  2. Announcements
  • M marceloaqno
    @jirm The configure script from MySensor repo is based on the https://github.com/TMRh20/RF24/blob/master/configure. Could you try with theTMRh20 master branch and post the result?
    git clone https://github.com/TMRh20/RF24.git
    cd RF24
    ./configure
    make
    jirmJ
    jirmJ
    jirm
    wrote on last edited by jirm
    #218
    @marceloaqno Sadly I´m so much bussy and traveling for few days and cannot acces to my OPI´s :-( , but I´m sure someone here (@aand , @hausinger, etc.. ) can give a try on her OPI the things we said before. At least I hope this ...
    • M marceloaqno
      @eyesoft thanks for the feedback, we need to add support for SPIDEV driver in order to use the BananaPi.
      jirmJ
      jirmJ
      jirm
      #219
      @marceloaqno I see some huge steps up on BananaPi...seems only need add SPIDEV support for make it working... :-)
      • OliO
        OliO
        Oli
        @marceloaqno I am rather copy/paste not a programming kind a guy, so sorry for my lame questions.
        pi@raspberrypi ~ $ git clone https://github.com/mysensors/MySensors.git
        fatal: destination path 'MySensors' already exists and is not an empty directory
        pi@raspberrypi ~/MySensors $ git checkout master
        Branch master set up to track remote branch master from origin.
        Switched to a new branch 'master'
        but after that:
        make: *** No targets specified and no makefile found. Stop.
        pi@raspberrypi ~/MySensors $ sudo make install
        make: *** No rule to make target 'install'. Stop.
        • eyesoftE
          eyesoftE
          eyesoft
          @Oli ... try :
          ./configure
          make
          sudo make install
          • OliO
            OliO
            Oli
            @eyesoft same errors
            jirmJ 1 Reply Last reply
            • eyesoftE
              eyesoftE
              eyesoft
              @Oli see commands above how to Install and Build, with git checkout master you are on master if you :
              cat README.md
              MySensors Library v2.1.0
              default on git clone you are on development :
              cat README.md
              MySensors Library v2.2.0-beta
              • OliO Oli
                jirmJ
                jirmJ
                jirm
                #224
                @Oli First you need delete all Mysensors directory on your machine.
                Then use step by step the guide on Mysensors Gateway installation process:
                https://www.mysensors.org/build/raspberry
                Dont forget put command sudo on sentences if needed.
                Regards
                • OliO
                  OliO
                  Oli
                  I wanna update not to re install of MySensors. I thought about something like ./updaterelease or ./updatebeta... I spend hours of make it work before, so I leave it as it is. No time or nerves for fighting next couple of days.
                  mfalkviddM jirmJ 2 Replies Last reply
                  • OliO Oli
                    #226
                    @Oli what did you have to do to make it work? It should just be a matter of following the instructions that @jirm linked to.
                    EDIT: Since you already have the MySensors repo cloned from git, you can update by running
                    pi@raspberrypi ~/MySensors $ git pull
                    Than run configure, make, etc as per the original instructions.
                    • OliO
                      OliO
                      Oli
                      @mfalkvidd I could not find ttyMySensorsGateway on Domoticz. Only ttyUSB0, ttyUSB20 and ttyAMA0. Even after I did ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                      • OliO Oli
                        @Oli so what did you do to make it work?
                        • OliO Oli
                          jirmJ
                          jirmJ
                          jirm
                          #229
                          @Oli I´m thinking is hard to "only" update (changing from develop to master branch) directly from github if the repository is not been previously prepared to do this kind of updates... but maybe I´m wrong.
                          Will be good you give feedback if you get it.
                          • OliO
                            OliO
                            Oli
                            @mfalkvidd hah... thats a good question, don't know. After dozen or more reinstallations, spending hours on Google I finally make it work. Got some notes but frankly I am worrying it will happen again. Hahaha
                            • OliO Oli
                              @Oli ah, ok. Then I'd recommend backing up everything before doing git pull, configure, make, etc so you can restore if it stops working.
                              • jirmJ jirm
                                jirmJ
                                jirmJ
                                jirm
                                #232
                                @Oli :-) :-)
                                Good !
                                I like when people can make something work that nobody even knows what it is :-)
                                For me it usually happens just the opposite I am not able to make work even the things I know perfectly well ... maybe it will be a matter of "bad karma" :-)
                                • OliO
                                  OliO
                                  Oli
                                  OK, I did it, I f....g did it, and guess what...
                                  s...t happened again.
                                  Everything went as it should, no errors at all, but no ttyUSBMySensorsGateway...
                                  log error message:
                                  2017-01-03 19:56:38.784 MySensors: Using serial port: /dev/ttyUSBMySensorsGateway
                                  2017-01-03 19:56:38.785 Error: MySensors: Error opening serial port!
                                  2017-01-03 19:56:39.785 MySensors: retrying in 30 seconds...
                                  and again...
                                  and again...
                                  any help would be appreciated.
                                  luizrrochaL 1 Reply Last reply
                                  • J
                                    J
                                    jacikaas
                                    wrote on last edited by jacikaas
                                    #234
                                    Could someone answer: if i have RPi NRF24 GW, how I could connect MYSController from other computer (for example from Windows computer)?
                                    1. Is it possible to make that type connection with RPi NRF24 GW?
                                    2. May I use some integrated web server for this type of connection in RPi to make it work? Is there are easier solutions?
                                    EDIT: no matter, already answered it by myself :)
                                    Its easy becose it's like Ethernet GW.
                                    • OliO Oli
                                      log error message:
                                      and again...
                                      and again...
                                      luizrrochaL
                                      luizrrochaL
                                      luizrrocha
                                      @Oli: when you do a "ls /dev" is ttyUSBMySensorsGateway shown ?
                                      • luizrrochaL luizrrocha
                                        luizrrochaL
                                        luizrrochaL
                                        luizrrocha
                                        @Oli: by the way, the name of the port you used is ttyMySensorsGateway, not ttyUSBMySensorsGateway:
                                        Is the gateway running, ie, "ps -ef "grep my" shows a process there ?
                                        Cheers,
                                        Luiz
                                          Cheers,
                                          Luiz
                                          luizrrochaL
                                          luizrrochaL
                                          luizrrocha
                                          @Oli: sorry, correct syntax is ps -ef | grep my
                                          OliO 1 Reply Last reply
