  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.7k Views 53 Watching
  • F
    F
    Fabien
    Yes ! Itead send me the gateway today
    alexsh1A 1 Reply Last reply
    • F Fabien
      alexsh1A
      alexsh1A
      alexsh1
      @Fabien said in 💬 Sensebender Gateway:
      I have got mine today. Very quick
      • tbowmoT tbowmo
        @Sander-Teunissen
        The hardware supports both NRF and RFM69 at the same time, they share the same SPI bus, but has separate chip select lines etc.
        Unfortunately the MySensors library doesn't support multiple transports, so this time it's the software that limits things.
        FotoFieberF
        FotoFieberF
        FotoFieber
        @tbowmo
        The fact, that MySensors doesn't support more then one radio, was the reason for me not to order the sensebender gateway.
        I am working on a gateway⁄controller based on an arduino due, which supports at least up to 3 serial gateways via hardware serial. It handles ID and time (synced with ntp) requests and does pub/sub to mqtt with readable topics.(inspired by the old mqtt client gateway)
        • FotoFieberF FotoFieber
          @tbowmo
          alexsh1A
          alexsh1A
          alexsh1
          @FotoFieber this is a software limitation. Hardware wise I do not see why Sensebender GW cannot handle two (nrf24l01+ and rfm69/rfm95) GWs at the same time
          • alexsh1A alexsh1
            FotoFieberF
            FotoFieberF
            FotoFieber
            @alexsh1
            The question is: will the software restriction be solved? If not, I do not care if it is a software or a hardware restriction. :)
            • tbowmoT
              tbowmoT
              tbowmo
              @FotoFieber
              Well, you need to hack the core anyways, if you want to accomplish your goal.
              You could also help out with the core development, so we can get support for multiple transport on one gateway ;)
              • tbowmoT tbowmo
                @FotoFieber
                FotoFieberF
                FotoFieberF
                FotoFieber
                @tbowmo
                No, I don't have to hack the core. I use the serial API. From an architectural point of view, I don't see the need to change anything in MySensors. A serial controller can be built for under 20€ Including the radio. Why should I add complexity to support more than one radio support with one cpu in MySensors, if I can have the functipnality with the abstraction layer of the serial API? Please keep MySensors s simple as possible.
                AnticimexA tbowmoT alexsh1A 3 Replies Last reply
                  @tbowmo
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @FotoFieber simple for who? Simplicity also involve maintenance and code complexity. What about testability and regression testing? Nobody gets paid for maintaining mysensors.
                    @tbowmo
                    tbowmoT
                    tbowmoT
                    tbowmo
                    @FotoFieber
                    But you ditched the sensebender Gateway, as it doesn't support multiple radios at the same time? Now you are saying that you would keep it as one radio per gateway?
                    This doesn't make sense :)
                    • tbowmoT tbowmo
                      @FotoFieber
                      FotoFieberF
                      FotoFieberF
                      FotoFieber
                      @tbowmo
                      Maybe the design of the sensebender gateway doesn't make sense to my architectural viewpoint....
                        @alexsh1
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @FotoFieber This is a question for the MySensors dev team. Sensebender can handle both radios. Currently, there is a software restriction.
                          @tbowmo
                          alexsh1A
                          alexsh1A
                          alexsh1
                          #98
                          @FotoFieber No, you do have to hack the core if you want both radios to be handled properly, i.e. to handle message queues with corresponding radios. For example, sending a message is done via rfm69 only and not via nrf24l01+
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            The architecture we use would place this kind of situation to the controller to solve. One gw per network. So one gw for nrf and one for rfm.
                            HW is cheap, and library should be kept simple.
                            • AnticimexA Anticimex
                              FotoFieberF
                              FotoFieberF
                              FotoFieber
                              @Anticimex
                              One gateway per radio, that is what I think is best. :+1:
                              What I try to do, is to implement a controller with arduino due for up to three serial gateways. If there would be a solution for ethernet&rfm69 I may not have invested time in this. :laughing:
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @FotoFieber
                                Well sensebender GW supports rfm69 with ethernet ;)
                                FotoFieberF alexsh1A 2 Replies Last reply
                                • tbowmoT tbowmo
                                  @FotoFieber
                                  FotoFieberF
                                  FotoFieberF
                                  FotoFieber
                                  @tbowmo
                                  Yes, that is really nice. :+1:
                                  My other goal was to have a new MQTTClientGateway, as it existed with MySensors 1.1 (which is not only a gateway, but a controller too). It would have been really painful to add it to MySensors 2.1.x, as I would have to patch core files. It is much easier, to throw hardware at it. :laughing:
                                  • tbowmoT tbowmo
                                    @FotoFieber
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @tbowmo More practical question. I have received the GW and it already has MySensors 2.1.0 software. Excellent service by Itead. Can you please help me how to map LEDs in the GW sketch? I can see that they are connected to pins 38, 41, 42, 39, 40 as LED1, LED2, LED3, LED4 and LED5. Thanks
                                    tbowmoT 1 Reply Last reply
                                    • alexsh1A alexsh1
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      #104
                                      @alexsh1
                                      you should be able to use LED_BLUE, LED_GREEN etc. defines (or even just LED_1, LED_2..) in your sketch, to access the different LED's on board the gateway. That is, if you are using the SenseBender GW hardware support files in arduino (installation instructions are here https://github.com/mysensors/ArduinoBoards)
                                      Also, look at the board definition files, located here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.cpp
                                      and here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h
                                      • tbowmoT tbowmo
                                        @alexsh1
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @tbowmo Excellent links, many thanks. BTW the board is working with the standard arduino samd, the problem I suppose comes with things LEDs.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @alexsh1
                                          You might be able to compile with the standard arduino zero BSP files. But the IO mapping is not the same at all.. I have swapped some pins to make routing a bit easier. Also the SPI channels are configured a bit differently than the standard arduino, if I remember right. So I will advise to use the mysensors gateway BSP files..
