an ID from Vera. This is what I was seeing before which was why I manually assigned the ID.
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                              TSM:FPAR
                              TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                              TSP:MSG:PAR OK (ID=0, dist=1)
                              TSM:FPAR:OK
                              TSM:ID
                              TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                              TSM:ID
                              TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0 l=0,sg=0,ft=0,st=ok:
                              TSM:ID
                              TSM:ID
                              !TSM:CHKID:FAIL (ID=255)
                              !TSM:FAILURE
                              TSM:PDT
                              This is the Vera log from start to stop inclusion with the node trying to get an ID. Here I see no c=0 or presentation entries.
                              50	12/27/16 12:24:41.287	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                              08	12/27/16 12:24:42.769	JobHandler_LuaUPnP::HandleActionRequest device: 10 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StartInclusion <0x73c23520>
                              08	12/27/16 12:24:42.770	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=10 <0x73c23520>
                              08	12/27/16 12:24:42.770	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x73c23520>
                              08	12/27/16 12:24:42.770	JobHandler_LuaUPnP::HandleActionRequest argument action=StartInclusion <0x73c23520>
                              50	12/27/16 12:24:42.772	luup_log:10: Arduino: Sending: 0;0;3;0;5;1 <0x779ea320>
                              04	12/27/16 12:24:42.774	 <0x779ea320>
                              50	12/27/16 12:24:43.305	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                              50	12/27/16 12:24:43.307	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                              50	12/27/16 12:24:45.325	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                              50	12/27/16 12:24:45.327	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                              50	12/27/16 12:24:51.308	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x73e23520>
                              50	12/27/16 12:24:51.310	luup_log:10: Arduino: Log: TSP:MSG:BC <0x73e23520>
                              50	12/27/16 12:24:51.314	luup_log:10: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x73e23520>
                              50	12/27/16 12:24:51.316	luup_log:10: Arduino: Log: TSP:CHKUPL:OK <0x73e23520>
                              50	12/27/16 12:24:51.319	luup_log:10: Arduino: Log: TSP:MSG:GWL OK <0x73e23520>
                              50	12/27/16 12:24:52.259	luup_log:10: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x73e23520>
                              50	12/27/16 12:24:53.331	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x73e23520>
                              50	12/27/16 12:24:53.332	luup_log:10: Arduino: Log: TSP:MSG:BC <0x73e23520>
                              50	12/27/16 12:24:53.334	luup_log:10: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x73e23520>
                              50	12/27/16 12:24:53.339	luup_log:10: Arduino: Log: TSP:CHKUPL:OK (FLDCTRL) <0x73e23520>
                              50	12/27/16 12:24:53.340	luup_log:10: Arduino: Log: TSP:MSG:GWL OK <0x73e23520>
                              50	12/27/16 12:24:54.252	luup_log:10: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x73e23520>
                              50	12/27/16 12:24:57.369	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                              50	12/27/16 12:24:57.370	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                              50	12/27/16 12:24:59.388	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                              50	12/27/16 12:24:59.390	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                              50	12/27/16 12:25:01.408	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                              50	12/27/16 12:25:01.410	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                              50	12/27/16 12:25:13.497	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x73e23520>
                              50	12/27/16 12:25:13.499	luup_log:10: Arduino: Log: TSP:MSG:BC <0x73e23520>
                              50	12/27/16 12:25:13.503	luup_log:10: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x73e23520>
                              50	12/27/16 12:25:13.505	luup_log:10: Arduino: Log: TSP:CHKUPL:OK <0x73e23520>
                              50	12/27/16 12:25:13.507	luup_log:10: Arduino: Log: TSP:MSG:GWL OK <0x73e23520>
                              08	12/27/16 12:25:13.563	JobHandler_LuaUPnP::HandleActionRequest device: 10 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StopInclusion <0x74423520>
                              08	12/27/16 12:25:13.564	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=10 <0x74423520>
                              08	12/27/16 12:25:13.564	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x74423520>
                              08	12/27/16 12:25:13.564	JobHandler_LuaUPnP::HandleActionRequest argument action=StopInclusion <0x74423520>
                              50	12/27/16 12:25:13.565	luup_log:10: Arduino: Sending: 0;0;3;0;5;0 <0x779ea320>
                              04	12/27/16 12:25:13.567	 <0x779ea320>
                              I am not sure what to do next.
