  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • ? A Former User
    @TimO
    Well this is bit of embarrassing...after changing the sleep time from 5 minutes to 1 minute for the troublesome node and re-uploading the sketch, it is reporting the temperature just fine. I tried all kinds of combinations trying to replicate the initial behavior, stopped the controller, rebooted the gateway, powered them off for while, moving back to 5 minutes sleep, to no avail, node registers and the temperature is reporting is showed in the paperui.
    On the other hand I don't see that I_TIME request received from... message in the logs (used log:set DEBUG org.openhab.binding.mysensors and log:tail) so I'm not sure if the receiveTime() is called.
    I suppose I can write something in the EEPROM when the callback function runs and check that.
    Thank you
    01:30:45.291 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:30:50.280 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;1;0;0;22.0
    01:30:50.282 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2017-01-06T01:30:50.281+0200
    01:30:50.285 [INFO ] [marthome.event.ItemStateChangedEvent] - TemperatureOutside_LastUpdate changed from 2017-01-06T01:28:52.282+0200 to 2017-01-06T01:30:50.281+0200
    01:30:53.550 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;23.1
    01:30:55.292 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:31:05.293 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:31:15.293 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:31:25.294 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:31:35.294 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:31:45.295 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:31:49.287 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;1;0;0;22.0
    01:31:53.541 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;23.1
    01:31:53.544 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2017-01-06T01:31:53.543+0200
    01:31:53.552 [INFO ] [marthome.event.ItemStateChangedEvent] - TemperatureGateway_LastUpdate changed from 2017-01-06T01:29:53.559+0200 to 2017-01-06T01:31:53.543+0200
    01:31:55.295 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:32:05.296 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:32:15.296 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:32:25.297 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:32:35.298 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:32:45.298 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    01:32:48.283 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;1;0;0;22.0
    01:32:48.284 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2017-01-06T01:32:48.284+0200
    01:32:48.290 [INFO ] [marthome.event.ItemStateChangedEvent] - TemperatureOutside_LastUpdate changed from 2017-01-06T01:30:50.281+0200 to 2017-01-06T01:32:48.284+0200
    01:32:53.532 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;23.1
    01:32:55.299 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    Node 0 is gateway attached, Node 2 is battery run -TemperatureOutside.
    TimO
    @frg Sometimes magic just happens. 😉
    I'm glad it is working now! :+1:
    • F
      F
      Fabien
      I try to send ORP calibration value to my sensors but it doesn't work.
      NODE_ID : 10, CHILD_NODE_ID : 0
      When I'm recieve ORP from my sensors it's ok :
      13:55:38.216 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;0;1;0;52;996.3
      But when I change the value, the value is not send :
      14:09:24.051 [INFO ] [marthome.event.ItemStateChangedEvent] - orp01 changed from 40 to 50
      14:09:24.266 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'orp01' received command 60
      14:09:24.266 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 10;0;1;0;0;
      Item :
      Number	orp01	"Redox [%.1f mV]" <faucet> (gPiscine) { channel="mysensors:waterQuality:gateway:orp01:orp"}
      Sitemap :
        sitemap test label="Main Menu" {
          Frame label="Piscine" {
      		Setpoint item=orp01 label="Calirabte ORP" minValue=0 maxValue=1000 step=10
      • F Fabien
        Item :
        Sitemap :
        TimO
        @Fabien I need a little bit more time to reproduce this behaviour. I've opened an issue here: https://github.com/tobof/openhab2-addons/issues/50
        • AndrewZA
          AndrewZA
          AndrewZ
          wrote on last edited by AndrewZ
          #349
          Hello everyone
          I'm slowly migrating to OH2, my small MySensors network generally works fine but I see some weird behavior with the binding configuration in Paper UI.
          So far it looks like "Disable network sanity check" is reversed - I'm sliding it to the left which means for me 'not disabled', i.e. 'enabled', but in the log I see "Checker thread disabled".
          2017-01-11 16:50:38.405 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
          2017-01-11 16:50:38.408 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;0;0;18;2.1.0
          2017-01-11 16:50:38.503 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
          2017-01-11 16:50:38.511 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.1.0
          2017-01-11 16:50:38.512 [DEBUG] [col.serial.MySensorsSerialConnection] - Good,Gateway is up and running! (Ver:2.1.0)
          2017-01-11 16:50:38.514 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
          2017-01-11 16:50:38.515 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
          2017-01-11 16:50:48.516 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
          Is that ok?
          • AndrewZA AndrewZ
            Hello everyone
            Is that ok?
            TimO
            @AndrewZ Don't worry about that message, the debug log looks good. The warning is confusing and we need to change that. :-)
            AndrewZA 1 Reply Last reply
            • T TimO
              AndrewZA
              AndrewZA
              AndrewZ
              @TimO Thanks, will keep it off in the GUI.
              • Duncan PullenD
                Duncan PullenD
                Duncan Pullen
                Hi @TimO
                I've logged a job to include documentation about non-native OpenHAB 2.0 bindings in the official OH2 docs.
