  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.7k Views 53 Watching
  • bjornhallbergB
    bjornhallbergB
    bjornhallberg
    Oh and another question, since I've never ordered anything from ITEAD before, how do they declare the customs value? Is it safe to order more than one gateway or should I order them one by one to be on the safe side? I'm talking about "SF E-Parcel" or "Registered Air Mail" of course, not TNT or DHL.
      @bjornhallberg, I don't remember what the value was set to on the latest package from them.
      Suggest you contact them here:
      https://www.itead.cc/contact-us
      • F
        F
        Fabien
        @bjornhallberg they declare a very low customs value (for my last order only 12x0.89€ ...)
        I juste order the gateway today.
        • FrancoisF
          FrancoisF
          Francois
          I also just order my gateway :-)
          • martinhjelmareM
            martinhjelmareM
            martinhjelmare
            This is on my most wanted purchase list now. :smile:
            FYI, I noticed the spelling of "Sensebender" is "Sensbender" for this gateway on openhardware.io, so you're breaking your brand name. :wink: Would it be possible to amend it? If you try to search for it with the original spelling you only find the two sensor Sensebenders.
            hekH 1 Reply Last reply
              Opps! Thanks for reporting @martinhjelmare.
              • alexsh1A
                alexsh1A
                alexsh1
                This has been on my watch list for some time. Excellent work guys - I placed an order and looking forward upgrading my gateway.
                • Sander TeunissenS
                  Sander TeunissenS
                  Sander Teunissen
                  Is this device capable of being a gateway for both nRF24L01+ radio and the Hope RF RFM69HCW radio simultaneously ?
                  I have some nRF24 nodes and see a lot of new goodies equiped with the RFM69 radio. One gateway to serve both would be excellent !
                  tbowmoT 1 Reply Last reply
                    No, only one radio type or rs485 is possible at the moment.
                    • Sander TeunissenS Sander Teunissen
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @Sander-Teunissen
                      The hardware supports both NRF and RFM69 at the same time, they share the same SPI bus, but has separate chip select lines etc.
                      Unfortunately the MySensors library doesn't support multiple transports, so this time it's the software that limits things.
                      • F
                        F
                        Fabien
                        Yes ! Itead send me the gateway today
                        alexsh1A 1 Reply Last reply
                        • F Fabien
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @Fabien said in 💬 Sensebender Gateway:
                          I have got mine today. Very quick
                          • tbowmoT tbowmo
                            @Sander-Teunissen
                            FotoFieberF
                            FotoFieberF
                            FotoFieber
                            @tbowmo
                            The fact, that MySensors doesn't support more then one radio, was the reason for me not to order the sensebender gateway.
                            I am working on a gateway⁄controller based on an arduino due, which supports at least up to 3 serial gateways via hardware serial. It handles ID and time (synced with ntp) requests and does pub/sub to mqtt with readable topics.(inspired by the old mqtt client gateway)
                            • FotoFieberF FotoFieber
                              @tbowmo
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @FotoFieber this is a software limitation. Hardware wise I do not see why Sensebender GW cannot handle two (nrf24l01+ and rfm69/rfm95) GWs at the same time
                              • alexsh1A alexsh1
                                FotoFieberF
                                FotoFieberF
                                FotoFieber
                                @alexsh1
                                The question is: will the software restriction be solved? If not, I do not care if it is a software or a hardware restriction. :)
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @FotoFieber
                                  Well, you need to hack the core anyways, if you want to accomplish your goal.
                                  You could also help out with the core development, so we can get support for multiple transport on one gateway ;)
                                  • tbowmoT tbowmo
                                    @FotoFieber
                                    FotoFieberF
                                    FotoFieberF
                                    FotoFieber
                                    @tbowmo
                                    No, I don't have to hack the core. I use the serial API. From an architectural point of view, I don't see the need to change anything in MySensors. A serial controller can be built for under 20€ Including the radio. Why should I add complexity to support more than one radio support with one cpu in MySensors, if I can have the functipnality with the abstraction layer of the serial API? Please keep MySensors s simple as possible.
                                    AnticimexA tbowmoT alexsh1A 3 Replies Last reply
                                      @tbowmo
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @FotoFieber simple for who? Simplicity also involve maintenance and code complexity. What about testability and regression testing? Nobody gets paid for maintaining mysensors.
                                        @tbowmo
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @FotoFieber
                                        But you ditched the sensebender Gateway, as it doesn't support multiple radios at the same time? Now you are saying that you would keep it as one radio per gateway?
                                        This doesn't make sense :)
                                        • tbowmoT tbowmo
                                          @FotoFieber
                                          FotoFieberF
                                          FotoFieberF
                                          FotoFieber
                                          @tbowmo
                                          Maybe the design of the sensebender gateway doesn't make sense to my architectural viewpoint....
