  2. Announcements
  • OliO Oli
    @eyesoft same errors
    jirmJ
    jirmJ
    jirm
    wrote on last edited by jirm
    #224
    @Oli First you need delete all Mysensors directory on your machine.
    Then use step by step the guide on Mysensors Gateway installation process:
    https://www.mysensors.org/build/raspberry
    Dont forget put command sudo on sentences if needed.
    Regards
    • OliO
      OliO
      Oli
      I wanna update not to re install of MySensors. I thought about something like ./updaterelease or ./updatebeta... I spend hours of make it work before, so I leave it as it is. No time or nerves for fighting next couple of days.
      mfalkviddM jirmJ 2 Replies Last reply
      • OliO Oli
        #226
        @Oli what did you have to do to make it work? It should just be a matter of following the instructions that @jirm linked to.
        EDIT: Since you already have the MySensors repo cloned from git, you can update by running
        pi@raspberrypi ~/MySensors $ git pull
        Than run configure, make, etc as per the original instructions.
        • OliO
          OliO
          Oli
          @mfalkvidd I could not find ttyMySensorsGateway on Domoticz. Only ttyUSB0, ttyUSB20 and ttyAMA0. Even after I did ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
          • OliO Oli
            @Oli so what did you do to make it work?
            • OliO Oli
              jirmJ
              jirmJ
              jirm
              #229
              @Oli I´m thinking is hard to "only" update (changing from develop to master branch) directly from github if the repository is not been previously prepared to do this kind of updates... but maybe I´m wrong.
              Will be good you give feedback if you get it.
              jirmJ 1 Reply Last reply
              • OliO
                OliO
                Oli
                @mfalkvidd hah... thats a good question, don't know. After dozen or more reinstallations, spending hours on Google I finally make it work. Got some notes but frankly I am worrying it will happen again. Hahaha
                • OliO Oli
                  @Oli ah, ok. Then I'd recommend backing up everything before doing git pull, configure, make, etc so you can restore if it stops working.
                  • jirmJ jirm
                    jirmJ
                    jirmJ
                    jirm
                    #232
                    @Oli :-) :-)
                    Good !
                    I like when people can make something work that nobody even knows what it is :-)
                    For me it usually happens just the opposite I am not able to make work even the things I know perfectly well ... maybe it will be a matter of "bad karma" :-)
                    • OliO
                      OliO
                      Oli
                      OK, I did it, I f....g did it, and guess what...
                      s...t happened again.
                      Everything went as it should, no errors at all, but no ttyUSBMySensorsGateway...
                      log error message:
                      2017-01-03 19:56:38.784 MySensors: Using serial port: /dev/ttyUSBMySensorsGateway
                      2017-01-03 19:56:38.785 Error: MySensors: Error opening serial port!
                      2017-01-03 19:56:39.785 MySensors: retrying in 30 seconds...
                      and again...
                      and again...
                      any help would be appreciated.
                      luizrrochaL 1 Reply Last reply
                      • J
                        J
                        jacikaas
                        wrote on last edited by jacikaas
                        #234
                        Could someone answer: if i have RPi NRF24 GW, how I could connect MYSController from other computer (for example from Windows computer)?
                        1. Is it possible to make that type connection with RPi NRF24 GW?
                        2. May I use some integrated web server for this type of connection in RPi to make it work? Is there are easier solutions?
                        EDIT: no matter, already answered it by myself :)
                        Its easy becose it's like Ethernet GW.
                        • OliO Oli
                          log error message:
                          and again...
                          and again...
                          luizrrochaL
                          luizrrochaL
                          luizrrocha
                          @Oli: when you do a "ls /dev" is ttyUSBMySensorsGateway shown ?
                          • luizrrochaL luizrrocha
                            luizrrochaL
                            luizrrochaL
                            luizrrocha
                            @Oli: by the way, the name of the port you used is ttyMySensorsGateway, not ttyUSBMySensorsGateway:
                            Is the gateway running, ie, "ps -ef "grep my" shows a process there ?
