  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • T Tag
    @marceloaqno
    Build the RF24 lib, without erros on the OPI Zero. and am now able to start the tools and radio seems to be recognised!. (was a faulty breadboard wire.... :( )
    Used the follwing to for the radio:
    RF24 radio(2,0);
    Output from gettingstarted:
    root@orangepizero:~/rf24libs/RF24/examples_linux# ./gettingstarted
    RF24/examples/GettingStarted/
    STATUS           = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
    RX_ADDR_P0-1     = 0x0000000000 0xff00000000
    RX_ADDR_P2-5     = 0xff 0xff 0xff 0xff
    TX_ADDR          = 0xffffffffff
    RX_PW_P0-6       = 0xff 0xff 0xff 0xff 0xff 0xff
    EN_AA            = 0xff
    EN_RXADDR        = 0xff
    RF_CH            = 0xbc
    RF_SETUP         = 0xff
    CONFIG           = 0xff
    DYNPD/FEATURE    = 0xff 0xff
    Data Rate        = 1MBPS
    Model            = nRF24L01
    CRC Length       = 16 bits
    PA Power         = PA_MAX
     ************ Role Setup ***********
    Choose a role: Enter 0 for pong_back, 1 for ping_out (CTRL+C to exit)
    marceloaqno
    Code Contributor
    wrote on last edited by marceloaqno
    #75
    @Tag Could you fill this table with your current setup?
    nRF24L01 | OrangePi  | OrangePi
             | phyPin    | GPIO
    _________|_______________________
    VCC      | 3V3-PWR   | 3V3-PWR
    GND      | GND       | GND
    CSN      |           |
    CE       |           |
    MOSI     | 19        | 15
    SCK      | 23        | 14
    MISO     | 21        | 16
    • M marceloaqno
               | phyPin    | GPIO
      GND      | GND       | GND
      CSN      |           |
      CE       |           |
      MOSI     | 19        | 15
      SCK      | 23        | 14
      MISO     | 21        | 16
      Tag
      @marceloaqno
      Sure here it is,
               | phyPin    | GPIO
      GND      | GND       | GND
      CSN      | 24        | 13
      CE       | 22        | 2
      MOSI     | 19        | 15
      SCK      | 23        | 14
      MISO     | 21        | 16
      Radio seems to be recognised, still need to test data transfer...
      • T Tag
        @marceloaqno
        Sure here it is,
                 | phyPin    | GPIO
        GND      | GND       | GND
        CSN      | 24        | 13
        CE       | 22        | 2
        MOSI     | 19        | 15
        SCK      | 23        | 14
        MISO     | 21        | 16
        marceloaqno
        Code Contributor
        #77
        I created the draft for the official article: https://www.mysensors.org/build/orange
        mfalkviddM T R 3 Replies Last reply
        • M marceloaqno
          @marceloaqno and everyone else involved in this effort: great work! I love when people come together to solve a problem.
          jirmJ 1 Reply Last reply
            jirmJ
            jirmJ
            jirm
            wrote on last edited by jirm
            #79
            @marceloaqno
            @mfalkvidd @Tag @pansen @Reza @mihai.aldea @hausinger
            Wooow woow woow !!!
            Only few days "off" and the problem to make work Mysensors on OPI are solved.
            So many many thanks to all people here that have been involved to make that OPI good little boards can work with Mysensors.
            This is the proof that when good people join can reach the most difficult achievements and all humanity can benefit.
            Awesome work !
            Regards
            • M marceloaqno
              Tag
              wrote on last edited by Tag
              #80
              @marceloaqno
              Great work!!! the GPIO part most probably needs some additions for OPI zero on the topic of the spidev1.0 driver and the GPIO pins, send it to you once i got everything documented.
              Really many thanks for your hard work here!!
              • R
                R
                Reza
                • M marceloaqno
                  R
                  R
                  Reza
                  @marceloaqno
                  thank you. but i have error:
                  root@OrangePI:~# ls /sys/class/gpio/export
                  ls: cannot access /sys/class/gpio/export: No such file or directory
                  root@OrangePI:~# modprobe gpio-sunxi
                  in class folder i dont have gpio folder (i use a orangepi one with ubuntu os )
                  i
                  • R Reza
                    @marceloaqno
                    i
                    Tag
                    @Reza
                    You need to create the files after each boot.