                ThomDeitrich is looking to know why it's not yet in the official distro. Can provide some info?
                https://github.com/openhab/openhab-docs/issues/188
                • Duncan PullenD Duncan Pullen
                  Hi @TimO
                  TimO
                  Hey @Duncan-Pullen !
                  The main reason is: I'm waiting for suggestions / approval from the OH2 developers. :)
                  The MySensors binding has grown big and a review takes some time.
                    @TimO, thank you for all the effort you've put into this!
                    • FusedHe3F
                      FusedHe3F
                      FusedHe3
                      wrote on last edited by FusedHe3
                      #355
                      Hi everyone,
                      @TimO, thanks for everything you did here!
                      I just made the 2.0 version (code in comments of respective post) of petewill's Simple Scene Controller and discovered that a Scene Controller is not yet implemented in the OpenHAB binding. Is there a possibility that it will be implemented in the future?
                      For now, is it possible to get this working with CustomSensor or Text?
                      • FusedHe3F FusedHe3
                        Hi everyone,
                        TimO
                        Hi @FusedHe3 !
                        My first thought was: that's easy, lets add this! But after a second thought ...
                        I see one problem with S_SCENE_CONTROLLER: how do I map this in OpenHAB?
                        In MySensors there is V_SCENE_ON and V_SCENE_OFF. The message contains the corresponding scene number.
                        In OpenHAB I've: Number, Switch, Selection ...
                        0_1484735515591_upload-dac7eae9-cec0-4cbd-95ec-a0428268441c
                        In OpenHAB I may choose between Scene A, Scene B and so on, but I can't select between ON and OFF. Is Scene A switched off, when I select Scene B?
                        I'm using scenes with a switch in OpenHAB. Something like "Christmas decoration ON". In OpenHAB I'm using a group for that gChristmasDecoration or a rule: switch light on, shutter to 33%, ..
                        My approach in implementing a (hardware) scene controller would be a mapping of those switches. So I would define a switch / child for every button (scene) on the controller.
                        I'm open for ideas on how to map V_SCENE_CONTROLLER in OpenHAB, so if you or someone else have and idea, shout it out. :D
                        FusedHe3F 1 Reply Last reply
                        • T
                          TimO
                          Ah, by the way, I forgot to mention: SmartSleep is supported since last week.
                          0_1484736645455_upload-d9d8432b-4892-4c07-876a-3abd4def86a0
                          • T TimO
                            Hi @FusedHe3 !
                            FusedHe3F
                            FusedHe3F
                            FusedHe3
                            @TimO Thanks for the quick reply!
                            I do think the ON/OFF switch for every scene would be the most logical solution. In that way it's fully compatibel with the MySensors Scene Controller and you can have multiple scenes active at the same time.
                            • AndrewZA
                              AndrewZA
                              AndrewZ
                              Just updated my OH2 installation from snapshot to RC/beta and immediately got an error with the binding:
                              [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.NumberFormatException: For input string: "Gateway startup complete.") on reading from connection, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
                              But then the usual:
                              What could be a problem? Do I need to perform some cleanup on my system? What exactly needs to be deleted?
                              • T TimO
                                Hey @Nicklas-Starkel !
                                I hope it will work out for you! :-)
                                It is not yet part of OH2 and downloadable within OH2 because my pull request is still open. A OH2 developer needs to look at it. :-)
                                K
                                K
                                krejcarek
                                I ran into trouble today by apt-get updating Openhab.
                                I am over redefining the Distro for Snapshot... I have 2.0.0-SNAPSHOT, Build #743 up and running.
                                my bundle list looks following:
                                204 | Active | 80 | 3.12.0.OH | nrjavaserial
                                205 | Installed | 80 | 2.0.0.201611221149 | MySensors Binding
                                Still getting these errors:
                                "03:17:10.911 [ERROR] [org.openhab.binding.mysensors ] - FrameworkEvent ERROR - org.openhab.binding.mysensors
                                org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [205]
                                Unresolved requirement: Require-Bundle: org.openhab.io.transport.serial"
                                Any idea for next step?
                                • K krejcarek
                                  TimO
                                  @krejcarek please upgrade the binding to the most recent version. :-)
                                  AndrewZA K 2 Replies Last reply
                                  • T TimO
                                    AndrewZA
                                    AndrewZA
                                    AndrewZ
                                    @TimO what about my error? I'm on the latest version already.
                                    • AndrewZA AndrewZ
                                      TimO
                                      @AndrewZ Sorry! Is it working despite the error? I need to test with RC1 myself. The error looks like it could be ignored. From time to time messages get corrupted, due to connection issues and the parser stumbles about that. But it should continue to work just fine. I suppose this is the case here, but I'll check!
                                      • T TimO
                                        AndrewZA
                                        AndrewZA
                                        AndrewZ
                                        @TimO yes, it is working, but please check this one and 2nd (Network Sanity Checker thread disabled). Thank you!
                                        • jogantJ
                                          jogantJ
                                          jogant
                                          I had the same error messages on first boot of OH. After finishing upgrade procedure and restarting OH once again error message is gone. New version of the binding is working well. No hickups at the moment.