                                #50
                                Hmm.. it looks like your Vera is sending out id 255.. (255;255;3;0;4;255) which usually means that all ids has been used up.
                                https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L299
                                The table of used ids is build during plugin startup.. here:
                                https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L686
                                I have no idea why this get filled up (or why the plugin thinks so..) when you don't have any child devices to your gateway.
                                dbemowskD 1 Reply Last reply
                                  dbemowskD
                                  dbemowskD
                                  @hek Is there any way for me to debug what is happening with the availableIds[i] array? or at least finding where it is stored and clearing it? If not, maybe I'll try restoring my unit to default and try again. I am assuming that would clear the availableIds array. The only thing I currently have set up on the unit is my 1-Wire temp sensors, and there is only 7 of them. I can rebuild those easy enough.
                                    Well, it iterates over all vera devices (luup.devices) and checks if anyone is has the current device as parent... which means it is a child device.
                                    For each child device it adds it to the array. The problem here is that it shouldn't find any child devices.. thus the availableIds should all be filled with false.
                                    Maybe you could add some debug logging in the section I pointed out to see what kind of devices it picks up?
                                    • dbemowskD
                                      dbemowskD
                                      I am more than interested in trying, I just need a little guidance on how to do that.
                                      In the nextAvailiableRadioId() function I could do the following before it searches for an ID, I am just not sure what code to use to find out what device is defined for that ID.
                                      	for i=1,255 do
                                      		if (availableIds[i] == false) then
                                      			--add code to log what device is holding this spot
                                      		end
                                      	end
                                        It might be more interesting if you'd add some logging in this area, which should appear in the log when you reload the luup engine:
                                        https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L682-L687
                                        v contains the device. See what it contains under "variable: devices" here:
                                        http://wiki.micasaverde.com/index.php/Luup_Lua_extensions
                                        • dbemowskD
                                          dbemowskD
                                          OK, so here is what I did:
                                          	-- build an lookup table for child device ids (altid -> id)
                                          	local lastDev = 0
                                          	for k, v in pairs(luup.devices) do
                                          		-- for debugging only remove for production run
                                          		for k2, v2 in pairs(v) do
                                          			if (k ~= lastDev) then
                                          				luup.log("Device #" .. k .. ":" .. k2 .. "=" .. tostring(v2))
                                          				luup.log("           " .. k2 .. "=" .. tostring(v2))
                                          			end
                                          			lastDev = k
                                          		end
                                          		-- end debugging
                                          		-- if I am the parent device
                                          		if v.device_num_parent == ARDUINO_DEVICE then
                                          			childIdLookupTable[v.id] = k
                                          			local split = v.id:split(";")
                                          			local radioId = tonumber(split[1])
                                          			availableIds[radioId] = false;
                                          		end
                                          	end
                                          I did this to show me every attribute of every device that the system sees. After the luup engine restarts, I get this in the logs:
                                          50	12/27/16 15:58:48.117	luup_log:19: Initialising One Wire Server <0x76be5520>
                                          50	12/27/16 15:58:48.221	luup_log:27: Arduino plugin: loading library L_Arduino ... <0x76be5520>
                                          50	12/27/16 15:58:48.239	luup_log:27: Arduino plugin: library L_Arduino loaded <0x76be5520>
                                          50	12/27/16 15:58:48.239	luup_log:27: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.5, 27 <0x76be5520>
                                          50	12/27/16 15:58:48.239	luup_log:27: Arduino: Trying for a serial connection <0x76be5520>
                                          50	12/27/16 15:58:48.240	luup_log:27: Arduino: Serial port is connected <0x76be5520>
                                          50	12/27/16 15:58:48.240	luup_log:27: Arduino: Baud is 115200 <0x76be5520>
                                          50	12/27/16 15:58:48.240	luup_log:27: Device #1:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.241	luup_log:27:            category_num=19 <0x76be5520>