                    After the modprobe, Issue this command:
                    sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
                    This will get you the files.
                    R 2 Replies Last reply
                    • R
                      R
                      Reza
                      root@OrangePI:~# git clone https://github.com/marceloaqno/MySensors.git orangepi               Cloning into 'orangepi'...
                      remote: Counting objects: 13858, done.
                      remote: Compressing objects: 100% (50/50), done.
                      remote: Total 13858 (delta 17), reused 0 (delta 0), pack-reused 13808
                      Receiving objects: 100% (13858/13858), 9.68 MiB | 79.00 KiB/s, done.
                      Resolving deltas: 100% (8304/8304), done.
                      Checking connectivity... done.
                      root@OrangePI:~# cd orangepi/
                      root@OrangePI:~/orangepi# git pull origin spidev
                      From https://github.com/marceloaqno/MySensors
                       * branch            spidev     -> FETCH_HEAD
                      Updating 570b607..63e1a81
                      Fast-forward
                       Makefile                                          |  16 +++
                       MyConfig.h                                        |   4 +
                       MySensors.h                                       |   2 +-
                       configure                                         |  79 ++++++++++---
                       core/MyHwLinuxGeneric.cpp                         |  17 +++
                       core/MyHwLinuxGeneric.h                           |  12 +-
                       core/MyHwRPi.cpp                                  |   1 +
                       core/MyHwRPi.h                                    |  28 -----
                       core/MyMainLinux.cpp                              |  30 ++---
                       drivers/{RPi => BCM}/SPI.cpp                      |  10 +-
                       drivers/{RPi => BCM}/SPI.h                        | 116 ++++++++++++-------
                       drivers/{RPi => BCM}/Wire.cpp                     |   0
                       drivers/{RPi => BCM}/Wire.h                       |   1 +
                       drivers/Linux/Arduino.h                           |  22 +++-
                       drivers/Linux/GPIO.cpp                            | 119 ++++++++++++++++++++
                       drivers/Linux/GPIO.h                              |  47 ++++++++
                       drivers/Linux/Stream.h                            |   1 +
                       drivers/Linux/compatibility.cpp                   |  11 +-
                       drivers/{RPi/rpi_util.cpp => Linux/interrupt.cpp} | 144 +++++-------------------
                       drivers/Linux/interrupt.h                         |  45 ++++++++
                       drivers/RF24/RF24.cpp                             |   4 +-
                       drivers/RF24/RF24.h                               |   2 +-
                       drivers/RPi/RPi.cpp                               |  59 ++++++++++
                       drivers/RPi/RPi.h                                 |  22 ++++
                       drivers/RPi/piHiPri.c                             |  49 --------
                       drivers/RPi/rpi_util.h                            |  76 -------------
                       drivers/RPi/wiring.cpp                            |  72 ++++++++++++
                       drivers/RPi/wiring.h                              |  24 ++++
                       drivers/SPIDEV/SPI.cpp                            | 223 +++++++++++++++++++++++++++++++++++++
                       drivers/SPIDEV/SPI.h                              | 178 +++++++++++++++++++++++++++++
                       30 files changed, 1054 insertions(+), 360 deletions(-)
                       rename drivers/{RPi => BCM}/SPI.cpp (100%)
                       rename drivers/{RPi => BCM}/SPI.h (62%)
                       rename drivers/{RPi => BCM}/Wire.cpp (100%)
                       rename drivers/{RPi => BCM}/Wire.h (99%)
                       create mode 100644 drivers/Linux/GPIO.cpp
                       create mode 100644 drivers/Linux/GPIO.h
                       rename drivers/{RPi/rpi_util.cpp => Linux/interrupt.cpp} (63%)
                       create mode 100644 drivers/Linux/interrupt.h
                       create mode 100644 drivers/RPi/RPi.cpp
                       create mode 100644 drivers/RPi/RPi.h
                       delete mode 100644 drivers/RPi/piHiPri.c
                       delete mode 100644 drivers/RPi/rpi_util.h
                       create mode 100644 drivers/RPi/wiring.cpp
                       create mode 100644 drivers/RPi/wiring.h
                       create mode 100644 drivers/SPIDEV/SPI.cpp
                       create mode 100644 drivers/SPIDEV/SPI.h
                      root@OrangePI:~/orangepi# ./configure
                      [OK] Finished.
