  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.5k Views 42 Watching
  • tekkaT tekka
    @Werwolfx As soon as the bootloader takes over, in your case after the reboot request (1), but before the MYS lib 2.1.0 init message (2):
    (1) 14.01.2017 11:38:03 TX  4;0;3;0;13;0
    (2) 14.01.2017 11:38:09 RX  4;255;0;0;17;2.1.0
    it will send a I_FIRMWARE_CONFIG_REQUEST message to inform the controller about the currently loaded FW and request a new FW.
    looks like this:
    4;255;4;0;0;BE0001003003D8490102
    This is missing in your case, therefore I'm wondering if you have incompatible radio settings. Please post your GW sketch and upload your MYSBootloader.hex file for further troubleshooting.
    W
    W
    Werwolfx
    wrote on last edited by Werwolfx
    #25
    @tekka GW on esp8266 (default sketch) + NRF24L01+
    on GW
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #define MY_BAUD_RATE 115200
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "WiFI"
    #define MY_ESP8266_PASSWORD "password[0_1484386469111_MYSBootloader.hex](/uploads/files/1484386469171-mysbootloader.hex) "
    // Enable UDP communication
    //#define MY_USE_UDP
    // #define MY_ESP8266_HOSTNAME "sensor-gateway"
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
      #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    In MYSController on mudule i click INFO
    FW Update = no
    Bootloader = N/A
    may be problem in the Bootloader.hex?
    0_1484386859986_upload-c59e469e-e015-4099-88d8-607a7408a1da
    tekkaT 1 Reply Last reply
    • W Werwolfx
      on GW
       * LED purposes:
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
       * GND        GND
      FW Update = no
      Bootloader = N/A
      tekkaT
      tekkaT
      tekka
      @Werwolfx Please also update the bootloader file.
      W 2 Replies Last reply
      • tekkaT tekka
        W
        W
        Werwolfx
        I'll update more than once, but there is no effect.
        avrdude writes that everything is OK
        I do not know what to do = (
        avrdude: erasing chip
        avrdude: auto set sck period (because given equals null)
        avrdude: warning: cannot set sck period. please check for usbasp firmware update.
        avrdude: reading input file "/media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex"
        avrdude: writing flash (32762 bytes):
        avrdude: 32762 bytes of flash written
        avrdude: verifying flash memory against /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
        avrdude: load data flash data from input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
        avrdude: input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex contains 32762 bytes
        avrdude: verifying ...
        avrdude: 32762 bytes of flash verified
        avrdude: reading input file "0x0F"
        avrdude: verifying lock memory against 0x0F:
        avrdude: load data lock data from input file 0x0F:
        avrdude: input file 0x0F contains 1 bytes
        avrdude done.  Thank you.
        • W Werwolfx
          tekkaT
          tekkaT
          tekka
          @Werwolfx sorry, maybe I was not clear - please upload it here to the forum I will try to reproduce your setup.
          • tekkaT tekka
            W
            W
            Werwolfx
            #29
            @tekka If i ENABLE #define MY_OTA_FIRMWARE_FEATURE
            i see ST_FIRMWARE_CONFIG_REQUEST in MYSCONTROLLER logs!!!
            if i DISABLE //#define MY_OTA_FIRMWARE_FEATURE msg not in log
            i not have external flash/
            402	14.01.2017 21:29:28	TX	4 - Water Meter	N/A	C_INTERNAL	NO	I_REBOOT	0
            403	14.01.2017 21:29:28	RX	4	1	C_REQ	NO	V_VAR1
            408	14.01.2017 21:29:34	RX	4	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFF48044E100300
            409	14.01.2017 21:29:34	TX	4	N/A	C_STREAM	NO	ST_FIRMWARE_CONFIG_RESPONSE	0A0001005000D446
            410	14.01.2017 21:29:34	RX	4	INTERNAL	C_PRESENTATION	NO	S_ARDUINO_NODE	2.1.0
            411	14.01.2017 21:29:34	RX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	0
            412	14.01.2017 21:29:34	TX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	M
            414	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_NAME	Water Meter
            417	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_VERSION	1.1
            419	14.01.2017 21:29:34	RX	4 - Water Meter	1 - S_WATER	C_PRESENTATION	NO	S_WATER
            i load this HEX
            load from Arduino IDE 1.8.0
            0_1484418874223_MYSBootloader.hex
            board.txt
            proMYSBL.bootloader.low_fuses=0xFF
            proMYSBL.bootloader.extended_fuses=0xFE
            • W Werwolfx
              i load this HEX
              board.txt
              tekkaT
              tekkaT
              tekka
              @Werwolfx Ok, seems like you also upload the sketch via USBasp thereby erasing/overwriting the bootloader. Try uploading the sketch via serial or OTA after flashing the bootloader.