                                          50	12/27/16 15:58:48.241	luup_log:27:            description=ZWave <0x76be5520>
                                          50	12/27/16 15:58:48.241	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.242	luup_log:27:            id= <0x76be5520>
                                          50	12/27/16 15:58:48.242	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.242	luup_log:27:            ip= <0x76be5520>
                                          50	12/27/16 15:58:48.242	luup_log:27:            room_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.242	luup_log:27:            udn=uuid:4d494342-5342-5645-0001-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.243	luup_log:27:            subcategory_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.243	luup_log:27:            invisible=true <0x76be5520>
                                          50	12/27/16 15:58:48.243	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.243	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.243	luup_log:27:            device_num_parent=0 <0x76be5520>
                                          50	12/27/16 15:58:48.243	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:ZWaveNetwork:1 <0x76be5520>
                                          50	12/27/16 15:58:48.244	luup_log:27: Device #2:mac=000D6F000C5BC6E6 <0x76be5520>
                                          50	12/27/16 15:58:48.244	luup_log:27:            category_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.244	luup_log:27:            description=Zigbee Network <0x76be5520>
                                          50	12/27/16 15:58:48.244	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.245	luup_log:27:            id= <0x76be5520>
                                          50	12/27/16 15:58:48.245	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.245	luup_log:27:            ip= <0x76be5520>
                                          50	12/27/16 15:58:48.245	luup_log:27:            room_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.245	luup_log:27:            udn=uuid:4d494342-5342-5645-0002-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.246	luup_log:27:            subcategory_num=-1 <0x76be5520>
                                          50	12/27/16 15:58:48.246	luup_log:27:            invisible=true <0x76be5520>
                                          50	12/27/16 15:58:48.246	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.246	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.246	luup_log:27:            device_num_parent=0 <0x76be5520>
                                          50	12/27/16 15:58:48.247	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:ZigbeeNetwork:1 <0x76be5520>
                                          50	12/27/16 15:58:48.247	luup_log:27: Device #3:mac=B4:A5:EF:ED:58:1D <0x76be5520>
                                          50	12/27/16 15:58:48.247	luup_log:27:            category_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.247	luup_log:27:            description=Bluetooth Network <0x76be5520>
                                          50	12/27/16 15:58:48.247	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.247	luup_log:27:            id= <0x76be5520>
                                          50	12/27/16 15:58:48.248	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.248	luup_log:27:            ip= <0x76be5520>
                                          50	12/27/16 15:58:48.248	luup_log:27:            room_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.248	luup_log:27:            udn=uuid:4d494342-5342-5645-0003-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.249	luup_log:27:            subcategory_num=-1 <0x76be5520>
                                          50	12/27/16 15:58:48.249	luup_log:27:            invisible=true <0x76be5520>
                                          50	12/27/16 15:58:48.249	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.249	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.249	luup_log:27:            device_num_parent=0 <0x76be5520>
                                          50	12/27/16 15:58:48.249	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:BluetoothNetwork:1 <0x76be5520>
                                          50	12/27/16 15:58:48.250	luup_log:27: Device #20:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.250	luup_log:27:            category_num=17 <0x76be5520>
                                          50	12/27/16 15:58:48.250	luup_log:27:            description=Bar South Temp <0x76be5520>
                                          50	12/27/16 15:58:48.250	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.250	luup_log:27:            id=FE0000047CE7AE28:Temperature <0x76be5520>
                                          50	12/27/16 15:58:48.251	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.251	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                          50	12/27/16 15:58:48.251	luup_log:27:            room_num=10 <0x76be5520>
                                          50	12/27/16 15:58:48.251	luup_log:27:            udn=uuid:4d494342-5342-5645-0014-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.251	luup_log:27:            subcategory_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.252	luup_log:27:            invisible=false <0x76be5520>
                                          50	12/27/16 15:58:48.252	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.252	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.252	luup_log:27:            device_num_parent=19 <0x76be5520>