                      root@OrangePI:~/orangepi# make
                      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                      g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                      g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                      g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                      g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                      g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                      g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                      g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                      g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                      g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                      drivers/Linux/interrupt.cpp: In function ‘void* interruptHandler(void*)’:
                      drivers/Linux/interrupt.cpp:107:26: warning: ignoring return value of ‘ssize_t read(int, void*, size_t)’, declared with attribute warn_unused_result [-Wunused-result]
                         (void)read (fd, &c, 1) ;
                      g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                      g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                      g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                      In file included from ./MySensors.h:294:0,
                                       from examples_linux/mysgw.cpp:74:
                      ./drivers/RF24/RF24.cpp:39:11: error: Not supported on this platform.
                        hwDigitalWrite(MY_RF24_CS_PIN, level);
                      ./drivers/RF24/RF24.cpp:44:11: error: Not supported on this platform.
                        hwDigitalWrite(MY_RF24_CE_PIN, level);
                      ./drivers/RF24/RF24.cpp:388:11: error: Not supported on this platform.
                        hwPinMode(MY_RF24_CE_PIN,OUTPUT);
                      ./drivers/RF24/RF24.cpp:389:11: error: Not supported on this platform.
                        hwPinMode(MY_RF24_CS_PIN,OUTPUT);
                      ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
                       LOCAL void RF24_csn(const bool level)
                      ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
                       LOCAL void RF24_ce(const bool level)
                      ./drivers/RF24/RF24.cpp: In function ‘uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)’:
                      ./drivers/RF24/RF24.cpp:56:11: error: ‘LOW’ was not declared in this scope
                        RF24_csn(LOW);
                      ./drivers/RF24/RF24.cpp:99:11: error: ‘HIGH’ was not declared in this scope
                        RF24_csn(HIGH);
                      ./drivers/RF24/RF24.cpp: In function ‘void RF24_startListening()’:
                      ./drivers/RF24/RF24.cpp:235:10: error: ‘HIGH’ was not declared in this scope
                        RF24_ce(HIGH);
                      ./drivers/RF24/RF24.cpp: In function ‘void RF24_stopListening()’:
                      ./drivers/RF24/RF24.cpp:241:10: error: ‘LOW’ was not declared in this scope
                        RF24_ce(LOW);
                      ./drivers/RF24/RF24.cpp: In function ‘void RF24_powerDown()’:
                      ./drivers/RF24/RF24.cpp:251:10: error: ‘LOW’ was not declared in this scope
                        RF24_ce(LOW);
                      ./drivers/RF24/RF24.cpp: In function ‘bool RF24_sendMessage(uint8_t, const void*, uint8_t)’:
                      ./drivers/RF24/RF24.cpp:269:10: error: ‘HIGH’ was not declared in this scope
                        RF24_ce(HIGH);
                      ./drivers/RF24/RF24.cpp:276:10: error: ‘LOW’ was not declared in this scope
                        RF24_ce(LOW);
                      ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
                      ./drivers/RF24/RF24.cpp:395:10: error: ‘LOW’ was not declared in this scope
                        RF24_ce(LOW);
                      ./drivers/RF24/RF24.cpp:396:11: error: ‘HIGH’ was not declared in this scope
                        RF24_csn(HIGH);
                      Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
                      root@OrangePI:~/orangepi#```
                      • T Tag
                        @Reza
                        R
                        R
                        Reza
                        @Tag
                        root@OrangePI:~/orangepi# sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
                        -bash: syntax error near unexpected token `do'
                        root@OrangePI:~/orangepi# ```
                        • T Tag
                          @Reza
                          R
                          R
                          Reza
                          orangepi one have 40 pins
                          • R Reza
                            marceloaqno
                            Code Contributor
                            @Reza Is there /sys/class/gpio/export file on your OPi?
                            • M marceloaqno
                              R
                              R
                              Reza
                              @marceloaqno
                              no i have not folder "gpio" in my orangepi
                                mihai.aldea
                                @marceloaqno It still doesn't work on my OPi Zero :confused:
                                root@opi-zero-1:~/orangepi# bin/mysgw -d
                                mysgw: Starting gateway...