              • Mark SwiftM
                Mark SwiftM
                Mark Swift
                wrote on last edited by Mark Swift
                #31
                @tekka am I correct in thinking the HEX found on Github can be used with all Arduino's? I noticed my old folder has one hex for 16, 8 and 1Mhz?
                I'm using this board.txt
                menu.cpu=Processor
                MYSBL13.name=MYS Bootloader - atmega328p
                MYSBL13.upload.tool=arduino:avrdude
                MYSBL13.upload.protocol=arduino
                MYSBL13.upload.maximum_size=30720
                MYSBL13.upload.maximum_data_size=2048
                MYSBL13.bootloader.tool=arduino:avrdude
                MYSBL13.bootloader.unlock_bits=0x3F
                MYSBL13.bootloader.lock_bits=0x0F
                MYSBL13.build.mcu=atmega328p
                MYSBL13.build.board=AVR_PRO
                MYSBL13.build.core=arduino:arduino
                MYSBL13.build.variant=arduino:standard
                MYSBL13.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8)
                MYSBL13.menu.cpu.16MHzatmega328.upload.speed=115200
                MYSBL13.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                MYSBL13.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                MYSBL13.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                MYSBL13.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                MYSBL13.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8)
                MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
                MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
                MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
                MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                MYSBL13.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8)
                MYSBL13.menu.cpu.1MHzatmega328.upload.speed=9600
                MYSBL13.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
                MYSBL13.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
                MYSBL13.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
                MYSBL13.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                MYSBL13.menu.cpu.1MHzatmega328.build.f_cpu=1000000L```
                • Mark SwiftM
                  Mark SwiftM
                  Mark Swift
                  I guess not... The old hex for 8Mhz works, but the one from this thread does not... :(
                  I'm trying to upload this to my Pro Mini, does anyone have an 8Mhz that works?
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    #33
                    @tekka I've noticed some odd things with my nodes when running the bootloader.
                    To test I uploaded a simple count time sketch. When running the MYS bootloader the timer resets every 10 seconds, see:
                    Time: 999
                    Time: 2000
                    Time: 3000
                    Time: 4001
                    Time: 5001
                    Time: 6002
                    Time: 7004
                    Time: 8003
                    Time: 9005
                    Time: 0
                    Time: 999
                    Time: 2000
                    Time: 3000
                    Time: 4001
                    Time: 5001
                    Time: 6002
                    Time: 7004
                    Time: 8003
                    Time: 9005
                    Time: 0
                    Using the stock Pro Mim 8Mhz 3.3v bootloader it works fine, any ideas?
                    Perhaps this is because I'm testing using a non-MySensors sketch?
                    • Mark SwiftM Mark Swift
                      Time: 999
                      Time: 2000
                      Time: 3000
                      Time: 4001
                      Time: 5001
                      Time: 6002
                      Time: 7004
                      Time: 8003
                      Time: 9005
                      Time: 0
                      Time: 999
                      Time: 2000
                      Time: 3000
                      Time: 4001
                      Time: 5001
                      Time: 6002
                      Time: 7004
                      Time: 8003
                      Time: 9005
                      Time: 0
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      #34
                      @Mark-Swift yeah, this is intended behavior: the watchdog kicks in after ~8s, so either you reset it in loop() or disable it in setup().