                                          50	12/27/16 15:58:48.252	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                          50	12/27/16 15:58:48.253	luup_log:27: Device #21:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.253	luup_log:27:            category_num=17 <0x76be5520>
                                          50	12/27/16 15:58:48.253	luup_log:27:            description=Guest Bedroom Temp <0x76be5520>
                                          50	12/27/16 15:58:48.253	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.253	luup_log:27:            id=9A02146426ECFF28:Temperature <0x76be5520>
                                          50	12/27/16 15:58:48.254	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.254	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                          50	12/27/16 15:58:48.254	luup_log:27:            room_num=9 <0x76be5520>
                                          50	12/27/16 15:58:48.254	luup_log:27:            udn=uuid:4d494342-5342-5645-0015-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.254	luup_log:27:            subcategory_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.255	luup_log:27:            invisible=false <0x76be5520>
                                          50	12/27/16 15:58:48.255	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.255	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.255	luup_log:27:            device_num_parent=19 <0x76be5520>
                                          50	12/27/16 15:58:48.255	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                          50	12/27/16 15:58:48.256	luup_log:27: Device #22:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.256	luup_log:27:            category_num=17 <0x76be5520>
                                          50	12/27/16 15:58:48.256	luup_log:27:            description=Office Temp <0x76be5520>
                                          50	12/27/16 15:58:48.256	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.257	luup_log:27:            id=C80000047D69C028:Temperature <0x76be5520>
                                          50	12/27/16 15:58:48.257	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.257	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                          50	12/27/16 15:58:48.257	luup_log:27:            room_num=7 <0x76be5520>
                                          50	12/27/16 15:58:48.257	luup_log:27:            udn=uuid:4d494342-5342-5645-0016-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.258	luup_log:27:            subcategory_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.258	luup_log:27:            invisible=false <0x76be5520>
                                          50	12/27/16 15:58:48.258	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.258	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.258	luup_log:27:            device_num_parent=19 <0x76be5520>
                                          50	12/27/16 15:58:48.258	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                          50	12/27/16 15:58:48.259	luup_log:27: Device #23:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.259	luup_log:27:            category_num=17 <0x76be5520>
                                          50	12/27/16 15:58:48.259	luup_log:27:            description=Master Bedroom Temp <0x76be5520>
                                          50	12/27/16 15:58:48.259	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.259	luup_log:27:            id=5602146472A5FF28:Temperature <0x76be5520>
                                          50	12/27/16 15:58:48.260	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.260	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                          50	12/27/16 15:58:48.260	luup_log:27:            room_num=8 <0x76be5520>
                                          50	12/27/16 15:58:48.260	luup_log:27:            udn=uuid:4d494342-5342-5645-0017-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.260	luup_log:27:            subcategory_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.261	luup_log:27:            invisible=false <0x76be5520>
                                          50	12/27/16 15:58:48.261	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.261	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.261	luup_log:27:            device_num_parent=19 <0x76be5520>
                                          50	12/27/16 15:58:48.261	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                          50	12/27/16 15:58:48.262	luup_log:27: Device #24:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.262	luup_log:27:            category_num=17 <0x76be5520>
                                          50	12/27/16 15:58:48.262	luup_log:27:            description=Kitchen Hall Temp <0x76be5520>
                                          50	12/27/16 15:58:48.262	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.262	luup_log:27:            id=9E000003A827AF28:Temperature <0x76be5520>
                                          50	12/27/16 15:58:48.263	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.263	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                          50	12/27/16 15:58:48.263	luup_log:27:            room_num=3 <0x76be5520>
                                          50	12/27/16 15:58:48.263	luup_log:27:            udn=uuid:4d494342-5342-5645-0018-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.263	luup_log:27:            subcategory_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.264	luup_log:27:            invisible=false <0x76be5520>
                                          50	12/27/16 15:58:48.264	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.264	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.264	luup_log:27:            device_num_parent=19 <0x76be5520>
