  2. Announcements
  • OliO Oli
    I wanna update not to re install of MySensors. I thought about something like ./updaterelease or ./updatebeta... I spend hours of make it work before, so I leave it as it is. No time or nerves for fighting next couple of days.
    #226
    @Oli what did you have to do to make it work? It should just be a matter of following the instructions that @jirm linked to.
    EDIT: Since you already have the MySensors repo cloned from git, you can update by running
    pi@raspberrypi ~/MySensors $ git pull
    Than run configure, make, etc as per the original instructions.
    • OliO
      OliO
      Oli
      @mfalkvidd I could not find ttyMySensorsGateway on Domoticz. Only ttyUSB0, ttyUSB20 and ttyAMA0. Even after I did ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
      • OliO Oli
        @Oli so what did you do to make it work?
        • OliO Oli
          jirmJ
          jirmJ
          jirm
          wrote on last edited by jirm
          #229
          @Oli I´m thinking is hard to "only" update (changing from develop to master branch) directly from github if the repository is not been previously prepared to do this kind of updates... but maybe I´m wrong.
          Will be good you give feedback if you get it.
          jirmJ 1 Reply Last reply
          • OliO
            OliO
            Oli
            @mfalkvidd hah... thats a good question, don't know. After dozen or more reinstallations, spending hours on Google I finally make it work. Got some notes but frankly I am worrying it will happen again. Hahaha
            • OliO Oli
              @Oli ah, ok. Then I'd recommend backing up everything before doing git pull, configure, make, etc so you can restore if it stops working.
              • jirmJ jirm
                jirmJ
                jirmJ
                jirm
                #232
                @Oli :-) :-)
                Good !
                I like when people can make something work that nobody even knows what it is :-)
                For me it usually happens just the opposite I am not able to make work even the things I know perfectly well ... maybe it will be a matter of "bad karma" :-)
                • OliO
                  OliO
                  Oli
                  OK, I did it, I f....g did it, and guess what...
                  s...t happened again.
                  Everything went as it should, no errors at all, but no ttyUSBMySensorsGateway...
                  log error message:
                  2017-01-03 19:56:38.784 MySensors: Using serial port: /dev/ttyUSBMySensorsGateway
                  2017-01-03 19:56:38.785 Error: MySensors: Error opening serial port!
                  2017-01-03 19:56:39.785 MySensors: retrying in 30 seconds...
                  and again...
                  and again...
                  any help would be appreciated.
                  luizrrochaL 1 Reply Last reply
                  • J
                    J
                    jacikaas
                    wrote on last edited by jacikaas
                    #234
                    Could someone answer: if i have RPi NRF24 GW, how I could connect MYSController from other computer (for example from Windows computer)?
                    1. Is it possible to make that type connection with RPi NRF24 GW?
                    2. May I use some integrated web server for this type of connection in RPi to make it work? Is there are easier solutions?
                    EDIT: no matter, already answered it by myself :)
                    Its easy becose it's like Ethernet GW.
                    • OliO Oli
                      log error message:
                      and again...
                      and again...
                      luizrrochaL
                      luizrrochaL
                      luizrrocha
                      @Oli: when you do a "ls /dev" is ttyUSBMySensorsGateway shown ?
                      • luizrrochaL luizrrocha
                        luizrrochaL
                        luizrrochaL
                        luizrrocha
                        @Oli: by the way, the name of the port you used is ttyMySensorsGateway, not ttyUSBMySensorsGateway:
                        Is the gateway running, ie, "ps -ef "grep my" shows a process there ?