                      • rmtuckerR
                        rmtuckerR
                        rmtucker
                        Is there a version or branch of this for the rfm69?
                        • rmtuckerR rmtucker
                          tekkaT
                          tekkaT
                          tekka
                          @rmtucker No, but everybody is welcome to contribute and enhance the functionality.
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            @tekka, I'm trying to compile the HEX using OSX. I have installed avr-gcc with homebrew but I get
                            rm *.o
                            rm: *.o: No such file or directory
                            make: [clean] Error 1 (ignored)
                            rm *.elf
                            rm: *.elf: No such file or directory
                            rm *.hex
                            rm: *.hex: No such file or directory
                            "avr-gcc" -funsigned-char -funsigned-bitfields -DF_CPU=16000000L -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -Wall -Wextra -Wundef -pedantic -mmcu=atmega328p -c -std=gnu99 -MD -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o" -I MYSBootloader.c -o MYSBootloader.o
                            avr-gcc: fatal error: no input files
                            compilation terminated.
                            make: *** [MYSBootloader.o] Error 1
                            When issueing the Make command, can you help, any suggestions?
                              rm *.o
                              rm *.elf
                              rm *.hex
                              tekkaT
                              tekkaT
                              tekka
                              @Mark-Swift I haven't tested that with OSX - maybe somebody can help here?
                              ? 1 Reply Last reply
                              • Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                @tekka, started a windows VM, run via MinGW and got this when running makefile, does it look okay?
                                C:\MySensorsBootloaderRF24-development>mingw32-make.exe
                                rm *.o
                                process_begin: CreateProcess(NULL, rm *.o, ...) failed.
                                make (e=2): The system cannot find the file specified.
                                Makefile:40: recipe for target 'clean' failed
                                mingw32-make.exe: [clean] Error 2 (ignored)
                                rm *.elf
                                process_begin: CreateProcess(NULL, rm *.elf, ...) failed.
                                rm *.hex
                                process_begin: CreateProcess(NULL, rm *.hex, ...) failed.
                                "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -funsigned-char -funsigned-bitfields
                                D -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o"  -IC:/Ardu
                                ino/hardware/tools/avr/avr/include/avr MYSBootloader.c -o MYSBootloader.o
                                In file included from Core.h:40:0,
                                                 from MYSBootloader.c:69:
                                HW.h:51:2: warning: #warning is a GCC extension
                                 #warning BAUD_RATE error greater than 2%
                                HW.h:51:2: warning: #warning BAUD_RATE error greater than 2% [-Wcpp]
                                In file included from Core.h:42:0,
                                MyMessage.h:292:3: warning: ISO C99 doesn't support unnamed structs/unions [-Wpe
                                dantic]
                                "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -nostartfiles -Wl,-s -Wl,-static -Wl
                                ,-Map=".map" -Wl,--start-group -Wl,--end-group -Wl,--gc-sections -mrelax -Wl,-se
                                ction-start=.text=0x7800 -mmcu=atmega328p   -o MYSBootloader.elf MYSBootloader.o
                                 -lm
                                "C:/Arduino/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom MYSBootloader
                                .elf MYSBootloader.hex
                                "C:/Arduino/hardware/tools/avr/bin/avr-size" MYSBootloader.elf
                                   text    data     bss     dec     hex filename
                                   2036       6      72    2114     842 MYSBootloader.elf
                                • Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  @tekka Just wanted to check if the above log looks okay, currently rolling the bootloader out to 14 nodes (painful process!) and wanted to check if it looks okay before I do.
                                  I'm also using this board.txt, I made a separate entry for my Uno's, do they all look okay? I basically used the fuses from the standard Arduino boards.txt with the change of 0x05 to 0x06 for the BOD? I noticed in the makefile that you can specify the fuses, do I need to compile a bootloader for each device with the exact fuses, or will one bootloader for 16 / 8 / 1Mhz suffice?
                                  Thank you very much in advance, the bootloader is amazing work.