                                          50	12/27/16 15:58:48.264	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                          50	12/27/16 15:58:48.265	luup_log:27: Device #25:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.265	luup_log:27:            category_num=17 <0x76be5520>
                                          50	12/27/16 15:58:48.265	luup_log:27:            description=Bar North Temp <0x76be5520>
                                          50	12/27/16 15:58:48.265	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.265	luup_log:27:            id=7A000003A7472828:Temperature <0x76be5520>
                                          50	12/27/16 15:58:48.266	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.266	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                          50	12/27/16 15:58:48.266	luup_log:27:            room_num=10 <0x76be5520>
                                          50	12/27/16 15:58:48.266	luup_log:27:            udn=uuid:4d494342-5342-5645-0019-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.266	luup_log:27:            subcategory_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.267	luup_log:27:            invisible=false <0x76be5520>
                                          50	12/27/16 15:58:48.267	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.267	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.267	luup_log:27:            device_num_parent=19 <0x76be5520>
                                          50	12/27/16 15:58:48.267	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                          50	12/27/16 15:58:48.268	luup_log:27: Device #26:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.268	luup_log:27:            category_num=17 <0x76be5520>
                                          50	12/27/16 15:58:48.268	luup_log:27:            description=Outside Temp <0x76be5520>
                                          50	12/27/16 15:58:48.268	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.268	luup_log:27:            id=F60000047DA93228:Temperature <0x76be5520>
                                          50	12/27/16 15:58:48.269	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.269	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                          50	12/27/16 15:58:48.269	luup_log:27:            room_num=13 <0x76be5520>
                                          50	12/27/16 15:58:48.269	luup_log:27:            udn=uuid:4d494342-5342-5645-001a-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.269	luup_log:27:            subcategory_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.269	luup_log:27:            invisible=false <0x76be5520>
                                          50	12/27/16 15:58:48.270	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.270	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.270	luup_log:27:            device_num_parent=19 <0x76be5520>
                                          50	12/27/16 15:58:48.270	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                          50	12/27/16 15:58:48.270	luup_log:27: Device #27:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.271	luup_log:27:            category_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.271	luup_log:27:            description=MySensors Plugin <0x76be5520>
                                          50	12/27/16 15:58:48.271	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.271	luup_log:27:            id= <0x76be5520>
                                          50	12/27/16 15:58:48.271	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.272	luup_log:27:            ip= <0x76be5520>
                                          50	12/27/16 15:58:48.272	luup_log:27:            room_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.272	luup_log:27:            udn=uuid:4d494342-5342-5645-001b-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.272	luup_log:27:            subcategory_num=-1 <0x76be5520>
                                          50	12/27/16 15:58:48.272	luup_log:27:            invisible=false <0x76be5520>
                                          50	12/27/16 15:58:48.273	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.273	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.273	luup_log:27:            device_num_parent=0 <0x76be5520>
                                          50	12/27/16 15:58:48.273	luup_log:27:            device_type=urn:schemas-arduino-cc:device:arduino:1 <0x76be5520>
                                          50	12/27/16 15:58:48.273	luup_log:27: Device #5:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.274	luup_log:27:            category_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.274	luup_log:27:            description=Serial_Portlist_2144272085 <0x76be5520>
                                          50	12/27/16 15:58:48.274	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.274	luup_log:27:            id=50009936 <0x76be5520>
                                          50	12/27/16 15:58:48.274	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.275	luup_log:27:            ip=127.0.0.1 <0x76be5520>
                                          50	12/27/16 15:58:48.275	luup_log:27:            room_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.275	luup_log:27:            udn=uuid:4d494342-5342-5645-0005-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.275	luup_log:27:            subcategory_num=-1 <0x76be5520>
                                          50	12/27/16 15:58:48.275	luup_log:27:            invisible=true <0x76be5520>
                                          50	12/27/16 15:58:48.276	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.276	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.276	luup_log:27:            device_num_parent=0 <0x76be5520>