                        Cheers,
                        Luiz
                          Cheers,
                          Luiz
                          luizrrochaL
                          luizrrochaL
                          luizrrocha
                          @Oli: sorry, correct syntax is ps -ef | grep my
                          OliO 1 Reply Last reply
                            OliO
                            OliO
                            Oli
                            @luizrrocha
                            pi@raspberrypi ~ $ ls /dev
                            autofs mmcblk0p1 stderr tty36 ttyAMA0
                            block mmcblk0p2 stdin tty37 ttyMySensorsGateway
                            btrfs-control net stdout tty38 ttyprintk
                            bus network_latency tty tty39 ttyUSB0
                            cachefiles network_throughput tty0 tty4 ttyUSB20
                            char null tty1 tty40 uhid
                            console ppp tty10 tty41 uinput
                            cpu_dma_latency ptmx tty11 tty42 urandom
                            cuse pts tty12 tty43 vc-cma
                            disk ram0 tty13 tty44 vchiq
                            fb0 ram1 tty14 tty45 vcio
                            fd ram10 tty15 tty46 vc-mem
                            full ram11 tty16 tty47 vcs
                            fuse ram12 tty17 tty48 vcs1
                            gpiomem ram13 tty18 tty49 vcs2
                            hwrng ram14 tty19 tty5 vcs3
                            i2c-1 ram15 tty2 tty50 vcs4
                            input ram2 tty20 tty51 vcs5
                            kmsg ram3 tty21 tty52 vcs6
                            log ram4 tty22 tty53 vcsa
                            loop0 ram5 tty23 tty54 vcsa1
                            loop1 ram6 tty24 tty55 vcsa2
                            loop2 ram7 tty25 tty56 vcsa3
                            loop3 ram8 tty26 tty57 vcsa4
                            loop4 ram9 tty27 tty58 vcsa5
                            loop5 random tty28 tty59 vcsa6
                            loop6 raw tty29 tty6 vhci
                            loop7 root tty3 tty60 watchdog
                            loop-control serial tty30 tty61 watchdog0
                            MAKEDEV shm tty31 tty62 xconsole
                            mapper snd tty32 tty63 zero
                            mem sndstat tty33 tty7
                            memory_bandwidth spidev0.0 tty34 tty8
                            mmcblk0 spidev0.1 tty35 tty9
                            pi@raspberrypi ~ $ ps -ef | grep my
                            root 2079 1 1 18:40 ? 00:02:49 /usr/local/bin/mysgw -b
                            pi 4214 4181 0 21:25 pts/2 00:00:00 grep --color=auto my
                            • OliO Oli
                              @luizrrocha
                              luizrrochaL
                              luizrrochaL
                              luizrrocha
                              @Oli : the port name is actually ttyMySensorsGateway, you have to correct the definition of the gateway on Domoticz to use it....
                              Luiz
                              • J jacikaas
                                luizrrochaL
                                luizrrochaL
                                luizrrocha
                                @jacikaas : on MYSController go to Settings -> Gateway -> TCP/IP and add the IP address of the Gateway and use port 5003. It works even if the gateway is feeding data to Domoticz, so you can monitor your sensors in "raw" mode.
                                Cheers,
                                Luiz
                                  Luiz
                                  OliO
                                  OliO
                                  Oli
                                  wrote on last edited by Oli
                                  #241
                                  @luizrrocha as You can see, on the picture above, I've wrote that ttyUSBMySensors.... is from my previous backup copy. On the same pictures You can also see that I can choose only from three serial ports: USB0, USB20 and AMA0. Thera are no ttyMySensorsGateway despite that it is present after ls /dev.
                                  And that's the problem, I dont know how to make it present in the serial ports popup menu.
                                  • OliO Oli
                                    luizrrochaL
                                    luizrrochaL
                                    luizrrocha
                                    @Oli : why not remove the old definition to avoid any trash information and restarting Domoticz to make shure it rereads the port info before creating the new entry ?
                                    And I do not understand why if you are running domoticz and the gateway on the same Pi, why not use a ethernet gateway and set 127.0.0.1 and port 5003 on the Domoticz gateway entry. I did that and never had to worry about USB ports at all.
                                      OliO
                                      OliO
                                      Oli
                                      @luizrrocha
                                      Of course I did that, I started from the scratch... but when it did not work I try to restore my backup... but it did not work also...
                                      simple... I have no free LAN on my rotuer... there is more, I also have raZberry daughter board (Z-Wave) connected to same Raspberry Pi GPIO port. And till today everything works perfect until... "Better is the enemy of the good" ;-)
                                      • OliO
                                        OliO
                                        Oli
                                        #244
                                        OK I found the solution (thanks to @luizrrocha). I change
                                        to
                                        ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSBMySensorsGateway and now its working.
                                        Question is, It's only workaround (in my case) or there is bug in the installation guide?
                                        • OliO Oli
                                          to
                                          luizrrochaL
                                          luizrrochaL
                                          luizrrocha
                                          @Oli : if both the gateway and Domoticz run on the same Raspi, there is no physical network involved, hence the 127.0.0.1 dummy local address is used by Domoticz to talk to the gateway on the same machine, just using port 5003... and since you use localhost (127.0.0.1, a virtual network) there is no need to create a virtual USB port which is what you did...
