  2. Announcements
  • OliO
    OliO
    Oli
    @mfalkvidd I could not find ttyMySensorsGateway on Domoticz. Only ttyUSB0, ttyUSB20 and ttyAMA0. Even after I did ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
    • OliO Oli
      @Oli so what did you do to make it work?
      • OliO Oli
        I wanna update not to re install of MySensors. I thought about something like ./updaterelease or ./updatebeta... I spend hours of make it work before, so I leave it as it is. No time or nerves for fighting next couple of days.
        jirmJ
        jirmJ
        jirm
        wrote on last edited by jirm
        #229
        @Oli I´m thinking is hard to "only" update (changing from develop to master branch) directly from github if the repository is not been previously prepared to do this kind of updates... but maybe I´m wrong.
        Will be good you give feedback if you get it.
        jirmJ 1 Reply Last reply
        • OliO
          OliO
          Oli
          @mfalkvidd hah... thats a good question, don't know. After dozen or more reinstallations, spending hours on Google I finally make it work. Got some notes but frankly I am worrying it will happen again. Hahaha
          • OliO Oli
            @Oli ah, ok. Then I'd recommend backing up everything before doing git pull, configure, make, etc so you can restore if it stops working.
            • jirmJ jirm
              jirmJ
              jirmJ
              jirm
              #232
              @Oli :-) :-)
              Good !
              I like when people can make something work that nobody even knows what it is :-)
              For me it usually happens just the opposite I am not able to make work even the things I know perfectly well ... maybe it will be a matter of "bad karma" :-)
              • OliO
                OliO
                Oli
                OK, I did it, I f....g did it, and guess what...
                s...t happened again.
                Everything went as it should, no errors at all, but no ttyUSBMySensorsGateway...
                log error message:
                2017-01-03 19:56:38.784 MySensors: Using serial port: /dev/ttyUSBMySensorsGateway
                2017-01-03 19:56:38.785 Error: MySensors: Error opening serial port!
                2017-01-03 19:56:39.785 MySensors: retrying in 30 seconds...
                and again...
                and again...
                any help would be appreciated.
                luizrrochaL 1 Reply Last reply
                • J
                  J
                  jacikaas
                  wrote on last edited by jacikaas
                  #234
                  Could someone answer: if i have RPi NRF24 GW, how I could connect MYSController from other computer (for example from Windows computer)?
                  1. Is it possible to make that type connection with RPi NRF24 GW?
                  2. May I use some integrated web server for this type of connection in RPi to make it work? Is there are easier solutions?
                  EDIT: no matter, already answered it by myself :)
                  Its easy becose it's like Ethernet GW.
                  • OliO Oli
                    log error message:
                    and again...
                    and again...
                    luizrrochaL
                    luizrrochaL
                    luizrrocha
                    @Oli: when you do a "ls /dev" is ttyUSBMySensorsGateway shown ?
                    • luizrrochaL luizrrocha
                      luizrrochaL
                      luizrrochaL
                      luizrrocha
                      @Oli: by the way, the name of the port you used is ttyMySensorsGateway, not ttyUSBMySensorsGateway:
                      Is the gateway running, ie, "ps -ef "grep my" shows a process there ?