                                  menu.cpu=Processor
                                  pro.name=MySensors Bootloader for Pro Mini
                                  pro.upload.tool=arduino:avrdude
                                  pro.upload.protocol=arduino
                                  pro.upload.maximum_size=30720
                                  pro.upload.maximum_data_size=2048
                                  pro.bootloader.tool=arduino:avrdude
                                  pro.bootloader.unlock_bits=0x3F
                                  pro.bootloader.lock_bits=0x0F
                                  pro.build.mcu=atmega328p
                                  pro.build.board=AVR_PRO
                                  pro.build.core=arduino:arduino
                                  pro.build.variant=arduino:standard
                                  ## Arduino with MYSBootloader Beta 2
                                  ## pro.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 2
                                  ## pro.menu.cpu.16MHzatmega328.upload.speed=115200
                                  ## pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                                  ## pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                                  ## pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                                  ## pro.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_16Mhz.hex
                                  ## pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                                  ## pro.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8) 1.3 Beta 2
                                  ## pro.menu.cpu.8MHzatmega328.upload.speed=38400
                                  ## pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
                                  ## pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                                  ## pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
                                  ## pro.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_8Mhz.hex
                                  ## pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                                  ## pro.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8) 1.3 Beta 2
                                  ## pro.menu.cpu.1MHzatmega328.upload.speed=9600
                                  ## pro.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
                                  ## pro.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
                                  ## pro.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
                                  ## pro.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_1Mhz.hex
                                  ## pro.menu.cpu.1MHzatmega328.build.f_cpu=1000000L
                                  ## Arduino with MYSBootloader Beta 3
                                  pro.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 3
                                  pro.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_16Mhz.hex
                                  pro.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8) 1.3 Beta 3
                                  pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
                                  pro.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_8Mhz.hex
                                  pro.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8) 1.3 Beta 3
                                  pro.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_1Mhz.hex
                                  menu.cpu=Processor
                                  uno.name=MySensors Bootloader for Uno
                                  uno.upload.tool=arduino:avrdude
                                  uno.upload.protocol=arduino
                                  uno.upload.maximum_size=32256
                                  uno.upload.maximum_data_size=2048
                                  uno.bootloader.tool=arduino:avrdude
                                  uno.bootloader.unlock_bits=0x3F
                                  uno.bootloader.lock_bits=0x0F
                                  uno.build.mcu=atmega328p
                                  uno.build.board=AVR_UNO
                                  uno.build.core=arduino:arduino
                                  uno.build.variant=arduino:standard
                                  ## uno.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 2
                                  ## uno.menu.cpu.16MHzatmega328.upload.speed=115200
                                  ## uno.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                                  ## uno.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                                  ## uno.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                                  ## uno.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_16Mhz.hex
                                  ## uno.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                                  uno.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 3
                                  uno.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_16Mhz.hex
                                    rm *.o
                                    rm *.elf
                                    rm *.hex
                                    dantic]
                                     -lm
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Mark-Swift What changes did you make to the bootloader - the code size seems increased
                                    Mark SwiftM 1 Reply Last reply
                                    • tekkaT tekka
                                      Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      #42
                                      @tekka None that I'm aware of? :(
                                      I just changed the fuses in the makefile to match the ones in my boards.txt, not sure if that's required, can you take a look at my questions above, I really want to be sure I'm doing all of this right before deploying.
                                      To recap with regards the bootloader.
                                      1. Installed Windows 7
                                      2. Installed mingw (core and c++ compiler)
                                      3. Installed Arduino IDE and MySensors library (Installed at the same location as you, at c drive root)
                                      4. Downloaded bootloader from github
                                      5. Edited the fuses and clock speed at the top of the makefile to match my boards.txt
                                      6. Ran makefile from cmd
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Mark-Swift ok, most probably a false alarm. I assume you tested it after compilation?
                                        • Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          @tekka It seems to work? I guess if there was an issue it wouldn't work at all?
                                          Please can you conform my fuses look okay in the boards.txt I posted above? Also, do I need to change the fuses in the makefile and make a file for each device, or just 1 x 16Mhz and 1 x 8Mhz for example?
