  3. Jeedom
  4. MySensors node doesn’t appear in Jeedom
Scheduled Pinned Locked Moved Jeedom
6 Posts 4 Posters 5.1k Views 4 Watching
  • philoudumdumP
    philoudumdumP
    philoudumdum
    After installing MySenor plugin on Jeedom, I switched a serial gateway arduino on my raspberry, and send messages by an arduino (value 1 and 0 every 10 seconds).
    I see it in MySensorsLog in my plugin jeedom interface :
    Thu Jan 05 2017 11:05:54 GMT+0000 (UTC) - Jeedom url : http://192.168.0.49:80/plugins/mySensors/core/api/jeeSensors.php?apikey=(...), gwAddress : /dev/ttyUSB0
    DEPRECATION: Please use require('serialport') instead of require('serialport').SerialPort
    Thu Jan 05 2017 11:05:54 GMT+0000 (UTC) - server bound on 8019
    Thu Jan 05 2017 11:05:54 GMT+0000 (UTC) - connected to serial gateway at /dev/ttyUSB0
    Thu Jan 05 2017 11:05:55 GMT+0000 (UTC) : 0;0;3;0;9;gateway started, id=0, parent=0, distance=0
    Thu Jan 05 2017 11:05:55 GMT+0000 (UTC) : 0;0;3;0;14;Gateway startup complete.
    Thu Jan 05 2017 11:05:59 GMT+0000 (UTC) : 0;0;3;0;9;read: 0-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1
    Thu Jan 05 2017 11:06:00 GMT+0000 (UTC) : 0;3;1;0;16;1
    Thu Jan 05 2017 11:06:10 GMT+0000 (UTC) : 0;0;3;0;9;read: 0-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0
    Thu Jan 05 2017 11:06:10 GMT+0000 (UTC) : 0;3;1;0;16;0
    But not any mySensor node appears in Jeedom with inclusion mode !
    denisvdbD 1 Reply Last reply
    • philoudumdumP philoudumdum
      denisvdbD
      denisvdbD
      denisvdb
      @philoudumdum
      did you restart any node when your are in inclusion mode?
      • gregaouG
        gregaouG
        gregaou
        I have the same problem, and i did a restart of my node when jeedom was in inclusion mode.
        Wed Jan 18 2017 19:22:03 GMT+0100 (CET) - Jeedom url : http://:80/plugins/mySensors/core/api/jeeSensors.php?apikey=KN3AxPW64r0xrnjGckMD5E9bD4TV6DZcZvCj3xgJZrmykMT1&gateway=master, gwAddress : /dev/ttyUSB020
        DEPRECATION: Please use `require('serialport')` instead of `require('serialport').SerialPort`
        Wed Jan 18 2017 19:22:03 GMT+0100 (CET) - server bound on 8019
        Wed Jan 18 2017 19:22:03 GMT+0100 (CET) - connected to serial gateway at /dev/ttyUSB020
        1/18/2017, 7:22:03 PM { [Error: socket hang up] code: 'ECONNRESET' }
        Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;255;0;0;17;2.1.0
        -> 105;255;3;0;6;M
        Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;255;3;0;6;0
        1/18/2017, 7:22:22 PM { [Error: socket hang up] code: 'ECONNRESET' }
        Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;255;3;0;11;TemperatureAndHumidity
        Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;255;3;0;12;1.1
        Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;1;0;0;6;
        Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;1;1;0;0;20.0
        Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;0;1;0;1;21.0
        • philoudumdumP
          philoudumdumP
          philoudumdum
          It works now.
          I just added gw.sendSketchInfo command in the setup of my sketch script.
          • R
            R
            rickyguff
            I've just installed a sensor node and a serial gateway with the last version of MySensors Library, 2.1.1 and nRF24L01+ network devices. The serial gateway is connected (/dev/ttyACM0) to my Jeedom box running the last software version (2.4.6.).
            The sensor node is running the Air Humidity sketch (with DHT22 device) found here and the serial gateway with the adequate sketch found hereon this web site.
            Communication between them seems to work correctly, the serial gateway seems also to be recognized by the Jeedom box via the MySensors Plugin (latest stable version), but Jeedom cannot see any sensor node, even with inclusion mode and after reconnecting the sensor node itself (off/on).
            Here is an extract of the the Jeedom plugin MySensors_node log.
            Thank you in advance.
            Fri Feb 10 2017 17:15:04 GMT+0100 (CET) - connected to serial gateway at /dev/ttyACM0
            2/10/2017, 5:15:04 PM null
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;TSM:INIT
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;TSF:WUR:MS=0
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;TSM:INIT:TSP OK
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;TSM:INIT:GW MODE
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;TSM:READY:ID=0,PAR=0,DIS=0
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;MCO:REG:NOT NEEDED
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;14;Gateway startup complete.
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;0;0;18;2.1.1
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;MCO:BGN:STP
            Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;MCO:BGN:INIT OK,TSP=1
            2/10/2017, 5:15:05 PM null
            Fri Feb 10 2017 17:15:56 GMT+0100 (CET) : 0;255;3;0;9;TSF:MSG:READ,3-3-0,s=1,c=1,t=0,pt=7,l=5,sg=0:20.0
            Fri Feb 10 2017 17:15:56 GMT+0100 (CET) : 3;1;1;0;0;20.0
            Fri Feb 10 2017 17:15:56 GMT+0100 (CET) : 0;255;3;0;9;TSF:MSG:READ,3-3-0,s=0,c=1,t=1,pt=7,l=5,sg=0:37.4
            Fri Feb 10 2017 17:15:56 GMT+0100 (CET) : 3;0;1;0;1;37.4
            2/10/2017, 5:15:56 PM null
            2/10/2017, 5:15:56 PM null```
            • R
              R
              rickyguff
              Hallelujah, I managed to get everything working perfect. Shame on me :kissing_closed_eyes:
              The main problem came from a bad definition of the internal address (Network configuration section), in particular the "complementary" part of the address (/jeedom) which was not to be defined for me (check your URL Jeedom access to be sure).
              So I have : http://jeedom:80 where "jeedom" is 127.0.1.1 (as to be defined in /etc/hosts).
              Hope this help.
              Eric.
              • OldSurferDudeO OldSurferDude referenced this topic on