                      Cheers,
                      Luiz
                        Cheers,
                        Luiz
                        luizrrochaL
                        luizrrochaL
                        luizrrocha
                        @Oli: sorry, correct syntax is ps -ef | grep my
                        OliO 1 Reply Last reply
                          OliO
                          OliO
                          Oli
                          @luizrrocha
                          pi@raspberrypi ~ $ ls /dev
                          autofs mmcblk0p1 stderr tty36 ttyAMA0
                          block mmcblk0p2 stdin tty37 ttyMySensorsGateway
                          btrfs-control net stdout tty38 ttyprintk
                          bus network_latency tty tty39 ttyUSB0
                          cachefiles network_throughput tty0 tty4 ttyUSB20
                          char null tty1 tty40 uhid
                          console ppp tty10 tty41 uinput
                          cpu_dma_latency ptmx tty11 tty42 urandom
                          cuse pts tty12 tty43 vc-cma
                          disk ram0 tty13 tty44 vchiq
                          fb0 ram1 tty14 tty45 vcio
                          fd ram10 tty15 tty46 vc-mem
                          full ram11 tty16 tty47 vcs
                          fuse ram12 tty17 tty48 vcs1
                          gpiomem ram13 tty18 tty49 vcs2
                          hwrng ram14 tty19 tty5 vcs3
                          i2c-1 ram15 tty2 tty50 vcs4
                          input ram2 tty20 tty51 vcs5
                          kmsg ram3 tty21 tty52 vcs6
                          log ram4 tty22 tty53 vcsa
                          loop0 ram5 tty23 tty54 vcsa1
                          loop1 ram6 tty24 tty55 vcsa2
                          loop2 ram7 tty25 tty56 vcsa3
                          loop3 ram8 tty26 tty57 vcsa4
                          loop4 ram9 tty27 tty58 vcsa5
                          loop5 random tty28 tty59 vcsa6
                          loop6 raw tty29 tty6 vhci
                          loop7 root tty3 tty60 watchdog
                          loop-control serial tty30 tty61 watchdog0
                          MAKEDEV shm tty31 tty62 xconsole
                          mapper snd tty32 tty63 zero
                          mem sndstat tty33 tty7
                          memory_bandwidth spidev0.0 tty34 tty8
                          mmcblk0 spidev0.1 tty35 tty9
                          pi@raspberrypi ~ $ ps -ef | grep my
                          root 2079 1 1 18:40 ? 00:02:49 /usr/local/bin/mysgw -b
                          pi 4214 4181 0 21:25 pts/2 00:00:00 grep --color=auto my
                          • OliO Oli
                            @luizrrocha
                            luizrrochaL
                            luizrrochaL
                            luizrrocha
                            @Oli : the port name is actually ttyMySensorsGateway, you have to correct the definition of the gateway on Domoticz to use it....
                            Luiz
                            • J jacikaas
                              luizrrochaL
                              luizrrochaL
                              luizrrocha
                              @jacikaas : on MYSController go to Settings -> Gateway -> TCP/IP and add the IP address of the Gateway and use port 5003. It works even if the gateway is feeding data to Domoticz, so you can monitor your sensors in "raw" mode.
                              Cheers,
                              Luiz
                                Luiz
                                OliO
                                OliO
                                Oli
                                wrote on last edited by Oli
                                #241
                                @luizrrocha as You can see, on the picture above, I've wrote that ttyUSBMySensors.... is from my previous backup copy. On the same pictures You can also see that I can choose only from three serial ports: USB0, USB20 and AMA0. Thera are no ttyMySensorsGateway despite that it is present after ls /dev.
                                And that's the problem, I dont know how to make it present in the serial ports popup menu.
                                • OliO Oli
                                  luizrrochaL
                                  luizrrochaL
                                  luizrrocha
                                  @Oli : why not remove the old definition to avoid any trash information and restarting Domoticz to make shure it rereads the port info before creating the new entry ?
                                  And I do not understand why if you are running domoticz and the gateway on the same Pi, why not use a ethernet gateway and set 127.0.0.1 and port 5003 on the Domoticz gateway entry. I did that and never had to worry about USB ports at all.
                                    OliO
                                    OliO
                                    Oli
                                    @luizrrocha
                                    Of course I did that, I started from the scratch... but when it did not work I try to restore my backup... but it did not work also...
                                    simple... I have no free LAN on my rotuer... there is more, I also have raZberry daughter board (Z-Wave) connected to same Raspberry Pi GPIO port. And till today everything works perfect until... "Better is the enemy of the good" ;-)
                                    • OliO
                                      OliO
                                      Oli
                                      #244
                                      OK I found the solution (thanks to @luizrrocha). I change
                                      to
                                      ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSBMySensorsGateway and now its working.
                                      Question is, It's only workaround (in my case) or there is bug in the installation guide?
                                      • OliO Oli
                                        to
                                        luizrrochaL
                                        luizrrochaL
                                        luizrrocha
                                        @Oli : if both the gateway and Domoticz run on the same Raspi, there is no physical network involved, hence the 127.0.0.1 dummy local address is used by Domoticz to talk to the gateway on the same machine, just using port 5003... and since you use localhost (127.0.0.1, a virtual network) there is no need to create a virtual USB port which is what you did...
                                          OliO
                                          OliO
                                          Oli
                                          @luizrrocha interesting... step by step instruction?