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: !TSM:INIT:TSP FAIL
                                mysgw: TSM:FAIL:CNT=1
                                mysgw: TSM:FAIL:PDT
                                mysgw: Received SIGINT
                                I do have the /sys/class/gpio/export and I ran for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
                                For the record, here's my OS:
                                BOARD=orangepizero
                                BOARD_NAME="Orange Pi Zero"
                                VERSION=5.24
                                LINUXFAMILY=sun8i
                                BRANCH=default
                                ARCH=arm
                                PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
                                NAME="Debian GNU/Linux"
                                VERSION_ID="8"
                                VERSION="8 (jessie)"
                                ID=debian
                                HOME_URL="http://www.debian.org/"
                                SUPPORT_URL="http://www.debian.org/support"
                                BUG_REPORT_URL="https://bugs.debian.org/"
                                • M mihai.aldea
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: TSM:FAIL:PDT
                                  BOARD=orangepizero
                                  VERSION=5.24
                                  LINUXFAMILY=sun8i
                                  BRANCH=default
                                  ARCH=arm
                                  VERSION_ID="8"
                                  ID=debian
                                  marceloaqno
                                  Code Contributor
                                  @mihai.aldea The gateway does the exporting when needed, you don't need to run:
                                  Could you send the output of this command?
                                  ls -lah /dev/spidev*
                                  • M marceloaqno
                                    Tag
                                    #91
                                    @marceloaqno
                                    Still issues here:
                                    root@orangepizero:~/orangepi/bin# ll /dev/spi*
                                    crw------- 1 root root 153, 0 Jan  9 22:51 /dev/spidev0.0
                                    crw------- 1 root root 153, 1 Jan  9 22:51 /dev/spidev1.0
                                    Then:
                                    ./configure --spi-spidev-device=/dev/spidev1.0
                                    added to examples_linux/mysgw.cpp
                                    #define MY_RF24_CE_PIN 2
                                    #define MY_RF24_CS_PIN 13
                                    end enabled radio debugging:
                                    output:
                                    root@orangepizero:~/orangepi/bin# ./mysgw -d
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: RF24:write register, reg=0, value=14
                                    mysgw: RF24:write register, reg=3, value=3
                                    mysgw: RF24:write register, reg=4, value=95
                                    mysgw: RF24:write register, reg=5, value=76
                                    mysgw: RF24:write register, reg=6, value=39
                                    mysgw: RF24:write register, reg=16, value=115
                                    mysgw: RF24:write register, reg=29, value=6
                                    mysgw: RF24:read register, reg=6, value=39
                                    mysgw: RF24:read register, reg=5, value=76
                                    mysgw: RF24:write register, reg=2, value=2
                                    mysgw: RF24:write register, reg=1, value=0
                                    mysgw: RF24:write register, reg=28, value=3
                                    mysgw: RF24:flushRX
                                    mysgw: RF24:flushTX
                                    mysgw: RF24:write register, reg=7, value=112
                                    mysgw: TSM:INIT:TSP OK
                                    mysgw: TSM:INIT:GW MODE
                                    mysgw: RF24:write register, reg=2, value=3
                                    mysgw: RF24:write register, reg=1, value=1
                                    mysgw: RF24:STRT LIS
                                    mysgw: RF24:write register, reg=0, value=15
                                    mysgw: RF24:write register, reg=10, value=0
                                    mysgw: MCO:REG:NOT NEEDED
                                    mysgw: RF24:read register, reg=23, value=17
                                    Illegal instruction
                                    Almost there?
                                    • M marceloaqno
                                      R
                                      R
                                      Reza
                                      wrote on last edited by Reza
                                      #92
                                      @marceloaqno
                                      in "orangepi one"(ubuntu os) there is not gpio folder in sys/class. but i think after run "modprobe gpio-sunxi" built a folder that name is "gpio_sw" and in this folder there are this files: normal_led,pa3,pa6,pa8 and 9,10,13,14,15,21 ,...
                                      M T 2 Replies Last reply
                                      • R Reza
                                        @marceloaqno
                                        mihai.aldea
                                        @Reza Is it too complicated to switch to Debian?
                                        R 1 Reply Last reply
                                        • M mihai.aldea
                                          R
                                          R
                                          Reza
                                          you told me i change my os ? to armbian ?