                                          50	12/27/16 15:58:48.276	luup_log:27:            device_type=urn:micasaverde-org:device:SerialPortRoot:1 <0x76be5520>
                                          50	12/27/16 15:58:48.276	luup_log:27: Device #4:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.277	luup_log:27:            category_num=14 <0x76be5520>
                                          50	12/27/16 15:58:48.277	luup_log:27:            description=_Scene Controller <0x76be5520>
                                          50	12/27/16 15:58:48.277	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.277	luup_log:27:            id=1 <0x76be5520>
                                          50	12/27/16 15:58:48.277	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.278	luup_log:27:            ip= <0x76be5520>
                                          50	12/27/16 15:58:48.278	luup_log:27:            room_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.278	luup_log:27:            udn=uuid:4d494342-5342-5645-0004-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.278	luup_log:27:            subcategory_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.278	luup_log:27:            invisible=true <0x76be5520>
                                          50	12/27/16 15:58:48.278	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.279	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.279	luup_log:27:            device_num_parent=1 <0x76be5520>
                                          50	12/27/16 15:58:48.279	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:SceneController:1 <0x76be5520>
                                          50	12/27/16 15:58:48.279	luup_log:27: Device #6:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.279	luup_log:27:            category_num=13 <0x76be5520>
                                          50	12/27/16 15:58:48.280	luup_log:27:            description=pl2303 <0x76be5520>
                                          50	12/27/16 15:58:48.280	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.280	luup_log:27:            id=usb-xhci-hcd-1.1 <0x76be5520>
                                          50	12/27/16 15:58:48.280	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.280	luup_log:27:            ip=127.0.0.1 <0x76be5520>
                                          50	12/27/16 15:58:48.281	luup_log:27:            room_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.281	luup_log:27:            udn=uuid:4d494342-5342-5645-0006-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.281	luup_log:27:            subcategory_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.281	luup_log:27:            invisible=true <0x76be5520>
                                          50	12/27/16 15:58:48.281	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.282	luup_log:27:            embedded=true <0x76be5520>
                                          50	12/27/16 15:58:48.282	luup_log:27:            device_num_parent=5 <0x76be5520>
                                          50	12/27/16 15:58:48.282	luup_log:27:            device_type=urn:micasaverde-org:device:SerialPort:1 <0x76be5520>
                                          50	12/27/16 15:58:48.282	luup_log:27: Device #19:mac= <0x76be5520>
                                          50	12/27/16 15:58:48.282	luup_log:27:            category_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.283	luup_log:27:            description=OWServer <0x76be5520>
                                          50	12/27/16 15:58:48.283	luup_log:27:            user= <0x76be5520>
                                          50	12/27/16 15:58:48.283	luup_log:27:            id= <0x76be5520>
                                          50	12/27/16 15:58:48.283	luup_log:27:            pass= <0x76be5520>
                                          50	12/27/16 15:58:48.283	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                          50	12/27/16 15:58:48.284	luup_log:27:            room_num=0 <0x76be5520>
                                          50	12/27/16 15:58:48.284	luup_log:27:            udn=uuid:4d494342-5342-5645-0013-000002fb1750 <0x76be5520>
                                          50	12/27/16 15:58:48.284	luup_log:27:            subcategory_num=-1 <0x76be5520>
                                          50	12/27/16 15:58:48.284	luup_log:27:            invisible=false <0x76be5520>
                                          50	12/27/16 15:58:48.284	luup_log:27:            hidden=false <0x76be5520>
                                          50	12/27/16 15:58:48.285	luup_log:27:            embedded=false <0x76be5520>
                                          50	12/27/16 15:58:48.285	luup_log:27:            device_num_parent=0 <0x76be5520>
                                          50	12/27/16 15:58:48.285	luup_log:27:            device_type=urn:cd-jackson-com:device:OWServer:1 <0x76be5520>
                                          50	12/27/16 15:58:48.286	luup_log:27: Arduino: Sending: 0;0;3;0;2;Get Version <0x76be5520>
                                          50	12/27/16 15:58:49.066	luup_log:27: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x739e5520>
                                          50	12/27/16 15:58:49.067	luup_log:27: Arduino: Sending: 255;255;3;0;4;1 <0x739e5520>
                                          50	12/27/16 15:58:50.547	luup_log:27: Arduino: Log: TSP:SANCHK:OK <0x739e5520>
                                          50	12/27/16 15:58:51.085	luup_log:27: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x739e5520>
                                          50	12/27/16 15:58:51.086	luup_log:27: Arduino: Sending: 255;255;3;0;4;2 <0x739e5520>
                                          The highest device # it shows is 27 which doesn't even come close to hitting the 254 mark. I am baffled.