                            Cheers,
                            Luiz
                              Cheers,
                              Luiz
                              luizrrochaL
                              luizrrochaL
                              luizrrocha
                              @Oli: sorry, correct syntax is ps -ef | grep my
                              OliO 1 Reply Last reply
                                OliO
                                OliO
                                Oli
                                @luizrrocha
                                pi@raspberrypi ~ $ ls /dev
                                autofs mmcblk0p1 stderr tty36 ttyAMA0
                                block mmcblk0p2 stdin tty37 ttyMySensorsGateway
                                btrfs-control net stdout tty38 ttyprintk
                                bus network_latency tty tty39 ttyUSB0
                                cachefiles network_throughput tty0 tty4 ttyUSB20
                                char null tty1 tty40 uhid
                                console ppp tty10 tty41 uinput
                                cpu_dma_latency ptmx tty11 tty42 urandom
                                cuse pts tty12 tty43 vc-cma
                                disk ram0 tty13 tty44 vchiq
                                fb0 ram1 tty14 tty45 vcio
                                fd ram10 tty15 tty46 vc-mem
                                full ram11 tty16 tty47 vcs
                                fuse ram12 tty17 tty48 vcs1
                                gpiomem ram13 tty18 tty49 vcs2
                                hwrng ram14 tty19 tty5 vcs3
                                i2c-1 ram15 tty2 tty50 vcs4
                                input ram2 tty20 tty51 vcs5
                                kmsg ram3 tty21 tty52 vcs6
                                log ram4 tty22 tty53 vcsa
                                loop0 ram5 tty23 tty54 vcsa1
                                loop1 ram6 tty24 tty55 vcsa2
                                loop2 ram7 tty25 tty56 vcsa3
                                loop3 ram8 tty26 tty57 vcsa4
                                loop4 ram9 tty27 tty58 vcsa5
                                loop5 random tty28 tty59 vcsa6
                                loop6 raw tty29 tty6 vhci
                                loop7 root tty3 tty60 watchdog
                                loop-control serial tty30 tty61 watchdog0
                                MAKEDEV shm tty31 tty62 xconsole
                                mapper snd tty32 tty63 zero
                                mem sndstat tty33 tty7
                                memory_bandwidth spidev0.0 tty34 tty8
                                mmcblk0 spidev0.1 tty35 tty9
                                pi@raspberrypi ~ $ ps -ef | grep my
                                root 2079 1 1 18:40 ? 00:02:49 /usr/local/bin/mysgw -b
                                pi 4214 4181 0 21:25 pts/2 00:00:00 grep --color=auto my
                                • OliO Oli
                                  @luizrrocha
                                  luizrrochaL
                                  luizrrochaL
                                  luizrrocha
                                  @Oli : the port name is actually ttyMySensorsGateway, you have to correct the definition of the gateway on Domoticz to use it....
                                  Luiz
                                  • J jacikaas
                                    luizrrochaL
                                    luizrrochaL
                                    luizrrocha
                                    @jacikaas : on MYSController go to Settings -> Gateway -> TCP/IP and add the IP address of the Gateway and use port 5003. It works even if the gateway is feeding data to Domoticz, so you can monitor your sensors in "raw" mode.
                                    Cheers,
                                    Luiz
                                      Luiz
                                      OliO
                                      OliO
                                      Oli
                                      wrote on last edited by Oli
                                      #241
                                      @luizrrocha as You can see, on the picture above, I've wrote that ttyUSBMySensors.... is from my previous backup copy. On the same pictures You can also see that I can choose only from three serial ports: USB0, USB20 and AMA0. Thera are no ttyMySensorsGateway despite that it is present after ls /dev.
                                      And that's the problem, I dont know how to make it present in the serial ports popup menu.
                                      • OliO Oli
                                        luizrrochaL
                                        luizrrochaL
                                        luizrrocha
                                        @Oli : why not remove the old definition to avoid any trash information and restarting Domoticz to make shure it rereads the port info before creating the new entry ?
                                        And I do not understand why if you are running domoticz and the gateway on the same Pi, why not use a ethernet gateway and set 127.0.0.1 and port 5003 on the Domoticz gateway entry. I did that and never had to worry about USB ports at all.
                                          OliO
                                          OliO
                                          Oli
                                          @luizrrocha
                                          Of course I did that, I started from the scratch... but when it did not work I try to restore my backup... but it did not work also...
                                          simple... I have no free LAN on my rotuer... there is more, I also have raZberry daughter board (Z-Wave) connected to same Raspberry Pi GPIO port. And till today everything works perfect until... "Better is the enemy of the good" ;-)
